HI,
Please provide me the IBIS model for 66AK2H14 SOC. The one already present in the TI website can not be used, it will give some error.
Thanks & Regards,
Madhu
HI,
Thanks & Regards,
Madhu
Madhu,
This is the first that we have heard of an IBIS model on the product page causing an error. Can you post the error log so that we can debug it?
Tom
Hi Tom,
Please find the error message below.
Madhu.
C:\MentorGraphics\9.2HL\SDD_HOME\hyperlynx64\LIBS\66ak2h14_r1p4.ibs: Warning : at line 17517 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3_ODT120: ;; Warning: Current (0.00525972) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (-0.00506797) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00521263) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 17746 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3_ODT40: ;; Warning: Current (0.0152607) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0139601) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0163546) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 17975 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3_ODT60: ;; Warning: Current (0.00999364) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00919041) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0111721) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 33645 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3L_ODT120: ;; Warning: Current (-0.00500232) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 33870 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3L_ODT40: ;; Warning: Current (0.0129819) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0122152) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0149213) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 34095 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDDRIO_D3FP3L_ODT60: ;; Warning: Current (0.00880946) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00814336) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00973351) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 49789 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3_ODT120: ;; Warning: Current (0.00526049) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (-0.00506856) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00521274) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 50018 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3_ODT40: ;; Warning: Current (0.0152607) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0139602) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0163546) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 50247 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3_ODT60: ;; Warning: Current (0.00999364) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0091909) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0111721) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 65917 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3L_ODT120: ;; Warning: Current (-0.00500232) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 66142 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3L_ODT40: ;; Warning: Current (0.0129819) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0122152) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0149212) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Warning : at line 66367 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Messages for model PDIFF_D3FF3L_ODT60: ;; Warning: Current (0.00881084) of summed typical power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.00814358) of summed minimum power and ground clamp curves exceed 0.005 amps in the range between power and ground. ;; Warning: Current (0.0097348) of summed maximum power and ground clamp curves exceed 0.005 amps in the range between power and ground. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gv used by the series pin mapping from pin AW35 to pin AW34 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gv used by the series pin mapping from pin AW32 to pin AW31 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gv used by the series pin mapping from pin AV34 to pin AV33 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gv used by the series pin mapping from pin AR39 to pin AR38 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gv used by the series pin mapping from pin A25 to pin B25 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gh used by the series pin mapping from pin AK3 to pin AL3 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gh used by the series pin mapping from pin B37 to pin C37 of component 66ak2hxx does not exist in this file. Error : at line 213344 in file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs : Pin model s_iclkrx0p9gh used by the series pin mapping from pin AL2 to pin AM2 of component 66ak2hxx does not exist in this file. Error : Parse failed on file C:/MentorGraphics/9.2HL/SDD_HOME/hyperlynx64/LIBS/66ak2h14_r1p4.ibs.
Hi Madhu,
The model for s_iclkrx0p9gv is defined by the [Model Selector] statement on line 1866 as either s_iclkrx0p9gv_encmint_0 for external common mode or s_iclkrx0p9gv_encmint_1 for internal common mode. You need to set up your tool to define the model needed. We have had reports from other customers that their tool doesn't handle the [Model Selector] correctly for series pin mapping definitions. The work-around is to edit the IBIS file and replace the model selector name with the actual model name in the [Series Pin Mapping] section. You should also report the bug in your tool to the tool manufacturer.
Bill
