I have questions about C6670 VCP2.
Question 1.
Do I need to perform any configuration for VCP2 after completion of first decode process and before starting the next decode process?
Question 2.
I want to know in what kind of case "Output parameters" should be transfer?
In VCP2 User Guide(sprugv6a) page. 50 Table 4-1, it said "Output parameter" is optional.
Should I transfer "Output parameters"?
Question 3.
There are 4 VCP2 instances on C6670.
Right now we are using 1 VCP2 instances from Core0. VCP2 are processing 30 Data blocks but I want to reduce the processing time. So, I'd like to make processing disperse using 4 VCP2 from one core. Is it available to use all 4 VCP2 instances from only one core?
best regards,
g.f.
