• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C5000 Ultra Low Power DSP » C5000 Ultra Low Power DSP Forum » Fingerprint Development Kit C5515!
Share
  • Forum
  • Announcements
Options
  • Subscribe via RSS
Top 6 Wiki Links
  • C5000 Main Wiki
  • C5000 Software
  • C5515 Boot-Image Programmer
  • CSL (including CSL 3.00)
  • C5000 Connected Audio Framework
  • Porting C5000 Teaching ROM to C5535 eZdsp
  • Fingerprint Development Kit C5515!
    This question has suggested answer(s)
    Erich Woka
    Posted by Erich Woka
    on Oct 03 2010 02:13 AM
    Prodigy20 points
    I just buy FDK C5515 for my school. I want to show the fingerprints that are store in the FDK board on the PC. Is that OK? And how can I do it?
    usb 5509A cfft_noscale profiling sample code image library GSYNC info on interrupts RTDX C5500 VC5505 C5505 C5515 FFT HWA VC5505 C5505 NAND Bootloader VC5000 Chip Select Library Unused Pins Security C5515 SPO2 Front End module struct JTAG C5506 TCK wake up EVM5515 TMS320VC55x circular addressing SEED XDS560 PLUS emulator C5515 TMS320C5515 Fingerprint TMS320VC55055 medical Evaluation kit (EVM) low power c5505 c5000 MMC/SD FAT LCD DMA conflict Help for TMDXBDKFP5515 C5515 Fingerprint Development Kit JTAG Emulator question 'c55x assembly mneumonic algebraic 'c5515 SP alignment x5509A McBSP Clock Stop Mode power supply sequencing 'C5515 Status Registers 'c5515 Address of DBSTAT XDS100 video
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • TommyG
      Posted by TommyG
      on Oct 04 2010 09:11 AM
      Genius12445 points
      Erich,
      The FDK does not store an image of the fingerprint if that is what you are thinking about.  This would take too much memory.  The FDK analyzes the scanned fingerprint and extracts features and stores information about the features in a database.
      Regards.
      ACAT/DCAT Team
      Please click the Verify Answer button on this post if it answers your question.
      C5515 fingerprint FDK
      Report Abuse
      • Reply
    • Mark Mckeown
      Posted by Mark Mckeown
      on Oct 06 2010 12:17 PM
      Suggested Answer
      Genius10200 points
      Hello Erich,
      You can show the intermediate images of the FDK image processing flow by...
      Connecting to the FDK with emulator,
      Opening the FDK_Demo project in CCS4 (located on the FDK CD-ROM at <DIR>\C5515 Fingerprint Development Kit\Software\C5515_code_development\FDK_Demo),
      Setting breakpoints in the TA_GetFeature function (located at the very bottom of TA_demo_algo.c),
      Opening the CCS4 Image Analyzer (Tools --> Image Analyzer) and entering the configuration shown in the below screen shot.
      If you want to display the fingerprints during run-time, you would have to modify the source code accordingly and burn it into the SPI Flash.
      Hope this helps,
      Mark
      Also see our C5000 Wiki
      FDK
      Report Abuse
      • Reply
    • Erich Woka
      on Oct 07 2010 19:58 PM
      Prodigy20 points
      Thanks Mark,
      That is what I want to ask the question. Can you send me the source code for "Setting breakpoints in the TA_GetFeature function (located at the very bottom of TA_demo_algo.c)", and "modify the source code accordingly and burn it into the SPI Flash." (My Email: dhdanh92@student.ctu.edu.vn). If you do not mind please detailed instructions (Image Instructions) because I do not have specialized.
      Once more question, My FDK board don't work accuracy after I had used RS232 cable to connect on the PC. Now my FDK board don't show any sound signal when I press any button.
      I need emulator to show the fingerprint image on PC. But my FDK board don't have any Emulator when I receive FDK board from TI Corp. Can I buy Emulator and JTAG?
      Thanks for your answer
      C5500 c5505 matlab simulink USB c5501 C5000 Code Coverage echo cancelation C5502 compression c54cst BOM C5500 UART boot bootloader C5409A Copy project CPU idle FFT Hardware Accelerator Grrrrrrrrrrrrr fingerprint C5505 Micro SD Card FAT File System CSL ATAFS FAT 5505 C5515 eZdsp C5515 Fingerprint Development Kit c5515 eZdsp 'c551x documentation resources c5505 C55x header file c5515 stack pointer Code Composer Studio 'C5515 Status Registers 'C5515 (TMX Silicon) IRQ Debugging 'c5515 Address of DBSTAT 'C5515 C5505 Availabiltiy DSK5510 AIC23 codec c5505 memory map Code Composer 4 interruption C5507
      Report Abuse
      • Reply
    • Alex Kuzmin
      Posted by Alex Kuzmin
      on Nov 12 2010 02:28 AM
      Prodigy10 points
      Hello Mark,
      I tried to display the fingerprint during debug as you wrote.
      But I can't change "Page type" field. I choose DATA from list, press Enter and field become clear. All other fields changes successfully.
      And I see bad fingerprint image.
      What am I doing wrong?
      Report Abuse
      • Reply
    • Yang58695
      Posted by Yang58695
      on Nov 14 2010 21:02 PM
      Prodigy230 points
      Hi Alex,
      I met with the same problem, then I output the data to a file and use Matlab to display it.
      P.S.  I have just created a google group to discuss questions about this FDK, please join us. Mark is in this group too.
       http://groups.google.com/group/c5515-fdk
       Yang
      FDK
      Report Abuse
      • Reply
    • Anvesh Manne
      Posted by Anvesh Manne
      on Dec 08 2010 05:38 AM
      Prodigy20 points
      In what format ae the extracted features stored? Does it comply with ISO 19794-2 minutiae data format?
      Thanks!
      Anvesh
      Report Abuse
      • Reply
    • K Md Feroz Irfan
      Posted by K Md Feroz Irfan
      on Apr 29 2011 05:12 AM
      Expert5630 points
      I dont think it complies with the standard ISO 19794-2. it is Tooan proprietary format.
      Somebody please correct me.
      It will be good to have the format open so. Can somebody help?
      Best Regards
      Feroz
      Report Abuse
      • Reply
    • jack r prasad
      Posted by jack r prasad
      on May 14 2012 14:59 PM
      Prodigy50 points
      hi erich,
      I am jack ...i am also working on the fingerprint device kit c5515....and i also want the fingerprint to be shown in the kit....could you help me out in how to do so ??or atleast send me the source code and related information...email: jackrprasad@yahoo.com
      jack
      Report Abuse
      • Reply
    • jack r prasad
      on May 14 2012 15:06 PM
      Prodigy50 points
      hi mark
      i want to do the same thing with the FDK kit ...could you guide me in how to do it.....
      and could you mail me the source code...for it...jackrprasad@yahoo.com
      jack
      Report Abuse
      • Reply
    • Anka Rao
      Posted by Anka Rao
      on Jun 19 2012 05:00 AM
      Prodigy80 points
      please send the modified source code to see the intermediate images to my id: ankaraoittadi@bel.co.in  and awaiting ur reply.
      source code
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
