Also if possible describe the process to generate the .bin file for bootloader image directly from EMIF16 NOR flash.
Sripad
Sripad
Sripad,
I have attached the binary from my 64bit Windows 7 machine. Can you try this out
7026.btoccs.zip
Have you tried to rebuild the utility on your machine. We have not seen any other reports of such issue so i am a little surprised that you are running into this issue.
Rahul
Rahul,
I'm able to generate the hex or boot table with these utilities on my desktop under 64bit environment.
Still could not test these output files, i need to update my command files. Thank you for the reply and the updated files.
Sripad J
