Part Number: TCI6630K2L
I am trying to run 15 MHz in AID RFSDK mode. However, there are no files for 15 MHz in RFSDK (Configuration, LTE-PHY etc.)
So we tried to modify the 20 MHz files, by changing the sampling rate from 30P72 to 23P04. However, since there are no specific target configuration (tgtcfg) files and (.out) for 15 MHz provided , we used the corresponding files from 20 MHz.
However, we are unable to run with 15 MHz. So is 15 MHz supported in RFSDK?
If yes, then could you please provide the required RFSDK Files for 15 MHz.
Ashish
