• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » DM36x IPNC V2.6 ActiveX crashing browser when audio is enabled
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
tek4
Posted by tek4
on Apr 05 2011 10:15 AM
Intellectual290 points
Ever since the new GoDB based GUI was released for the TI IPNC Dm36x, audio crashes the ActiveX on Windows 7.
This issue is still present in the latest 2.6 release, both in the distributed binaries and recompiled code.
It does not happen on Windows XP.
To reproduce the problem, use Windows 7 to view IPNC with all defaults except audio enabled.
It will show video and audio, however upon the first click in the user interface to any of the menus the browser will crash.
This happens on both IE 8 and IE 9, and on computers from different manufacturers, and with distributed IPNC binaries or recompiled sources.
So far we only tried Windows 7 32 bit.
Any solution ?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Raghu Kudva
    Posted by Raghu Kudva
    on Apr 06 2011 02:19 AM
    Expert6665 points
    Hi, We haven’t tested the ActiveX control with Audio On in Windows 7. But earlier when we tried without audio, the application was running without any crash issue in Windows 7 with IE 8 browser. Regards, Raghu
    Please mark this reply as Verify Answer on this post if it answers the question.
    Report Abuse
    • Reply
  • tek4
    Posted by tek4
    on Apr 06 2011 09:21 AM
    Thank you for your response. Yes, it is correct that it works without audio on Windows 7. And if you don't click on any part of the user interface, it even works with audio. But as mentioned the first click on any menu causes Internet Explorer to crash when using Windows 7 and audio enabled. When viewed on XP the same camera works fine. Perhaps the problem is related to the stopping and restarting the ActiveX. Different GUI menus have their own small preview window, and on XP the audio has a short pause when you click on different menus. Unfortunately Internet Explorer on Windows7 does not seem to survive this transition from one preview window to another. This problem seems very consistent. We now tried Windows 7 computers from 4 different manufacturers. The end result is that we cannot effectively demonstrate the full functionality on current computers and have to use old XP boxes. Any help from the GUI developers would be appreciated.
    Report Abuse
    • Reply
  • tek4
    Posted by tek4
    on Apr 12 2011 18:33 PM
    Raghu, any chance that you or someone else at TI could check if they see the same issue with audio on Windows 7 ?
    It would be surprising if nobody else ever found this issue. Also would be surprising if we are the only ones seeing this, since we tried a number of windows 7 computers from different manufacturers, and also a number of different IPNC cameras.
    When audio is enabled one of the next few clicks in the user interface crashes Intenernet Explorer 8 or 9.
    Report Abuse
    • Reply
  • rulphie
    Posted by rulphie
    on May 28 2011 10:48 AM
    Prodigy110 points
    I am seeing the same issue with audio on Windows 7.
    Thanks.
    Report Abuse
    • Reply
  • Raghu Kudva
    on May 28 2011 11:20 AM
    Expert6665 points
    Currently, the activeX plugin is not fully supported for windows7. This was developed for winxp for IE version 7or above.
    Raghu
    Report Abuse
    • Reply
  • tek4
    Posted by tek4
    on May 28 2011 12:57 PM
    Raghu, maybe TI management could consider the priority of this bug. If end users are foced to use only obsolete PCs it would really limit the commercial appeal and success of the DM368 IPNC platform. Thanks
    Report Abuse
    • Reply
  • bioz
    Posted by bioz
    on Sep 27 2011 20:50 PM
    Expert1495 points
    I also got this bug. I think this one should be a serious issue. I have tried to pass over this but nothing new until now.
    Report Abuse
    • Reply
  • rulphie
    Posted by rulphie
    on Dec 14 2011 01:39 AM
    Prodigy110 points
    any news with this one?
    thanks,
    rulphie
    Report Abuse
    • Reply
  • Raghu Kudva
    on Dec 22 2011 08:40 AM
    Expert6665 points
    win7fix.zip
    All,
    Please use the attached fix for this and let us know the feedback
    GUI Version is 2.0.29 with the ActiveX Control Version 2.0.0.9, you can verify in support page.
    Raghu
    Report Abuse
    • Reply
  • Raghu Kudva
    on Jan 04 2012 09:50 AM
    Expert6665 points
    win7fix.zip
    Attaching the windows7 fix for IPNC RDK GUI, please test this and let us know the feedback.
    One need to extract this at ipnc_app\webdata\gui folder in their codebase
     Following are the versions of this patch:
    • godbATL.dll version 1.0.0.19
    • gffx.dll version 2.0.0.10
    • GUI version 2.0.30
    Raghu
    Report Abuse
    • Reply
  • bioz
    Posted by bioz
    on Jan 08 2012 22:57 PM
    Expert1495 points
    must I update both GODB interface and ACtiveX? I am using a custom GODB, so is it ok if I just replace my old video activex by new one here?
    Report Abuse
    • Reply
  • Raghu Kudva
    on Jan 12 2012 02:26 AM
    Expert6665 points
    OK, in that case you can replace the activeX player and check. Let us know your inputs on this
    Raghu
    Report Abuse
    • Reply
  • bioz
    Posted by bioz
    on Jan 13 2012 01:06 AM
    Expert1495 points
    for the previous version of video activex controls, it worked well except window 7 + micro on + live view page -> crash. The updated version have not got the same problem with previous one but it look like this one is not stable in common case. Sometime my IE was crashed. I have already checked this for Winxp, 7, vista, the result is same.
    thanks
    Report Abuse
    • Reply
  • Lai Justin
    Posted by Lai Justin
    on Apr 23 2012 20:48 PM
    Prodigy20 points
    Could be provided the fix part source code? Because I want compile custom activex object(gffx.dll). Thanks!
    GoDB Activex
    Report Abuse
    • Reply
  • bioz
    Posted by bioz
    on Apr 23 2012 20:56 PM
    Expert1495 points
    At the current time, the version 3.0 for IPNC has already released. I also tested the activex and this error was fixed. You can contact to appro FTP for the downloading.
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
