My customer wants to know Input capacitance information for 66AK2G12 pins. I checked the datasheet, but i could not find the spec. Do you have any suggestions ?
NK
NK
Hi NK,
I'm not sure what you are asking for. Are you trying to define the bypass capacitance needed for the power delivery network?
Regards, Bill
Hi NK,
Based on your question it sounds like you are planning on driving multiple clock inputs with a single buffer. I would recommend you avoid this. Reflections on clock signals can cause noise on the clock input to the device creating false edges and, possibly, false clock inputs into your part. I strongly suggest you drive each clock with it's own buffer. Clock distribution parts are available that will keep these clock edges close.
Regards, Bill
Hi NK,
Those clocks use standard LVCMOS buffers. The load capacitance is 4pF.
Regards, Bill
