Dear Champs,
Could you please let me know if power-down sequence is needed for 66AK2G02?
I could not find it in datasheet, and want to get your confirm on this.
Thanks and Best Regards,
SI.
Dear Champs,
SI.
Hi Sung-IL,
As was stated in the other replies, the power down sequence should be the reverse of the power up sequence for the K2G. I will check and find out why it isn't listed in the data sheet. While a controlled power down isn't always possible the reverse order should be implemented when the supplies are powered down in a controlled fashion.
Bill
