Dear Charlie and TI support team
I'm using CCS V5.1.1 to run ECU testing (I wrote these codes based on references on TI forum site).
Some additional information:
- I'm testing on TI EVM6472 platform.
- ECU version: 10.92.1.0
Here is my code:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ti/mas/ecu/ecu.h>
#include <ti/mas/types/types.h>
#include "hyb.h"
#include "mua.h"
// Parameters
#define ECHO_CANCEL_FRAME_SIZE 80 // Frame Length
#define ECU_SEARCH_FILTER_LENGTH 1024 // Filter Length
#define ECU_FILTER_SEGMENT_COUNT 3 // Filter Segment Count
#define ECU_FILTER_SEGMENT_LENGTH 256 // Filter Segment Length
#define Y2X_DELAY 80 // Delay
// ECU Parameters
struct ecu_params{
tuint ID;
void *ecu_Inst; //Signal limiter Instance
ecomemBuffer_t *ecu_buffers;
ecuConfig_t ecuCfg;
ecuControl_t ecuCtl;
ecuNewConfig_t ecuCfgNew;
linSample ecu_rx_buffer[80];
linSample ecu_tx_buffer[80];
linSample ecu_ec_buffer[80];
// EcuContext
ecuContext_t ecuContext = {
NULL, // Exception handler
NULL, // Debug streaming function pointer
NULL, // MIPS Agent open/close event handler
NULL, // Search filter swapping function
NULL, // Send out function pointer
NULL, // Receive out function pointer
ECHO_CANCEL_FRAME_SIZE, // Maximum number of samples per frame
ECU_SEARCH_FILTER_LENGTH , // Maximum filter length in taps
ECU_FILTER_SEGMENT_LENGTH, // Maximum filter segment buffer length in taps
ECU_FILTER_SEGMENT_COUNT, // Maximum allowed active filter segments
Y2X_DELAY, // Maximum y2x delay in samples
0L, // Bitfield representing those portions of the delay line already expanded.
NULL, // Pointer to base of the scratch delay line
NULL, // TDM aligned pointer within scratch delay line
NULL, // TDM aligned pointer within packed delay line
void main() {
linSample sinBuffer[80];
linSample rinLinear[80];
tint rinCompr[80];
tword rinBuffer[80];
tint i;
tint length = 80;
// List of Buffers
tint *InstanceBuffer;
Fract *fg_fs, *bg_fs, *bg_ub, *dt_xp, *erl_ye, *acom_ee;
Fract *bsdl, *wbs, *sb, *ssb, *sc;
tint *bg_fsdl, *fg_fsdl;
linSample *bg_er_sig, *exp_dl;
linSample *far_end_dl;
struct ecu_params echo;
// Clear data
for(i=0;i<length;i++){
echo.ecu_rx_buffer[i]=0;
echo.ecu_tx_buffer[i]=0;
echo.ecu_ec_buffer[i]=0;
sinBuffer[i] = 0;
rinCompr[i]=0;
// Getsize, Provide memory for all buffers
tint ecuNumberOfBuffers;
const ecomemBuffer_t *internalMemoryBuffers = NULL;
tint ecuStatus;
//Get size
ecuStatus = ecuGetSizes (&ecuNumberOfBuffers, &internalMemoryBuffers, (void *)NULL);
// Provide memory for all buffers
echo.ecu_buffers = (ecomemBuffer_t *)calloc(ecuNumberOfBuffers, sizeof(ecomemBuffer_t));
// List of Buffer memory
InstanceBuffer = (tint *) malloc(internalMemoryBuffers[0].size); //Instance Buffer
fg_fs = (Fract *) malloc(internalMemoryBuffers[1].size); //Foreground filter segment (NV)
bg_fs = (Fract *) malloc(internalMemoryBuffers[2].size); //Background filter segment (NV)
bg_er_sig = (linSample *) malloc(internalMemoryBuffers[3].size); //Background error signal (NV)
far_end_dl = (linSample *) malloc(internalMemoryBuffers[4].size); //Far End Delay Line
exp_dl = (linSample *) malloc(internalMemoryBuffers[5].size); //Expanded Delay Line
bg_ub = (Fract *) malloc(internalMemoryBuffers[6].size); //Background Update Buffer
dt_xp = (Fract *) malloc(internalMemoryBuffers[7].size); //Doubletalk x-Power
erl_ye = (Fract *) malloc(internalMemoryBuffers[8].size); //ERL y-Energy
acom_ee = (Fract *) malloc(internalMemoryBuffers[9].size); //ACOM e-Energy
bg_fsdl = (tint *) malloc(internalMemoryBuffers[10].size); //Background Filter Segment Delays/Lengths
fg_fsdl = (tint *) malloc(internalMemoryBuffers[11].size); //Foreground Filter Segment Delays/Lengths
bsdl = (Fract *) malloc(internalMemoryBuffers[12].size); //Band Split Delay Lines
wbs = (Fract *) malloc(internalMemoryBuffers[13].size); //Wide Band Scratch
sb = (Fract *) malloc(internalMemoryBuffers[14].size); //Search Buffer
ssb = (Fract *) malloc(internalMemoryBuffers[15].size); //Search Scratch Buffer
sc = (Fract *) malloc(internalMemoryBuffers[16].size); //Search Counter
echo.ecu_buffers[0] = internalMemoryBuffers[0];
echo.ecu_buffers[0].base = InstanceBuffer;
echo.ecu_buffers[1] = internalMemoryBuffers[1];
echo.ecu_buffers[1].base = fg_fs;
echo.ecu_buffers[2] = internalMemoryBuffers[2];
echo.ecu_buffers[2].base = bg_fs;
echo.ecu_buffers[3] = internalMemoryBuffers[3];
echo.ecu_buffers[3].base = bg_er_sig;
echo.ecu_buffers[4] = internalMemoryBuffers[4];
echo.ecu_buffers[4].base = far_end_dl;
echo.ecu_buffers[5] = internalMemoryBuffers[5];
echo.ecu_buffers[5].base = exp_dl;
echo.ecu_buffers[6] = internalMemoryBuffers[6];
echo.ecu_buffers[6].base = bg_ub;
echo.ecu_buffers[7] = internalMemoryBuffers[7];
echo.ecu_buffers[7].base = dt_xp;
echo.ecu_buffers[8] = internalMemoryBuffers[8];
echo.ecu_buffers[8].base = erl_ye;
echo.ecu_buffers[9] = internalMemoryBuffers[9];
echo.ecu_buffers[9].base = acom_ee;
echo.ecu_buffers[10] = internalMemoryBuffers[10];
echo.ecu_buffers[10].base = bg_fsdl;
echo.ecu_buffers[11] = internalMemoryBuffers[11];
echo.ecu_buffers[11].base = fg_fsdl;
echo.ecu_buffers[12] = internalMemoryBuffers[12];
echo.ecu_buffers[12].base = bsdl;
echo.ecu_buffers[13] = internalMemoryBuffers[13];
echo.ecu_buffers[13].base = wbs;
echo.ecu_buffers[14] = internalMemoryBuffers[14];
echo.ecu_buffers[14].base = sb;
echo.ecu_buffers[15] = internalMemoryBuffers[15];
echo.ecu_buffers[15].base = ssb;
echo.ecu_buffers[16] = internalMemoryBuffers[16];
echo.ecu_buffers[16].base = sc;
echo.ecuCfgNew.ID = 1;
//ecunew
ecuStatus = ecuNew(&(echo.ecu_Inst), ecuNumberOfBuffers, echo.ecu_buffers, &(echo.ecuCfgNew));
// Config & Ecu open
ecuConfigParam_t cfgParam;
cfgParam.filter_length = ECU_SEARCH_FILTER_LENGTH ;
cfgParam.noise_level = 0;
cfgParam.config_bitfield = ecu_ENABLE_ECHO_CANCELLER | // ENABLE ECU, ENABLE NLP, ENABLE UPDATE
ecu_ENABLE_UPDATE |
ecu_ENABLE_NLP |
ecu_ENABLE_AUTO_UPDATE |
ecu_ENABLE_SEARCH |
ecu_ENABLE_CNG_ADAPT |
ecu_ENABLE_OPNLP_DETECT;
cfgParam.config_bitfield1 = ecu_ENABLE_NLP_PHASE_RND;
cfgParam.nlp_aggress = 0; // balance performance
cfgParam.cn_config = 0; // pink noise
echo.ecuCfg.cfgParam = &cfgParam;
echo.ecuCfg.y2x_delay = 80; // One frame default y2x delay
echo.ecuCfg.samples_per_frame = 80; // 10ms default frame duration
echo.ecuCfg.pcm_zero = 0;
echo.ecuCfg.pcm_expand_tbl = NULL;
// ecuopen
ecuOpen (echo.ecu_Inst, &echo.ecuCfg);
ecuStatus = ecuControl(echo.ecu_Inst,&echo.ecuCtl);
// Read file
FILE *pt1,*pt2,*pt3;
int Fnum;
pt1 = fopen("../rin.pcm","rb");
pt2 = fopen("../sin.pcm","rb");
pt3 = fopen("../sout.pcm","wb");
for(Fnum=0;Fnum<1500;Fnum++){
fseek(pt1,Fnum*length,SEEK_SET);
fread(rinLinear,sizeof(linSample),length,pt1);
fseek(pt2,Fnum*length,SEEK_SET);
fread(sinBuffer,sizeof(linSample),length,pt2);
// Data Compression
muaTblUlawCmpr(length, rinLinear, rinCompr);
for (i=0; i<length; i++) {
rinBuffer[i] = rinCompr[i] & 0xFF;
// EcuSendin
ecuSendIn(echo.ecu_Inst, sinBuffer, rinBuffer, echo.ecu_ec_buffer);
fseek(pt3,Fnum*length,SEEK_SET);
fwrite(echo.ecu_ec_buffer,2,length,pt3);
printf("\n Frame %d",Fnum);
printf("\n");
printf("%d,",sinBuffer[i]);
printf("\n");
printf("%d,",rinBuffer[i]);
printf("\n");
printf("%d,",echo.ecu_ec_buffer[i]);
fclose(pt1);
fclose(pt2);
fclose(pt3);
However, the results of "echo.ecu_ec_buffer" is as same as "sinBuffer". I tried many times, but can not solve this problem. I don't know how to run it to get correct results? Please help me.
Thank you and regards,
Phong
