In my multicore project I need high performance communication between cores. Actually I use BIOS so I can use IPC. It works good but IPC is too slow for ma application. For data transfer in parallel computing I use MCSM RAM. I need simple but fast synchronization method with interrupts. Simple solution is Notify from IPC module but it's too slow. I need only send simple command "start calculation" from master to all slaves and "calculation complete" from slaves to master. I can do that for example with GPIO interrupts but I'm looking for better solution.
How can I solve this problem ?
