Hi Sir,
I am using TMS320C6455 DSP. We are using GPIO3 & GPIO5 interrupts .I am doing initializations of both interrupts seperately at the starting of the program.the interrupt generation code will be in while loop so that both interrupts should come continuously , But Only one ISR is running.Another ISR it is not hooking.What may be the reason?
If I Initialize every time before getting interrupt, both interrupts are servicing.When I initialize only once at the starting only one ISR is running.But Both the events are generating.If two events comes at a time any one event will miss? one event is servicing but another event is not servicing?Can you please help to solve this issue.
Thanks&Regards,
Vaishnavi.
