Other Parts Discussed in Thread: TMS320C6670, SYSBIOS
Champs,
Customer requires clarifications wrt few c6655 device errata:
1. Advisory 13: Single MFENCE issue. Customer does not have any assembly code of their own, uses IBL version 1.0.0.14, and the TI compiler version v7.4.11. Has this issue been taken care of in is these versions?
2. Advisory 14: Read Exception and Data Corruption Issue. Question: Is TI platform SW supposed to take care of disabling PFX bits in MARs 12-15? If not - where this should be done (boot loader/application startup)?
3. Usage Note 13: Revised PLL Programming Sequence Usage Note. Customer code is based on TI IBL version 1.0.0.14 Nov 2011, and application code makes use of CSL Revision: 01.00.00.05. Can you confirm if this usage note is implemented in the above versions?
thank you!
Michael
