I've just unpacked my shiney new C5535 eZdsp kit and...
a). Just tested the C5535 eZdsp demo. Check, that works okay.
b). Proceeded to section 5.0 of the "quick start guide" and installed CCS Version: 4.2.4.00033. Check, that runs up okay.
c). Removed the micro-SD card and proceeded to section 6.0 "CCS configuration instructions"...
...only to fall over at "Target -> Connect Target" with...
C55xx: Error connecting to the target: (Error -600 @ 0x0) A required dynamic library could not be located. The library isn't on the search path. (Release 5.0.429.0)
I'm capable of following simple instructions, so I'm a bit mystified as to why this "out of the box" kit should fail so simply.
I'm thoroughly fed up and dispirited. Please help me fix this and make me feel a lot better.
Rich
