• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » How Inter-Processor Interrput works?
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      OpenMP - All aboard!
      Posted 1 hour ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 1 day ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
      It’s our second anniversary, but you get the present!
      Posted 8 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
    This question is not answered
    Haifei Wu
    Posted by Haifei Wu
    on Mar 15 2012 20:32 PM
    Prodigy220 points
    In the document "INTC for KeyStone Devices UG", it says that when set the IPCG of IPCGRx, the corex's interrupt works.(Am i right ?). In this document, it also introduces IPCGR and INCAR (registers), SRCS and SRCC(bits). I don't know if i want to use Inter-Processor Interrupt, what pre-work and post-work should be done. Can anybody give detail information? Thank you!
    multicore C6678 Inter-Processor Interrput
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Steven Ji
      Posted by Steven Ji
      on Mar 16 2012 13:30 PM
      Expert8595 points
      Haifei,
      IPC is used for interrupt communication between core to core within DSP and can also be used to communicate with external host.
      You can find some more information in the IPC section of CSL document as the follows file:
      \pdk_C6678_1_0_0_17\packages\ti\csl\docs\csldocs.chm
      You can see how those registers are being affected in the descriptions of each function.
      The usage of IPC interrupt is similar as the other interrupt generation. We have to enable CorePac INTC to accept the interrupt first and clear pending status after triggering.
      I also attached one simple example that Core0 and Core1 generate IPC interrupts to each other. You can load the same output file to both of the cores and execute the two cores simultaneously (need to make sure the CorePac INTC has been setup completely in two cores before they trigger the interrupts, you can add more delay in the source code ).
      Hope those information helps.
      0143.IPC_Example.zip
      Sincerely,
      Steven
      Sincerely,
      Steven
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Sebastian Jegeras
      Posted by Sebastian Jegeras
      on May 08 2012 07:56 AM
      Prodigy20 points
      Hello Steven,
      I have tried to run the example you've provided without success.
      The problem is that the interrupts are never fired, which means it halts on the first while loop in the main-function.
      I'm running on a C6616 device, but the event id seems to be correct from what I could find in the documentation.
      Any idea what I could be missing?
      Sebastian
      Report Abuse
      • Reply
    • one and zero
      Posted by one and zero
      on May 08 2012 08:01 AM
      Expert6825 points
      Hi Sebastian,
      please check this post.
      http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/187011.aspx
      I also attached a project that triggers an IPC from core 0 to core 1. There's synchronization in the code that makes sure everything is set up properly before the IPC interrupt is being triggered. You can load the same .out file to core 0 and 1 ...
      This was targeted for the C6678 but should work for C6670 as well ...
      Kind regards,
      one and zero
      You can also follow me on Twitter: http://twitter.com/oneandzeroTI
      Do you want to read interesting multicore articles? Check out our Multicore Mix
      Report Abuse
      • Reply
    • Sebastian Jegeras
      on May 10 2012 03:10 AM
      Prodigy20 points
      one and zero,
      That example worked, thank you.
      The part that was missing in the example in this thread was that the bootcfg wasn't unlocked, when I added that to the first example, that too worked as expected.
      Sebastian
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
