How do I solve memory range overlaps problem? I followed the TIesr instruction and searched forum about this issue but no good to resolve it.
Here is log data,
Building target: "TIesrDemoC55.out"
Invoking: C5500 Linker
"C:/ti/ccsv8/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --define=c5515 --define=C55x --define=PF_C5535_EZDSP --define=c5535 --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic -z -m"TIesrDemoC55.map" --stack_size=0x200 --heap_size=0 -i"C:/ti/ccsv8/tools/compiler/c5500_4.4.1/lib" -i"C:/ti/ccsv8/tools/compiler/c5500_4.4.1/include" -i"C:/ti/bios_5_42_02_10/packages/ti/rtdx/lib/c5500" -i"C:/ti/bios_5_42_02_10/packages/ti/bios/lib" -i"C:/ti/c55_lp/c55_csl_3.08/ccs_v6.x_examples/C55XXCSL_LP/Debug" -i"C:/ti/c55_lp/c55_csl_3.08/demos/TIesr/c5535/TIesr_C55_demo/TIesrEngineC55/ccsv5/Debug" -i"C:/ti/bios_5_42_02_10/packages/ti/rtdx/lib/c5500" -i"C:/ti/bios_5_42_02_10/packages/ti/bios/lib" --reread_libs --display_error_number --warn_sections --xml_link_info="TIesrDemoC55_linkInfo.xml" --rom_model --sys_stacksize=0x200 -o "TIesrDemoC55.out" "./TIesrDemoC55cfg.obj" "./TIesrDemoC55cfg_c.obj" "./audio_data_collection.obj" "./codec_aic3254.obj" "./gd_config.obj" "./gd_dim.obj" "./gd_gconst.obj" "./gd_hmm.obj" "./gd_mixture.obj" "./gd_mu.obj" "./gd_net.obj" "./gd_pdf.obj" "./gd_tran.obj" "./gd_var.obj" "./gd_word.obj" "./gpio_control.obj" "./lcd_osd.obj" "./pll_control.obj" "./recognizer.obj" "./sys_init.obj" "./user_interface.obj" "C:/ti/c55_lp/c55_csl_3.08/demos/TIesr/c5535/TIesr_C55_demo/build/C5515.cmd" "../C5535.cmd" -l"./TIesrDemoC55cfg.cmd" -lC55XXCSL_LP.lib -lTIesrEngineC55.lib -llibc.a
<Linking>
"./TIesrDemoC55cfg.cmd", line 155: error #10264: VECT memory range overlaps
existing memory range DARAM7
"./TIesrDemoC55cfg.cmd", line 159: error #10264: DARAM memory range overlaps
existing memory range DARAM0
existing memory range DARAM1
existing memory range DARAM2
existing memory range DARAM3
existing memory range DARAM4
existing memory range DARAM5
existing memory range DARAM6
"./TIesrDemoC55cfg.cmd", line 160: error #10264: SARAM memory range overlaps
existing memory range SARAM0
existing memory range SARAM1
existing memory range SARAM2
existing memory range SARAM3
existing memory range SARAM4
existing memory range SARAM5
existing memory range SARAM6
existing memory range SARAM7
existing memory range SARAM8
existing memory range SARAM9
existing memory range SARAM10
existing memory range SARAM11
existing memory range SARAM12
existing memory range SARAM13
existing memory range SARAM14
existing memory range SARAM15
existing memory range SARAM16
existing memory range SARAM17
existing memory range SARAM18
existing memory range SARAM19
existing memory range SARAM20
existing memory range SARAM21
existing memory range SARAM22
existing memory range SARAM23
existing memory range SARAM24
existing memory range SARAM25
existing memory range SARAM26
existing memory range SARAM27
existing memory range SARAM28
existing memory range SARAM29
existing memory range SARAM30
"./TIesrDemoC55cfg.cmd", line 161: error #10263: SARAM31 memory range has
already been specified
>> Compilation failure
makefile:167: recipe for target 'TIesrDemoC55.out' failed
"./TIesrDemoC55cfg.cmd", line 161: error #10264: SARAM31 memory range overlaps
existing memory range SARAM31
"./TIesrDemoC55cfg.cmd", line 162: error #10264: Char_ROM memory range overlaps
existing memory range ROM
undefined first referenced
symbol in file
__STACK_SIZE C:/ti/bios_5_42_02_10/packages/ti/bios/lib/bios_NONINST.a55H<boot.o55H>
__SYSSTACK_SIZE C:/ti/bios_5_42_02_10/packages/ti/bios/lib/bios_NONINST.a55H<boot.o55H>
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "TIesrDemoC55.out" not built
gmake: *** [TIesrDemoC55.out] Error 1
gmake: Target 'all' not remade because of errors.
