I've been attempting to send messages from an FPGA to a C6472. I had it close to working a couple of weeks ago, and I've been trying to get the last piece of info for this thread: http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/439/t/351156.aspx
But I have been getting Illegal Transaction Decode errors in the ERR_DET register.
Here is a register dump from CCS:
[0 ... 99]
PORT_OPTION_0_SP_RST_OPT 0x00000000 Port Reset Option CSR [Memory Mapped]
PORT_OPTION_0_SP_CTL_INDEP 0x21A201C0 Port Control Independent register [Memory Mapped]
PORT_OPTION_0_SP_SILENCE_TIMER 0x10000000 Port Silence Timer [Memory Mapped]
PORT_OPTION_0_SP_MULT_EVNT_CS 0x00000000 Port Multicast-Event Control Symbol Request register [Memory Mapped]
PORT_OPTION_0_SP_CS_TX 0x40FC8000 Port Control Symbol Transmit [Memory Mapped]
PORT_OPTION_1_SP_RST_OPT 0x00000000 Port Reset Option CSR [Memory Mapped]
PORT_OPTION_1_SP_CTL_INDEP 0x00000000 Port Control Independent register [Memory Mapped]
PORT_OPTION_1_SP_SILENCE_TIMER 0x00000000 Port Silence Timer [Memory Mapped]
PORT_OPTION_1_SP_MULT_EVNT_CS 0x00000000 Port Multicast-Event Control Symbol Request register [Memory Mapped]
PORT_OPTION_1_SP_CS_TX 0x00000000 Port Control Symbol Transmit [Memory Mapped]
PORT_OPTION_2_SP_RST_OPT 0x00000000 Port Reset Option CSR [Memory Mapped]
PORT_OPTION_2_SP_CTL_INDEP 0x00000000 Port Control Independent register [Memory Mapped]
PORT_OPTION_2_SP_SILENCE_TIMER 0x00000000 Port Silence Timer [Memory Mapped]
PORT_OPTION_2_SP_MULT_EVNT_CS 0x00000000 Port Multicast-Event Control Symbol Request register [Memory Mapped]
PORT_OPTION_2_SP_CS_TX 0x00000000 Port Control Symbol Transmit [Memory Mapped]
PORT_OPTION_3_SP_RST_OPT 0x00000000 Port Reset Option CSR [Memory Mapped]
PORT_OPTION_3_SP_CTL_INDEP 0x00000000 Port Control Independent register [Memory Mapped]
PORT_OPTION_3_SP_SILENCE_TIMER 0x00000000 Port Silence Timer [Memory Mapped]
PORT_OPTION_3_SP_MULT_EVNT_CS 0x00000000 Port Multicast-Event Control Symbol Request register [Memory Mapped]
PORT_OPTION_3_SP_CS_TX 0x00000000 Port Control Symbol Transmit [Memory Mapped]
PORT_ERROR_0_SP_ERR_DET 0x80100000 Port Error Detect CSR [Memory Mapped]
PORT_ERROR_0_SP_RATE_EN 0x807E0033 Port Error Enable CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_ATTR_CAPT_DBG0 0x00000000 Port Attributes Error Capture CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_CAPT_DBG_0 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_CAPT_DBG_1 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_CAPT_DBG_2 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_CAPT_DBG_3 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_RATE 0x0F000404 Port Error Rate CSR [Memory Mapped]
PORT_ERROR_0_SP_ERR_THRESH 0x0A0A0000 Port Error Rate Threshold CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_DET 0x00000000 Port Error Detect CSR [Memory Mapped]
PORT_ERROR_1_SP_RATE_EN 0x00000000 Port Error Enable CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_ATTR_CAPT_DBG0 0x00000000 Port Attributes Error Capture CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_CAPT_DBG_0 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_CAPT_DBG_1 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_CAPT_DBG_2 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_CAPT_DBG_3 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_RATE 0x00000000 Port Error Rate CSR [Memory Mapped]
PORT_ERROR_1_SP_ERR_THRESH 0x00000000 Port Error Rate Threshold CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_DET 0x00000000 Port Error Detect CSR [Memory Mapped]
PORT_ERROR_2_SP_RATE_EN 0x00000000 Port Error Enable CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_ATTR_CAPT_DBG0 0x00000000 Port Attributes Error Capture CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_CAPT_DBG_0 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_CAPT_DBG_1 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_CAPT_DBG_2 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_CAPT_DBG_3 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_RATE 0x00000000 Port Error Rate CSR [Memory Mapped]
PORT_ERROR_2_SP_ERR_THRESH 0x00000000 Port Error Rate Threshold CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_DET 0x00000000 Port Error Detect CSR [Memory Mapped]
PORT_ERROR_3_SP_RATE_EN 0x00000000 Port Error Enable CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_ATTR_CAPT_DBG0 0x00000000 Port Attributes Error Capture CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_CAPT_DBG_0 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_CAPT_DBG_1 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_CAPT_DBG_2 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_CAPT_DBG_3 0x00000000 Port Packet/Control Symbol Error Capture CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_RATE 0x00000000 Port Error Rate CSR [Memory Mapped]
PORT_ERROR_3_SP_ERR_THRESH 0x00000000 Port Error Rate Threshold CSR [Memory Mapped]
PORT_0_SP_LM_REQ 0x00000000 Port Link Maintenance Request CSR [Memory Mapped]
PORT_0_SP_LM_RESP 0x800003A5 Port Link Maintenance Response CSR [Memory Mapped]
PORT_0_SP_ACKID_STAT 0x05000000 Port Local AckID Status CSR [Memory Mapped]
PORT_0_SP_ERR_STAT 0x04010012 Port Error and Status CSR [Memory Mapped]
PORT_0_SP_CTL 0x0068000D Port Control CSR [Memory Mapped]
PORT_1_SP_LM_REQ 0x00000000 Port Link Maintenance Request CSR [Memory Mapped]
PORT_1_SP_LM_RESP 0x000003A5 Port Link Maintenance Response CSR [Memory Mapped]
PORT_1_SP_ACKID_STAT 0x05000000 Port Local AckID Status CSR [Memory Mapped]
PORT_1_SP_ERR_STAT 0x04010012 Port Error and Status CSR [Memory Mapped]
PORT_1_SP_CTL 0x0068000D Port Control CSR [Memory Mapped]
PORT_2_SP_LM_REQ 0x00000000 Port Link Maintenance Request CSR [Memory Mapped]
PORT_2_SP_LM_RESP 0x000003A5 Port Link Maintenance Response CSR [Memory Mapped]
PORT_2_SP_ACKID_STAT 0x05000000 Port Local AckID Status CSR [Memory Mapped]
PORT_2_SP_ERR_STAT 0x04010012 Port Error and Status CSR [Memory Mapped]
PORT_2_SP_CTL 0x0068000D Port Control CSR [Memory Mapped]
PORT_3_SP_LM_REQ 0x00000000 Port Link Maintenance Request CSR [Memory Mapped]
PORT_3_SP_LM_RESP 0x000003A5 Port Link Maintenance Response CSR [Memory Mapped]
PORT_3_SP_ACKID_STAT 0x05000000 Port Local AckID Status CSR [Memory Mapped]
PORT_3_SP_ERR_STAT 0x04010012 Port Error and Status CSR [Memory Mapped]
PORT_3_SP_CTL 0x0068000D Port Control CSR [Memory Mapped]
MAP_0_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_0_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_1_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_1_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_2_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_2_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_3_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_3_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_4_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_4_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_5_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_5_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_6_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_6_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_7_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_7_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_8_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_8_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_9_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_9_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_10_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_10_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_11_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_11_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
[100 ... 199]
MAP_12_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_12_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_13_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_13_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_14_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_14_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_15_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_15_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_16_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_16_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_17_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_17_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_18_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_18_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_19_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_19_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_20_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_20_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_21_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_21_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_22_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_22_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_23_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_23_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_24_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_24_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_25_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_25_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_26_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_26_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_27_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_27_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_28_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_28_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_29_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_29_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_30_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_30_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
MAP_31_RXU_MAP_L 0x000000EE MailBox-to-queue mapping register [Memory Mapped]
MAP_31_RXU_MAP_H 0x00000102 MailBox-to-queue mapping register [Memory Mapped]
BLK_ENABLE_0_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_0_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_1_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_1_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_2_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_2_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_3_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_3_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_4_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_4_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_5_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_5_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_6_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_6_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_7_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_7_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
BLK_ENABLE_8_BLK_EN 0x00000001 Block Enable [Memory Mapped]
BLK_ENABLE_8_BLK_EN_STAT 0x00000001 Block Enable Status [Memory Mapped]
LSU_0_LSU_REG0 0x00000000 LSU Control register0 [Memory Mapped]
LSU_0_LSU_REG1 0x00000000 LSU Control register1 [Memory Mapped]
LSU_0_LSU_REG2 0x00000000 LSU Control register2 [Memory Mapped]
LSU_0_LSU_REG3 0x00000000 LSU Control register3 [Memory Mapped]
LSU_0_LSU_REG4 0x00000000 LSU Control register4 [Memory Mapped]
LSU_0_LSU_REG5 0x00000000 LSU Control register5 [Memory Mapped]
LSU_0_LSU_REG6 0x00000000 LSU Control register6 [Memory Mapped]
LSU_0_LSU_FLOW_MASKS 0x0000FFFF Core n LSU Congestion Control Flow Mask [Memory Mapped]
LSU_1_LSU_REG0 0x00000000 LSU Control register0 [Memory Mapped]
LSU_1_LSU_REG1 0x00000000 LSU Control register1 [Memory Mapped]
LSU_1_LSU_REG2 0x00000000 LSU Control register2 [Memory Mapped]
LSU_1_LSU_REG3 0x00000000 LSU Control register3 [Memory Mapped]
LSU_1_LSU_REG4 0x00000000 LSU Control register4 [Memory Mapped]
LSU_1_LSU_REG5 0x00000000 LSU Control register5 [Memory Mapped]
LSU_1_LSU_REG6 0x00000000 LSU Control register6 [Memory Mapped]
LSU_1_LSU_FLOW_MASKS 0x0000FFFF Core n LSU Congestion Control Flow Mask [Memory Mapped]
LSU_2_LSU_REG0 0x00000000 LSU Control register0 [Memory Mapped]
LSU_2_LSU_REG1 0x00000000 LSU Control register1 [Memory Mapped]
LSU_2_LSU_REG2 0x00000000 LSU Control register2 [Memory Mapped]
LSU_2_LSU_REG3 0x00000000 LSU Control register3 [Memory Mapped]
LSU_2_LSU_REG4 0x00000000 LSU Control register4 [Memory Mapped]
LSU_2_LSU_REG5 0x00000000 LSU Control register5 [Memory Mapped]
LSU_2_LSU_REG6 0x00000000 LSU Control register6 [Memory Mapped]
LSU_2_LSU_FLOW_MASKS 0x0000FFFF Core n LSU Congestion Control Flow Mask [Memory Mapped]
LSU_3_LSU_REG0 0x00000000 LSU Control register0 [Memory Mapped]
LSU_3_LSU_REG1 0x00000000 LSU Control register1 [Memory Mapped]
LSU_3_LSU_REG2 0x00000000 LSU Control register2 [Memory Mapped]
LSU_3_LSU_REG3 0x00000000 LSU Control register3 [Memory Mapped]
LSU_3_LSU_REG4 0x00000000 LSU Control register4 [Memory Mapped]
LSU_3_LSU_REG5 0x00000000 LSU Control register5 [Memory Mapped]
LSU_3_LSU_REG6 0x00000000 LSU Control register6 [Memory Mapped]
LSU_3_LSU_FLOW_MASKS 0x0000FFFF Core n LSU Congestion Control Flow Mask [Memory Mapped]
DOORBELL_INTR_0_DOORBELL_ICSR 0x00000000 DOORBELL Interrupt Status register [Memory Mapped]
DOORBELL_INTR_0_DOORBELL_ICCR 0x00000000 DOORBELL Interrupt Clear register [Memory Mapped]
DOORBELL_INTR_1_DOORBELL_ICSR 0x00000000 DOORBELL Interrupt Status register [Memory Mapped]
DOORBELL_INTR_1_DOORBELL_ICCR 0x00000000 DOORBELL Interrupt Clear register [Memory Mapped]
DOORBELL_INTR_2_DOORBELL_ICSR 0x00000000 DOORBELL Interrupt Status register [Memory Mapped]
DOORBELL_INTR_2_DOORBELL_ICCR 0x00000000 DOORBELL Interrupt Clear register [Memory Mapped]
DOORBELL_INTR_3_DOORBELL_ICSR 0x00000000 DOORBELL Interrupt Status register [Memory Mapped]
DOORBELL_INTR_3_DOORBELL_ICCR 0x00000000 DOORBELL Interrupt Clear register [Memory Mapped]
DOORBELL_INTR_ROUTE_0_DOORBELL_ICRR 0x00000000 DOORBELL Interrupt Condition Routing register (0 to 7) [Memory Mapped]
DOORBELL_INTR_ROUTE_0_DOORBELL_ICRR2 0x00000000 DOORBELL Interrupt Condition Routing register (8 to 15) [Memory Mapped]
[200 ... 299]
DOORBELL_INTR_ROUTE_1_DOORBELL_ICRR 0x00000000 DOORBELL Interrupt Condition Routing register (0 to 7) [Memory Mapped]
DOORBELL_INTR_ROUTE_1_DOORBELL_ICRR2 0x00000000 DOORBELL Interrupt Condition Routing register (8 to 15) [Memory Mapped]
DOORBELL_INTR_ROUTE_2_DOORBELL_ICRR 0x00000000 DOORBELL Interrupt Condition Routing register (0 to 7) [Memory Mapped]
DOORBELL_INTR_ROUTE_2_DOORBELL_ICRR2 0x00000000 DOORBELL Interrupt Condition Routing register (8 to 15) [Memory Mapped]
DOORBELL_INTR_ROUTE_3_DOORBELL_ICRR 0x00000000 DOORBELL Interrupt Condition Routing register (0 to 7) [Memory Mapped]
DOORBELL_INTR_ROUTE_3_DOORBELL_ICRR2 0x00000000 DOORBELL Interrupt Condition Routing register (8 to 15) [Memory Mapped]
HW_PKT_FWD_0_PF_16BIT_CNTL 0xFFFFFFFF Packet Forwarding register for 16b DeviceIDs [Memory Mapped]
HW_PKT_FWD_0_PF_8BIT_CNTL 0x0003FFFF Packet Forwarding register for 8b DeviceIDs [Memory Mapped]
HW_PKT_FWD_1_PF_16BIT_CNTL 0xFFFFFFFF Packet Forwarding register for 16b DeviceIDs [Memory Mapped]
HW_PKT_FWD_1_PF_8BIT_CNTL 0x0003FFFF Packet Forwarding register for 8b DeviceIDs [Memory Mapped]
HW_PKT_FWD_2_PF_16BIT_CNTL 0xFFFFFFFF Packet Forwarding register for 16b DeviceIDs [Memory Mapped]
HW_PKT_FWD_2_PF_8BIT_CNTL 0x0003FFFF Packet Forwarding register for 8b DeviceIDs [Memory Mapped]
HW_PKT_FWD_3_PF_16BIT_CNTL 0xFFFFFFFF Packet Forwarding register for 16b DeviceIDs [Memory Mapped]
HW_PKT_FWD_3_PF_8BIT_CNTL 0x0003FFFF Packet Forwarding register for 8b DeviceIDs [Memory Mapped]
PID 0x44A23102 Peripheral Identification Register [Memory Mapped]
PCR 0x00000005 Peripheral Control register [Memory Mapped]
PER_SET_CNTL 0x0D400360 Peripheral Settings Control register [Memory Mapped]
GBL_EN 0x00000001 Peripheral Global Enable register [Memory Mapped]
GBL_EN_STAT 0x00000073 Peripheral Global Enable Status [Memory Mapped]
DEVICEID_REG1 0x00FF00FF RapidIO DEVICEID1 Register [Memory Mapped]
DEVICEID_REG2 0x00FF00FF RapidIO DEVICEID2 Register [Memory Mapped]
SERDES_CFGRX_CNTL_0 0x00081101 SerDes RX Channels CFG register [Memory Mapped]
SERDES_CFGRX_CNTL_1 0x00081101 SerDes RX Channels CFG register [Memory Mapped]
SERDES_CFGRX_CNTL_2 0x00000000 SerDes RX Channels CFG register [Memory Mapped]
SERDES_CFGRX_CNTL_3 0x00000000 SerDes RX Channels CFG register [Memory Mapped]
SERDES_CFGTX_CNTL_0 0x00000401 SerDes TX Channels CFG register [Memory Mapped]
SERDES_CFGTX_CNTL_1 0x00000400 SerDes TX Channels CFG register [Memory Mapped]
SERDES_CFGTX_CNTL_2 0x00000000 SerDes TX Channels CFG register [Memory Mapped]
SERDES_CFGTX_CNTL_3 0x00000000 SerDes TX Channels CFG register [Memory Mapped]
SERDES_CFG_CNTL_0 0x0000000F SerDes Macros CFG register [Memory Mapped]
SERDES_CFG_CNTL_1 0x00000000 SerDes Macros CFG register [Memory Mapped]
SERDES_CFG_CNTL_2 0x00000000 SerDes Macros CFG register [Memory Mapped]
SERDES_CFG_CNTL_3 0x00000000 SerDes Macros CFG register [Memory Mapped]
RX_CPPI_ICSR 0x00000000 RX CPPI Interrupt Status register [Memory Mapped]
RX_CPPI_ICCR 0x00000000 RX CPPI Interrupt Clear register [Memory Mapped]
TX_CPPI_ICSR 0x00000000 TX CPPI Interrupt Status register [Memory Mapped]
TX_CPPI_ICCR 0x00000000 TX CPPI Interrupt Clear register [Memory Mapped]
LSU_ICSR 0x00000000 LSU Status Interrupt register [Memory Mapped]
LSU_ICCR 0x00000000 LSU Clear Interrupt register [Memory Mapped]
ERR_RST_EVNT_ICSR 0x00000004 Error, Reset, and Special Event Status Interrupt register [Memory Mapped]
ERR_RST_EVNT_ICCR 0x00000000 Error, Reset, and Special Event Clear Interrupt register [Memory Mapped]
RX_CPPI_ICRR 0x00000000 RX CPPI Interrupt Condition Routing register (0 to 7) [Memory Mapped]
RX_CPPI_ICRR2 0x00000000 RX CPPI Interrupt Condition Routing register (8 to 15) [Memory Mapped]
TX_CPPI_ICRR 0x00000000 TX CPPI Interrupt Condition Routing register (0 to 7) [Memory Mapped]
TX_CPPI_ICRR2 0x00000000 TX CPPI Interrupt Condition Routing register (8 to 15) [Memory Mapped]
LSU_ICRR_0 0x00000000 LSU Module Interrupt Condition Routing register [Memory Mapped]
LSU_ICRR_1 0x00000000 LSU Module Interrupt Condition Routing register [Memory Mapped]
LSU_ICRR_2 0x00000000 LSU Module Interrupt Condition Routing register [Memory Mapped]
LSU_ICRR_3 0x00000000 LSU Module Interrupt Condition Routing register [Memory Mapped]
ERR_RST_EVNT_ICRR 0x00000000 Err/Reset/special event Interrupt Condition Routing register [Memory Mapped]
ERR_RST_EVNT_ICRR2 0x00000000 Err/Reset/special event Interrupt Condition Routing register [Memory Mapped]
ERR_RST_EVNT_ICRR3 0x00000000 Err/Reset/special event Interrupt Condition Routing register [Memory Mapped]
INTDST_DECODE_0 0x40000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_1 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_2 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_3 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_4 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_5 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_6 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_DECODE_7 0x00000000 INTDST Interrupt Status Decode registers [Memory Mapped]
INTDST_RATE_CNTL_0 0x00000001 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_1 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_2 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_3 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_4 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_5 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_6 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
INTDST_RATE_CNTL_7 0x00000000 INTDST Interrupt Rate Control registers [Memory Mapped]
QUEUE_TXDMA_HDP_0 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_1 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_2 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_3 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_4 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_5 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_6 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_7 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_8 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_9 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_10 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_11 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_12 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_13 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_14 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_HDP_15 0x00000000 Queue TX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_TXDMA_CP_0 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_1 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_2 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_3 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_4 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_5 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_6 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_7 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_8 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_9 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_10 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_11 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_12 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_13 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_14 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
QUEUE_TXDMA_CP_15 0x00000000 Queue TX DMA Completion Pointer [Memory Mapped]
[300 ... 394]
QUEUE_RXDMA_HDP_0 0x02E00000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_1 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_2 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_3 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_4 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_5 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_6 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_7 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_8 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_9 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_10 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_11 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_12 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_13 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_14 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_HDP_15 0x00000000 Queue RX DMA Head Descriptor Pointer [Memory Mapped]
QUEUE_RXDMA_CP_0 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_1 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_2 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_3 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_4 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_5 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_6 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_7 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_8 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_9 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_10 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_11 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_12 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_13 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_14 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
QUEUE_RXDMA_CP_15 0x00000000 Queue RX DMA Completion Pointer [Memory Mapped]
TX_QUEUE_TEAR_DOWN 0x00000000 TX Queue Tear-down Register [Memory Mapped]
TX_CPPI_FLOW_MASKS_0 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_1 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_2 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_3 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_4 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_5 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_6 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
TX_CPPI_FLOW_MASKS_7 0xFFFFFFFF TX CPPI Supported Flow Mask [Memory Mapped]
RX_QUEUE_TEAR_DOWN 0x00000000 RX Queue Tear-down Register [Memory Mapped]
RX_CPPI_CNTL 0x00000000 RX CPPI Control register [Memory Mapped]
TX_QUEUE_CNTL0 0x03020100 TX CPPI Weighted Round Robin Control [Memory Mapped]
TX_QUEUE_CNTL1 0x07060504 TX CPPI Weighted Round Robin Control [Memory Mapped]
TX_QUEUE_CNTL2 0x0B0A0908 TX CPPI Weighted Round Robin Control [Memory Mapped]
TX_QUEUE_CNTL3 0x0F0E0D0C TX CPPI Weighted Round Robin Control [Memory Mapped]
FLOW_CNTL_0 0x000100FF Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_1 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_2 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_3 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_4 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_5 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_6 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_7 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_8 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_9 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_10 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_11 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_12 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_13 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_14 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
FLOW_CNTL_15 0x00010000 Flow Control Table Entry Registers [Memory Mapped]
DEV_ID 0x00000030 Device Identity CAR [Memory Mapped]
DEV_INFO 0x00000000 Device Information CAR [Memory Mapped]
ASBLY_ID 0x00000030 Assembly Identity CAR [Memory Mapped]
ASBLY_INFO 0x00000100 Assembly Information CAR [Memory Mapped]
PE_FEAT 0x20000019 Processing Element Features CAR [Memory Mapped]
SRC_OP 0x0000FDF4 Source Operations CAR [Memory Mapped]
DEST_OP 0x0000FC04 Destination Operations CAR [Memory Mapped]
PE_LL_CTL 0x00000000 Processing Element Logical Layer Control CSR [Memory Mapped]
LCL_CFG_HBAR 0x00000000 Local Configuration Space Base Address 0 CSR [Memory Mapped]
LCL_CFG_BAR 0x005A0200 Local Configuration Space Base Address 1 CSR [Memory Mapped]
BASE_ID 0x00FF00FF Base Device ID CSR [Memory Mapped]
HOST_BASE_ID_LOCK 0x0000FFFF Host Base Device ID Lock CSR [Memory Mapped]
COMP_TAG 0x00000000 Component Tag CSR [Memory Mapped]
SP_MB_HEAD 0x10000001 1x/4x LP-Serial Port Maintenance Block Header [Memory Mapped]
SP_LT_CTL 0x00FFFF00 Port Link Time-Out Control CSR [Memory Mapped]
SP_RT_CTL 0x00FFFF00 Port Response Time-Out Control CSR [Memory Mapped]
SP_GEN_CTL 0xC0000000 Port General Control CSR [Memory Mapped]
ERR_RPT_BH 0x00000007 Error Reporting Block Header [Memory Mapped]
ERR_DET 0x08000000 Logical/Transport Layer Error Detect CSR [Memory Mapped]
ERR_EN 0x8DC000C0 Logical/Transport Layer Error Enable CSR [Memory Mapped]
H_ADDR_CAPT 0x00000000 Logical/Transport Layer High Address Capture CSR [Memory Mapped]
ADDR_CAPT 0x00000000 Logical/Transport Layer Address Capture CSR [Memory Mapped]
ID_CAPT 0x00FF00EE Logical/Transport Layer Device ID Capture CSR [Memory Mapped]
CTRL_CAPT 0xB0000000 Logical/Transport Layer Control Capture CSR [Memory Mapped]
PW_TGT_ID 0x00000000 Port-Write Target Device ID CSR [Memory Mapped]
SP_IP_DISCOVERY_TIMER 0x90800000 Port IP Discovery Timer in 4x mode [Memory Mapped]
SP_IP_MODE 0x4000002A Port IP Mode CSR [Memory Mapped]
IP_PRESCAL 0x00000021 Serial Port IP Prescalar [Memory Mapped]
SP_IP_PW_IN_CAPT_0 0x00000000 Port-Write-In Capture CSR [Memory Mapped]
SP_IP_PW_IN_CAPT_1 0x00000000 Port-Write-In Capture CSR [Memory Mapped]
SP_IP_PW_IN_CAPT_2 0x00000000 Port-Write-In Capture CSR [Memory Mapped]
SP_IP_PW_IN_CAPT_3 0x00000000 Port-Write-In Capture CSR [Memory Mapped]
I'm at a bit of a loss as to why messages are no longer getting into the part. The Dev ID and Logical / Transport capture registers look OK to me for a message packet (Type 11)
Thanks!
