• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » how to abort a EDMA3 transfer in progress?
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      It’s our second anniversary, but you get the present!
      Posted 5 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
      Limited time offer: Save $100 on Keystone-based EVM!
      Posted 18 days ago
      by tscheck
      Have you been thinking about ordering a TI Keystone-based EVM...
      Imagine the impact…TI’s KeyStone SoC + HP Moonshot
      Posted 29 days ago
      by Sanjay35057
      Last week, market leader Hewlett Packard announced a huge change...
    This question is not answered
    Lyndon McGlothin
    Posted by Lyndon McGlothin
    on May 01 2012 09:03 AM
    Prodigy170 points
    how can I abort an EDMA that is in progress?
    I have a situation that I will need to abort a EDMA transfer if it takes too long.
    while I am polling the IPR bit for completion, if I detect a timeout I need to
    abort the current EDMA transfer and do what ever EDMA cleanup needed
    so a different EDMA transfer can be done.
    here is high level code example:
       CSL_edma3Init(NULL)
       handle = CSL_edma3Open(&obj, edmaNum, NULL, &status);
       channelHandle = CSL_edma3ChannelOpen(&channelObj, edmaNum, &channelAttr, &status);
       CSL_edma3HwChannelSetupQue(channelHandle, evtQue)
       CSL_edma3MapDMAChannelToParamBlock (handle, dmaChannel, paramNum);
       paramHandle = CSL_edma3GetParamHandle(channelHandle, paramNum, &status);
       CSL_edma3ParamSetup(paramHandle, &paramSetup)
       CSL_edma3HwControl(handle, CSL_EDMA3_CMD_INTR_ENABLE, &cmdIntr);
       CSL_edma3HwChannelControl(channelHandle, CSL_EDMA3_CMD_CHANNEL_SET, NULL);
       // poll IPR bit for completion
       do {
          CSL_edma3GetHwStatus(handle, CSL_EDMA3_QUERY_INTRPEND, &cmdIntr);
       } while ((!(cmdIntr.intr & chIPRBit)) && (timeoutFlag==0));
       if (timeoutFlag == 1) {
          // HOW TO ABORT EDMA TRANSFER
       CSL_edma3HwControl(handle, CSL_EDMA3_CMD_INTRPEND_CLEAR, &cmdIntr);
       CSL_edma3ChannelClose(channelHandle)
       CSL_edma3Close(handle)
    thanks in advance for any help,
    lwmcgl
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chad Courtney
      Posted by Chad Courtney
      on May 07 2012 08:30 AM
      Mastermind22515 points
      Lyndon,
      Once in the Transfer Controller's Queue it can not be canceled w/o flushing the queue itself.
      Chad
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Karthik Ramana Sankar
      Posted by Karthik Ramana Sankar
      on May 09 2012 10:30 AM
      Intellectual1695 points
      Lyndon,
      Adding to Chad's point.
      If an EDMA Transfer request is taking more time than expected for completing the transfer, then there can be two reasons for this to happen:
      1) EDMA TR encounters an error condition and the DSP CPU should handle this EDMA TC error condition. Please, refer to section 4.3.4 "Error Registers" of the Keystone EDMA3 users guide.
      2) There is congestion in the TeraNet or at the memory end point (DDR3, MSMC or L2) interface and you need to re-visit your traffic scenario in this case.
      I hope this helps.
      Karthik
      If you need more help, please reply back. If this answers the question, please click  Verify Answer , below.
      edma3
      Report Abuse
      • Reply
    • Lyndon McGlothin
      on May 09 2012 12:25 PM
      Prodigy170 points
      Thank you both for your replies.
      My issue is that I have a lower priority task start a DMA transfer
      while the DMA transfer is being done, a higher priority task
      is started and needs to do a DMA transfer also, so I was looking
      for a way to stop the current lower priority DMA transfer so the
      higher priority DMA could start.
      Report Abuse
      • Reply
    • Lyndon McGlothin
      on May 09 2012 12:28 PM
      Prodigy170 points
      forgot,
      also, one of my other requirements is that if the
      DMA transfer takes more time than allocated
      I need to stop/abort the DMA transfer.
      thanks again,
      lwmcgl
      Report Abuse
      • Reply
      on May 11 2012 14:05 PM
      Hi Lyndon,
      As Chad mentioned previously, it is not possible to cancel or abort a EDMA transfer request, which is already submitted to the transfer controller queue. One possible way to perform DMA transfers at different priority is to use separate transfer controllers (in other words TC queue) for each of the DMA transfers. There are totally 10 transfer controllers in Keystone devices.
      Another point which I like to add here is that, please select the DMA transfer timeout values always to be the worst case values for your current traffic scenario.
      I hope this helps
      Karthik
      Report Abuse
      • Reply
    • RandyP
      Posted by RandyP
      on May 13 2012 08:55 AM
      Guru59970 points
      Lyndon,
      Another solution to your problem could be to break the low priority transfer into many smaller transfers.
      If you are transferring 16KB, for example, with ACNT=4 and BCNT = 4096 and CCNT=1 and SYNCDIM=ABSYNC, this would be submitted as a single TR. Instead, break this into 16 separate TRs by using ACNT=4 and BCNT = 256 and CCNT=16 and SYNCDIM=ABSYNC, with ITCCHEN=1 and TCC=<this DMA channel number> and TCCMODE=NORMAL.
      With this, if the higher priority transfer is requested, it will only have to wait behind at most 1024 bytes being transferred on the lower priority transfer. Make that even smaller if you need to. This will increase the total time to do the lower priority transfer, but that does not sound like an issue for you.
      RandyP
      Search for answers, Ask a question, click  Verify  when complete, Help others, Learn more.
      Report Abuse
      • Reply
    • Lyndon McGlothin
      on May 14 2012 12:25 PM
      Prodigy170 points
      Thanks again for your replies,
      I think the best solution will be to break up the lower priority DMA
      transfer so a higher priority task can come in and do a transfer
      in-between the lower priority transfers.
      lwmcgl
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
