Hi, all,
I have questions about the following DDR3 registers of 66AK2H12.
Please tell me how to use it.
I check the DDR3 UG(SPRUHN7A) but can not understand the registers settings.
Do you have more detailed documentation of these registers?
- SDTIM2.T_RTW
- dqs_delay_for_cs0 and dqs_delay_for_cs1
- command_delay_for_cs0 and command_delay_for_cs1
- wr_leveling_tolerance
1. How do I derive the above values?
- SDTIM4.T_CSTA
2. How do I derive the above values?
- PGCR1.DLDLMT
3. How should I determine this value?
- PGCR1.FDEPTH
4. How should I determine this value?
5. What is the effects?
- PGCR1.LPFDEPTH
6. How should I determine this value?
7. What is the effects?
- PGCR1.MDLEN
8. What is the Master Delay Line?
9. What is the effects by this bit set to 1?
- PGCR1.WLSELT
10. How should I determine this value?
- PGCR1.WLSTEP
11. What is the difference of setting 32 step and 1 step.
- PGCR1.WLMODE
12. I think this bit field is to indicate whether it is Write Leveling Mode.
So, I understand this is only used to read access, right?
- ZQnCR1.ZPROG
13. How should I determine this value?
- DXnGCR
14. I do not know what to set this register.
Do you have more detailed documentation of each bit field?
H.U
