• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » Compiling ImgLib in CCSv5 and Linking it to my RTSC project
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      Geeks UNITE for Geek Pride Day
      Posted 1 day ago
      by Lauren Reed1
      Happy Geek Pride Day from the Processors team! We wanted to celebrate...
      OpenMP - All aboard!
      Posted 3 days ago
      by Debbie Greenstreet
      With so many end products today relying on multicore DSPs for...
      A look back: Two years of Multicore Mix
      Posted 4 days ago
      by Lauren Reed1
      A big thank you to everyone who participated in our contest last...
    This question is answered
    BrandyJ
    Posted by BrandyJ
    on Apr 24 2012 14:50 PM
    Genius4370 points
    I could use some advice on how to compile this library in CCSv5.  The instructions I have found in the directory are vague and limited to makefiles and CCsv4.  Also, what is the best way to link this into an RTSC project?  Can I put it into the config file some how?
    The below instructions don't work and build a .out file, not a library.
    The following tools are required to build IMGLIB using CCS (links provided). Download and install all tools to a single local (C:) directory, for example, c:\Program Files\Texas Instruments.
    • Code Generation Tools Version 7.2
    • CCS Version 4
    Note:
    A "My.TI" account is required for download and can be registered at my.ti.com
    The IMGLIB may be compiled with CCS following the procedure below:
    1. Open CCS
    2. Import the IMGLIB makefilebased project
      • Open the Projectmenu
      • Select Import Existing Eclipse Project
      • Import from the IMGLIB /lib directory
    3. Modify install paths and settings in makefileif necessary
      • Within CCS, open the makefile from the ProjectTAB
      • Check the CGT path: C6X_GEN_INSTALL_DIR
      • Check the CGT version: CCSCGTVER
      • Check the CCS path: CCS_INSTALL_DIR
      • Check the IMGLIB path: IMGLIB_INSTALL_DIR
    4. Build the project
      • Select Rebuild Active Project from Project menu
    Note:
    If the RMDIR utility in the makefile is not recognized, you may need to redefine it for a local utility.
    And these library instructions don't work either:
    Linking IMGLIB
    The path to the IMGLIB libraries must be provided to the linker via the -l directive. See Library Directory for IMGLIB library details.
    Please advise.
    Brandy
    C6678 IMGLIB ccsv5 compiling linking
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Uday
      Posted by Uday
      on Apr 24 2012 18:38 PM
      Expert3750 points
      Hi Brandy,
      I have brought the import and build issues to the attention of the IMGLIB team. We are currently investigating this and will get back to you soon.
      - Uday
      --- If you need more help, please reply. If this answers your question, please Verify Answer below this post ---
      IMGLIB
      Report Abuse
      • Reply
    • BrandyJ
      Posted by BrandyJ
      on May 01 2012 07:39 AM
      Genius4370 points
      Hello Gurnani,
      Any update on this?  Can you provide the steps to properly import IMGLIB?
      Report Abuse
      • Reply
    • CharlieF
      Posted by CharlieF
      on May 01 2012 16:32 PM
      Intellectual1535 points
      Hi Brandy,
      Which version of IMGLIB are you working with?  Also, what is your target processor?
      Charlie
      IMGLIB
      Report Abuse
      • Reply
    • BrandyJ
      Posted by BrandyJ
      on May 02 2012 06:49 AM
      Genius4370 points
      Hi Charlie,
      It is imglib_C66x_3_1_0_0.
      I am using the C6678.
      And although you didn't ask, its CCS Version: 5.1.0.09000
      Brandy
      Report Abuse
      • Reply
    • Uday
      Posted by Uday
      on May 17 2012 14:51 PM
      Expert3750 points
      Hi Brandy
      Thanks for your patience as we were investigating and working towards a solution. The IMGLIB team has begun work on an incremental version (IMGLIB v3.1.1) that will address these issues and allow you to successfully import and build IMGLIB using CCSv5.1. As per the team, IMGLIB v3.1.1 should be available by the end of next week at http://software-dl.ti.com/sdoemb/sdoemb_public_sw/imglib/latest/index_FDS.html
      - Uday
      imglib ccs 5.1
      Report Abuse
      • Reply
    • BrandyJ
      Posted by BrandyJ
      on May 18 2012 07:32 AM
      Genius4370 points
      Sounds good.  Thanks!
      Report Abuse
      • Reply
    • Uday
      Posted by Uday
      on May 25 2012 15:02 PM
      Expert3750 points
      Hi Brandy,
      The team is trying to incorporate a few more last-minute updates in the software package before release. They now anticipate that the new IMGLIB will be available Friday, June 1. We'll post again here as soon as it's online.
      - Uday
      IMGLIB
      Report Abuse
      • Reply
    • Uday
      Posted by Uday
      on Jun 04 2012 13:57 PM
      Verified Answer
      Verified by BrandyJ
      Expert3750 points
      Hi Brandy,
      The new IMGLIB release is now available at http://software-dl.ti.com/sdoemb/sdoemb_public_sw/imglib/latest/index_FDS.html
      - Uday
      IMGLIB
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
