Hi all,
I am using ezdsp5535 board and written down the code for 2048 point FFT by using HWAFFT. After getting FFT results (Floating point array) i have found out maximum value in FFT bin. then i have compared this maximum value with one fixed value(A). if (Max>A), it should blink 2 leds else it should blink 3 leds. both Max and A (0.75) are floating point. Since max value is 0.99985, only 2 led should be blink. On code composer it is working correctly. But when i created bin file and copied in SD card, while running through SD card, 3 leds are blinking means it is going in else loop.
Kindly help.
If any further details required, Please let me know.
