• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » CDCE62005 vs CDCE72010
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      OpenMP - All aboard!
      Posted 10 hours ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 1 day ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
      It’s our second anniversary, but you get the present!
      Posted 8 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
    This question is not answered
    Wenjun Huang
    Posted by Wenjun Huang
    on Mar 28 2012 23:24 PM
    Expert1770 points
    The C6678 EVB uses 2x CDCE62005 which has 5 differential output clocks each. I am intending to use 1x CDCE72010 which has 10 output clocks.
    However, the CDCE62005 and CDCE72010 seems a bit different. CDCE72010 is a Ten Output High Performance Clock Synchronizer, Jitter Cleaner and Clock Distributor whereas CDCE62005 is a Five/Ten Output Clock Generator/ Jitter Cleaner With Integrated Dual VCOs.
    Could I replace 2x CDCE62005 with 1x  CDCE72010 just like that. My concern is that I may lose some functionality if I switch from CDCE62005 to CDCE72010 (such as the Integrate VCO in CDCE62005 which is not mentioned in CDCE72010).
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Bill Taboada
      Posted by Bill Taboada
      on Mar 29 2012 10:33 AM
      Expert8180 points
      The two CDCE62005 clock generators are currently used to generate six possible clock inputs to the C6678.  There are a number of issues to consider if you were switching to the  CDCE72010 and I can't say whether it would work for you application without additional details on what you're trying to accomplish.  It's clear that you would have to add an external VCXO and it's appropriate circuitry to use the CDCE72010 and calculate whether all the frequencies you need could be divided down from a single synthesized frequency.  This couldn't be accomplished for the EVM but that depended, in large part, on the frequencies that we selected for some of the clock inputs.  Remember that we are trying to create an evaluation board that is as flexible as possible and that adds some complexity that you might not need.  For example, both the CORE_CLK and the PA_SS_CLK have 100MHz clock sources, the CORE_CLK from the first CECE62005 and the PA_SS_CLK is from the second.  This was done to provide the possibility of a different clock frequencies for these two inputs but in a real application if both inputs needed 100MHz the PACLKSEL pins could be pulled low allowing the CORE_CLK input to be used by the PA PLL and eliminating the need for a clock on the PA_SS_CLK input.
      What are the clock requirements for you application board?  Are you using all of the SERDES interfaces?  Can you use the same generated clock for the serdes clock inputs by using a clock distribution as opposed to generating each individually?  All these questions need to be answered before determining you clock generator needs.
      If you need more help, please reply back. If your question is answered, please click  Verify Answer
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
