• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » C64x Multicore DSP Forum » About CCS IDE update issue for C6474
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      OpenMP - All aboard!
      Posted 1 day ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 2 days ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
      It’s our second anniversary, but you get the present!
      Posted 9 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
    This question is answered
    touse
    Posted by touse
    on Apr 09 2009 05:22 AM
    Expert1475 points
    Dear all:
    I want to simulate TMS320C6474 DSP with CCS v3.3, and it requires to update the CCS V3.3 to support this DSP, so I download the SR12_CCS_v3.3_SR_3.3.82.13.exe from my.TI. But when running the update package, following warning is given:
    Warning
    Setup has not found any valid products to update.
    Your system may already be up-to-date or you are
    attempting to install a serial update out of sequence.
    Setup will now abort.
    When I press the OK button, the update aborts! The same situation still exists for other SR package such as SR2 and SR10.
    I search for the answers for this problem, and uninstall the original CCS v3.3 and re-intall the CCS v3.3 and this time I can install the update, but another problem exists, when I use C6474 simulator to run the program, the time I start CCS, a file named 'emif.log' is created under the Disk C:\, which is my OS disk. And the file is written when running the CCS
    program, in one or two miniutes, the emif.log is as much as 2GB large.
    So I uninstall the CCS and clean the registry as the FAQ listed in
    http://tiexpressdsp.com/wiki/index.php?title=CCStudio_FAQ
    1.1.34 Q: When upgrading to newer versions of Code Composer Studio, how do I clean the Windows Registry?
    . But when I install CCS v3.3 again, this time I can't install the update package. This problem remains when I uninstall and re-install the CCS v3.3! Would u pls give an instuction on how to update the CCS? This problem troubles me much!
    Thanks for your reply!
    Best Regards
    Touse from AVST
    Digital Signal Processing, ARM DSPs, Embedded System, Multi-core Programming
    C6474 CCS v3.3
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Manivannan E
      Posted by Manivannan E
      on Apr 09 2009 09:00 AM
      Suggested Answer
      Intellectual2010 points
         I suggest you install CCS in different location rather than the default location. This should get you going on CCSv3.3.
      About the C6467 simulator - emif.log, this is a debug log & i believe it's accidentaly enabled in the release. To avoid this, open CCSetup, click on one of the CPUs,  check what is the Simulator Config file on the right pane of CCSetup. Open the simulator config file, search for "test_log_file" and comment that line. (comment syntax - //). After this you shouldn't see emif.log getting generated.
      regards,
      Mani
      If my reply answers your question please mark the thread as answered
      Check the Wiki for more info - link
      Report Abuse
      • Reply
    • touse
      Posted by touse
      on Apr 09 2009 21:35 PM
      Expert1475 points
      Thanks!I've tried to install CCS in different location, but it doesn't work!
      As to the log problem, I'll check it! But the problem is whatever I reinstall, the SR packaged can't be
      patched!
      Report Abuse
      • Reply
    • Ki-Soo Lee
      Posted by Ki-Soo Lee
      on Apr 12 2009 16:33 PM
      Guru116815 points
      Hello Touse,
      Are you using a limited version (evaluation, DSK, etc) of CCS 3.3?
      ki
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
      Having CCSv5 problems? Check out the CCSv5 Troubleshooting Guide
      Click here to track an issue. Enter your bug id in the "Find Record ID" box
      Report Abuse
      • Reply
    • touse
      Posted by touse
      on Apr 27 2009 06:10 AM
      Verified Answer
      Verified by BrandonAzbell
      Expert1475 points
      I got a newer version of CCS v3.3, now it works well, Thanks all!
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
