I've connected the LAN cable to the ethernet port and the led on the ethernet port is lit, but when i tried to ping the board i am unable to do so. The code used for the EVM init and setting up of the network is the same as other projects i've done, except that this is a custom board based on the EVM6678.
Any advice and direction on how i should go about debugging this issue?
Thanks.
