Hi.
There was a problem for the C6655 power-down/wake-up.
PLL User Guide (SPRUGV2F) I, in accordance with 3.1.1 Initialization to PLL Mode, I started out with a device.
Then, after a sequence of 3.3 Main PLL Power Down,
There is a case for the CPU to hang up If you do 3.4 Main PLL Wake Up.
At that time, you will not be able to confirm what kind of state because an error occurs in the debugger.
Are there any that you hit something about this?
Best Regards
hamada
