Other Parts Discussed in Thread: PCM1864
I am working on Audio Pre-processing on C5535 EZDSP. I have a question with to the document http://www.ti.com/lit/ug/tiducy1b/tiducy1b.pdf
1. To run pre-processing, do I need to make changes in the code each time I change array from linear and circular ( or circular to linear; After generating BF coefficients). Also by default what geometry does the example code use?
2. What steps to follow if I need to run Pre-processing for Distributed Mic array, provided I know the distance and angle between arrays?
