• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » C64x Multicore DSP Forum » Probelms about AIF Inter DSP Communication
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      It’s our second anniversary, but you get the present!
      Posted 5 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
      Limited time offer: Save $100 on Keystone-based EVM!
      Posted 17 days ago
      by tscheck
      Have you been thinking about ordering a TI Keystone-based EVM...
      Imagine the impact…TI’s KeyStone SoC + HP Moonshot
      Posted 29 days ago
      by Sanjay35057
      Last week, market leader Hewlett Packard announced a huge change...
    This question is not answered
    ziteng xue
    Posted by ziteng xue
    on Feb 27 2012 22:04 PM
    Prodigy40 points
    Hello!
        I am studing communications between two DSPs using AIFon TMS320C6474EVM. I have got InterDSP_AIF_BIOS_Advanced_Example_1.5 code from TI web. Now i have one questions about this project:
       When i choose the "Non_loopback" mode to achieve the communication between Faraday DSP1 and Faraday DSP2, Compiling, Linking, and Program loading are just fine. 不but the two DSPs both only showed:
        0 Main started
        1 TX task: started
        2 RX task: started
        Then it showed nothing. It means that the datas are not transmitted and received successfuly. Can you tell me the reason ?
       Thank you very much! Best reagards!
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Karthik Ramana Sankar
      Posted by Karthik Ramana Sankar
      on Mar 16 2012 14:34 PM
      Intellectual1695 points
      Hi Ziteng,
      Please, find the latest IAClib_v1.6 attached
      8322.AIF_Driver_4x_Obsai_PS.zip
      I am able to successfully get the AIF communication between DSP1 and DSP2 working on a C6474 EVM. This example is designed to run on CCSv3.3. However, I ported this example on CCSv5.1 and was able to get it working successfully. For more details about this example and steps to run this example, please refer to the app note attached:
      7245.InterDSP_AIF_appnote_v1 5.pdf
      For viewing the DSP BIOS LOG_printf log in CCSv5.1, go to tools --> RTA --> printf
      Let me know if you can get this example working on your end.
      Karthik
      If you need more help, please reply back. If this answers the question, please click  Verify Answer , below.
      C6000 DSP/BIOS C6474 DSP BIOS C6474 C6474 example code
      Report Abuse
      • Reply
    • trinh chien
      Posted by trinh chien
      on Apr 04 2012 02:01 AM
      Prodigy120 points
      Hi. Now I want to transmit data between 2 DSP in a Kit by using AIF interface. Could you tell me if I have to use daughter board as TRF7310 or not need?
      Thank you very much. Awaiting for your response.
      Report Abuse
      • Reply
    • trinh chien
      on Apr 05 2012 05:21 AM
      Prodigy120 points
      Hello Karthik Ramana Sankar
      Actually, your code is for EVM6474 or TCI6488? Because I can't load to TCI6488.
      Report Abuse
      • Reply
      on Apr 05 2012 09:27 AM
      Hi Chien,
      The Inter DSP AIF example provided in this thread above, should work with both C6474 and TCI6488 EVM. I got this example working successfully on TCI6488 EVM. Please, check your Endianess DIP switch settings on your EVM.
      Karthik
      C6474 AIF
      Report Abuse
      • Reply
    • trinh chien
      on Apr 06 2012 01:06 AM
      Prodigy120 points
      Hi Karthik Ramana Sankar!
      Thank for your response!
      I have already loaded your code to TCI6488. However, Message log only shows " 0 Main started, 1 TX started, 2 RX: Started". Andthen, nothing to show. Otherwise, I loaded your code to EVM6474. It is ok. Unfortunately, I am not used EVM6474 frequently. Please do me a favor by checking again your code to I can apply it on TCI6488.
      Thank you so much!
      Report Abuse
      • Reply
    • dien bk36
      Posted by dien bk36
      on Apr 09 2012 06:53 AM
      Prodigy55 points
      Hi,Karthik Ramana Sanka!
      i'm having a project about AIF module  in C6474. I've run example which is downloaded from this link : https://gforge.ti.com/gf/project/aifinterdsp/
      and the result is same with the MessageLog Picture that you have done. Now, i want to know about frequency carrier of AIF module. I've used  Spectrum Analyzer machine to measure at TXN0 and TXP0 . But nothing to show .i think   i don't  know center frequency so i can't do . I hope you can help me! thanks!
      Report Abuse
      • Reply
      on Apr 09 2012 15:37 PM
      dien bk36,
      The data output of the AIF module is I/Q symbols. These I/Q symbols will be provided to the radio module for transmission. My understanding is that, the radio module will be using a carrier frequency for transmitting on the air.  What do you mean by  "frequency carrier of AIF module"?. For more details about the AIF clocks on the C6474 EVM, refer to the following E2E post:
      http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/439/t/181195.aspx#653448
      For more details about C6474 AIF module, please refer to C6474 AIF users guide.
      Karthik
      C6474 AIF 6474
      Report Abuse
      • Reply
      on Apr 09 2012 15:45 PM
      Hi all,
      Please, open a new thread for any new questions related to C6474 AIF. Also, if you have your question answered (especially the thread creator), please verify the answer.
      Karthik
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
