Part Number: TCI6630K2L
We would like to stream the ADC data around the DFE in "DFE RX Bypass" mode.
We are using dfeTest1 on the Keystone Arm Linux processor successfully as a starting point.
My goal is to modify dfeTest1 so that it puts the DFE/JESD into RX bypass mode, so that we can receive ADC data from the AFE board. Does this seem like a reasonable approach?
We have the RFSDK package from TI, but that looks like a significant amount of effort to get all set up in the TI Keystone eval board. Do we need to do that? Would you recommend that we spend the time to get that all set up and running on the Keystone eval board?
Is there some example code that receives data in from the JESD bus (as opposed to using internal loopback) and configures Rx Bypass mode?
Is there DFE register-level documentation for how to set up Rx Bypass mode? The only DFE documentation I have been able to find is the few pages in the main K2L data sheet, the Keystone II DFE User's Guide, and the doxygen comments in the dfe source code.
Greg Johnson
