I'm using 4 of the MT41J256M16 (64 bit wide) DDR3 devices implemented in a single-rank topolgy with the C6678.
Is there a ready made configuration file for the C6678's DDR registers for this setup?
BR,
Noam
BR,
Noam
Hi Noam,
You will need to populate the PHY calc and Reg calc spreadsheets to get the configuration registers for your design. Once you've generated the values you need, it's easy to substitute them into the configuration Gel provided with the EVM.
Regards, Bill
Hi Noam,
If you don't have ECC populated, you can leave these cells as 0.
Regards, Bill
