SSL output mismatch in BCP PUSCH
Hi, I have two questions.
First, I am observing 32 words header in the soft slicer output. What does the header mean? I can't find it in the BCP’s user guides.
Second, , I found that the LLR mismatch at the last 2 symbol position in every column index in case of 1 RB test.
My test parameters are given below. (The project is used the BCP test project, I checked the partially de-interleaved input to BCP.)
SNReven = SNRodd = 1.;
rms = 1024;
Q format : 0
QPSK, 1RB,
The remaining parameters are same as that of BCP test project.
The input data = {
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x04000400
0x08000800
0x0c000c00
0x10001000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x14001400
0x18001800
0x1c001c00
0x20002000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000
0x24002400
0x28002800
0x2c002c00
0x30003000};
Desired Output
MSB LSB
-1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1
-3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3
-4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4
-6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6
-7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7
-9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9
-10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10
-11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11
-13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13
-14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14
-16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16
-17 -17 0 0 0 0 -17 -17 -17 -17 -17 -17 0 0 0 0 -17 -17
BCP Output is given below :
MSB LSB
-7 -7 -7 -7 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1
-9 -9 -9 -9 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3 -3
-10 -10 -10 -10 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4 -4
-11 -11 -11 -11 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6 -6
-13 -13 -13 -13 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7 -7
-14 -14 -14 -14 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9 -9
-16 -16 -16 -16 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10 -10
-17 -17 -17 -17 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11 -11
-7 -7 -7 -7 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13 -13
-9 -9 -9 -9 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14 -14
-10 -10 -10 -10 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16 -16
  • Hi Hyekyung,
    Can you please send the complete BCP input packet, including BCP Global Header and all sub-module headers?
    -Nitin
  • Hi, Nitin
    Thank you so much for your interest.
    I attached the BCP input packet and the test code file (test_lte_ul.c).
    Please see the codes if mistake.
    And, I always reset the board whenever I restart or build.
    If not be reset, the BCP output is below as
    Hyekyung Jwa
    5861.test_lte_ul.c
     *   @file  test_lte_ul.c
     *   @brief
     *      Runs LTE Uplink (UL) test case using BCP driver APIs.
     *  \par
     *  @n   (C) Copyright 2010, Texas Instruments, Inc.
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "bcp_test.h"
    #include "bcp_test_lte.h"
    #define		BCP_TEST_DEBUG
    #define     TX_DATA_BUFFER_SIZE             2048 * 2
    #define     RX_DATA_BUFFER_SIZE             2048
    #define     TX_NUM_DESC                     2
    #define     RX_NUM_DESC                     (BCP_TEST_NUM_HOST_DESC/4 - TX_NUM_DESC)
    #define     RX_Q_NUM                        900 + CSL_chipReadReg (CSL_CHIP_DNUM)
    #define     RX_FLOW_ID                      0 + CSL_chipReadReg (CSL_CHIP_DNUM)
    extern UInt32   totalNumTestsPass, totalNumTestsFail;
    #pragma DATA_SECTION (tbSize, ".testData");
    static UInt32   tbSize;
    #pragma DATA_SECTION (numSymbPerSumbfrm, ".testData");
    static UInt8    numSymbPerSumbfrm;
    #pragma DATA_SECTION (modulation, ".testData");
    static UInt8    modulation;
    #pragma DATA_SECTION (numSubcarrier, ".testData");
    static UInt16   numSubcarrier;
    #pragma DATA_SECTION (numRiSubcs, ".testData");
    static UInt16   numRiSubcs;
    #pragma DATA_SECTION (numAckSubcs, ".testData");
    static UInt16   numAckSubcs;
    #pragma DATA_SECTION (numCqiSubcs, ".testData");
    static UInt16   numCqiSubcs;
    #pragma DATA_SECTION (rnti, ".testData");
    static UInt16   rnti;
    #pragma DATA_SECTION (cellID, ".testData");
    static UInt16   cellID;
    #pragma DATA_SECTION (numAckBits, ".testData");
    static UInt8    numAckBits;
    #pragma DATA_SECTION (ackBeta, ".testData");
    static UInt8    ackBeta;
    #pragma DATA_SECTION (numRiBits, ".testData");
    static UInt8    numRiBits;
    #pragma DATA_SECTION (riBeta, ".testData");
    static UInt8    riBeta;
    #pragma DATA_SECTION (numCqiBits, ".testData");
    static UInt8    numCqiBits;
    #pragma DATA_SECTION (cqiBeta, ".testData");
    static UInt8    cqiBeta;
    #pragma DATA_SECTION (ns, ".testData");
    static UInt8    ns;
    #pragma DATA_SECTION (rms, ".testData");
    static UInt16   rms;
    #pragma DATA_SECTION (snrEven, ".testData");
    #pragma DATA_SECTION (snrOdd, ".testData");
    static float    snrEven, snrOdd;
    #pragma DATA_SECTION (scale1, ".testData");
    #pragma DATA_SECTION (scale2, ".testData");
    static Int32    scale1, scale2;
    #pragma DATA_SECTION (rvIndex, ".testData");
    static UInt8    rvIndex;
    #pragma DATA_SECTION (numTrans, ".testData");
    static UInt8    numTrans;
    #pragma DATA_SECTION (subfrmIdx, ".testData");
    static UInt8    subfrmIdx;
    #pragma DATA_SECTION (soundFlag, ".testData");
    static UInt8    soundFlag;
    #pragma DATA_SECTION (numPrbInPusch, ".testData");
    static UInt8 numPrbInPusch[45]={1, 2, 3, 4, 5, 6, 8, 9, 10,12,15,16, 18,20,24,25, 27,30,32,36, 40,45,48,50, 54,60,64,72, 75,80,
    81,90,96,100,108,120,128,144,150,160,162,180,192,200,216};
    /* Turbo Code Internal Interleaver Parameters */
    #pragma DATA_SECTION (TurboInterTable, ".testData");
    static const UInt16 TurboInterTable[189][3] = {
    /*K=Data Size  f1      f2 */
        {0	    , 0	     ,     0  },
        {40	    , 3	     ,    10  },
        {48	    , 7	     ,    12  },
        {56	    , 19	 ,    42  },
        {64	    , 7	     ,    16  },
        {72	    , 7	     ,    18  },
        {80	    , 11	 ,    20  },
        {88	    , 5	     ,    22  },
        {96	    , 11	 ,    24  },
        {104	, 7	     ,    26  },
        {112	, 41	 ,    84  },
        {120	, 103	 ,    90  },
        {128	, 15	 ,    32  },
        {136	, 9	     ,    34  },
        {144	, 17	 ,    108 },
        {152	, 9	     ,    38  },
        {160	, 21	 ,    120 },
        {168	, 101	 ,    84  },
        {176	, 21	 ,    44  },
        {184	, 57	 ,    46  },
        {192	, 23	 ,    48  },
        {200	, 13	 ,    50  },
        {208	, 27	 ,    52  },
        {216	, 11	 ,    36  },
        {224	, 27	 ,    56  },
        {232	, 85	 ,    58  },
        {240	, 29	 ,    60  },
        {248	, 33	 ,    62  },
        {256	, 15	 ,    32  },
        {264	, 17	 ,    198 },
        {272	, 33	 ,    68  },
        {280	, 103	 ,    210 },
        {288	, 19	 ,    36  },
        {296	, 19	 ,    74  },
        {304	, 37	 ,    76  },
        {312	, 19	 ,    78  },
        {320	, 21	 ,    120 },
        {328	, 21	 ,    82  },
        {336	, 115	 ,    84  },
        {344	, 193	 ,    86  },
        {352	, 21	 ,    44  },
        {360	, 133	 ,    90  },
        {368	, 81	 ,    46  },
        {376	, 45	 ,    94  },
        {384	, 23	 ,    48  },
        {392	, 243	 ,    98  },
        {400	, 151	 ,    40  },
        {408	, 155	 ,    102 },
        {416	, 25	 ,    52  },
        {424	, 51	 ,    106 },
        {432	, 47	 ,    72  },
        {440	, 91	 ,    110 },
        {448	, 29	 ,    168 },
        {456	, 29	 ,    114 },
        {464	, 247	 ,    58  },
        {472	, 29	 ,    118 },
        {480	, 89	 ,    180 },
        {488	, 91	 ,    122 },
        {496	, 157	 ,    62  },
        {504	, 55	 ,    84  },
        {512	, 31	 ,    64  },
        {528	, 17	 ,    66  },
        {544	, 35	 ,    68  },
        {560	, 227	 ,    420 },
        {576	, 65	 ,    96  },
        {592	, 19	 ,    74  },
        {608	, 37	 ,    76  },
        {624	, 41	 ,    234 },
        {640	, 39	 ,    80  },
        {656	, 185	 ,    82  },
        {672	, 43	 ,    252 },
        {688	, 21	 ,    86  },
        {704	, 155	 ,    44  },
        {720	, 79	 ,    120 },
        {736	, 139	 ,    92  },
        {752	, 23	 ,    94  },
        {768	, 217	 ,    48  },
        {784	, 25	 ,    98  },
        {800	, 17	 ,    80  },
        {816	, 127	 ,    102 },
        {832	, 25	 ,    52  },
        {848	, 239	 ,    106 },
        {864	, 17	 ,    48  },
        {880	, 137	 ,    110 },
        {896	, 215	 ,    112 },
        {912	, 29	 ,    114 },
        {928	, 15	 ,    58  },
        {944	, 147	 ,    118 },
        {960	, 29	 ,    60  },
        {976	, 59	 ,    122 },
        {992	, 65	 ,    124 },
        {1008	, 55	 ,    84  },
        {1024	, 31	 ,    64  },
        {1056	, 17	 ,    66  },
        {1088	, 171	 ,    204 },
        {1120	, 67	 ,    140 },
        {1152	, 35	 ,    72  },
        {1184	, 19	 ,    74  },
        {1216	, 39	 ,    76  },
        {1248	, 19	 ,    78  },
        {1280	, 199	 ,    240 },
        {1312	, 21	 ,    82  },
        {1344	, 211	 ,    252 },
        {1376	, 21	 ,    86  },
        {1408	, 43	 ,    88  },
        {1440	, 149	 ,    60  },
        {1472	, 45	 ,    92  },
        {1504	, 49	 ,    846 },
        {1536	, 71	 ,    48  },
        {1568	, 13	 ,    28  },
        {1600	, 17	 ,    80  },
        {1632	, 25	 ,    102 },
        {1664	, 183	 ,    104 },
        {1696	, 55	 ,    954 },
        {1728	, 127	 ,    96  },
        {1760	, 27	 ,    110 },
        {1792	, 29	 ,    112 },
        {1824	, 29	 ,    114 },
        {1856	, 57	 ,    116 },
        {1888	, 45	 ,    354 },
        {1920	, 31	 ,    120 },
        {1952	, 59	 ,    610 },
        {1984	, 185	 ,    124 },
        {2016	, 113	 ,    420 },
        {2048	, 31	 ,    64  },
        {2112	, 17	 ,    66  },
        {2176	, 171	 ,    136 },
        {2240	, 209	 ,    420 },
        {2304	, 253	 ,    216 },
        {2368	, 367	 ,    444 },
        {2432	, 265	 ,    456 },
        {2496	, 181	 ,    468 },
        {2560	, 39	 ,    80  },
        {2624	, 27	 ,    164 },
        {2688	, 127	 ,    504 },
        {2752	, 143	 ,    172 },
        {2816	, 43	 ,    88  },
        {2880	, 29	 ,    300 },
        {2944	, 45	 ,    92  },
        {3008	, 157	 ,    188 },
        {3072	, 47	 ,    96  },
        {3136	, 13	 ,    28  },
        {3200	, 111	 ,    240 },
        {3264	, 443	 ,    204 },
        {3328	, 51	 ,    104 },
        {3392	, 51	 ,    212 },
        {3456	, 451	 ,    192 },
        {3520	, 257	 ,    220 },
        {3584	, 57	 ,    336 },
        {3648	, 313	 ,    228 },
        {3712	, 271	 ,    232 },
        {3776	, 179	 ,    236 },
        {3840	, 331	 ,    120 },
        {3904	, 363	 ,    244 },
        {3968	, 375	 ,    248 },
        {4032	, 127	 ,    168 },
        {4096	, 31	 ,    64  },
        {4160	, 33	 ,    130 },
        {4224	, 43	 ,    264 },
        {4288	, 33	 ,    134 },
        {4352	, 477	 ,    408 },
        {4416	, 35	 ,    138 },
        {4480	, 233	 ,    280 },
        {4544	, 357	 ,    142 },
        {4608	, 337	 ,    480 },
        {4672	, 37	 ,    146 },
        {4736	, 71	 ,    444 },
        {4800	, 71	 ,    120 },
        {4864	, 37	 ,    152 },
        {4928	, 39	 ,    462 },
        {4992	, 127	 ,    234 },
        {5056	, 39	 ,    158 },
        {5120	, 39	 ,    80  },
        {5184	, 31	 ,    96  },
        {5248	, 113	 ,    902 },
        {5312	, 41	 ,    166 },
        {5376	, 251	 ,    336 },
        {5440	, 43	 ,    170 },
        {5504	, 21	 ,    86  },
        {5568	, 43	 ,    174 },
        {5632	, 45	 ,    176 },
        {5696	, 45	 ,    178 },
        {5760	, 161	 ,    120 },
        {5824	, 89	 ,    182 },
        {5888	, 323	 ,    184 },
        {5952	, 47	 ,    186 },
        {6016	, 23	 ,    94  },
        {6080	, 47	 ,    190 },
        {6144	, 263	 ,    480 }
    #pragma DATA_SECTION (BETAOFFSET_ACK_INDEX, ".testData");
    float BETAOFFSET_ACK_INDEX[16]={2.0f, 2.5f, 3.125f, 4.0f, 5.0f, 6.25f, 8.0f, 10.0f, 12.625f, 15.875f, 20.0f, 31.0f,  50.0f, 80.0f, 126.0f, 0.f};
    #pragma DATA_SECTION (BETAOFFSET_RI_INDEX, ".testData");
    float BETAOFFSET_RI_INDEX[16]={1.25f, 1.625f, 2.0f, 2.5f, 3.125f, 4.0f, 5.0f, 6.250f, 8.0f, 10.0f, 12.625f, 15.875f, 20.0f, 0.f,0.f,0.f};
    #pragma DATA_SECTION (BETAOFFSET_CQI_INDEX, ".testData");
    float BETAOFFSET_CQI_INDEX[16]=	{0.f, 0.f, 1.125f, 1.25f,
    		1.375f, 1.625f,1.75f,2.0f,
    		2.25f, 2.5f, 2.875f, 3.125f,
    		3.5f,4.0f,5.0f, 6.25f};
    #pragma DATA_SECTION (harqInput, ".testData");
    static UInt32 harqInput [132];
    #pragma DATA_SECTION (harqOutput, ".testData");
    static UInt32 harqOutput [132];
    /* Reference Output Data for the test */
    /* Output packet 1 payload - CQI bits */
    #define LTE_UL_OUTPUT_PKT_1_WRD_SIZE  5
    #pragma DATA_SECTION (lte_ul_output_packet_1, ".testData");
    static UInt32 lte_ul_output_packet_1[LTE_UL_OUTPUT_PKT_1_WRD_SIZE] = {
    #ifndef SIMULATOR_SUPPORT
    /* The packet header (first 4 words) generated by BCP is pre-swapped
     * inside RD and is produced as 8 bit byte data. In this application we
     * are comparing packet header as 32 bit data entities and not
     * 8 bit byte data. Hence, we need to maintain endian dependent
     * version of packet header. The RD output data on other hand is
     * produced as 32 bit data as programmed in TM flow table, and hence
     * no endian specific conversion required here.
    #ifdef  xdc_target__bigEndian
      0x00000400, 0x00000000, 0x00000000, 0xffff0000, 0xf2fcf4fc
    #else
      0x00000004, 0x00000000, 0x00000000, 0xffff0000, 0xf2fcf4fc
    #endif
    #else
    /* Simulator bug workaround: BCP TM module endian handling not correct. */
    #endif
    /* Output packet 2 payload */
    #define LTE_UL_OUTPUT_PKT_2_WRD_SIZE  140
    #pragma DATA_SECTION (lte_ul_output_packet_2, ".testData");
    static UInt32 lte_ul_output_packet_2[LTE_UL_OUTPUT_PKT_2_WRD_SIZE] = {
      0x0000a800, 0x00000000, 0x00000000, 0x00000000,
    #else
      0x000000a8, 0x00000000, 0x00000000, 0x00000000,
    #endif
    #else
    #endif
      0x09fd09fd, 0xfcfb02fd, 0x02060001, 0x0efff002,
      0x05edfd07, 0xfcfb00f9, 0xf4fe01f1, 0xfe0403f6,
      0x04fe1507, 0xfb140c02, 0xffebfff9, 0xf2fff90a,
      0x0cfffcf7, 0x00f100f3, 0x04fe0605, 0xf603f805,
      0x0c040004, 0xff0df7f9, 0xffed00ff, 0xfcfc0306,
      0x02fbfbfa, 0x010afd0e, 0xfcf9fefa, 0x0efefdfc,
      0x010603f7, 0x0017ec05, 0x07f40604, 0xfff8f8f8,
      0xf003fc03, 0x010701eb, 0x040f04f4, 0xf203ff0f,
      0xf9010104, 0x05fef7f7, 0x00030d04, 0x02fe01fe,
      0x03000700, 0xfd0908f8, 0xf9f8fcfa, 0x05fdfcf5,
      0xf2fc0207, 0x03ecf508, 0xf8ef1202, 0x00000000,
      0xfcff04f9, 0x050609ff, 0xfef90ff4, 0x05fd08fd,
      0xfc0703fa, 0x01fa0bff, 0xf7fb0204, 0x07ed04fc,
      0x04f7fdf0, 0xfffe02f8, 0x07f40bf0, 0x04fffcfe,
      0x08040b04, 0x07fe0d02, 0xec0306ff, 0xf711fb0f,
      0xf4080b00, 0x0c04f5f2, 0xf80506ff, 0x030109fa,
      0xfe0801f7, 0xfe07f705, 0x06030efc, 0xf5fff4fd,
      0xfefff90b, 0xf5fbfd07, 0xf5f8f30c, 0xf504fcfc,
      0xfaf9fefd, 0x01090af3, 0xfff7f5fd, 0x07040106,
      0xf2f7fd13, 0x0cfc0c00, 0xff010afa, 0x0200f8f7,
      0x01fdf908, 0xfff4f6f8, 0x04f5f6fe, 0xf50a0502,
      0xfef904fd, 0xf7080604, 0xf1f9ebf5, 0x00000000,
      0x020505f4, 0xf1030202, 0xfb07f408, 0x0504ff01,
      0x0709fe0d, 0xecffffec, 0x08fa00fd, 0xf909f006,
      0xf706ff02, 0x07f9ecfe, 0xffedfafd, 0x03fa0409,
      0xf8f305ff, 0xf30d000b, 0xfffa02e8, 0xe1edff07,
      0x0908100a, 0x07fa020d, 0xf901f5fc, 0xfeff0202,
      0x01f7fafc, 0xf8fcfa05, 0xf8f803ff, 0xf704fafb,
      0x04f40bfa, 0x03f5f30c, 0xf9f6ee08, 0xff01050c,
      0xfe040104, 0x04f9f3fc, 0x01f60301, 0x08f8000d,
      0x0d0f01fc, 0xfe0702fd, 0x04f80f04, 0x03010605,
      0x04fc080a, 0xf4fc06fd, 0x050afffe, 0x18fd03fa,
      0xfbf20405, 0x02fcfefa, 0x0202ebfd, 0x00000000,
      0x727f656e, 0x564d4336, 0x7268677f, 0x6a52636d};
    #pragma DATA_SECTION (lte_ul_output_mem, ".testData");
    static UInt32 lte_ul_output_mem[132] = {
    0x09fd09fd,
    0xfcfb02fd,
    0x02060001,
    0x0efff002,
    0x05edfd07,
    0xfcfb00f9,
    0xf4fe01f1,
    0xfe0403f6,
    0x04fe1507,
    0xfb140c02,
    0xffebfff9,
    0xf2fff90a,
    0x0cfffcf7,
    0x00f100f3,
    0x04fe0605,
    0xf603f805,
    0x0c040004,
    0xff0df7f9,
    0xffed00ff,
    0xfcfc0306,
    0x02fbfbfa,
    0x010afd0e,
    0xfcf9fefa,
    0x0efefdfc,
    0x010603f7,
    0x0017ec05,
    0x07f40604,
    0xfff8f8f8,
    0xf003fc03,
    0x010701eb,
    0x040f04f4,
    0xf203ff0f,
    0xf9010104,
    0x05fef7f7,
    0x00030d04,
    0x02fe01fe,
    0x03000700,
    0xfd0908f8,
    0xf9f8fcfa,
    0x05fdfcf5,
    0xf2fc0207,
    0x03ecf508,
    0xf8ef1202,
    0x00000000,
    0xfcff04f9,
    0x050609ff,
    0xfef90ff4,
    0x05fd08fd,
    0xfc0703fa,
    0x01fa0bff,
    0xf7fb0204,
    0x07ed04fc,
    0x04f7fdf0,
    0xfffe02f8,
    0x07f40bf0,
    0x04fffcfe,
    0x08040b04,
    0x07fe0d02,
    0xec0306ff,
    0xf711fb0f,
    0xf4080b00,
    0x0c04f5f2,
    0xf80506ff,
    0x030109fa,
    0xfe0801f7,
    0xfe07f705,
    0x06030efc,
    0xf5fff4fd,
    0xfefff90b,
    0xf5fbfd07,
    0xf5f8f30c,
    0xf504fcfc,
    0xfaf9fefd,
    0x01090af3,
    0xfff7f5fd,
    0x07040106,
    0xf2f7fd13,
    0x0cfc0c00,
    0xff010afa,
    0x0200f8f7,
    0x01fdf908,
    0xfff4f6f8,
    0x04f5f6fe,
    0xf50a0502,
    0xfef904fd,
    0xf7080604,
    0xf1f9ebf5,
    0x00000000,
    0x020505f4,
    0xf1030202,
    0xfb07f408,
    0x0504ff01,
    0x0709fe0d,
    0xecffffec,
    0x08fa00fd,
    0xf909f006,
    0xf706ff02,
    0x07f9ecfe,
    0xffedfafd,
    0x03fa0409,
    0xf8f305ff,
    0xf30d000b,
    0xfffa02e8,
    0xd9edff07,
    0x0908100a,
    0x07fa020d,
    0xf901f5fc,
    0xfeff0202,
    0x01f7fafc,
    0xf8fcfa05,
    0xf8f803ff,
    0xf704fafb,
    0x04f40bfa,
    0x03f5f30c,
    0xf9f6ee08,
    0xff01050c,
    0xfe040104,
    0x04f9f3fc,
    0x01f60301,
    0x08f8000d,
    0x0d0f01fc,
    0xfe0702fd,
    0x04f80f04,
    0x03010605,
    0x04fc080a,
    0xf4fc06fd,
    0x050afffe,
    0x18fd03fa,
    0xfbf20405,
    0x02fcfefa,
    0x0202ebfd,
    0x00000000};
     *   @n@b read_test_config
     *   @b Description
     *   @n Utility function that reads the input test vector params from a given
     *      file.
     *   @param[in]
     *   @n fp              Test configuration file handle.
     *   @return
     *   @n None.
    static Void read_test_config(FILE* fp)
    	Char            lineBuf[300];
    	Char*           ptrBuf;
    	Int32           i, j;
        while (fgets (lineBuf, 300, fp) != NULL)
            if ((ptrBuf = strstr(lineBuf, "="))!=NULL)
    			ptrBuf ++;
    			if (strstr(lineBuf,"numOFDM")!=NULL)
    				sscanf(ptrBuf,"%d", &i);
    				numSymbPerSumbfrm = i;
    				continue;
    			if (strstr(lineBuf,"SoundEn")!=NULL)
    				soundFlag = i;
    				continue;
    			if (strstr(lineBuf,"TBS")!=NULL)
    				tbSize = i;
    				continue;
    			if (strstr(lineBuf,"RNTI")!=NULL)
    				rnti = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"CellId")!=NULL)
    				cellID = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"Alloc")!=NULL)
    				sscanf(ptrBuf,"%d:%d", &i, &j);
    				numSubcarrier = (j - i + 1) * 12;
    				continue;
    			if (strstr(lineBuf,"ModSch")!=NULL)
    				modulation = i;
    				continue;
    			if (strstr(lineBuf,"AckBits")!=NULL)
    				numAckBits = i;
    				continue;
    			if (strstr(lineBuf,"McsACKoff")!=NULL)
    				ackBeta = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"RiBits")!=NULL)
    				numRiBits = (UInt16) i;
    				continue;
    			if (strstr(lineBuf,"McsRIoff")!=NULL)
    				riBeta = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"CqiBits")!=NULL)
    				numCqiBits = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"McsCQIoff")!=NULL)
    				cqiBeta = (UInt8) i;
    				continue;
    			if (strstr(lineBuf,"numTrans")!=NULL)
    				numTrans = (UInt8) i;
    				continue;
        return;
     *   @n@b compute_cbparams_ref
     *   @b Description
     *   @n Given a small subset of 3GPP Params, this function calculates and maps
     *      them out to actual BCP H/w parameters.
     *   @param[in]
     *   @n tbSize          Transport block size
     *   @param[out]
     *   @n pCodeBlkParams  LTE input parameters calculated for this test.
     *   @return
     *   @n None.
    static Void compute_cbparams_ref (UInt32 tbSize, BcpTest_LteCBParams* pCodeBlkParams)
    	UInt32          numCodeBlocks;
    	UInt32          outputbitsNoFiller;
    	UInt32          firstSegmtSize;
    	UInt32          secondSegmtSize;
    	UInt32          firstSegCount;
    	UInt32          secondSegCount;
    	Int16           idx;
    	UInt8           crcOrder = 24;
    	UInt8           delaK;
    	UInt16          numFillerBits;
    	UInt32          numInputBits = tbSize + 24;  // tb size + 24 bits crc
    	/* calculate the number of code blocks to be generated from imput bit stream */
    	if( numInputBits <= MAX_CODE_BLOCK_SIZE )
    		numCodeBlocks = 1;
    		outputbitsNoFiller = numInputBits;
    	else
          	numCodeBlocks = (UInt32)ceil((double)numInputBits/( MAX_CODE_BLOCK_SIZE - crcOrder));
    		outputbitsNoFiller = numInputBits + ( numCodeBlocks * crcOrder) ;
    	/* calculate number of bits in each block only when numCodeBlocks!=0 */
    	if( numCodeBlocks != 0)
    		/* K+ = is minimum K in 3GPP TS 36.212 table 5.1.3-3 C * K >= B' */
    		for(idx=0; idx < MAX_BLOCK_INDEX; idx++)
    			firstSegmtSize = TurboInterTable[idx][0];
    			if( (numCodeBlocks * firstSegmtSize) >= outputbitsNoFiller)
    				firstSegCount = 1;
    				break;
    		pCodeBlkParams->f1Kp = TurboInterTable[idx][1];
    		pCodeBlkParams->f2Kp = TurboInterTable[idx][2];
    		if(numCodeBlocks == 1)
    			secondSegmtSize	= 0;
    			secondSegCount  = 0;
    			/* no kminues */
    			pCodeBlkParams->f1Km = 0;
    			pCodeBlkParams->f2Km = 0;
    		else if(numCodeBlocks > 1)
    			for(idx = MAX_BLOCK_INDEX - 1; idx >=0; idx--)
    				secondSegmtSize = TurboInterTable[idx][0];
    				if( secondSegmtSize < firstSegmtSize )
    					break;
    			pCodeBlkParams->f1Km = TurboInterTable[idx][1];
    			pCodeBlkParams->f2Km = TurboInterTable[idx][2];
    			delaK = firstSegmtSize - secondSegmtSize;
    			secondSegCount = ( numCodeBlocks * firstSegmtSize ) - outputbitsNoFiller;
    			secondSegCount = (UInt32)floor( secondSegCount / delaK );
    			firstSegCount =  numCodeBlocks - secondSegCount;
    		numFillerBits = firstSegCount * firstSegmtSize + secondSegCount * secondSegmtSize - outputbitsNoFiller;
    		/* Update the code block parameters with values calculated */
    		pCodeBlkParams->numCodeBks          =	numCodeBlocks;
    		pCodeBlkParams->outputbitsNoFiller  =   outputbitsNoFiller;
    		pCodeBlkParams->numCodeBksKp        =   firstSegCount;
    		pCodeBlkParams->codeBkSizeKp        =   firstSegmtSize;
    		pCodeBlkParams->numCodeBksKm        =   secondSegCount;
    		pCodeBlkParams->codeBkSizeKm        =   secondSegmtSize;
    		pCodeBlkParams->numFillerBits       =   numFillerBits;
        return;
     *   @n@b compute_uciBits
     *   @b Description
     *   @n Computes UCI parameters for the test.
    Void compute_uciBits
        BcpTest_LteCBParams*    pCodeBlkParams,
        UInt16                  numPrb,
        UInt8                   numOFDMsym,
        UInt8                   numAckBits,
    	UInt8                   ackIdx,
    	UInt8                   numRiBits,
        UInt8                   riIdx,
    	UInt8                   numCqiBits,
    	UInt8                   cqiIdx,
    	UInt16*                 pNumRiSubcs,
    	UInt16*                 pNnumAckSubcs,
    	UInt16*                 pNumCqiSubcs
    	UInt32          sumKr, temp1;
    	float           temp;
    	UInt16          cqiL;
    	sumKr = pCodeBlkParams->codeBkSizeKm * pCodeBlkParams->numCodeBksKm + pCodeBlkParams->numCodeBksKp * pCodeBlkParams->codeBkSizeKp;
    	temp = numAckBits * numPrb * 12 * numOFDMsym * BETAOFFSET_ACK_INDEX[ackIdx];
    	temp = (float) ceil(temp /(float) sumKr);
    	temp1= (UInt32) temp;
    	if (temp1 < (UInt32)(4 * numPrb * 12))
    		* pNnumAckSubcs = temp1;
    	else
    		* pNnumAckSubcs = 4 * numPrb * 12;
    	temp = numRiBits * numPrb * 12 * numOFDMsym * BETAOFFSET_RI_INDEX[riIdx];
    		*pNumRiSubcs = temp1;
    	else
    		*pNumRiSubcs = 4 * numPrb * 12 ;
    //	if (numCqiBits <= 11)
    		cqiL  = 0;
    //	else cqiL = 8;
    	temp = (numCqiBits + cqiL) * numPrb * 12 * numOFDMsym * BETAOFFSET_CQI_INDEX[cqiIdx] ;
    	if (temp1 < (numPrb * 12  * numOFDMsym  - (*pNumRiSubcs)) )
    		* pNumCqiSubcs  = temp1;
    	else
    		* pNumCqiSubcs  = numPrb * 12 * numOFDMsym  - (*pNumRiSubcs);
     *   @n@b compute_rmGamma_ref
     *   @b Description
     *   @n Computes Rate matching parameters for the test.
    static Void compute_rmGamma_ref
        UInt32                      numChannelBits,
        UInt8                       mod,
        UInt8                       numLayers,
        UInt8                       rvIndex,
        float                       ratioKm, //for PDSCH only, between 1 to 3
        float                       ratioKp,
        UInt32                      Nir,
        UInt8                       testFlag,
        BcpTest_RateMatchParams*    pRmParams
    	UInt16 Gprime;
        UInt32 Gamma, E0, E1;
    	UInt32 G;
    	UInt8 modulationType , blkMap, numCodeBks;
    	UInt16 numRows;
    	UInt32 vBufferSize;
    	G = numChannelBits;
    	modulationType = mod;
    	blkMap = numLayers;
    	numCodeBks = pCodeBlkParams->numCodeBks;
    	Gprime = G / (blkMap * modulationType);
        Gamma = Gprime % numCodeBks ;
        //E0 = blkMap * modulationType * ((UInt32)floor( Gprime / numCodeBks));
        //E1 = blkMap * modulationType * ((UInt32)ceil( Gprime / numCodeBks ));
    	E0 = blkMap *modulationType * (Gprime /numCodeBks);
    	if (Gprime % numCodeBks==0)
    		E1 = 0;
    	else
    		E1 = blkMap *modulationType * (Gprime /numCodeBks+1);
    	pRmParams->Gamma   = Gamma;
    	pRmParams->E0      = E0;
    	pRmParams->E1      = E1;
    	Bcp_osalLog ("Gamma : %d, E0 : %d E1 : %d\n",Gamma, E0, E1);
    	if (testFlag==LTE_PDSCH) //PDSCH
    		if(pRmParams->E0 > 64000) //satuarate to maximum
    			pRmParams->E0 = 64000/modulationType * modulationType;
    		if (pRmParams->E1 > 64000)
    			pRmParams->E1 = 64000/modulationType * modulationType;;
    	if (pCodeBlkParams->numCodeBksKm)
    		numRows = ((pCodeBlkParams->codeBkSizeKm + 4) + 31)/32;
    		vBufferSize = numRows * 32 * 3;
    			if (ratioKm != 0)
    				pRmParams->NcbKm = (UInt32) (ratioKm * numRows * 32.f);
    			else //Nir is the input
    				if (Nir/numCodeBks < vBufferSize)
    					pRmParams->NcbKm =Nir/numCodeBks;
    				else
    					pRmParams->NcbKm = vBufferSize;
    		else //PUSCH_SIC
    		if (pRmParams->NcbKm == numRows * 32)
    			pRmParams->NcbKm ++; //not in the end of systematic bits
    		pRmParams->rvKmCol = (UInt32) (2 * ceil(pRmParams->NcbKm/(8.f * numRows)) * rvIndex + 2);
    		pRmParams->NcbKmCol = ( pRmParams->NcbKm - numRows * 32 - 1)/( 2 * numRows);
    		pRmParams->NcbKmRow = ( pRmParams->NcbKm - numRows * 32 - 1)% (2 * numRows);
    		if (pRmParams->rvKmCol > 31)
    			pRmParams->rvKm = (pRmParams->rvKmCol - 32)/ 2 + 32;
    		else
    			pRmParams->rvKm = pRmParams->rvKmCol;
    	else
    		pRmParams->NcbKm = 0;
    		pRmParams->rvKm = 0;
    		pRmParams->rvKmCol = 0;
    		pRmParams->NcbKmCol = 0;
    		pRmParams->NcbKmRow = 0;
    	if (pCodeBlkParams->numCodeBksKp)
    		numRows = ((pCodeBlkParams->codeBkSizeKp + 4) + 31)/32;
    		pRmParams->NcbKp = vBufferSize;
    		if (pRmParams->NcbKp == numRows * 32)
    			pRmParams->NcbKp++;
    		//pRmParams->rvKpCol = (UInt32) (2 * ceil(pRmParams->NcbKp/(8.f * numRows)) * rvIndex + 2);
    		pRmParams->rvKpCol = 0;
    		pRmParams->NcbKpCol = ( pRmParams->NcbKp - numRows * 32 - 1)/( 2 * numRows);
    		pRmParams->NcbKpRow = ( pRmParams->NcbKp - numRows * 32 - 1)% (2 * numRows);
    		if (pRmParams->rvKpCol > 31)
    			pRmParams->rvKp = (pRmParams->rvKpCol - 32)/ 2 + 32;
    		else
    			pRmParams->rvKp = pRmParams->rvKpCol;
    	else
    		pRmParams->NcbKp = 0;
    		pRmParams->rvKp = 0;
    		pRmParams->NcbKpCol = 0;
    		pRmParams->NcbKpRow = 0;
    	Bcp_osalLog ("numRows: %d, rvKpCol: %d, rvKp : %d, rvindex: %d\n", numRows, pRmParams->rvKpCol, pRmParams->rvKp, rvIndex);
        return;
     *   @n@b prepare_sslhdr_cfg
     *   @b Description
     *   @n Sets up the Soft Slicer (SSL) header for the test based on inputs passed.
    static Void prepare_sslhdr_cfg
        Bcp_SslHdr_LteCfg*  pSslHdrCfg,
        Bcp_RadioStd        radioStd,
        UInt32              Rprime, //number of subcarrier
        UInt8               mod,
        UInt8               numOFDMSymPerSubfrm, //lte only
        UInt8               numLayers,
        UInt16              rms,
        UInt8               Qfmt,
        UInt32              cinit,   //lte scrambling only
        UInt16              numRi,
        UInt16              numAck,
        Int32               scaleEven,    //noise scale for even slot
        Int32               scaleOdd      //noise scale for odd slot
    	UInt8               idx;
    	UInt32              Rprime1;
    	UInt8               prbList[45]={1, 2, 3, 4, 5, 6, 8, 9, 10,12,15,16, 18,20,24,25, 27,30,32,36, 40,45,48,50, 54,60,64,72, 75,80,
        /* Setup the SSL header as per params passed */
        memset (pSslHdrCfg, 0, sizeof (Bcp_SslHdr_LteCfg));
        pSslHdrCfg->local_hdr_len = 15;
        if (radioStd == Bcp_RadioStd_LTE)
            pSslHdrCfg->modeSelCfg.split_mode_en       =   numLayers-1;
            pSslHdrCfg->modeSelCfg.jack_bit            =   0;
            pSslHdrCfg->modeSelCfg.lte_descrambler_en  =   0;
            pSslHdrCfg->modeSelCfg.mod_type_sel        =   (Bcp_ModulationType) (mod/2);
            pSslHdrCfg->modeSelCfg.cmux_ln             =   (Bcp_CmuxLength) (numOFDMSymPerSubfrm - 9);
            pSslHdrCfg->modeSelCfg.q_format            =   (Bcp_QFormat) (Qfmt);
    		Rprime1 = 12 * prbList[Rprime] * numLayers;
            pSslHdrCfg->modeSelCfg.b_matrix_sel        =   gind_row_index(Rprime1 * mod);
            pSslHdrCfg->modeSelCfg.rmux_ln_index       =   Rprime;
            pSslHdrCfg->ri_ln               =   numRi;
            pSslHdrCfg->ack_ln              =   numAck;
            pSslHdrCfg->cinit_p2            =   cinit;
        else
            pSslHdrCfg->modeSelCfg.split_mode_en       =   0;
            pSslHdrCfg->modeSelCfg.cmux_ln             =   (Bcp_CmuxLength) (0);
            pSslHdrCfg->modeSelCfg.b_matrix_sel        =   0;
            pSslHdrCfg->modeSelCfg.rmux_ln_index       =   0;
            pSslHdrCfg->ri_ln               =   0;
            pSslHdrCfg->ack_ln              =   0;
            pSslHdrCfg->cinit_p2            =   0;
        if (mod == 1 || mod == 2)   // BPSK or QPSK
            pSslHdrCfg->uva                 =   ((rms * 23170 + 0x4000) >> 15);
        else if (mod == 4)  // 16 QAM
            pSslHdrCfg->uva                 =   ((rms * 10362 + 0x4000) >> 15);
        else if (mod == 6)  // 64 QAM
            pSslHdrCfg->uva                 =   ((rms * 5056 + 0x4000) >> 15);
        else    // 256 QAM
            pSslHdrCfg->uva                 =   ((rms * 2513 + 0x4000) >> 15);
    		for(idx = 0; idx < (numOFDMSymPerSubfrm + 1)/2; idx++)
                pSslHdrCfg->scale_c0 [idx] = scaleEven;
    		for(idx = (numOFDMSymPerSubfrm + 1)/2; idx < numOFDMSymPerSubfrm; idx++)
                pSslHdrCfg->scale_c0 [idx] = scaleOdd;
    		if (numLayers == 2)
    			for(idx = 0; idx<(numOFDMSymPerSubfrm + 1)/2; idx++)
                    pSslHdrCfg->scale_c1 [idx] = scaleEven;
    			for(idx = (numOFDMSymPerSubfrm + 1)/2; idx<numOFDMSymPerSubfrm; idx++)
                    pSslHdrCfg->scale_c1 [idx] = scaleOdd;
        return;
     *   @n@b prepare_lte_rdhdr_cfg
     *   @b Description
     *   @n Sets up the LTE Rate Dematching (RD) header for the test.
    static Void prepare_lte_rdhdr_cfg
        Bcp_RdHdr_LteCfg*           pRdHdrCfg,
        BcpTest_RateMatchParams*    pRmParams,
        UInt8                       numCqiPayload,
        UInt16                      numCqiOutBits,
        UInt8                       uciFlag,
        UInt8                       harqFlag,
        UInt8                       cqiPassThroughFlag
        /* Setup the LTE Rate dematching header as per inputs */
        memset (pRdHdrCfg, 0, sizeof (Bcp_RdHdr_LteCfg));
        pRdHdrCfg->local_hdr_len                =   7;
        if (!pCodeBlkParams->numCodeBksKm)
            pRdHdrCfg->num_code_blocks_c1       =   pCodeBlkParams->numCodeBksKp;
            pRdHdrCfg->block_size_k1            =   pCodeBlkParams->codeBkSizeKp;
            pRdHdrCfg->num_code_blocks_c2       =   0;
            pRdHdrCfg->block_size_k2            =   0;
        else
            pRdHdrCfg->num_code_blocks_c1       =   pCodeBlkParams->numCodeBksKm;
            pRdHdrCfg->block_size_k1            =   pCodeBlkParams->codeBkSizeKm;
            pRdHdrCfg->num_code_blocks_c2       =   pCodeBlkParams->numCodeBksKp;
            pRdHdrCfg->block_size_k2            =   pCodeBlkParams->codeBkSizeKp;
        pRdHdrCfg->num_code_blocks_ce1          =   pCodeBlkParams->numCodeBks - pRmParams->Gamma;
        pRdHdrCfg->block_size_e1                =   pRmParams->E0;
        pRdHdrCfg->num_code_blocks_ce2          =   pRmParams->Gamma;
        pRdHdrCfg->block_size_e2                =   pRmParams->E1;
        if (uciFlag)
            if (cqiPassThroughFlag)
                pRdHdrCfg->block_size_outq_cqi  =   numCqiOutBits;
            else
                pRdHdrCfg->block_size_outq_cqi  =   numCqiPayload;
            pRdHdrCfg->block_size_inq_cqi       =   numCqiOutBits;
            pRdHdrCfg->cqi_pass_through         =   cqiPassThroughFlag;
        else
            pRdHdrCfg->block_size_outq_cqi      =   0;
            pRdHdrCfg->block_size_inq_cqi       =   0;
            pRdHdrCfg->cqi_pass_through         =   1;
        pRdHdrCfg->rv_start_column              =   pRmParams->rvKp;
        pRdHdrCfg->num_filler_bits_f            =   pCodeBlkParams->numFillerBits;
    	if (harqFlag)
            pRdHdrCfg->enable_harq_input        =   1;
    	else
            pRdHdrCfg->enable_harq_input        =   0;
        pRdHdrCfg->enable_harq_output           =   1;
        pRdHdrCfg->harq_input_address           =   convert_coreLocalToGlobalAddr ((UInt32)harqInput);
        pRdHdrCfg->harq_output_address          =   convert_coreLocalToGlobalAddr ((UInt32)harqOutput);
        pRdHdrCfg->init_cb_flowId               =   0;
        pRdHdrCfg->flowId_hi                    =   0;
        pRdHdrCfg->flowId_cqi_offset            =   0;
        pRdHdrCfg->tcp3d_scale_factor           =   16;		// unsigned Q4 format, 16 --> 1.0
        pRdHdrCfg->tcp3d_dyn_range              =   0;
        return;
     *   @n@b prepare_tmhdr_cfg
     *   @b Description
     *   @n Sets up the Traffic Manager header for the test.
     *   @param[out]
     *   @n pTmHdrCfg   TM Header configuration thus populated for the test.
     *   @return
     *   @n None.
    static Void prepare_tmhdr_cfg (Bcp_TmHdrCfg* pTmHdrCfg)
        pTmHdrCfg->ps_data_size     =   0;
        pTmHdrCfg->info_data_size   =   0;
        return;
     *   @n@b add_test_config_data
     *   @b Description
     *   @n Given a data buffer, this API sets up the packet contents for the test.
     *      It adds all the BCP configuration params (header) and the payload to the
     *      data buffer. On success, returns the number of bytes of configuration
     *      and payload data added to the data buffer passed.
     *   @param[in]
     *   @n hBcp        BCP driver handle
     *   @param[in]
     *   @n pDataBuffer Data Buffer handle to which the payload and BCP configuration
     *                  params need to be added.
     *   @return        Int32
     *   @n >0      -   Number of bytes of data (payload + header configuration) added
     *                  to the data buffer.
     *   @n -1      -   Error populating the data buffer.
    static Int32 add_test_config_data (Bcp_DrvHandle hBcp, UInt8*  pDataBuffer)
    	FILE*                       pTestCfgFile;
    	FILE*                       pTestSnrCfgFile;
        Char                        lineBuf [256];
    	Char*                       ptrBuf;
        UInt32                      dataBufferLen, tmpLen, temp, harq_address, num_words;
        BcpTest_LteCBParams*        pCodeBlkParams;
        BcpTest_RateMatchParams*    pRmParams;
        UInt32                      lteChanType, cInit;
        Bcp_RadioStd                radioStd;
        Bcp_GlobalHdrCfg            bcpGlblHdrCfg;
        Bcp_TmHdrCfg                tmHdrCfg;
        Bcp_SslHdr_LteCfg           sslHdrCfg;
        Bcp_RdHdr_LteCfg            rdHdrCfg;
    	float                       noiseVar;
    	UInt32                      numChannelBits, readTemp;
    	UInt8                       numCqiPayload;
    	UInt8                       uciFlag, harqFlag,   cqiPassThroughFlag, index;
    	UInt16                      numCqiOutBits, cellIDTemp;
    	UInt8                       rvOrder[4]={0,2,1,3};
    	Int32						tmp;
        /* Allocate space for test configuration */
        if ((pCodeBlkParams = Bcp_osalMalloc (sizeof (BcpTest_LteCBParams), FALSE)) == NULL)
    #ifdef BCP_TEST_DEBUG
            Bcp_osalLog ("Failed to allocate memory for holding test configuration.\n");
    #endif
            return -1;
        memset (pCodeBlkParams, 0, sizeof (BcpTest_LteCBParams));
        if ((pRmParams = Bcp_osalMalloc (sizeof (BcpTest_RateMatchParams), FALSE)) == NULL)
    #endif
            return -1;
        memset (pRmParams, 0, sizeof (BcpTest_RateMatchParams));
        /* Get the test configuration from the file. */
        Bcp_osalLog ("Reading test configuration ... \n");
    #endif
        if ((pTestCfgFile = fopen("C:\\ti\\pdk_C6670_1_0_0_21\\packages\\ti\\drv\\bcp\\test\\lte\\pusch_paramters_UV620.txt","r")) == NULL)
            Bcp_osalLog ("Failed to open test configuration file: ..\..\lte\pusch_paramters_UV620.txt\n");
    #endif
            return -1;
        read_test_config(pTestCfgFile);
        fclose (pTestCfgFile);
        /* Get the code block params */
        soundFlag = 0;
        compute_cbparams_ref (tbSize, pCodeBlkParams);
        if (numCqiBits)
            uciFlag = 1;
        else
            uciFlag = 0;
        cellIDTemp = cellID;
        if ((pTestSnrCfgFile = fopen("C:\\ti\\pdk_C6670_1_0_0_21\\packages\\ti\\drv\\bcp\\test\\lte\\pusch_paramters_UV620_RxSNR.txt","r")) == NULL)
            Bcp_osalLog ("Failed to open test configuration Rx SNR file: ..\..\lte\pusch_paramters_UV620_RxSNR.txt\n");
    #endif
            return -1;
        /* To begin with, lets test LTE PUSCH channel */
        radioStd    =   Bcp_RadioStd_LTE;
        lteChanType =   LTE_PUSCH;
        /* Initialize our data buffer length running counter */
        dataBufferLen   =   0;
        for (index = 0; index < numTrans; index ++)		// numTrans : 2 --> index ==> Slot
            fgets(lineBuf,256,pTestSnrCfgFile);
            sscanf(lineBuf,"%f", &snrEven);
            ptrBuf = strstr(lineBuf,"frame:");
            ptrBuf += 7;
            sscanf(ptrBuf,"%d", &readTemp);
            ptrBuf = strstr(lineBuf,"subframe:");
            ptrBuf += 10;
            subfrmIdx = (UInt8)readTemp;
            sscanf(lineBuf,"%f", &snrOdd);
            if (index == 0)
                continue;
            if (soundFlag)
                if (index) //second one sounding is enable
                    numSymbPerSumbfrm--;
            if (numCqiBits < 12)
                compute_uciBits(pCodeBlkParams,
                                numSubcarrier/12,
    						    numSymbPerSumbfrm,
    						    numAckBits,
    					        ackBeta,
    				            numRiBits,
    						    riBeta,
    							numCqiBits,
    							cqiBeta,
    							&numRiSubcs,
    							&numAckSubcs,
    							&numCqiSubcs);
                numCqiPayload = numCqiBits;
    			cqiPassThroughFlag = 1;
            else
                                numSubcarrier/12,
    							numSymbPerSumbfrm,
    							numAckBits,
    							ackBeta,
    							numRiBits,
    							riBeta,
    							numCqiBits + 8,
    							cqiBeta,
    						    &numRiSubcs,
    							&numAckSubcs,
    							&numCqiSubcs);
                numCqiPayload = numCqiBits + 8;
                cqiPassThroughFlag = 0;
            numChannelBits = numSubcarrier * numSymbPerSumbfrm * modulation;
            numChannelBits -= (numRiSubcs * modulation);
            numChannelBits -= (numCqiSubcs * modulation);
            numCqiOutBits = numCqiSubcs *modulation;
            rvIndex = rvOrder[index];
         //   Bcp_osalLog ("numAckSubcs : %d, numRiSubcs : %d, numCqiSubcs : %d\n",numAckSubcs, numRiSubcs, numCqiSubcs);
         //   Bcp_osalLog ("numChannelBits : %d, numCqiOutBits : %d\n",numChannelBits, numCqiOutBits);
    #endif
            compute_rmGamma_ref (numChannelBits,
                                modulation,
                                1,
                                pCodeBlkParams,
                                rvIndex,
                                0,
                                0,
                                0,
                                lteChanType,
                                pRmParams);
            if (index == 0)
                harqFlag  = 0;
            else
                harqFlag  = 1;
            ns = subfrmIdx * 2;
            rms = 1024; //convert the data into fix point
            /* snrEven is 1/noiseVar (one-dimension) */
            snrEven = 1.f;
            snrOdd = 1.f;
            noiseVar = (float) snrEven/rms/rms/2.f;
            scale1 = * ((Int32 *) &noiseVar);
            noiseVar = (float) snrOdd/rms/rms/2.f;
            scale2 = * ((Int32 *) &noiseVar);
            cInit = (rnti * (1<<14)) + ((ns / 2) * (1<<9)) + cellIDTemp;
           // scale1 = 1;
           // scale2 = 1;
            Bcp_osalLog ("scale1 : %x, scale2 : %x\n",scale1, scale2);
    #endif
            /* Start adding BCP Packet headers based on the test configuration we read. */
            tmpLen			=	0;
            /* Header 1: Global Header */
            bcpGlblHdrCfg.pkt_type          =   Bcp_PacketType_Normal;
            bcpGlblHdrCfg.flush             =   0;
            bcpGlblHdrCfg.drop              =   0;
            bcpGlblHdrCfg.halt              =   0;
            bcpGlblHdrCfg.radio_standard    =   radioStd;
            bcpGlblHdrCfg.hdr_end_ptr       =   28; // 2 + 16 + 8 + 2
            bcpGlblHdrCfg.flow_id           =   RX_FLOW_ID;
            bcpGlblHdrCfg.destn_tag         =   0xDEAD;
            if (Bcp_addGlobalHeader (&bcpGlblHdrCfg, pDataBuffer, &tmpLen) < 0)
                Bcp_osalLog ("Failed to add Global Header to packet \n");
    #endif
                return -1;
            pDataBuffer 	+=	tmpLen;
            dataBufferLen	+=	tmpLen;
            tmpLen			=	0;
            /* Header 2: SSL Header */
                UInt8 uu;
    			UInt8 allocIdx;
    			for (uu = 0; uu < 25; uu++)
    				if (numPrbInPusch[uu] == numSubcarrier/12)
    					allocIdx = uu;
    					break;
             //   prepare_sslhdr_cfg (&sslHdrCfg, radioStd, allocIdx, modulation, numSymbPerSumbfrm, 1, rms, 2,
             //                       cInit, numRiSubcs, numAckSubcs, scale1, scale2);
                prepare_sslhdr_cfg (&sslHdrCfg, radioStd, allocIdx, modulation, numSymbPerSumbfrm, 1, rms, 0,
            if (Bcp_addLTE_SSLHeader (&sslHdrCfg, pDataBuffer, &tmpLen) < 0)
                Bcp_osalLog ("Failed to add SSL Header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
            /* Header 3: Rate de-matching header */
          //  prepare_lte_rdhdr_cfg (&rdHdrCfg, pCodeBlkParams, pRmParams, numCqiPayload, numCqiOutBits, uciFlag, harqFlag, cqiPassThroughFlag);
          //  if (Bcp_addLTE_RDHeader (&rdHdrCfg, pDataBuffer, &tmpLen) < 0)
          //     Bcp_osalLog ("Failed to add lte rate modulation header to packet \n");
    #endif
          //      return -1;
            tmpLen			=	0;
            /* Also, initialize the memory block from which RD will read HARQ Input Data */
            if ((pTestCfgFile = fopen("C:\\ti\\pdk_C6670_1_0_0_21\\packages\\ti\\drv\\bcp\\test\\lte\\pusch_rdMemIn_0004.dat","r")) == NULL)
                Bcp_osalLog ("Cannot open HARQ data input file: ..\..\lte\pusch_rdMemIn_0004.dat\n");
    #endif
                return -1;
    	    fscanf(pTestCfgFile, "0x%x\n", &harq_address);		// harq address ����...
            fscanf(pTestCfgFile, "0x%x\n", &num_words);			// number of words
            harq_address	= convert_coreLocalToGlobalAddr ((UInt32)harqInput);
            temp = 0;
            read_harq_data_from_file (pTestCfgFile, (UInt8*)(harq_address), &temp);
            Int32 i;
            for(i=0;i<132;i++) //Bcp_osalLog ("%d, 0x%x\n",i, harqInput[i]);
            	harqInput[i] = 0x0;
            	//harqInput[i] = 0xE1E1E1E1;
    #else
            read_data_from_file (pTestCfgFile, (UInt8*)(harq_address), &temp);
    #endif
            if (temp != num_words * 4)
                Bcp_osalLog ("Error initializing HARQ Input \n");
    #endif
                return -1;
            /* Header 4: Traffic Manager header */
            prepare_tmhdr_cfg (&tmHdrCfg);
            if (Bcp_addTMHeader (&tmHdrCfg, pDataBuffer, &tmpLen) < 0)
                Bcp_osalLog ("Failed to add Traffic Manager header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
            /* No Info words/PS to be added for now */
    	    /* Add padding to align data on 128 bits */
            pDataBuffer 	+=	0;
            dataBufferLen	+=	0;
            /* Finally add the data to the packet in the same order as the headers */
            if ((pTestCfgFile = fopen("C:\\ti\\pdk_C6670_1_0_0_21\\packages\\ti\\drv\\bcp\\test\\lte\\pusch_sslIn_0005.dat","r")) == NULL)
          //  if ((pTestCfgFile = fopen("C:\\ti\\pdk_C6670_1_0_0_21\\packages\\ti\\drv\\bcp\\test\\lte\\pusch_rdlIn_0004.dat","r")) == NULL)
                Bcp_osalLog ("Cannot open data input file: ..\..\lte\pusch_sslIn_0004.dat\n");
    #endif
                return -1;
            read_data_from_file (pTestCfgFile, pDataBuffer, &dataBufferLen);
        fclose (pTestSnrCfgFile);
        Bcp_osalFree (pRmParams, sizeof (BcpTest_RateMatchParams), FALSE);
        Bcp_osalFree (pCodeBlkParams, sizeof (BcpTest_LteCBParams), FALSE);
        /* Successfully read the test configuration */
        return dataBufferLen;
     *   @n@b test_lte_ul
     *   @b Description
     *   @n Sets up the parameters required and runs an LTE Uplink (UL) test case.
     *   @param[in]
     *   @param[in]
     *   @n hGlblFDQ    Global free descriptor queue handle. The test will allocate all its
     *                  free descriptors from this queue for its run and release them
     *                  back once done to this queue.
     *   @return
     *   @n None
    Void test_lte_ul (Bcp_DrvHandle hBcp, Qmss_QueueHnd hGlblFDQ)
        Bcp_TxCfg           txCfg;
        Bcp_TxHandle        hTx = NULL;
        Bcp_RxCfg           rxCfg;
        Bcp_RxHandle        hRx = NULL;
        Qmss_QueueHnd       hTxFDQ, hRxFDQ;
        UInt8               rxFlowId, rxSrcId;
        UInt32              i, dataBufferLen, rxDataBufferLen, rxPsInfoLen, rxDataTotalLen, numRxPackets, testFail = 0, numTestPkts;
        UInt16              rxDestnTag;
        Cppi_Desc*          pCppiDesc;
        UInt8*              pDataBuffer;
        UInt8*              pRxDataBuffer;
        UInt8*              pRxPsInfo;
        Bcp_DrvBufferHandle hRxDrvBuffer;
        Bcp_DrvBufferHandle hVoid;
        Bcp_DrvBufferHandle hTmp;
        Int32               dataBufferLenUsed;
        UInt32				k;
        Int32				tmp;
        /* Setup Rx side:
         *  -   Open BCP Rx queue on which BCP results are to be received
         *  -   Setup a Rx FDQ, Rx flow to receive data
         *  -   Set the BCP Tunnel Rx endpoint configuration to NULL since we
         *      are processing BCP packets locally.
        if (allocate_fdq (hGlblFDQ, RX_NUM_DESC, RX_DATA_BUFFER_SIZE, 0, &hRxFDQ, NULL) < 0)
            Bcp_osalLog ("Error opening Tx FDQ \n");
            return;
        else
            Bcp_osalLog ("Rx FDQ %d successfully setup with %d descriptors\n", hRxFDQ, RX_NUM_DESC);
        rxCfg.rxQNum                        =   RX_Q_NUM;
        rxCfg.bUseInterrupts                =   0;              // Use polling
        memset (&rxCfg.flowCfg, 0, sizeof(Cppi_RxFlowCfg));
        rxCfg.flowCfg.flowIdNum             =   RX_FLOW_ID;
        rxCfg.flowCfg.rx_dest_qmgr          =   0;
        rxCfg.flowCfg.rx_dest_qnum          =   RX_Q_NUM;
        rxCfg.flowCfg.rx_desc_type          =   Cppi_DescType_HOST;
        rxCfg.flowCfg.rx_ps_location        =   Cppi_PSLoc_PS_IN_DESC;
        rxCfg.flowCfg.rx_psinfo_present     =   0;
        rxCfg.flowCfg.rx_error_handling     =   0;              //  Drop the packet, do not retry on starvation
        rxCfg.flowCfg.rx_einfo_present      =   0;              //  By default no EPIB info
        rxCfg.flowCfg.rx_dest_tag_lo_sel    =   4;              //  Pick dest tag 7:0 bits from the PD dest_tag
        rxCfg.flowCfg.rx_dest_tag_hi_sel    =   5;              //  Pick the dest tag 15:8 bits from the PD dest_tag
        rxCfg.flowCfg.rx_src_tag_lo_sel     =   2;              //  Pick the src tag 7:0 bits from the PD flow_id 7:0
        rxCfg.flowCfg.rx_src_tag_hi_sel     =   4;              //  Pick the src tag 15:8 bits from the PD src_tag 7:0
        rxCfg.flowCfg.rx_size_thresh0_en    =   0;
        rxCfg.flowCfg.rx_size_thresh1_en    =   0;
        rxCfg.flowCfg.rx_size_thresh2_en    =   0;
        rxCfg.flowCfg.rx_size_thresh0       =   0x0;
        rxCfg.flowCfg.rx_size_thresh1       =   0x0;
        rxCfg.flowCfg.rx_size_thresh2       =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz0_qmgr      =   0;
        rxCfg.flowCfg.rx_fdq0_sz0_qnum      =   hRxFDQ;
        rxCfg.flowCfg.rx_fdq0_sz1_qnum      =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz1_qmgr      =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz2_qnum      =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz2_qmgr      =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz3_qnum      =   0x0;
        rxCfg.flowCfg.rx_fdq0_sz3_qmgr      =   0x0;
        rxCfg.flowCfg.rx_fdq1_qnum          =   hRxFDQ;
        rxCfg.flowCfg.rx_fdq1_qmgr          =   0;
        rxCfg.flowCfg.rx_fdq2_qnum          =   hRxFDQ;
        rxCfg.flowCfg.rx_fdq2_qmgr          =   0;
        rxCfg.flowCfg.rx_fdq3_qnum          =   hRxFDQ;
        rxCfg.flowCfg.rx_fdq3_qmgr          =   0;
        /* Setup TM flow entry configuration for BCP */
    #ifdef SIMULATOR_SUPPORT
        rxCfg.tmFlowCfg.endian_in           =   Bcp_EndianFormat_128;
        rxCfg.tmFlowCfg.endian_out          =   Bcp_EndianFormat_128;
    #else
        rxCfg.tmFlowCfg.endian_in           =   Bcp_EndianFormat_32;
        rxCfg.tmFlowCfg.endian_out          =   Bcp_EndianFormat_32;
    #endif
        rxCfg.tmFlowCfg.format_in           =   Bcp_DataFormat_NoChange;
        rxCfg.tmFlowCfg.pkt_type            =   0;      // No special pkt assignments
        rxCfg.tmFlowCfg.dsp_int_sel         =   0;      // Interrupt core 0
        rxCfg.tmFlowCfg.format_out          =   Bcp_DataFormat_NoChange;
        rxCfg.tmFlowCfg.qfifo_out           =   RX_FLOW_ID;      // Use Rx QFIFO 2
        rxCfg.tmFlowCfg.ps_flags            =   0;      // No PS for now
        if ((hRx = Bcp_rxOpen (hBcp, &rxCfg, NULL)) == NULL)
            Bcp_osalLog ("BCP Rx Open failed \n");
    		goto cleanup_and_return;
        else
            Bcp_osalLog ("Flow %d opened to send data to RxQ: %d \n", RX_FLOW_ID, RX_Q_NUM);
        /* Setup Tx side:
         *  -   Open BCP Tx queue using which data would be sent
         *  -   Setup a Tx FDQ and initialize it with some Tx FDs
         *  -   Set the BCP Tunnel Tx endpoint configuration to NULL since we
        txCfg.txQNum    =   Bcp_QueueId_0;
        if ((hTx = Bcp_txOpen (hBcp, &txCfg, NULL)) == NULL)
            Bcp_osalLog ("BCP Tx Open failed \n");
            return;
        if (allocate_fdq (hGlblFDQ, TX_NUM_DESC, TX_DATA_BUFFER_SIZE, 0, &hTxFDQ, NULL) < 0)
            return;
        else
            Bcp_osalLog ("Tx FDQ %d successfully setup with %d descriptors\n", hTxFDQ, TX_NUM_DESC);
        /* Build and Send a packet with LTE UL parameters for BCP Processing */
        for (numTestPkts = 0; numTestPkts < BCP_TEST_NUM_PACKETS; numTestPkts ++)
            if ((pCppiDesc = (Cppi_Desc*) Qmss_queuePop (hTxFDQ)) == NULL)
                Bcp_osalLog ("Out of Tx FDs! \n");
    #endif
                testFail ++;
            pCppiDesc = (Cppi_Desc *) (QMSS_DESC_PTR (pCppiDesc));
            Cppi_getData (Cppi_DescType_HOST, pCppiDesc, &pDataBuffer, &dataBufferLen);
    	    memset (pDataBuffer, 0, dataBufferLen);
            /* Read test configuration */
            if ((dataBufferLenUsed = add_test_config_data (hBcp, pDataBuffer)) <= 0)
                Bcp_osalLog ("Error reading test vectors/populating packet \n");
                testFail ++;
       	    Bcp_osalLog ("Sending a packet of len %d to BCP ...\n", dataBufferLenUsed);
    #endif
            /* Setup the data length in the descriptor */
            Cppi_setDataLen (Cppi_DescType_HOST, pCppiDesc, dataBufferLenUsed);
            Cppi_setPacketLen (Cppi_DescType_HOST, pCppiDesc, dataBufferLenUsed);
            /* Since BCP is local to the device, set destination address to NULL */
            Bcp_send (hTx, (Bcp_DrvBufferHandle) pCppiDesc, BCP_TEST_SIZE_HOST_DESC, NULL);
            /* Wait on data to be received from BCP and validate it */
            for (i = 0; i < 400; i ++);
            while ((numRxPackets = Bcp_rxGetNumOutputEntries (hRx)) == 0);
            Bcp_osalLog ("Got %d packet(s) from BCP \n", Bcp_rxGetNumOutputEntries (hRx));
    #endif
            for (i = 0; i < numRxPackets; i ++)
                /* Data could arrive scattered across multiple linked descriptors.
                 * Collect data from all linked descriptors and validate it.
                rxDataTotalLen  =   0;
                Bcp_recv (hRx,
                        &hRxDrvBuffer,
                        &pRxDataBuffer,
                        &rxDataBufferLen,
                        &pRxPsInfo,
                        &rxPsInfoLen,
                        &rxFlowId,
                        &rxSrcId,
                        &rxDestnTag);
                for(k=0;k<rxDataBufferLen;k++) {
                	//tmp = (((pRxDataBuffer[k] >> 7) & 0x01) == 1)? (pRxDataBuffer[k]-256) : pRxDataBuffer[k];
                	//Bcp_osalLog("%d, %x, %x, %x \n", tmp, pRxDataBuffer[k], pRxDataBuffer[k] >> 2, pRxDataBuffer[k]&0x3);
                	if(pRxDataBuffer[k]>= 128)
                		Bcp_osalLog("%d, %d, 0x%2x, %d \n", i, k, pRxDataBuffer[k],  pRxDataBuffer[k]-256);
                	else
                		Bcp_osalLog("%d, %d, 0x%2x, %d \n", i, k, pRxDataBuffer[k],  pRxDataBuffer[k]);
                if (i == 0)		// CQI
                    if (validate_rxdata ((UInt8 *)lte_ul_output_packet_1,
                                        LTE_UL_OUTPUT_PKT_1_WRD_SIZE*4,
                                        pRxDataBuffer,
                                        rxDataBufferLen,
                                        rxDataTotalLen) != 0)
                        testFail ++;
                else				// UL-SCH
                	Bcp_osalLog("%d, %d, 0x%2x \n", i, k, pRxDataBuffer[k]);
                    if (validate_rxdata ((UInt8 *)lte_ul_output_packet_2,
                                        LTE_UL_OUTPUT_PKT_2_WRD_SIZE*4,
                                        pRxDataBuffer,
                                        rxDataBufferLen,
                        testFail ++;
                rxDataTotalLen  +=  rxDataBufferLen;
                Bcp_osalLog ("[Pkt %d]: rx first check \n", i);
                /* Check if there are any descriptors linked to this Rx desc */
                while (hRxDrvBuffer)
                    /* Save original Rx desc handle. */
                    hTmp = hRxDrvBuffer;
                    if ((hRxDrvBuffer = Cppi_getNextBD (Cppi_getDescType (hRxDrvBuffer), hRxDrvBuffer)))
                        Bcp_rxProcessDesc  (hRx,
                                            hRxDrvBuffer,
                                            &hVoid,
                                            &pRxDataBuffer,
                                            &rxDataBufferLen,
                                            &pRxPsInfo,
                                            &rxPsInfoLen,
                                            &rxFlowId,
                                            &rxSrcId,
                                            &rxDestnTag);
                        if (i == 0)
                                                pRxDataBuffer,
                                                rxDataBufferLen,
                                testFail ++;
                        else
                                                pRxDataBuffer,
                                                rxDataBufferLen,
                                testFail ++;
                        	Bcp_osalLog("%dth output : %x \n", k, pRxDataBuffer[k]);
                        Bcp_osalLog ("[Pkt %d]: rx second check \n", i);
                    Bcp_rxFreeRecvBuffer (hRx, hTmp, BCP_TEST_SIZE_HOST_DESC);
                Bcp_osalLog ("[Pkt %d]: Total Len: %d DestnTag: 0x%x SrcId: 0x%x \n", i, rxDataTotalLen, rxDestnTag, rxSrcId);
    #endif
                if ((i == 0 && rxDataTotalLen != LTE_UL_OUTPUT_PKT_1_WRD_SIZE * 4) ||
                    (i == 1 && rxDataTotalLen != LTE_UL_OUTPUT_PKT_2_WRD_SIZE * 4))
                    testFail ++;
            /* Compare HARQ output */
          //  for(k=0;k<132*4;k++)
          //  	Bcp_osalLog("%d, 0x%x, \n", k, harqOutput[k]);
            if (validate_harqoutput (lte_ul_output_mem, 132 * 4, harqOutput, 132 * 4, 0) != 0)
    #else
            if (validate_rxdata ((UInt8 *)lte_ul_output_mem, 132 * 4, (UInt8 *)harqOutput, 132 * 4, 0) != 0)
    #endif
                testFail ++;
    cleanup_and_return:
        if (testFail > 0)
            Bcp_osalLog ("LTE UL Test:    FAILED\n");
            totalNumTestsFail ++;
        else
            Bcp_osalLog ("LTE UL Test:    PASS\n");
            totalNumTestsPass ++;
        if (hRx)
            Bcp_rxClose (hRx);
        deallocate_fdq (hRxFDQ, hGlblFDQ, RX_NUM_DESC, RX_DATA_BUFFER_SIZE, NULL);
        if (hTx)
            Bcp_txClose (hTx);
        deallocate_fdq (hTxFDQ, hGlblFDQ, TX_NUM_DESC, TX_DATA_BUFFER_SIZE, NULL);
        return;
    3007.pusch_sslIn_0005.dat
  • Hi Hyekyung,
    The data you provided in 3007.pusch_sslIn_0005.dat still only contains the BCP Payload part which you listed in your original post. In order analyze the issue, I need the BCP Header information as well. You can dump the complete input packet (including BCP header inormation and payload) using the Data Pointer of the CPPI decriptor right before the descriptor is sent to the BCP in bcp_send(). It is not possible to look at the problem without getting the BCP header information. Thanks.
    -Nitin
    Hi, Nitin,
    I am sorry to trouble you. I attached the complete input packet file including BCP header infomation and payload.
    Thanks.
    Hyekyung
    2818.pusch_sslIn_databuf.dat
  • Hi Hyekyung,
    Is this in Big Endian format or Little Endian Format?
    -Nitin
    Hi Nitin,
    This is in Little Endian Format.
    Thanks.
    Hyekyung
    Hi Nitin,
    There's something wrong with my header and payloads?
    I hope to get your reply as soon as possible.
    Hyekyung
  • Hi Hyekyung,
    I'm looking into the data you provided and will get back once I have some results. Thanks.
    -Nitin
  • Hi Hyekyung,
    The GHDR_END_PTR value in your BCP global header is 0x1C i.e. 28 words which is wrong. The length of the BCP header in this case is 20 words (2 words Global header + 16 Words SSL Header + 2 Words TM Header) so the correct value is 0x14. The data you see coming out before the output is not a header but the first 8 words from the input itself becuase of the wrong header length specified.
    With this fixed, SSL output matched the expected output. I've also attached the original and corrected input packets for comparison.
    -Nitin
    7870.BCP_SSL_input_hyekyung_error.txt
    0x001C0000, //Global Header
    0x0000DEAD,
    0x02D4090F, //SSL Header
    0x00000310,
    0x00040003,
    0x0001c4ec,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x00000001, //TM Header
    0x00000000, //TM Header ends here
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000
    2870.BCP_SSL_input_fixed.txt
    0x00140000, //Global Header
    0x0000DEAD,
    0x00000310,
    0x00040003,
    0x0001c4ec,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x35000000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x04000400,
    0x08000800,
    0x0c000c00,
    0x10001000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x14001400,
    0x18001800,
    0x1c001c00,
    0x20002000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000,
    0x24002400,
    0x28002800,
    0x2c002c00,
    0x30003000
    6661.SSL_output.txt
    -17	-17
  • Hi Nitin,
    I can get the correct output with the fixed setting.
    Thank you so much.
    Hyekyung.
  • Hi Nitin,
    I just started working on PUSCH decoding, checked the example code with the 2870.BCP_SSL_input_fixed.txt and my output is matching and this is with descrambler disabled. In my project I need to do descrambling also, is it possible for you to give output file with descrambler enabled with 2870.BCP_SSL_input_fixed.txt as input so that I can go ahead in my project.
    Thanks & Regards,
    Anjibabu
  • Hi Anjibabu,
    The BCP PDK example does have LTE de-scrambler enabled in the SSL input parameters (refer to function prepare_sslhdr_cfg in bcp_lte_ul.c) which means that the SSL input data provided in the PDK example is scrambled.
    -Nitin
  • Hi Nitin,
    Thanks for your response. I tried PDK example with LTE de-scrambler enabled but the output is not matching with MATLAB equivalent. I have one basic doubt regarding this, does BCP de-scramble control information along with data or data alone?. In case if BCP de-scrambling both, how is it done? does BCP apply different de-scrambling sequences for control and data soft bits?. According to 3GPP specifications de-scrambling is different for data and control.
    Anjibabu
  • Hi Nitin,
    Expecting your reply on this. Please let me know if my question is not clear.
    Anjibabu
  • Hi Anjibabu,
    BCP (SSL) punctures the RI bits and overwrites ACK/NACK softbits with 0 so you cannot get this information from BCP output. Control symbols needs to be extracted from the input data in software, before sending it to the BCP and processed seperately. TI's LTE library provides optimized functions to handle this processing in software.
    -Nitin
  • Hi Nitin,
    Thank you for your response. I understand that we get two output packets from BCP out of which one is CQI data and other is payload. These two outputs will come after rate de-matching module.
    1.If I try to disable rate de-matching and see de-srambling output, it is not matching with matlab equivalent.
    2.Even if I enable Rate de-matcher in PDK example, CQI output is matching but payload (data) is not matching.
    I am attaching my input and output files with de-scrambling enabled, rate de-matching enabled and main file. Please have a look into it and let me know if any bug/error is there in the code.
    bcp_lte_ul.c
     *   @file  bcp_lte_ul.c
     *   @brief
     *  \par
     *  are met:
     *    distribution.
    #include "bcp_example.h"
    #include "bcp_lte.h"
    #define     RX_NUM_DESC                     (BCP_EXAMPLE_NUM_HOST_DESC/4 - TX_NUM_DESC)
    static UInt16   rnti;
    static UInt8    ns;
    static UInt16   rms;
        {0	    , 0	     ,     0  },
        {40	    , 3	     ,    10  },
        {48	    , 7	     ,    12  },
        {56	    , 19	 ,    42  },
        {64	    , 7	     ,    16  },
        {72	    , 7	     ,    18  },
        {80	    , 11	 ,    20  },
        {88	    , 5	     ,    22  },
        {96	    , 11	 ,    24  },
        {104	, 7	     ,    26  },
        {112	, 41	 ,    84  },
        {120	, 103	 ,    90  },
        {128	, 15	 ,    32  },
        {136	, 9	     ,    34  },
        {144	, 17	 ,    108 },
        {152	, 9	     ,    38  },
        {160	, 21	 ,    120 },
        {168	, 101	 ,    84  },
        {176	, 21	 ,    44  },
        {184	, 57	 ,    46  },
        {192	, 23	 ,    48  },
        {200	, 13	 ,    50  },
        {208	, 27	 ,    52  },
        {216	, 11	 ,    36  },
        {224	, 27	 ,    56  },
        {232	, 85	 ,    58  },
        {240	, 29	 ,    60  },
        {248	, 33	 ,    62  },
        {256	, 15	 ,    32  },
        {264	, 17	 ,    198 },
        {272	, 33	 ,    68  },
        {280	, 103	 ,    210 },
        {288	, 19	 ,    36  },
        {296	, 19	 ,    74  },
        {304	, 37	 ,    76  },
        {312	, 19	 ,    78  },
        {320	, 21	 ,    120 },
        {328	, 21	 ,    82  },
        {336	, 115	 ,    84  },
        {344	, 193	 ,    86  },
        {352	, 21	 ,    44  },
        {360	, 133	 ,    90  },
        {368	, 81	 ,    46  },
        {376	, 45	 ,    94  },
        {384	, 23	 ,    48  },
        {392	, 243	 ,    98  },
        {400	, 151	 ,    40  },
        {408	, 155	 ,    102 },
        {416	, 25	 ,    52  },
        {424	, 51	 ,    106 },
        {432	, 47	 ,    72  },
        {440	, 91	 ,    110 },
        {448	, 29	 ,    168 },
        {456	, 29	 ,    114 },
        {464	, 247	 ,    58  },
        {472	, 29	 ,    118 },
        {480	, 89	 ,    180 },
        {488	, 91	 ,    122 },
        {496	, 157	 ,    62  },
        {504	, 55	 ,    84  },
        {512	, 31	 ,    64  },
        {528	, 17	 ,    66  },
        {544	, 35	 ,    68  },
        {560	, 227	 ,    420 },
        {576	, 65	 ,    96  },
        {592	, 19	 ,    74  },
        {608	, 37	 ,    76  },
        {624	, 41	 ,    234 },
        {640	, 39	 ,    80  },
        {656	, 185	 ,    82  },
        {672	, 43	 ,    252 },
        {688	, 21	 ,    86  },
        {704	, 155	 ,    44  },
        {720	, 79	 ,    120 },
        {736	, 139	 ,    92  },
        {752	, 23	 ,    94  },
        {768	, 217	 ,    48  },
        {784	, 25	 ,    98  },
        {800	, 17	 ,    80  },
        {816	, 127	 ,    102 },
        {832	, 25	 ,    52  },
        {848	, 239	 ,    106 },
        {864	, 17	 ,    48  },
        {880	, 137	 ,    110 },
        {896	, 215	 ,    112 },
        {912	, 29	 ,    114 },
        {928	, 15	 ,    58  },
        {944	, 147	 ,    118 },
        {960	, 29	 ,    60  },
        {976	, 59	 ,    122 },
        {992	, 65	 ,    124 },
        {1008	, 55	 ,    84  },
        {1024	, 31	 ,    64  },
        {1056	, 17	 ,    66  },
        {1120	, 67	 ,    140 },
        {1152	, 35	 ,    72  },
        {1184	, 19	 ,    74  },
        {1216	, 39	 ,    76  },
        {1248	, 19	 ,    78  },
        {1312	, 21	 ,    82  },
        {1376	, 21	 ,    86  },
        {1408	, 43	 ,    88  },
        {1440	, 149	 ,    60  },
        {1472	, 45	 ,    92  },
        {1504	, 49	 ,    846 },
        {1536	, 71	 ,    48  },
        {1568	, 13	 ,    28  },
        {1600	, 17	 ,    80  },
        {1632	, 25	 ,    102 },
        {1696	, 55	 ,    954 },
        {1728	, 127	 ,    96  },
        {1760	, 27	 ,    110 },
        {1792	, 29	 ,    112 },
        {1824	, 29	 ,    114 },
        {1856	, 57	 ,    116 },
        {1888	, 45	 ,    354 },
        {1920	, 31	 ,    120 },
        {1952	, 59	 ,    610 },
        {2048	, 31	 ,    64  },
        {2112	, 17	 ,    66  },
        {2560	, 39	 ,    80  },
        {2624	, 27	 ,    164 },
        {2816	, 43	 ,    88  },
        {2880	, 29	 ,    300 },
        {2944	, 45	 ,    92  },
        {3072	, 47	 ,    96  },
        {3136	, 13	 ,    28  },
        {3328	, 51	 ,    104 },
        {3392	, 51	 ,    212 },
        {3584	, 57	 ,    336 },
        {4096	, 31	 ,    64  },
        {4160	, 33	 ,    130 },
        {4224	, 43	 ,    264 },
        {4288	, 33	 ,    134 },
        {4416	, 35	 ,    138 },
        {4672	, 37	 ,    146 },
        {4736	, 71	 ,    444 },
        {4800	, 71	 ,    120 },
        {4864	, 37	 ,    152 },
        {4928	, 39	 ,    462 },
        {5056	, 39	 ,    158 },
        {5120	, 39	 ,    80  },
        {5184	, 31	 ,    96  },
        {5312	, 41	 ,    166 },
        {5440	, 43	 ,    170 },
        {5504	, 21	 ,    86  },
        {5568	, 43	 ,    174 },
        {5632	, 45	 ,    176 },
        {5696	, 45	 ,    178 },
        {5824	, 89	 ,    182 },
        {5952	, 47	 ,    186 },
        {6016	, 23	 ,    94  },
        {6080	, 47	 ,    190 },
        {6144	, 263	 ,    480 }
    #else
    #endif
    #else
    #endif
    #else
    #endif
    #else
    #endif
    0x09fd09fd,
    0xfcfb02fd,
    0x02060001,
    0x0efff002,
    0x05edfd07,
    0xfcfb00f9,
    0xf4fe01f1,
    0xfe0403f6,
    0x04fe1507,
    0xfb140c02,
    0xffebfff9,
    0xf2fff90a,
    0x0cfffcf7,
    0x00f100f3,
    0x04fe0605,
    0xf603f805,
    0x0c040004,
    0xff0df7f9,
    0xffed00ff,
    0xfcfc0306,
    0x02fbfbfa,
    0x010afd0e,
    0xfcf9fefa,
    0x0efefdfc,
    0x010603f7,
    0x0017ec05,
    0x07f40604,
    0xfff8f8f8,
    0xf003fc03,
    0x010701eb,
    0x040f04f4,
    0xf203ff0f,
    0xf9010104,
    0x05fef7f7,
    0x00030d04,
    0x02fe01fe,
    0x03000700,
    0xfd0908f8,
    0xf9f8fcfa,
    0x05fdfcf5,
    0xf2fc0207,
    0x03ecf508,
    0xf8ef1202,
    0x00000000,
    0xfcff04f9,
    0x050609ff,
    0xfef90ff4,
    0x05fd08fd,
    0xfc0703fa,
    0x01fa0bff,
    0xf7fb0204,
    0x07ed04fc,
    0x04f7fdf0,
    0xfffe02f8,
    0x07f40bf0,
    0x04fffcfe,
    0x08040b04,
    0x07fe0d02,
    0xec0306ff,
    0xf711fb0f,
    0xf4080b00,
    0x0c04f5f2,
    0xf80506ff,
    0x030109fa,
    0xfe0801f7,
    0xfe07f705,
    0x06030efc,
    0xf5fff4fd,
    0xfefff90b,
    0xf5fbfd07,
    0xf5f8f30c,
    0xf504fcfc,
    0xfaf9fefd,
    0x01090af3,
    0xfff7f5fd,
    0x07040106,
    0xf2f7fd13,
    0x0cfc0c00,
    0xff010afa,
    0x0200f8f7,
    0x01fdf908,
    0xfff4f6f8,
    0x04f5f6fe,
    0xf50a0502,
    0xfef904fd,
    0xf7080604,
    0xf1f9ebf5,
    0x00000000,
    0x020505f4,
    0xf1030202,
    0xfb07f408,
    0x0504ff01,
    0x0709fe0d,
    0xecffffec,
    0x08fa00fd,
    0xf909f006,
    0xf706ff02,
    0x07f9ecfe,
    0xffedfafd,
    0x03fa0409,
    0xf8f305ff,
    0xf30d000b,
    0xfffa02e8,
    0xd9edff07,
    0x0908100a,
    0x07fa020d,
    0xf901f5fc,
    0xfeff0202,
    0x01f7fafc,
    0xf8fcfa05,
    0xf8f803ff,
    0xf704fafb,
    0x04f40bfa,
    0x03f5f30c,
    0xf9f6ee08,
    0xff01050c,
    0xfe040104,
    0x04f9f3fc,
    0x01f60301,
    0x08f8000d,
    0x0d0f01fc,
    0xfe0702fd,
    0x04f80f04,
    0x03010605,
    0x04fc080a,
    0xf4fc06fd,
    0x050afffe,
    0x18fd03fa,
    0xfbf20405,
    0x02fcfefa,
    0x0202ebfd,
    0x00000000};
     *   @n@b read_bcp_config
     *   @b Description
     *      file.
     *   @param[in]
     *   @return
     *   @n None.
    static Void read_bcp_config(FILE* fp)
    	Char            lineBuf[300];
    	Char*           ptrBuf;
    	Int32           i, j;
    			ptrBuf ++;
    				continue;
    				soundFlag = i;
    				continue;
    				tbSize = i;
    				continue;
    				rnti = (UInt8) i;
    				continue;
    				cellID = (UInt8) i;
    				continue;
    				continue;
    				modulation = i;
    				continue;
    				numAckBits = i;
    				continue;
    				continue;
    				continue;
    				riBeta = (UInt8) i;
    				continue;
    				continue;
    				continue;
    				continue;
        return;
     *   @b Description
     *   @param[in]
     *   @param[out]
     *   @return
     *   @n None.
    	Int16           idx;
    	UInt8           delaK;
    		numCodeBlocks = 1;
    	else
    				firstSegCount = 1;
    				break;
    			secondSegCount  = 0;
    			/* no kminues */
    					break;
        return;
     *   @b Description
        UInt16                  numPrb,
        UInt8                   numOFDMsym,
        UInt8                   numAckBits,
    	UInt8                   ackIdx,
    	UInt8                   numRiBits,
        UInt8                   riIdx,
    	UInt8                   numCqiBits,
    	UInt8                   cqiIdx,
    	float           temp;
    	UInt16          cqiL;
    	else
    	else
    		cqiL  = 0;
    //	else cqiL = 8;
    	else
     *   @b Description
        UInt8                       mod,
        UInt8                       numLayers,
        UInt8                       rvIndex,
        float                       ratioKp,
        UInt32                      Nir,
        UInt8                       testFlag,
    	UInt16 Gprime;
    	UInt32 G;
    	UInt16 numRows;
    	UInt32 vBufferSize;
    	G = numChannelBits;
    	blkMap = numLayers;
    		E1 = 0;
    	else
    	pRmParams->E0      = E0;
    	pRmParams->E1      = E1;
    			if (ratioKm != 0)
    				else
    		else //PUSCH_SIC
    		else
    	else
    			if (ratioKp != 0)
    				pRmParams->NcbKp = (UInt32) (ratioKp * numRows * 32.f);
    			else
    					pRmParams->NcbKp =Nir/numCodeBks;
    				else
    		else
    			pRmParams->NcbKp++;
    		else
    	else
        return;
     *   @b Description
        UInt8               mod,
        UInt8               numLayers,
        UInt16              rms,
        UInt8               Qfmt,
        UInt16              numRi,
        UInt16              numAck,
    	UInt8               idx;
    	UInt32              Rprime1;
            pSslHdrCfg->modeSelCfg.lte_descrambler_en  =   1;
        else
        else    // 256 QAM
    		if (numLayers == 2)
        return;
     *   @b Description
        UInt8                       uciFlag,
        UInt8                       harqFlag,
        else
        if (uciFlag)
            else
        else
    	if (harqFlag)
    	else
        return;
     *   @b Description
     *   @param[out]
     *   @return
     *   @n None.
        return;
     *   @n@b add_bcp_config_data
     *   @b Description
     *   @param[in]
     *   @param[in]
     *   @return        Int32
    static Int32 add_bcp_config_data (Bcp_DrvHandle hBcp, UInt8*  pDataBuffer)
    	FILE*                       pTestCfgFile;
        Char                        lineBuf [256];
    	Char*                       ptrBuf;
    	float                       noiseVar;
    #ifdef BCP_EXAMPLE_DEBUG
            System_printf ("Failed to allocate memory for holding test configuration.\n");
    #endif
            return -1;
    #endif
            return -1;
        System_printf ("Reading test configuration ... \n");
    #endif
        if ((pTestCfgFile = fopen("C:\\ti\\pdk_tci6614_1_02_01_03\\packages\\ti\\drv\\bcp\\example\\lte\\pusch_paramters_UV620.txt","r")) == NULL)
            System_printf ("Failed to open test configuration file: ..\..\lte\pusch_paramters_UV620.txt\n");
    #endif
            return -1;
        read_bcp_config(pTestCfgFile);
        soundFlag = 0;
        if (numCqiBits)
            uciFlag = 1;
        else
            uciFlag = 0;
        if ((pTestSnrCfgFile = fopen("C:\\ti\\pdk_tci6614_1_02_01_03\\packages\\ti\\drv\\bcp\\example\\lte\\pusch_paramters_UV620_RxSNR.txt","r")) == NULL)
            System_printf ("Failed to open test configuration Rx SNR file: ..\..\lte\pusch_paramters_UV620_RxSNR.txt\n");
    #endif
            return -1;
        dataBufferLen   =   0;
            ptrBuf += 7;
            ptrBuf += 10;
            if (index == 0)
                continue;
            if (soundFlag)
                                numSubcarrier/12,
    						    numSymbPerSumbfrm,
    						    numAckBits,
    					        ackBeta,
    				            numRiBits,
    						    riBeta,
    							numCqiBits,
    							cqiBeta,
    							&numRiSubcs,
    							&numAckSubcs,
    							&numCqiSubcs);
            else
                                numSubcarrier/12,
    							numSymbPerSumbfrm,
    							numAckBits,
    							ackBeta,
    							numRiBits,
    							riBeta,
    							numCqiBits + 8,
    							cqiBeta,
    						    &numRiSubcs,
    							&numAckSubcs,
    							&numCqiSubcs);
                                modulation,
                                1,
                                pCodeBlkParams,
                                rvIndex,
                                0,
                                0,
                                0,
                                lteChanType,
                                pRmParams);
            if (index == 0)
                harqFlag  = 0;
            else
                harqFlag  = 1;
            ns = subfrmIdx * 2;
            tmpLen			=	0;
                System_printf ("Failed to add Global Header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
                UInt8 uu;
    			UInt8 allocIdx;
    					allocIdx = uu;
    					break;
                System_printf ("Failed to add SSL Header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
                System_printf ("Failed to add lte rate modulation header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
            if ((pTestCfgFile = fopen("C:\\ti\\pdk_tci6614_1_02_01_03\\packages\\ti\\drv\\bcp\\example\\lte\\pusch_rdMemIn_0004.dat","r")) == NULL)
                System_printf ("Cannot open HARQ data input file: ..\..\lte\pusch_rdMemIn_0004.dat\n");
    #endif
                return -1;
            temp = 0;
    #else
    #endif
                System_printf ("Error initializing HARQ Input \n");
    #endif
                return -1;
                System_printf ("Failed to add Traffic Manager header to packet \n");
    #endif
                return -1;
            tmpLen			=	0;
            pDataBuffer 	+=	0;
            dataBufferLen	+=	0;
            if ((pTestCfgFile = fopen("C:\\ti\\pdk_tci6614_1_02_01_03\\packages\\ti\\drv\\bcp\\example\\lte\\pusch_sslIn_0004.dat","r")) == NULL)
                System_printf ("Cannot open data input file: ..\..\lte\pusch_sslIn_0004.dat\n");
    #endif
                return -1;
     *   @n@b test_lte_ul
     *   @b Description
     *   @param[in]
     *   @param[in]
     *   @return
     *   @n None
        Bcp_TxCfg           txCfg;
        Bcp_RxCfg           rxCfg;
        UInt16              rxDestnTag;
        UInt8*              pDataBuffer;
        UInt8*              pRxPsInfo;
        /* Setup Rx side:
            System_printf ("Error opening Tx FDQ \n");
            return;
        else
            System_printf ("Rx FDQ %d successfully setup with %d descriptors\n", hRxFDQ, RX_NUM_DESC);
    #else
    #endif
            System_printf ("BCP Rx Open failed \n");
        else
            System_printf ("Flow %d opened to send data to RxQ: %d \n", RX_FLOW_ID, RX_Q_NUM);
        /* Setup Tx side:
            System_printf ("BCP Tx Open failed \n");
            return;
            return;
        else
            System_printf ("Tx FDQ %d successfully setup with %d descriptors\n", hTxFDQ, TX_NUM_DESC);
                System_printf ("Out of Tx FDs! \n");
    #endif
                testFail ++;
            if ((dataBufferLenUsed = add_bcp_config_data (hBcp, pDataBuffer)) <= 0)
                System_printf ("Error reading test vectors/populating packet \n");
                testFail ++;
       	    System_printf ("Sending a packet of len %d to BCP ...\n", dataBufferLenUsed);
    #endif
            Bcp_send (hTx, (Bcp_DrvBufferHandle) pCppiDesc, BCP_EXAMPLE_SIZE_HOST_DESC, NULL);
            System_printf ("Got %d packet(s) from BCP \n", Bcp_rxGetNumOutputEntries (hRx));
    #endif
                rxDataTotalLen  =   0;
                Bcp_recv (hRx,
                        &hRxDrvBuffer,
                        &pRxDataBuffer,
                        &rxDataBufferLen,
                        &pRxPsInfo,
                        &rxPsInfoLen,
                        &rxFlowId,
                        &rxSrcId,
                        &rxDestnTag);
                if (i == 0)
                                        pRxDataBuffer,
                                        rxDataBufferLen,
                        testFail ++;
                else
                                        pRxDataBuffer,
                                        rxDataBufferLen,
                        testFail ++;
                                            hRxDrvBuffer,
                                            &hVoid,
                                            &pRxDataBuffer,
                                            &rxDataBufferLen,
                                            &pRxPsInfo,
                                            &rxPsInfoLen,
                                            &rxFlowId,
                                            &rxSrcId,
                                            &rxDestnTag);
                        if (i == 0)
                                                pRxDataBuffer,
                                                rxDataBufferLen,
                                testFail ++;
                        else
                                                pRxDataBuffer,
                                                rxDataBufferLen,
                                testFail ++;
                    Bcp_rxFreeRecvBuffer (hRx, hTmp, BCP_EXAMPLE_SIZE_HOST_DESC);
                System_printf ("[Pkt %d]: Total Len: %d DestnTag: 0x%x SrcId: 0x%x \n", i, rxDataTotalLen, rxDestnTag, rxSrcId);
    #endif
                    testFail ++;
    #else
    #endif
                testFail ++;
    cleanup_and_return:
        if (testFail > 0)
            System_printf ("LTE UL Test:    FAILED\n");
        else
            System_printf ("LTE UL Test:    PASS\n");
        if (hRx)
            Bcp_rxClose (hRx);
        if (hTx)
            Bcp_txClose (hTx);
        return;
    ssl_output_bcp_exmple.dat
    +1.9542e+00    # frame: 0, subframe: 4, slot 0, sample:     1
    +6.4167e-01    # frame: 0, subframe: 4, slot 1, sample:     1
    +1.1271e+00    # frame: 1, subframe: 2, slot 0, sample:     1
    +1.2505e+00    # frame: 1, subframe: 2, slot 1, sample:     1
    1122.pusch_paramters_UV620_RxSNR.txt
    pusch_rdMemIn_0004.datpusch_sslIn_0004.dat
    Anjibabu
  • Hi Nitin,
    Expecting your response on this. Please let me know if you need any clarification or any information/files.
    Anjibabu
  • Hi Nitin,
    Did you look into my issue, I am waiting for your response. SSL example code output is not matching with test output. Please have a look into the files that I attached and let me know if I am doing anything wrong.
    Reagrds,
    Anjibabu
  • Anjibabu,
    Do you get an output mismatch with the BCP PDK example (without any modifications to it and using the provided test data) or is it an issue with your own test data? . In case the problem is with your own test data (scrambled), please note that the input to SSL is partially de-interleaved block (i.e. after first stage de-interleaving as mentioned in section 4.7.1.1)
    -Nitin
  • Hi Nithin,
    Output is not matching in PDK example without any modifications. I am using test data provided in example not my own test data.
    Anjibabu
  • Anjibabu,
    We're looking into it and shall get back with the results.
    -Nitin
  • Anjibabu,
    Please provide a link to the exact version of the PDK containing the BCP LTE example you're using so that I can try to reproduce the issue on my setup.
    Additionally, can you please confirm that by output mismatch, do you mean that BCP RD output does not match the reference output provided in bcp_lte_ul.c in global arrays lte_ul_output_packet_1 (CQI) and lte_ul_output_packet_2 (data payload)?
    -Nitin
  • Hi Nitin,
    1. Sorry for late response. Below is the link for MCSDK we are using, please have a look into that.
    2. Yes, BCP RD output is not matching the reference output provided in bcp_lte_ul.c
    Thanks & Regards,
    Anjibabu
  • Anjibabu,
    This is just to let you know that we are working on this and will let you know our findings asap. Thanks.
    -Nitin
  • Hi Nithin,
    I am waiting for your reply. Meanwhile I tried running bcp_ssl in big endian mode but as soon as I load .out in core it is throwing up error saying target endianness doesn't match. Please let me know whether it will work or not in big endian mode?
    Anjibabu
  • Anjibabu,
    We are looking into the PDK example output mismatch issue. Regarding the big-endian question, assuming that you are using a TCI6614 EVM (TI Part no. TMDXEVM6614LXE), you need to configure the EVM in big-endian mode before applying power to it. This is done using the DIP switches as defined in the EVM Technical Reference Manual. SW3, bit 1 controls the device endian mode as defined in section 3.3.3 of the following document.
    http://wfcache.advantech.com/support/DSPM-8303_EVM(6614)-2.0/TMDXEVM6614LXE_Technical_Reference_Manual_V1.0.pdf
    -Nitin
  • Hi Nithin,
    Thankyou for your response. Endianess mismatch issue is resolved but bcp_ssl output is not matching in the big endian mode also.
    Anjibabu
  • Anjibabu,
    Based on initial tests, there appears to be a partial mismatch in the second output packet (the first packet i.e. CQI matches with the reference).This is a test vector issue and we will povide updated test vectors in any future planned relases. We'll also update this thread whenever updated test vectors are available, however this shouldn't gate you from proceeding with using your own test data. The PDK example code can be used as a reference or modified to use your own test data.
    -Nitin
  • Nithin,
    After several tries I found out that BCP UL test is passing if we call test_wcdma_dl() in bcp_main.c before calling test_lte_ul (). Can you please clarify why is this happening?
    Anjibabu
  • Hi Nithin,
    Can you please respond to my previous query?. I have one more query, We won't be having UCI along with ULSCH data all the time(what I mean is some times there may not be control info from UE/Terminal) in that case we have to skip de-interleaving stage1 and stage2. We can skip stage1 de-interleaving easily as it is SW implemented/controlled but how to skip stage2 de-interleaving?
    Anjibabu
  • Anjibabu,
    I have responded to the separate thread you created on the subject of decoding PUSCH blocks with no UCI information as given below:
    https://e2e.ti.com/support/dsp/c6000_multi-core_dsps/f/639/t/455982
    Additionally, you cannot skip second stage de-interleaving in the BCP, however as indicated in the response to the above query, you don't need to do so in order to decode PUSCH blocks with no UCI information.
    I haven't got a chance to look into the bcp test issue you mentioned earlier (i.e. the need to run test_wcdma_dl before running test_lte_ul).
    -Nitin
  • Thank you nithin for your valuable reply.
    Anjibabu
  • Hi Anjibabu,
    I'm trying the BCP Test project for LTE UL Test and I am also facing the same issue as you had faced. That is the CQI packet matching with the reference but Data packet not matching with reference output. And after going through this thread and I also tried running WCDMA_DL_Test before LTE_UL_Test and then both Data and CQI matched their respective reference outputs. I'm using the K2L PDK. Have you resolved this issue..? Have you got it working fine..? Wanted to know the fix if you have fixed this issue.
    Thanks & regards,
    Ashok
  • Hi Ashok,
    As Nithin mentioned in one of his replies, it seems that is the issue with test_vector. Currently I am not using PUSCH+PUCCH decoding, I am using BCP for decoding only PUSCH (no control info). I think you can try with your own i/p and o/p and check the o/p with MATLAB.
    Thanks & regards,
    Anjibabu
  • Hi Anjibabu,
    Thanks for the reply.  I don't think its a test vector issue. Because if its a test vector issue it should not have worked when we run WCDMA DL Test and then LTE UL test. It should have failed there also. I guess we are missing some setting in LTE UL which is taken care when we run WCDMA DL and LTE UL Tests one after the other.
    Any way the LTE UL test was available only for POLLING Mode and I merged the necessary changes from LTE DL tests for interrupt mode. Now with interrupt mode, the LTE UL test is also passing with the given test vector. No issues with the test vector.
    Thanks & Regards,
    Ashok
  • Hi Anjibabu/Nitin,
    I see that the SSL output without the descrambler is something like this:
    I val | Q val | b0 | b1 |
    -ve | -ve | +ve| +ve|
    -ve | +ve | +ve| - ve|
    +ve | -ve | -ve | +ve|
    +ve | +ve | -ve | -ve|
    Is this expected or is there anything to be done to reverse this signs..?
    Also when I enable the descrambler my SSL output is not matching with my reference output. This is for my own test case. Please note that with descrambler disabled, SSL output matches with my reference output except for a sign reversal as mentioned above. I expect the descrambled output also should behave the same...i.e., a sign reversal...but its entirely not matching.
    What could be the issue..?
    Ashok
