• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » Core connection error
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      OpenMP - All aboard!
      Posted 14 hours ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 1 day ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
      It’s our second anniversary, but you get the present!
      Posted 8 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
    This question is answered
    FeruzM
    Posted by FeruzM
    on Apr 16 2012 03:37 AM
    Intellectual705 points
    Hi everybody,
    I have got error while connecting on my TMSC6678L device
    Connecting Target...
    C66xx_0: GEL Output: DSP core #0
    C66xx_0: GEL Output: No initialization performed since bootmode = 0x00000005
    C66xx_0: GEL Output: You can manually initialize with GlobalDefaultSetup
    Earlier error was fixed http://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/177029.aspx and I am suspecting there is still some sort of configuration error.
    If I try to load program here is what I get
    C66xx_0: File Loader: Data verification failed at address 0x80080000 Please verify target memory and memory map.
    C66xx_0: GEL: File: path/filename.out: a data verification error occurred, file load failed.
    Any help appreciated, thanks!
    Feruz
    target connection globaldefaultsetup
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chad Courtney
      Posted by Chad Courtney
      on Apr 16 2012 08:12 AM
      Mastermind22595 points
      It would appear that you've not configured the DDR memory and you're code has some portion of it located in DDR memory.  When you attempt to load this code to DDR it fails since it's not configured.  You will need to configure the DDR before loading code to it, which can be done via the GEL file.
      Chad
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • FeruzM
      Posted by FeruzM
      on Apr 16 2012 08:31 AM
      Hi Chad,
      Thank you for respond.
      But I am using given GEL file, in /emulation/boards/evmc6678l/gel/emvc6678l.gel.
      Perhaps, some change in gel file would help?
      Feruz
      Report Abuse
      • Reply
    • Naoki Takahashi
      Posted by Naoki Takahashi
      on Apr 16 2012 09:22 AM
      Prodigy130 points
      Hi FeruzM,
      I do not own the C6678 EVM (I'm a C6670 EVM user), but isn't it related to the DIP SW settings on your EVM?
      I had a quick look at the gel file for C6678 which I found under my CCSv5.1 installation folder.
      The error message seems to come from the following gel codes:
              if (DEVSTAT & 0x0000000E)
                  GEL_TextOut("No initialization performed since bootmode = %x \n",,,,,(DEVSTAT >> 1 ) & 0xF);
                  GEL_TextOut("You can manually initialize with GlobalDefaultSetup\n");
              }else...
      The lower 3 bits of DEVSTAT register tells you the boot device settings, which you can configure by the DIP SW.
      So, how about configuring the EVM for the NO BOOT MODE?
      Oddly, there is no such codes in C6670 EVM's gel...
      BR,
      Naoki
      Report Abuse
      • Reply
    • FeruzM
      Posted by FeruzM
      on Apr 16 2012 09:41 AM
      Hi Naoki,
      Well, I haven't changed anything for long, unless some of my colleagues did, but here: how DIP SW looks
      I hope it is visible!
      btw: using with usb emulator, ccsv5.1
      Thanks!
      Feruz
      Report Abuse
      • Reply
    • Chad Courtney
      on Apr 16 2012 16:30 PM
      Feruz,
      Yes, you're loading the GEL file, but if you look at the message, it stops initializing things because you're in I2C boot (bootmode = 5.)  Which is not configuring the DDR memories.  So the DDR memories on not configured and then you try to load the code which some of it is in the DDR memory space, and you get the loading verfication error at 0x80008000.  There's a drop down menu for the GEL and you can go ahead and have the GEL file configure the DDR, which it has not done at this point.  From the GEL menu perform a Global_Default_Setup and this will configure the DDR memory.
      Chad
      Report Abuse
      • Reply
    • FeruzM
      Posted by FeruzM
      on Apr 25 2012 07:08 AM
      Hi Chad,
      Thank you for reply. Yes it is working, but how would I do it automatically so that I won't need to make it manually for every core?
      Feruz
      Report Abuse
      • Reply
    • Chad Courtney
      on Apr 25 2012 09:25 AM
      Verified Answer
      Verified by FeruzM
      Feruz,
      You would only need to do it once per device, not per core.
      The DDR needs to be configured before anything is ever written to it.  In a real system where code/data is written to DDR at boot time you can do one of two things.
      1.) Use an intermediate bootloader which configures IPs such as DDR that is required to complete the reset of the bootloading
      2.) Use an IP for bootloading that you can have the host write the config registers for you to do the configuration (SRIO and PCIe are a couple examples of IPs that can do this.)
      That said, for initial development on an EVM people tend not to worry about this as they're focused on the code developement and they just want the DDR to work.  Gel files are general used for this.  I'm assuming CCS is configured to run that GEL script every time you connect to target.  If not I'd suggest you make it do so.  Then go in and modify the GEL script to go ahead and run the initialization routine even though it's done a I2C boot.  In this case every time the DSP goes through a POR or Power Cycle and you have to reconnect w/ CCS, then you'll run the script to initialize DDR automatically.
      Chad
      Report Abuse
      • Reply
    • FeruzM
      Posted by FeruzM
      on Apr 25 2012 10:09 AM
      I see!
      Thank you very much!
      Feruz
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
