• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » C6000 Multicore DSP » Keystone Multicore Forum (C66, 66A, AM5) » Internal exception: IERR=0x8 - EVMC6678LE
Share
C6000 Multicore DSP
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Training Available
TI provides self-paced online training that introduces the primary components of the KeyStone II family of SoC devices.
  • KeyStone II SoC Overview >
  • KeyStone II Software Overview >
  • KeyStone II ARM Cortex-A15 Corepac Overview >
  • More Information >
  • Check out
    Multicore Mix blog
    • $core_v2_blog.Current.Name
      It’s our second anniversary, but you get the present!
      Posted 5 days ago
      by Lindsey Bare
      It’s hard to believe it’s already been two years...
      Limited time offer: Save $100 on Keystone-based EVM!
      Posted 18 days ago
      by tscheck
      Have you been thinking about ordering a TI Keystone-based EVM...
      Imagine the impact…TI’s KeyStone SoC + HP Moonshot
      Posted 29 days ago
      by Sanjay35057
      Last week, market leader Hewlett Packard announced a huge change...
    This question is not answered
    weber de souza calixto
    Posted by weber de souza calixto
    on May 07 2012 12:05 PM
    Expert1070 points
    I got this error while running a project on EVMC6687LE. CCS 5.1.1, on Linux.
    I'm running a big library, which requires big heap memory. I've place heap memory to DDR3 and increasead its size, then I got this error while booting:
    (With smaller heap, the system boots and run, until I call the library and the heap memory is completely filled and the system crashes)
    [C66xx_0]
    [C66xx_0]
    [C66xx_0] MCSDK IMAGE PROCESSING DEMONSTRATION
    [C66xx_0]
    [C66xx_0] QMSS successfully initialized
    [C66xx_0] CPPI successfully initialized
    [C66xx_0] PA successfully initialized
    [C66xx_0] EVM in StaticIP mode at 192.168.0.225
    [C66xx_0] Set IP address of PC to 192.168.0.98
    [C66xx_0] Starting webfiles_add
    [C66xx_0] Done webfiles_add
    [C66xx_0] HTTP Status Added
    [C66xx_0] Debug Message Level Added
    [C66xx_0] Last while
    [C66xx_0] PASS successfully initialized
    [C66xx_0] Ethernet subsystem successfully initialized
    [C66xx_0] Ethernet eventId : 48 and vectId (Interrupt) : 7
    [C66xx_0] Registration of the EMAC Successful, waiting for link up ..
    [C66xx_0] Network Added: If-1:192.168.0.225
    [C66xx_0] Service Status: HTTP : Enabled : : 000
    [C66xx_0] A0=0x0 A1=0x0
    [C66xx_0] A2=0x0 A3=0x80002448
    [C66xx_0] A4=0x90 A5=0x15000103
    [C66xx_0] A6=0xd0 A7=0x0
    [C66xx_0] A8=0x1844018 A9=0x1
    [C66xx_0] A10=0x90 A11=0x8000
    [C66xx_0] A12=0x1d0c0300 A13=0x80002448
    [C66xx_0] A14=0x0 A15=0x0
    [C66xx_0] A16=0xc207c80 A17=0xc
    [C66xx_0] A18=0x80000d54 A19=0x0
    [C66xx_0] A20=0x0 A21=0x0
    [C66xx_0] A22=0x0 A23=0x0
    [C66xx_0] A24=0x0 A25=0x0
    [C66xx_0] A26=0x0 A27=0x0
    [C66xx_0] A28=0x0 A29=0xe100a8c0
    [C66xx_0] A30=0x0 A31=0x1
    [C66xx_0] B0=0x36f6 B1=0x0
    [C66xx_0] B2=0x0 B3=0x8820de50
    [C66xx_0] B4=0x0 B5=0xc08aed4
    [C66xx_0] B6=0xe600010 B7=0x883d3138
    [C66xx_0] B8=0x883d51a8 B9=0x15000102
    [C66xx_0] B10=0xc087e4c B11=0x90
    [C66xx_0] B12=0x0 B13=0x0
    [C66xx_0] B14=0x809b88 B15=0x809a90
    [C66xx_0] B16=0x0 B17=0xc08a138
    [C66xx_0] B18=0xc07f8f7 B19=0x10
    [C66xx_0] B20=0x80000548 B21=0x4
    [C66xx_0] B22=0xd B23=0x0
    [C66xx_0] B24=0x3000 B25=0x0
    [C66xx_0] B26=0x2e2 B27=0x0
    [C66xx_0] B28=0x0 B29=0xc0
    [C66xx_0] B30=0x0 B31=0x0
    [C66xx_0] NTSR=0x1020f
    [C66xx_0] ITSR=0xd
    [C66xx_0] IRP=0x88251f80
    [C66xx_0] SSR=0x0
    [C66xx_0] AMR=0x0
    [C66xx_0] RILC=0x0
    [C66xx_0] ILC=0x0
    [C66xx_0] Exception at 0x8000246c
    [C66xx_0] EFR=0x2 NRP=0x8000246c
    [C66xx_0] Internal exception: IERR=0x8
    [C66xx_0] Opcode exception
    [C66xx_0] ti.sysbios.family.c64p.Exception: line 248: E_exceptionMin: pc = 0x88251f80, sp = 0x00809a90.
    [C66xx_0] To see more exception detail, use ROV or set 'ti.sysbios.family.c64p.Exception.enablePrint = true;'
    [C66xx_0] xdc.runtime.Error.raise: terminating execution
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chad Courtney
      Posted by Chad Courtney
      on May 07 2012 16:26 PM
      Mastermind22515 points
      The exception is for an illegal OpCode.  I'd open a disassembly window at the NRP and see what was there.  Does it look like code or data.
      Any number of issues could have cause this, ran off into the weeds because of bad pointer, data corruption, overwrote program space with data due to buffer overflow, etc.  The only way to determine why it happened is to start debugging.  Look at where the CorePac was executing when the Exception occurred (i.e. NRP)
      You may also want to consider using CP_Tracer to trace the program.
      Chad
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Jean-Baptiste Theou
      Posted by Jean-Baptiste Theou
      on May 10 2012 21:22 PM
      Intellectual270 points
      I have exactly the same problem. Every thing works fine with small heap, but with bigger heap, my program crash with the same exception.
      In your case, what is the solution ?
      Thanking you in advance,
      Jean-Baptiste
      Report Abuse
      • Reply
    • weber de souza calixto
      on May 10 2012 21:34 PM
      Expert1070 points
      I've got a weird error with big heap/stack and the Idle Thread.
      Every time I place heap/stack into DDR3 in order to fit my size requirements, some weird problem related to sysbios.knl.task module happens.
      So far, I've noticed that disabling the IdleTask at .cfg files seems to solve the problem. But I'm not so sure about that.
      Please check my other posts, on a few of them there are more valuable responses from TI staff.
      Weber
      Report Abuse
      • Reply
      on May 10 2012 21:40 PM
      Hi weber,
      Thank for your answer. I use disassembly view right now ... I will try without Idle task.
      Report Abuse
      • Reply
      on May 10 2012 21:52 PM
      Expert1070 points
      Could you share here a snap from the disassembly around NPR's location?
      I'n my case, the processor jumped into code data, while disassembly the code for similar problem.
      Report Abuse
      • Reply
      on May 10 2012 22:03 PM
      I'm still in trouble without Idle task, but no more exception ... Just crash !
      I rebuild to have exception and I share here the disassembl around NPR.
      Jean-Baptiste
      Report Abuse
      • Reply
      on May 10 2012 22:14 PM
      Expert1070 points
      Ok. The disassembly piece of code around NPR should give at least a clue of what happened.
      Have you disable using?:
      Task.enableIdleTask = false;
      Task.allBlockedFunc = Idle.run;
      Report Abuse
      • Reply
      on May 10 2012 22:18 PM
      Yes, I use your code on .cfg.
      Please find my snap :
      makeCrsp:
      8357f4e0:   441AB29E     [ B1]  LDBU.D2T2     *+B15[6834],B8
      8357f4e4:   44898000     [ B1]  NOP           13
      8357f4e8:   44A28000            .word         0x44a28000
      8357f4ec:   00000002            NOP
      8357f4f0:   06FC0000            NOP
      8357f4f4:   00000001            NOP
      8357f4f8:   00010000 ||         NOP           9
      8357f4fc:   00000032            MPY2.M2       B0,B0,B1:B0
      8357f500:   00000003            NOP
      8357f504:   42800000 ||  [ B1]  NOP
      8357f508:   3F800000     [!B0]  NOP
      8357f50c:   FFFFFFFB            .word         0xfffffffb
      8357f510:   00010001 ||         NOP           9
      8357f514:   0000     ||         ADD.L1        A0,A0,A0
      8357f516:   0000                ADD.L1        A0,A0,A0
      8357f518:   03201861            DADD.S1X        0,B9:B8,A7:A6
      8357f51c:   E4000001            .fphead       n, l, W, BU, nobr, nosat, 0100000b
      8357f520:   CCCD                LDW.D2T1      *B15[6],A4
      8357f522:   3E4C                LDBU.D1T2     *A4++[2],B4
      8357f524:   3E4CCCCD ||  [!B0]  LDH.D2T1      *+B15[19660],A28
      8357f528:   100F1413 ||         CALLP.S2      __strasgi_64plus (PC+30880 = 0x83586dc0),B3
      8357f52c:   3851B717 ||         .word         0x3851b717
      8357f530:   0000     ||         ADD.L1        A0,A0,A0
      8357f532:   8F32     ||         MVK.S1        172,A6
      8357f534:   023C9058 ||         ADD.L1X       4,B15,A4
      makeCrsp is one of my function, and if I use L2SRAM rather than DDR3, it works fine. The exception looks appear during NOP ... That is weird !
      Thanking you in advance if you have any idea
      Report Abuse
      • Reply
      on May 10 2012 22:29 PM
      Expert1070 points
      Once NOP stands for No Operation Performed, I also have no specific idea about the error.
      However, one thing crossed my mind: To where the processor goes after a NOP instruction? I'm not much a assembly guy, but IF it goes to the next instruction it will rise a crash, because the next instruction is data definition (.word). Maybe the TI's assembly language tools users guide answers it.
      The assembly user guide for C66 is SPRU186V.8484.SPRU186V.pdf
      If you open a new thread to this problem, please let me know, I want to follow the discussions.
      Weber
      Report Abuse
      • Reply
      on May 10 2012 22:35 PM
      I remove my last question ;) It is obvious.
      I see that one TI employe talk about L2 Cache. I am going to make some try without L2 cache
      Report Abuse
      • Reply
      on May 11 2012 04:31 AM
      Expert1070 points
      Just check my other post: http://e2e.ti.com/support/embedded/bios/f/355/p/187339/674520.aspx#674520
      There it is well-enough explained a TI's guy.
      Weber
      Report Abuse
      • Reply
      on May 11 2012 06:37 AM
      Expert1070 points
      I've checked it. The processor goes to the next instruction.
      Once .word isn't a valid processor instruction, the system crashes just as mine that I've reported on the other post.
      Weber
      Report Abuse
      • Reply
    • Chad Courtney
      on May 11 2012 08:46 AM
      Jean-Baptiste,
      The "Code" looks like garabage, I'd guess something overwrote this (possibly buffer overflowing.)  Can you go back and load the code and dump the dissassembly at the same location after loading the code.  If you compare the two I'd bet you have something drastically different.  Also, look at your buffers that are mapped immediately before this section of code.  That's what you'd most likely have overflowing.
      makeCrsp:
      Chad
      Report Abuse
      • Reply
      on May 11 2012 08:51 AM
      Expert1070 points
      The debugger shouldn't report the overflow prior to the final error?
      Report Abuse
      • Reply
    • Chad Courtney
      on May 11 2012 09:02 AM
      Weber,
      These are not HW buffers (Heaps, Stack, etc)  These buffers are using memory in the same space as everything else that's out there in DDR in this case.  There's nothing to prevent you from overflowing the buffer, you need to make it sufficiently large.  I'd guess the reason you didn't see it when you moved code to another space, is you left the buffer out in DDR, hence the overflow didn't affect anyone.
      Note, this is why I suggested to take a look at the dissassembly.  So you could see if it was garbage or not, as this was one of the reasons you would have had the failure, that is executing invalid opcodes which is what the error message was.  Either it jumped to an area with garbage code, or something overwrote the code w/ garbage.
      Chad
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
