We are using UPP bus on the 6655 DSP to receive large-volume transfers (up to 2 megabytes) from an FPGA.
UPP receive DMA is always configured, for efficiency of our application.
However, at certain times in our application we need to redirect the transfer to a different buffer *before* the transfer has been initiated by the FPGA.
Is it possible to reconfigure UPP receive DMA after it has already been set up without resetting the whole UPP bus? That is, is it possible to modify the UPP DMA Window Address after it has been programmed, but before the transfer has been started, without issuing a reset? And if it is possible, how?
The user guide is very helpful in explaining how the transfers are set up, but, unfortunately, does not contain a lot of information about how to reconfigure and/or modify the settings.
Thank you very much in advance,
Dmitry.
