I have downloaded H264 Decoder, Version 2.00.002 from TI Web site. I read release note and known that the library supports C6472. I successfully compile the TestAppDecoder sample and load to the simulator. Console shows log as bellow:
[C64+_0]
Read Configuration Set 1
Running in Output Dump Mode
FileSize = 69161
Input File read successfully...
Creating Algorithm Instance...
Algorithm Instance Creation Done..
Using debug I know that program is suspended at:
/* Basic Algorithm process() call */
/* Start the decode process for one frame/field by calling process */
/* function. */
retVal = ividDecFxns->process((IVIDDEC2_Handle)handle,
(XDM1_BufDesc *)&inputBufDesc,
(XDM_BufDesc *)&outputBufDesc,
(IVIDDEC2_InArgs *)&inArgs.viddecInArgs,
(IVIDDEC2_OutArgs *)&outArgs);
Could you tell me how to debug, trace and fix the problems.
