I'm trying to bring up Linux on a new 66ak2h12 design, loosely based on the K2H-EVM. I have U-Boot from
git://git.ti.com/ti-u-boot/ti-u-boot.git
the boot monitor from
git://git.ti.com/processor-firmware/ks2-boot-monitor.git
and the kernel from
git://git.ti.com/processor-sdk/processor-sdk-linux.git
The ROM boot loader gets U-Boot via the UART (xmodem), U-Boot starts up and downloads the kernel and flattened device tree using TFTP, and the boot up commences. Everything goes fine -- boot log is attached (ignore the panic at the end, which is because I haven't set up a root filesystem yet), except that cores 1-3 fail to come online (core 0 is running, of course). I turned on all the debugging flags, and even added some debuggery of my own, and as far as I can see, it looks like the ARM CorePac power domains start transitioning and never finish (the PDSTAT register indicates that the power domain is stuck in the transition state).
I took a look at the CVDD current, and it looks like it is well within the capabilities of our regulator (about 5 amps out of 13). No alerts are generated on the PMBus.
Can anybody lend me a clue?
initcall: 0c03dbcd
initcall: 0c03fed5
U-Boot 2016.03-00673-g028b7fb-dirty (May 04 2016 - 15:08:45 -0400)
initcall: 0c00dc31
initcall: 0c000c55
CPU: 66AK2Hx SR2.0
initcall: 0c00dd41
I2C: ready
initcall: 0c00dd31
DRAM: initcall: 0c001d85
DDR3 speed 1600
DRAM: 2 GiB (includes reported below)
Clear entire DDR3 memory to enable ECC
initcall: 0c00de75
initcall: 0c00dc4d
initcall: 0c00dc61
initcall: 0c00dc8f
initcall: 0c00dc93
initcall: 0c00dcbd
initcall: 0c00dde1
initcall: 0c00dccd
initcall: 0c00dcd1
initcall: 0c00dce7
initcall: 0c00dd29
initcall: 0c00deb1
initcall: 0c00de59
initcall: 0c00de11
2 GiB
initcall: 0c00dd21
initcall: 0c00ddb5
initcall: 0c00dd8f
initcall: fff3def1
initcall: fff3def5
initcall: 0c00e025 (relocated to fff3e025)
initcall: 0c00dffd (relocated to fff3dffd)
initcall: 0c00df09 (relocated to fff3df09)
initcall: 0c00dfe5 (relocated to fff3dfe5)
initcall: 0c00df0d (relocated to fff3df0d)
initcall: 0c00deed (relocated to fff3deed)
initcall: 0c00dfd3 (relocated to fff3dfd3)
fdtdec_get_int_array: ranges
get_prop_check_min_len: ranges
Looking for 'serial' at 16988, name serial@02530c00
- serial0, /soc/serial@02530c00
Found seq 0
Looking for 'serial' at 17144, name serial@02531000
Not found
initcall: 0c00dfc7 (relocated to fff3dfc7)
initcall: 0c001db9 (relocated to fff31db9)
initcall: 0c03b7a9 (relocated to fff6b7a9)
initcall: 0c013c11 (relocated to fff43c11)
initcall: 0c00dfbd (relocated to fff3dfbd)
fdtdec_get_int: reg-offset: (not found)
fdtdec_get_int: reg-shift: 0x2 (2)
fdtdec_get_int: clock-frequency: (not found)
initcall: 0c00df15 (relocated to fff3df15)
initcall: 0c00df11 (relocated to fff3df11)
initcall: 0c00dfa9 (relocated to fff3dfa9)
NAND: 1024 MiB
initcall: 0c00df61 (relocated to fff3df61)
fdtdec_get_config_int: load-environment
NAND read from offset 100000 failed -74
*** Warning - readenv() failed, using default environment
Destroy Hash Table: fff8b600 table = 00000000
Create Hash Table: N=438
DELETE CANDIDATE: "bootargs"
hdelete: DELETE key "bootargs"
DELETE ERROR ##############################
INSERT: table fff8b600, filled 1/439 rv feef7394 ==> name="bootcmd" value="run init_${boot} init_fw_rd_${boot} get_fdt_${boot} get_mon_${boot} get_kern_${boot} run_mon run_kern"
INSERT: table fff8b600, filled 2/439 rv feef7c7c ==> name="bootdelay" value="2"
INSERT: table fff8b600, filled 3/439 rv feef7434 ==> name="baudrate" value="115200"
INSERT: table fff8b600, filled 4/439 rv feef7ac4 ==> name="arch" value="arm"
INSERT: table fff8b600, filled 5/439 rv feef7858 ==> name="cpu" value="armv7"
INSERT: table fff8b600, filled 6/439 rv feef7fb0 ==> name="board" value="ks2_evm"
INSERT: table fff8b600, filled 7/439 rv feef6fac ==> name="board_name" value="ks2_evm"
INSERT: table fff8b600, filled 8/439 rv feef75c4 ==> name="vendor" value="ti"
INSERT: table fff8b600, filled 9/439 rv feef6750 ==> name="soc" value="keystone"
INSERT: table fff8b600, filled 10/439 rv feef8708 ==> name="loadaddr" value="0x82000000"
INSERT: table fff8b600, filled 11/439 rv feef7c2c ==> name="kernel_addr_r" value="0x82000000"
INSERT: table fff8b600, filled 12/439 rv feef74ac ==> name="fdtaddr" value="0x88000000"
INSERT: table fff8b600, filled 13/439 rv feef8780 ==> name="fdt_addr_r" value="0x88000000"
INSERT: table fff8b600, filled 14/439 rv feef7e0c ==> name="rdaddr" value="0x88080000"
INSERT: table fff8b600, filled 15/439 rv feef7614 ==> name="ramdisk_addr_r" value="0x88080000"
INSERT: table fff8b600, filled 16/439 rv feef6bb0 ==> name="scriptaddr" value="0x80000000"
INSERT: table fff8b600, filled 17/439 rv feef67b4 ==> name="pxefile_addr_r" value="0x80100000"
INSERT: table fff8b600, filled 18/439 rv feef82bc ==> name="bootm_size" value="0x10000000"
INSERT: table fff8b600, filled 19/439 rv feef74d4 ==> name="name_fw_rd" value="k2-fw-initrd.cpio.gz"
INSERT: table fff8b600, filled 20/439 rv feef7e34 ==> name="set_rd_spec" value="setenv rd_spec ${rdaddr}:${filesize}"
INSERT: table fff8b600, filled 21/439 rv feef77b8 ==> name="init_fw_rd_net" value="dhcp ${rdaddr} ${tftp_root}/${name_fw_rd}; run set_rd_spec"
INSERT: table fff8b600, filled 22/439 rv feef8884 ==> name="init_fw_rd_ramfs" value="setenv rd_spec -"
INSERT: table fff8b600, filled 23/439 rv feef7704 ==> name="init_fw_rd_ubi" value="ubifsload ${rdaddr} ${bootdir}/${name_fw_rd}; run set_rd_spec"
INSERT: table fff8b600, filled 24/439 rv feef78f8 ==> name="boot" value="ubi"
INSERT: table fff8b600, filled 25/439 rv feef669c ==> name="addr_mon" value="0x0c5f0000"
INSERT: table fff8b600, filled 26/439 rv feef7ab0 ==> name="args_ubi" value="setenv bootargs ${bootargs} rootfstype=ubifs root=ubi0:rootfs rootflags=sync rw ubi.mtd=ubifs,2048"
INSERT: table fff8b600, filled 27/439 rv feef84ec ==> name="name_fdt" value="k2hk-evm.dtb"
INSERT: table fff8b600, filled 28/439 rv feef849c ==> name="name_mon" value="skern-k2hk.bin"
INSERT: table fff8b600, filled 29/439 rv feef8474 ==> name="name_ubi" value="k2hk-evm-ubifs.ubi"
INSERT: table fff8b600, filled 30/439 rv feef8820 ==> name="name_uboot" value="u-boot-spi-k2hk-evm.gph"
INSERT: table fff8b600, filled 31/439 rv feef6b60 ==> name="name_fs" value="arago-console-image-k2hk-evm.cpio.gz"
INSERT: table fff8b600, filled 32/439 rv feef86e0 ==> name="bootdir" value="/boot"
INSERT: table fff8b600, filled 33/439 rv feef83d4 ==> name="tftp_root" value="/"
INSERT: table fff8b600, filled 34/439 rv feef82a8 ==> name="nfs_root" value="/export"
INSERT: table fff8b600, filled 35/439 rv feef85f0 ==> name="mem_lpae" value="1"
INSERT: table fff8b600, filled 36/439 rv feef7a88 ==> name="mem_reserve" value="512M"
INSERT: table fff8b600, filled 37/439 rv feef6674 ==> name="addr_ubi" value="0x82000000"
INSERT: table fff8b600, filled 38/439 rv feef8370 ==> name="addr_secdb_key" value="0xc000000"
INSERT: table fff8b600, filled 39/439 rv feef8848 ==> name="name_kern" value="zImage"
INSERT: table fff8b600, filled 40/439 rv feef66b0 ==> name="run_mon" value="mon_install ${addr_mon}"
INSERT: table fff8b600, filled 41/439 rv feef8438 ==> name="run_kern" value="bootz ${loadaddr} ${rd_spec} ${fdtaddr}"
INSERT: table fff8b600, filled 42/439 rv feef7128 ==> name="init_net" value="run args_all args_net"
INSERT: table fff8b600, filled 43/439 rv feef68cc ==> name="init_nfs" value="setenv autoload no; dhcp; run args_all args_net"
INSERT: table fff8b600, filled 44/439 rv feef8758 ==> name="init_ubi" value="run args_all args_ubi; ubi part ubifs; ubifsmount ubi:rootfs;"
INSERT: table fff8b600, filled 45/439 rv feef83ac ==> name="get_fdt_net" value="dhcp ${fdtaddr} ${tftp_root}/${name_fdt}"
INSERT: table fff8b600, filled 46/439 rv feef6b10 ==> name="get_fdt_nfs" value="nfs ${fdtaddr} ${nfs_root}/boot/${name_fdt}"
INSERT: table fff8b600, filled 47/439 rv feef6fe8 ==> name="get_fdt_ubi" value="ubifsload ${fdtaddr} ${bootdir}/${name_fdt}"
INSERT: table fff8b600, filled 48/439 rv feef8078 ==> name="get_kern_net" value="dhcp ${loadaddr} ${tftp_root}/${name_kern}"
INSERT: table fff8b600, filled 49/439 rv feef6e44 ==> name="get_kern_nfs" value="nfs ${loadaddr} ${nfs_root}/boot/${name_kern}"
INSERT: table fff8b600, filled 50/439 rv feef7650 ==> name="get_kern_ubi" value="ubifsload ${loadaddr} ${bootdir}/${name_kern}"
INSERT: table fff8b600, filled 51/439 rv feef7b14 ==> name="get_mon_net" value="dhcp ${addr_mon} ${tftp_root}/${name_mon}"
INSERT: table fff8b600, filled 52/439 rv feef73a8 ==> name="get_mon_nfs" value="nfs ${addr_mon} ${nfs_root}/boot/${name_mon}"
INSERT: table fff8b600, filled 53/439 rv feef8118 ==> name="get_mon_ubi" value="ubifsload ${addr_mon} ${bootdir}/${name_mon}"
INSERT: table fff8b600, filled 54/439 rv feef7934 ==> name="get_uboot_net" value="dhcp ${loadaddr} ${tftp_root}/${name_uboot}"
INSERT: table fff8b600, filled 55/439 rv feef7588 ==> name="get_uboot_nfs" value="nfs ${loadaddr} ${nfs_root}/boot/${name_uboot}"
INSERT: table fff8b600, filled 56/439 rv feef7ad8 ==> name="burn_uboot_spi" value="sf probe; sf erase 0 0x80000; sf write ${loadaddr} 0 ${filesize}"
INSERT: table fff8b600, filled 57/439 rv feef73e4 ==> name="burn_uboot_nand" value="nand erase 0 0x100000; nand write ${loadaddr} 0 ${filesize}"
INSERT: table fff8b600, filled 58/439 rv feef7d80 ==> name="args_all" value="setenv bootargs console=ttyS0,115200n8 rootwait=1"
INSERT: table fff8b600, filled 59/439 rv feef86cc ==> name="args_net" value="setenv bootargs ${bootargs} rootfstype=nfs root=/dev/nfs rw nfsroot=${serverip}:${nfs_root},${nfs_options} ip=dhcp"
INSERT: table fff8b600, filled 60/439 rv feef82f8 ==> name="nfs_options" value="v3,tcp,rsize=4096,wsize=4096"
INSERT: table fff8b600, filled 61/439 rv feef74c0 ==> name="get_fdt_ramfs" value="dhcp ${fdtaddr} ${tftp_root}/${name_fdt}"
INSERT: table fff8b600, filled 62/439 rv feef7e5c ==> name="get_kern_ramfs" value="dhcp ${loadaddr} ${tftp_root}/${name_kern}"
INSERT: table fff8b600, filled 63/439 rv feef6c3c ==> name="get_mon_ramfs" value="dhcp ${addr_mon} ${tftp_root}/${name_mon}"
INSERT: table fff8b600, filled 64/439 rv feef70b0 ==> name="get_fs_ramfs" value="dhcp ${rdaddr} ${tftp_root}/${name_fs}"
INSERT: table fff8b600, filled 65/439 rv feef6cf0 ==> name="get_ubi_net" value="dhcp ${addr_ubi} ${tftp_root}/${name_ubi}"
INSERT: table fff8b600, filled 66/439 rv feef81cc ==> name="get_ubi_nfs" value="nfs ${addr_ubi} ${nfs_root}/boot/${name_ubi}"
INSERT: table fff8b600, filled 67/439 rv feef7664 ==> name="burn_ubi" value="nand erase.part ubifs; nand write ${addr_ubi} ubifs ${filesize}"
INSERT: table fff8b600, filled 68/439 rv feef8730 ==> name="init_ramfs" value="run args_all args_ramfs get_fs_ramfs"
INSERT: table fff8b600, filled 69/439 rv feef8230 ==> name="args_ramfs" value="setenv bootargs ${bootargs} rdinit=/sbin/init rw root=/dev/ram0 initrd=0x808080000,80M"
INSERT: table fff8b600, filled 70/439 rv feef7a60 ==> name="no_post" value="1"
INSERT: table fff8b600, filled 71/439 rv feef6d68 ==> name="mtdparts" value="mtdparts=davinci_nand.0:1024k(bootloader)ro,512k(params)ro,-(ubifs)"
INSERT: free(data = feef5a88)
INSERT: done
initcall: 0c00e031 (relocated to fff3e031)
initcall: 0c013c25 (relocated to fff43c25)
initcall: 0c00df57 (relocated to fff3df57)
initcall: 0c0124f9 (relocated to fff424f9)
initcall: 0c001d31 (relocated to fff31d31)
initcall: 0c00089d (relocated to fff3089d)
initcall: 0c00df4d (relocated to fff3df4d)
initcall: 0c00df35 (relocated to fff3df35)
initcall: 0c00df21 (relocated to fff3df21)
Net: SERDES lane 0 initialized
Could not get PHY for ethernet-mdio: addr -1
K2HK_EMAC, K2HK_EMAC1
Error: K2HK_EMAC1 address not set.
, K2HK_EMAC2
Error: K2HK_EMAC2 address not set.
, K2HK_EMAC3
Error: K2HK_EMAC3 address not set.
initcall: 0c00df19 (relocated to fff3df19)
fdtdec_get_config_int: bootdelay
fdtdec_get_config_int: kernel-offset
fdtdec_get_config_int: rootdisk-offset
fdtdec_get_config_string: bootcmd
fdtdec_get_config_int: bootsecure
Hit any key to stop autoboot: 2 0
OJM-SoC> dhcp ${loadaddr}
+ emac_close
+ emac_open
- emac_open
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 192.168.1.3 (1009 ms)
Using K2HK_EMAC device
TFTP from server 192.168.1.1; our IP address is 192.168.1.3
Filename '/uImage'.
Load address: 0x82000000
Loading: *#################################################################
3.6 MiB/s
done
Bytes transferred = 3864496 (3af7b0 hex)
+ emac_close
- emac_close
OJM-SoC> tftpboot ${addr_mon} skern-k2hk.bin
+ emac_close
+ emac_open
- emac_open
Filename 'skern-k2hk.bin'.
Load address: 0xc5f0000
Loading: *####
3.6 MiB/s
done
Bytes transferred = 45056 (b000 hex)
+ emac_close
- emac_close
OJM-SoC> mon_install ${addr_mon}
DEBUG: Message2 from Secure Mode: Core freq - 200000000Hz
K2_BM_15.07-39-g035329c-dirty SoC:k2hk built:13:26:40, May 5 2016
DEBUG: ARMCOREPAC_PID=0x44902300
DEBUG: AINTC_PID=0x44912100
## installed monitor, freq [200000000], status 0
OJM-SoC> tftpboot ${fdtaddr} k2hk-ojm.dtb
+ emac_close
+ emac_open
- emac_open
Filename 'k2hk-ojm.dtb'.
Load address: 0x88000000
Loading: *####
3.4 MiB/s
done
Bytes transferred = 50434 (c502 hex)
+ emac_close
- emac_close
OJM-SoC> bootm ${loadaddr} - ${fdtaddr}
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.1.18-gbbe8cfc-dirty
Created: 2016-05-05 15:05:49 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3864432 Bytes = 3.7 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Loading Device Tree to 8fff0000, end 8ffff501 ... OK
Starting kernel ...
DEBUG: >>>> skern_poweron_cpu(1) >>>>
DEBUG: >>>> before pdstat=0x00020002
DEBUG: >>>> after pdstat=0x08040000
DEBUG: >>>> skern_poweron_cpu(2) >>>>
DEBUG: >>>> skern_poweron_cpu(3) >>>>
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.18-gbbe8cfc-dirty (ch22073@517033-mitll) (gcc version 4.9.3 20150413 (prerelease) (Linaro GCC 4.9-2015.05) ) #3 SMP PREEMPT Thu May 5 11:05:40 EDT 2016
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM
[ 0.000000] Switching physical address space to 0x800000000
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp_common_cma_pool, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000820000000, size 512 MiB
[ 0.000000] Reserved memory: initialized node dsp_reserved_mpm_area, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x000000085f000000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 262144
[ 0.000000] free_area_init_node: node 0, pgdat c078dbc0, node_mem_map debf5000
[ 0.000000] DMA zone: 1520 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 131072 pages, LIFO batch:31
[ 0.000000] HighMem zone: 131072 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 12 pages/cpu @deb96000 s17536 r8192 d23424 u49152
[ 0.000000] pcpu-alloc: s17536 r8192 d23424 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260624
[ 0.000000] Kernel command line: console=ttyS0,115200n8 debug earlyprintk
[ 0.000000] log_buf_len individual max cpu contribution: 4096 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 12288 bytes
[ 0.000000] log_buf_len min size: 16384 bytes
[ 0.000000] log_buf_len: 32768 bytes
[ 0.000000] early log buf free: 14264(87%)
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 1006980K/1048576K available (5178K kernel code, 344K rwdata, 1888K rodata, 316K init, 174K bss, 17020K reserved, 24576K cma-reserved, 507904K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06eeb68 (7067 kB)
[ 0.000000] .init : 0xc06ef000 - 0xc073e000 ( 316 kB)
[ 0.000000] .data : 0xc073e000 - 0xc0794014 ( 345 kB)
[ 0.000000] .bss : 0xc0797000 - 0xc07c29f0 ( 175 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 200.00MHz (virt).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000011] Switching to timer-based delay loop, resolution 5ns
[ 0.000165] keystone timer clock @200000000 Hz
[ 0.000386] Console: colour dummy device 80x30
[ 0.000401] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=2000000)
[ 0.000411] pid_max: default: 4096 minimum: 301
[ 0.000472] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000479] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000919] Initializing cgroup subsys blkio
[ 0.000931] Initializing cgroup subsys devices
[ 0.000941] Initializing cgroup subsys freezer
[ 0.000958] CPU: Testing write buffer coherency: ok
[ 0.001133] /cpus/cpu@0 missing clock-frequency property
[ 0.001160] /cpus/cpu@1 missing clock-frequency property
[ 0.001186] /cpus/cpu@2 missing clock-frequency property
[ 0.001212] /cpus/cpu@3 missing clock-frequency property
[ 0.001221] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001259] Setting up static identity map for 0x800082c0 - 0x800083cc
[ 1.070890] CPU1: failed to come online
[ 2.102239] CPU2: failed to come online
[ 3.134101] CPU3: failed to come online
[ 3.134134] Brought up 1 CPUs
[ 3.134148] SMP: Total of 1 processors activated (400.00 BogoMIPS).
[ 3.134161] CPU: All CPU(s) started in SVC mode.
[ 3.134721] devtmpfs: initialized
[ 3.165292] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 3.165929] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 3.166769] pinctrl core: initialized pinctrl subsystem
[ 3.167272] NET: Registered protocol family 16
[ 3.169659] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 3.196386] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.197314] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.198052] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.198614] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.199166] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.199810] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.200362] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.201177] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 3.221333] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 3.221347] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 3.258767] vgaarb: loaded
[ 3.259293] SCSI subsystem initialized
[ 3.260234] usbcore: registered new interface driver usbfs
[ 3.260433] usbcore: registered new interface driver hub
[ 3.260750] usbcore: registered new device driver usb
[ 3.267840] Switched to clocksource arch_sys_counter
[ 3.370417] NET: Registered protocol family 2
[ 3.371140] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 3.371180] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 3.371243] TCP: Hash tables configured (established 4096 bind 4096)
[ 3.371308] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 3.371332] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 3.371592] NET: Registered protocol family 1
[ 3.372158] RPC: Registered named UNIX socket transport module.
[ 3.372173] RPC: Registered udp transport module.
[ 3.372186] RPC: Registered tcp transport module.
[ 3.372199] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 3.372222] PCI: CLS 0 bytes, default 64
[ 3.372753] CPU PMU: Failed to parse /pmu/interrupt-affinity[0]
[ 3.372803] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 3.374662] platform alarmtimer: set dma_pfn_offset00780000
[ 3.376355] futex hash table entries: 16 (order: -2, 1024 bytes)
[ 3.416646] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 3.416839] ntfs: driver 2.1.32 [Flags: R/O].
[ 3.417749] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 3.422876] NET: Registered protocol family 38
[ 3.422959] bounce: pool size: 64 pages
[ 3.423356] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 3.423375] io scheduler noop registered
[ 3.423392] io scheduler deadline registered
[ 3.423446] io scheduler cfq registered (default)
[ 3.423744] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28
[ 3.427803] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192
[ 3.432148] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek f01c0000, reg_status f01e2000, reg_config f01e4000, reg_region f01e6000, reg_push f0200000, reg_pop f0240000
[ 3.432169] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192
[ 3.432445] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek f0280000, reg_status f01e8400, reg_config f01ea000, reg_region f01ec000, reg_push f02c0000, reg_pop f0300000
[ 3.433067] keystone-navigator-qmss soc:qmss@2a40000: failed to get firmware for pdsp pdsp0
[ 3.433185] keystone-navigator-qmss soc:qmss@2a40000: failed to get firmware for pdsp pdsp3
[ 3.433303] keystone-navigator-qmss soc:qmss@2a40000: failed to get firmware for pdsp pdsp7
[ 3.435647] keystone-navigator-qmss soc:qmss@2a40000: pdsp id 0 not started for range acc-low-0
[ 3.437361] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
[ 3.437643] keystone-navigator-dma soc:knav_dmas@0: DMA dma_xgbe registered 48 logical channels, flows 32, tx chans: 16, rx chans: 16
[ 3.647220] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.647390] platform serial8250: set dma_pfn_offset00780000
[ 3.654031] console [ttyS0] disabled
[ 3.654109] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 12500000) is a 16550A
[ 4.529398] console [ttyS0] enabled
[ 4.535691] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 12500000) is a 16550A
[ 4.557333] loop: module loaded
[ 4.561236] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[ 4.573133] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0
[ 4.579939] spi_davinci 21000400.spi: Controller at 0xf026a400
[ 4.586612] spi_davinci 21000600.spi: Controller at 0xf026c600
[ 4.593451] spi_davinci 21000800.spi: Controller at 0xf026e800
[ 4.602114] Division by zero in kernel.
[ 4.605975] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.18-gbbe8cfc-dirty #3
[ 4.613233] Hardware name: Keystone
[ 4.616756] [<c0016198>] (unwind_backtrace) from [<c0012afc>] (show_stack+0x10/0x14)
[ 4.624543] [<c0012afc>] (show_stack) from [<c04e99d8>] (dump_stack+0x88/0x9c)
[ 4.631806] [<c04e99d8>] (dump_stack) from [<c0291910>] (Ldiv0+0x8/0x10)
[ 4.638546] [<c0291910>] (Ldiv0) from [<c0370f94>] (__davinci_mdio_reset+0x64/0x80)
[ 4.646245] [<c0370f94>] (__davinci_mdio_reset) from [<c0370fc0>] (davinci_mdio_reset+0x10/0x94)
[ 4.655077] [<c0370fc0>] (davinci_mdio_reset) from [<c036f9d8>] (mdiobus_register+0xb8/0x180)
[ 4.663646] [<c036f9d8>] (mdiobus_register) from [<c03714f8>] (davinci_mdio_probe+0x1f0/0x420)
[ 4.672303] [<c03714f8>] (davinci_mdio_probe) from [<c0318edc>] (platform_drv_probe+0x44/0xa4)
[ 4.680957] [<c0318edc>] (platform_drv_probe) from [<c0317a6c>] (driver_probe_device+0x17c/0x2bc)
[ 4.689875] [<c0317a6c>] (driver_probe_device) from [<c0317c7c>] (__driver_attach+0x8c/0x90)
[ 4.698357] [<c0317c7c>] (__driver_attach) from [<c0315fcc>] (bus_for_each_dev+0x68/0x9c)
[ 4.706577] [<c0315fcc>] (bus_for_each_dev) from [<c0317210>] (bus_add_driver+0x14c/0x1f4)
[ 4.714883] [<c0317210>] (bus_add_driver) from [<c0318030>] (driver_register+0x78/0xf8)
[ 4.722928] [<c0318030>] (driver_register) from [<c00096f0>] (do_one_initcall+0x8c/0x1d8)
[ 4.731147] [<c00096f0>] (do_one_initcall) from [<c06efdd0>] (kernel_init_freeable+0x144/0x1e4)
[ 4.739891] [<c06efdd0>] (kernel_init_freeable) from [<c04e61fc>] (kernel_init+0xc/0xe8)
[ 4.748023] [<c04e61fc>] (kernel_init) from [<c000f368>] (ret_from_fork+0x14/0x2c)
[ 4.798245] davinci_mdio 2090300.mdio: davinci mdio revision 1.5
[ 4.804283] davinci_mdio 2090300.mdio: no live phy, scanning all
[ 4.822252] davinci_mdio: probe of 2090300.mdio failed with error -5
[ 5.879164] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
[ 6.290481] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
[ 6.298508] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 6.304928] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 6.313292] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x00210010
[ 6.322114] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000
[ 6.328427] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 6.335250] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.342578] usb usb1: Product: xHCI Host Controller
[ 6.347481] usb usb1: Manufacturer: Linux 4.1.18-gbbe8cfc-dirty xhci-hcd
[ 6.354373] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 6.360538] hub 1-0:1.0: USB hub found
[ 6.364558] hub 1-0:1.0: 1 port detected
[ 6.369401] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 6.375330] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 6.383360] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 6.391800] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 6.398693] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.405951] usb usb2: Product: xHCI Host Controller
[ 6.410983] usb usb2: Manufacturer: Linux 4.1.18-gbbe8cfc-dirty xhci-hcd
[ 6.417718] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 6.423859] hub 2-0:1.0: USB hub found
[ 6.427930] hub 2-0:1.0: 1 port detected
[ 6.433608] usbcore: registered new interface driver usb-storage
[ 6.440635] mousedev: PS/2 mouse device common for all mice
[ 6.447070] i2c /dev entries driver
[ 6.452732] davinci-wdt 22f0080.wdt: heartbeat 60 sec
[ 6.461791] usbcore: registered new interface driver usbhid
[ 6.467392] usbhid: USB HID core driver
[ 6.474933] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xb3
[ 6.481481] nand: Micron 30000000.nand
[ 6.485250] nand: bus width 8 instead 16 bit
[ 6.489612] nand: No NAND device found
[ 6.493875] davinci_nand: probe of 30000000.nand failed with error -22
[ 6.501694] platform oprofile-perf.0: set dma_pfn_offset00780000
[ 6.508739] oprofile: using timer interrupt.
[ 6.513068] Netfilter messages via NETLINK v0.30.
[ 6.518082] nf_conntrack version 0.5.0 (16118 buckets, 64472 max)
[ 6.525215] ctnetlink v0.93: registering with nfnetlink.
[ 6.533303] ipip: IPv4 over IPv4 tunneling driver
[ 6.539433] gre: GRE over IPv4 demultiplexor driver
[ 6.544592] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 6.550440] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully
[ 6.556870] arp_tables: (C) 2002 David S. Miller
[ 6.561745] Initializing XFRM netlink socket
[ 6.566068] NET: Registered protocol family 17
[ 6.570631] NET: Registered protocol family 15
[ 6.575104] 8021q: 802.1Q VLAN Support v1.8
[ 6.579450] Registering SWP/SWPB emulation handler
[ 6.773068] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 6.780661] Please append a correct "root=" boot option; here are the available partitions:
[ 6.789290] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 6.797597] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.1.18-gbbe8cfc-dirty #3
[ 6.804856] Hardware name: Keystone
[ 6.808373] [<c0016198>] (unwind_backtrace) from [<c0012afc>] (show_stack+0x10/0x14)
[ 6.816160] [<c0012afc>] (show_stack) from [<c04e99d8>] (dump_stack+0x88/0x9c)
[ 6.823422] [<c04e99d8>] (dump_stack) from [<c04e7810>] (panic+0xa0/0x200)
[ 6.830336] [<c04e7810>] (panic) from [<c06f0190>] (mount_block_root+0x18c/0x228)
[ 6.837858] [<c06f0190>] (mount_block_root) from [<c06f0334>] (mount_root+0x108/0x110)
[ 6.845816] [<c06f0334>] (mount_root) from [<c06f0494>] (prepare_namespace+0x158/0x19c)
[ 6.853863] [<c06f0494>] (prepare_namespace) from [<c06efe60>] (kernel_init_freeable+0x1d4/0x1e4)
[ 6.862780] [<c06efe60>] (kernel_init_freeable) from [<c04e61fc>] (kernel_init+0xc/0xe8)
[ 6.870914] [<c04e61fc>] (kernel_init) from [<c000f368>] (ret_from_fork+0x14/0x2c)
[ 6.878536] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
