Hi TI engineers,
I am using tci6670 , 20MHz LTE, CPRI link 4x over optical fibre cable.
1)Can anyone tell me what exactly is pi and delta timing?
the diagram in user guide aif2 isn't clear enough for me.
2)Also in UL or while receiving samples using AIF2 the symbol number and slot number information present in psInfo of descriptor,
where does aif2 gets this value from PHY_timer or RAD_timer.
3)What is the way to find out if AxCOFFSET programmed is right in case of the aif2 is connected via optical fibre to RF? How do I find out the correct value for axcoffset?
4) In CPRI link , if momentarily the RF is shutdown and rebooted again, but the DSP is running just fine, but momentarily iaf2 wont be rx any UL iq data, Then should this cause any error, like loss of packet?
