Tool/software: TI-RTOS
Thank you for your attention to my post.
When we test K2GEVM ,We found there is a hardware problem .We connect the pins( MCK pin,BCK pin,FCK pin,Data1 pin,Data2 pin,Data3 pin,Data4 pin,SDA pin and SCL pin ) of K2GEVM to our circuit board which is
supplied by 12V single. we find that the votage of MCK pin, SDA pin and SCL pin is 3.3V ,meanwhile the other pin output votage is 1.8 V .The K2GEVM does not work properly. We don't know what is wrong with the
problem. What shoud we do to make the K2GEVM work normally ? Thank you for your help .
Wujun
