• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » The camera MT9D131 can not communicate with the board DM365.
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Mingming Chen
Posted by Mingming Chen
on Jun 06 2011 03:38 AM
Intellectual310 points
      I am the beginner of programmation of DM365, now I have a problem that my boss demande me to write a driver of camera MT9D131, now I can successfully register this camera and can read and write the registers in the camera. I have finish my first version of driver with only the fonction ".init  .set_fmt   .try_fmt   .s_stream", but when I use the demo function to test the driver, the demo "encode" reply to me that "No camera was connected", I do not know what is the problem.
      My question is:
             1.Because I have fused the camera by myself, so I am not sure this is correct, the connection is like this:
                 MT9D131                                   DM365(interface of image)
                  DOUT0...3          ->                         DDC-DATA12...15
                  DOUT4...7          ->                         DDC-DATA0...3
                  I2C...DATA         ->                          I2C...DATA
                  I2C...CLK        ->                             I2C...CLK
                  V_Valide            ->                          CCD-VSYNC
                  H_Valide            ->                         CCD_HSYNC
                  RESET               ->                          CCD_DDSRST
                  PCLK                  ->                          PCLK
                   EXTCLK            ->                          SP14_SD1_GPIO_MD2_CONN(Clock1)
              2.Have you any reference about the programmation of DM365, the code of demo is too complicated for me to understande
              3. My code of certaine fonction is like this, thank you very much.
                   static int mt9d131_init(struct v4l2_subdev *sd, u32 val)
    int ret;
    struct i2c_client *client = v4l2_get_subdevdata(sd);
    ret=pll_disable(client);
    if(ret<0)
        return -EIO;
    //Perform MCU reset
    ret=change_page(client,1);
    if(ret<0)
        return -EIO;
    ret=reg_write(client,MT9D131_MCU_BOOTMODE,0x0501);
    if(ret<0)
        return -EIO;
    //Enable Reset
    if(ret<0)
        return -EIO;
    ret=reg_write(client,MT9D131_RESET_LOGICIEL,0x0021);
    if(ret<0)
        return -EIO;
    //Disable Reset,ignore the pin Standby
    ret=reg_write(client,MT9D131_RESET_LOGICIEL,0x00A0);
    if(ret<0)
        return -EIO;
    msleep(20);
    //Enable PLL
    return pll_enable(client,18,8,2)>0?0:-EIO;
static int mt9d131_s_stream(struct v4l2_subdev *sd, int enable)
    int ret;
    //Change mode to capture
    if(change_mode(client,1)<0)
        return -EIO;
    //Enable the output
    if (enable) {
        if (driver_write(client,MT9D131_ID_SEQ,MT9D131_SEQ_CMD,2,1) < 0)
            return -EIO;
    } else {
    //Disable the output
        if (driver_write(client,MT9D131_ID_SEQ,MT9D131_SEQ_CMD,1,1) < 0)
            return -EIO;
    return 0;
static int mt9d131_set_fmt(struct v4l2_subdev *sd,struct v4l2_format *f)
    int i,ret;
    int flag=0;
    struct v4l2_pix_format *pix = &f->fmt.pix;
    for(i=0;i<mt9d131_num_formats;i++)
        if(pix->pixelformat==mt9d131_formats[i].pixelformat)
            //bypass the JPEG
            ret=driver_write(client,MT9D131_ID_MODE,MT9D131_MODE_CONFIG,0x30,1);
            switch(mt9d131_formats[i].index){
            case 0://When output of the format match the YUV
                ret=driver_clear(client,MT9D131_ID_MODE,MT9D131_OUT_FORMATB,0x21,1);
                break;
            case 1://When output of the format match the RGB
                ret=driver_write(client,MT9D131_ID_MODE,MT9D131_OUT_FORMATB,0x20,1);
                break;
            case 2://When output of the format match the JPEG
                ret=driver_write(client,MT9D131_ID_MODE,MT9D131_MODE_CONFIG,0x10,1);//Allow the JPEG in context B
                ret=driver_write(client,MT9D131_ID_JPEG,MT9D131_JPEG_FORMAT,0,1);
            printk("Use %s.\n",mt9d131_formats[i].description);
            flag=1;
            if(ret<0)
                printk("Out put register error\n");
                return ret;
            break;
    if(flag==0)
        return -EIO;
    if(pix->width<=MT9D131_MAX_WIDTHB&&pix->height<=MT9D131_MAX_HEIGHTB)//Change the size of window
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_OUTPUT_WIDTHB,pix->width,0);
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_OUTPUT_HEIGHTB,pix->height,0);
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_CROP_X0B,0,0);
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_CROP_X1B,pix->width,0);
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_CROP_Y0B,0,0);
        ret=driver_write(client,MT9D131_ID_MODE,MT9D131_CROP_Y1B,pix->width,0);
        if(ret<0)
            return ret;
    else
        return -EIO;
    ret=change_mode(client,1);
    ret=driver_write(client,MT9D131_ID_SEQ ,MT9D131_SEQ_CMD,5,1);//Refresh the register
    ret=driver_write(client,MT9D131_ID_SEQ,MT9D131_SEQ_CMD,2,1);//Begin to start capture
    return ret<0?ret:0;
static int mt9d131_try_fmt(struct v4l2_subdev *sd,struct v4l2_format *f)
    int ret,i;
    int flag=0;
            flag=1;
            break;
    if(!flag)
        pix->pixelformat=mt9d131_formats[0].pixelformat;
    if(pix->width>MT9D131_MAX_WIDTHB)
        pix->width=MT9D131_MAX_WIDTHB;
    if(pix->width>MT9D131_MAX_HEIGHTB)
        pix->width=MT9D131_MAX_HEIGHTB;
    pix->width &= ~0x01; /* has to be even */
    pix->height &= ~0x01; /* has to be even */
    return 0;
DM365 driver MT9D131 programme
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Nagabhushana
    Posted by Nagabhushana
    on Jun 06 2011 04:52 AM
    Expert4685 points
    Mingming Chen,
    Mingming Chen
    which demo you are referring to?
    Nagabhushana
    Does this help in finding the answer? If not, please provide more info. If it helps, please click the Verify Answer button below.
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 06 2011 07:49 AM
    The demo of DVSDK3.xxxxxxxxxx
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 06 2011 08:10 AM
    Expert4685 points
    I assume that you are referring to kernel source code which comes with DVSDK. In that case, referring sensor drivers(for mt9p031/mt9t031) in it is the easiest way to develop driver for your sensor. Also, you can check if driver is already there for your sensor in open source.
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 06 2011 08:39 AM
    But, my probleme is that I have only the MT9D131,and is anyone knows how the interface VPFE work, for example, now my connection is
    DOUT[0...7](camera) <===========>CCD_DATA[12....15,0....3]<==================>YIN[0.....7](DM365)
    Is this right?
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 07 2011 01:42 AM
    Expert4685 points
    Mingming Chen,
    Please refer to dm36x VPFE user guide section 2 to understand how to interface ISIF with sensor.
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 07 2011 08:02 AM
    My probleme now is that my connection is D_Out[0....7] to Yin[0....7], the user guide say that whether use Yin or Cin for the 8 bit YCbCr input is depend on YCSWP, but I do not know this value is 1 or 0. I have already change the code in board-dm365-evm.c like this:
            .module_name = "mt9d131",
            .is_camera = 1,
            .grp_id = VPFE_SUBDEV_MT9D131,
            .num_inputs = ARRAY_SIZE(mt9t031_inputs),
            .inputs = mt9td131_inputs,
            .ccdc_if_params = {
                .if_type = VPFE_YCBCR_SYNC_8,
                .hdpol = VPFE_PINPOL_POSITIVE,
                .vdpol = VPFE_PINPOL_POSITIVE,
            .board_info = {
                I2C_BOARD_INFO("mt9d131", 0xBA>>1),
                /* this is for PCLK rising edge */
                .platform_data = (void *)1,
    but I still do not know whether I should connect to Yin or Cin
    Furthuermore now I can already use the I2C to communicate with the registers but when I lance the demo encode the result is
    Failed to detect video standard, video input connected?
    In the Capture.c of demo encoder, I can see this phrase:
    if(Capture_detectVideoStd(NULL,&videoStd,&cAttrs)<0)
             ERR("Failed to detect video standard,video input connected?\n");
     My question is
    1. By default, we use Yin or Cin for 8 bits input?
    2. My bootargs for using the camera is ' ................video=davincifb:vid0=OFF:vid1=OFF:osd0=720x576x16,2025K dm365_imp.oper_mode=0 vpfe_capture.interface=1 vpfe_capture.bufsize=4147200 davinci_enc_mngr.ch0_mode=1080-30I'  Is this right? Or there is any reference for me.
    3. How the function Capture_detectVideoStd works,
    Thank you very much
    DM365 VPFE daVinci dm355 MT9D131
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 07 2011 08:34 AM
    Expert4685 points
    In the board file, do you see support for any sensor like mt9p031/mt9t031? You can use that code as a reference in that case.
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 07 2011 08:42 AM
    I have already write a driver of MT9D131, but the probleme is when I lance the demo DMAI_DEBUG=2 , Capture says "can not open /dev/video0", but my camera have already registered as a sub_device of vpfe,
    v4l2_sub device MT9D131 registered!
    So now I can not fix my probleme
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 07 2011 09:24 AM
    Expert4685 points
    Can you please provide all the debug/print messages starting from linux kernel booting till application spits out error?
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 07 2011 10:47 AM
    You can also read the code of my driver if you want
    Starting kernel ...
    Uncompressing Linux.............................................................
    Linux version 2.6.32-rc2-davinci1 (administrateur@ubuntu) (gcc version 4.3.3 (S0
    CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    CPU: VIVT data cache, VIVT instruction cache
    Machine: DaVinci DM365 EVM
    Memory policy: ECC disabled, Data cache writeback
    DaVinci dm365_rev1.2 variant 0x8
    Clocks: enable vpss_dac at 243000000 Hz
    Clocks: enable arm_clk at 297000000 Hz
    Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 15240
    Kernel command line: mem=60M console=ttyS0,115200n8 root=/dev/nfs rw nfsroot=190
    PID hash table entries: 256 (order: -2, 1024 bytes)
    Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Memory: 60MB = 60MB total
    Memory: 56276KB available (3968K code, 387K data, 144K init, 0K highmem)
    SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    Hierarchical RCU implementation.
    NR_IRQS:245
    Clocks: enable timer0 at 24000000 Hz
    Console: colour dummy device 80x30
    Calibrating delay loop... 147.86 BogoMIPS (lpj=739328)
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    Clocks: enable gpio at 121500000 Hz
    DaVinci: 8 gpio irqs
    NET: Registered protocol family 16
    Clocks: enable uart0 at 24000000 Hz
    Clocks: enable uart1 at 121500000 Hz
    davinci_serial_init:97: failed to get UART2 clock
    Clocks: enable clkout1 at 24000000 Hz
    CLOCK : Clkout1 is ON
    Clocks: enable aemif at 121500000 Hz
    Reset to high
    EVM: HD imager video input
    bio: create slab <bio-0> at 0
    DM365 IPIPE initialized in Continuous mode
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    Clocks: enable i2c at 24000000 Hz
    pca9543a_probe
    vpss vpss: dm365_vpss vpss probed
    vpss vpss: dm365_vpss vpss probe success
    dm365_afew_hw_init
    ch0 default output "COMPOSITE", mode "NTSC"
    VPBE Encoder Initialized
    cfg80211: Using static regulatory domain info
    cfg80211: Regulatory domain: US
            (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
            (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
            (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
            (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
            (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
            (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
            (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
    cfg80211: Calling CRDA for country: US
    LogicPD encoder initialized
    Switching to clocksource timer0_1
    musb_hdrc: version 6.0, cppi-dma, host, debug=0
    Clocks: enable usb at 24000000 Hz
    musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
    musb_hdrc musb_hdrc: MUSB HDRC host driver
    musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
    usb usb1: configuration #1 chosen from 1 choice
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    NET: Registered protocol family 2
    IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    TCP established hash table entries: 2048 (order: 2, 16384 bytes)
    TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
    TCP: Hash tables configured (established 2048 bind 2048)
    TCP reno registered
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
    msgmni has been set to 110
    alg: No test for stdrng (krng)
    io scheduler noop registered
    io scheduler anticipatory registered (default)
    davincifb davincifb.0: dm_osd0_fb: 0x0x16@0,0 with framebuffer size 2025KB
    davincifb davincifb.0: dm_vid0_fb: 0x0x16@0,0 with framebuffer size 1020KB
    davincifb davincifb.0: dm_osd1_fb: 720x480x4@0,0 with framebuffer size 675KB
    davincifb davincifb.0: dm_vid1_fb: 0x0x16@0,0 with framebuffer size 1020KB
    DM365 IPIPEIF probed
    imp serializer initialized
    davinci_previewer initialized
    davinci_resizer initialized
    Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
    serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
    console [ttyS0] enabled
    brd: module loaded
    at24 1-0050: 32768 byte 24c256 EEPROM (writable)
    Read MAC addr from EEPROM: 00:0e:99:02:cd:cc
    Clocks: enable spi0 at 121500000 Hz
    spi_davinci spi_davinci.0: DaVinci SPI driver in EDMA mode
    Using RX channel = 17 , TX channel = 16 and event queue = 3
    at25 spi0.0: 8 KByte at25640 eeprom, pagesize 32
    spi_davinci spi_davinci.0: Controller at 0xfec66000
    console [netcon0] enabled
    netconsole: network logging started
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    usbcore: registered new interface driver usbtest
    input: DM365 EVM Controls as /devices/platform/i2c_davinci.1/i2c-1/1-0025/input0
    i2c /dev entries driver
    Linux video capture interface: v2.00
    ths7303 1-002c: chip found @ 0x58 (DaVinci I2C adapter)
    Enabling mt9d131 sensor
    vpfe_init
    Clocks: enable vpss_master at 243000000 Hz
    vpfe-capture: vpss clock vpss_master enabled
    vpfe-capture vpfe-capture: v4l2 device registered
    vpfe-capture vpfe-capture: video device registered
    Reset to high
    msg.addr = 115
    dm365evm_enable_pca9543a, status = -121
    EVM: switch to HD imager video input
    mt9d131 1-005d: Detected a MT9D131 chip ID 1519
    mt9d131 1-005d: mt9d131 1-005d decoder driver registered !!
    vpfe-capture vpfe-capture: v4l2 sub device mt9d131 registered
    vpfe_register_ccdc_device: DM365 ISIF
    DM365 ISIF is registered with vpfe.
    af major#: 252, minor# 0
    AF Driver initialized
    aew major#: 251, minor# 0
    AEW Driver initialized
    Trying to register davinci display video device.
    layer=c26ff200,layer->video_dev=c26ff370
    layer=c25a9e00,layer->video_dev=c25a9f70
    davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
    Clocks: enable timer2 at 24000000 Hz
    watchdog watchdog: heartbeat 60 sec
    Clocks: enable mmcsd0 at 121500000 Hz
    davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
    usbcore: registered new interface driver usbhid
    usbhid: v2.6:USB HID core driver
    Advanced Linux Sound Architecture Driver Version 1.0.21.
    No device for DAI tlv320aic3x
    Clocks: enable asp0 at 121500000 Hz
    No device for DAI davinci-i2s
    asoc: tlv320aic3x <-> davinci-i2s mapping ok
    ALSA device list:
      #0: DaVinci EVM (tlv320aic3x)
    TCP cubic registered
    NET: Registered protocol family 17
    lib80211: common routines for IEEE802.11 drivers
    Clocks: enable emac at 121500000 Hz
    emac-mii: probed
    eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, id=221613)
    IP-Config: Guessing netmask 255.255.255.0
    IP-Config: Complete:
         device=eth0, addr=192.168.2.199, mask=255.255.255.0, gw=255.255.255.255,
         host=192.168.2.199, domain=, nis-domain=(none),
         bootserver=255.255.255.255, rootserver=192.168.2.30, rootpath=
    Looking up port of RPC 100003/2 on 192.168.2.30
    PHY: 1:01 - Link is Up - 100/Full
    Looking up port of RPC 100005/1 on 192.168.2.30
    VFS: Mounted root (nfs filesystem) on device 0:14.
    Freeing init memory: 144K
    INIT: version 2.86 booting
    Starting the hotplug events dispatcher: udevd.
    Synthesizing the initial hotplug events...done.
    Waiting for /dev to be fully populated...done.
    Activating swap...done.
    Remounting root filesystem...done.
    Calculating module dependencies
    WARNING: Couldn't open directory /lib/modules/2.6.32-rc2-davinci1: No such filey
    FATAL: Could not open /lib/modules/2.6.32-rc2-davinci1/modules.dep.temp for wriy
    Loading modules:
    Checking all file systems: fsck
    fsck 1.40 (29-Jun-2007)
    Mounting local filesystems: mount nothing was mounted
    umount.nfs: /dev/root: not found or not mounted
    Setting up networking ....
    /etc/network/options is deprecated.
    Setting up IP spoofing protection: rp_filter done.
    Disabling IPv4 packet forwarding: done.
    Disabling TCP/IP Explicit Congestion Notification: done.
    Starting network interfaces: done.
    Starting hotplug subsystem:
       pci
       pci      [success]
       usb
       usb      [success]
       isapnp
       isapnp   [success]
       ide
       ide      [success]
       input
       input    [success]
       scsi
       scsi     [success]
    done.
    Starting portmap daemon....
    Cleaning: /tmp /var/lock /var/run done.
    Setting pseudo-terminal access permissions...done.
    Updating /etc/motd...done.
    INIT: Entering runlevel: 3
    Starting system log daemon: syslogd klogd.
    Starting NFS common utilities: statd.
    Starting internet superserver: inetd.
    Starting OpenBSD Secure Shell server: sshd@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    @         WARNING: UNPROTECTED PRIVATE KEY FILE!          @
    Permissions 0755 for '/etc/ssh/ssh_host_key' are too open.
    It is recommended that your private key files are NOT accessible by others.
    This private key will be ignored.
    bad permissions: ignore key: /etc/ssh/ssh_host_key
    Could not load host key: /etc/ssh/ssh_host_key
    Permissions 0755 for '/etc/ssh/ssh_host_rsa_key' are too open.
    bad permissions: ignore key: /etc/ssh/ssh_host_rsa_key
    Could not load host key: /etc/ssh/ssh_host_rsa_key
    Permissions 0755 for '/etc/ssh/ssh_host_dsa_key' are too open.
    bad permissions: ignore key: /etc/ssh/ssh_host_dsa_key
    Could not load host key: /etc/ssh/ssh_host_dsa_key
    Disabling protocol version 1. Could not load host key
    Disabling protocol version 2. Could not load host key
    sshd: no hostkeys available -- exiting.
     failed (1: ).
    MontaVista(R) Linux(R) Professional Edition 5.0.0 (0801921)
    192.168.2.199 login: root
    Last login: Thu Jan  1 00:00:42 1970 on console
    Linux 192.168.2.199 2.6.32-rc2-davinci1 #147 PREEMPT Wed Aug 18 15:02:52 CEST 2x
    Welcome to MontaVista(R) Linux(R) Professional Edition 5.0.0 (0801921).
    root@192.168.2.199:~# cd /opt
    root@192.168.2.199:/opt# ./loadmodules_hd.sh
    CMEMK module: built on Jun  7 2011 at 17:06:03
      Reference Linux version 2.6.32
      File /home/chemi/dvsdk/dvsdk_3_10_00_19/linuxutils_2_25_04_10/packages/ti/sdoc
    allocated heap buffer 0xc5000000 of size 0x8d5000
    cmemk initialized
    IRQK module: built on Jun  7 2011 at 17:06:07
    Clocks: enable mjcp at 243000000 Hz
    irqk initialized
    EDMAK module: built on Jun  7 2011 at 17:06:06
    root@192.168.2.199:/opt# DMAI_DEBUG=2 ./encode -v 2.m4v
    ./encode: /usr/lib/libpng12.so.0: no version information available (required by)
    Encode demo started.
    @0x0006cc1a:[T:0x4001f970] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note.
    @0x000b8850:[T:0x4001f970] ti.sdo.dmai - [Display] Found width=720 height=480, 4
    @0x000b89ef:[T:0x4001f970] ti.sdo.dmai - [Display] Setting width=720 height=4800
    @0x000b8afe:[T:0x4001f970] ti.sdo.dmai - [Display] New width=720, height=480, y4
    @0x000b8c42:[T:0x4001f970] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffes
    @0x000b8e6d:[T:0x4001f970] ti.sdo.dmai - [Buffer] Set user pointer 0x403ca000 ()
    @0x000b93b4:[T:0x4001f970] ti.sdo.dmai - [Display] Display buffer 0 mapped to 00
    @0x000c1733:[T:0x40bf6490] ti.sdo.dmai - [Capture] Composite input not found (I)
    Error: Failed to detect video standard, video input connected?
    @0x000c1f29:[T:0x413f6490] ti.sdo.dmai - [Venc1] Creating encoder mpeg4enc for 4
    @0x000c5b04:[T:0x413f6490] ti.sdo.dmai - [Venc1] Failed to open video encode al)
    Error: Failed to create video encoder: mpeg4enc
    @0x000e26e4:[T:0x41bf6490] ti.sdo.dmai - [BufTab] Allocating BufTab for 9 buffes
    @0x000e2901:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e2ae5:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e2cf1:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e2ec1:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e30b6:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e332a:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e3509:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e3711:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e38ec:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000e4218:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e4337:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e4417:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e44e2:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e45aa:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e46a2:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e4773:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e4838:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000e48ff:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x0001c32b:[T:0x4001f970] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note.
    @0x0006a2eb:[T:0x4001f970] ti.sdo.dmai - [Display] Found width=720 height=480, 4
    @0x0006a483:[T:0x4001f970] ti.sdo.dmai - [Display] Setting width=720 height=4800
    @0x0006a599:[T:0x4001f970] ti.sdo.dmai - [Display] New width=720, height=480, y4
    @0x0006a6e1:[T:0x4001f970] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffes
    @0x0006a90a:[T:0x4001f970] ti.sdo.dmai - [Buffer] Set user pointer 0x403ca000 ()
    @0x0006ae51:[T:0x4001f970] ti.sdo.dmai - [Display] Display buffer 0 mapped to 00
    @0x000734ab:[T:0x40bf6490] ti.sdo.dmai - [Capture] Composite input not found (I)
    @0x00073cc2:[T:0x413f6490] ti.sdo.dmai - [Venc1] Creating encoder mpeg4enc for 4
    @0x00077b8f:[T:0x413f6490] ti.sdo.dmai - [Venc1] Failed to open video encode al)
    @0x000b5215:[T:0x41bf6490] ti.sdo.dmai - [BufTab] Allocating BufTab for 9 buffes
    @0x000b545d:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b5643:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b5818:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b59eb:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b5bbb:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b5d90:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b5f62:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b6133:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b6306:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000b6b9e:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b6cbf:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b6d97:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b6e66:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b6f2a:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b6fe9:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b70af:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b7171:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000b7302:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    root@192.168.2.199:/opt# rm encode
    @0x0006743f:[T:0x4001f970] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note.
    @0x000b969e:[T:0x4001f970] ti.sdo.dmai - [Display] Found width=720 height=480, 4
    @0x000b983c:[T:0x4001f970] ti.sdo.dmai - [Display] Setting width=720 height=4800
    @0x000bb972:[T:0x4001f970] ti.sdo.dmai - [Display] New width=720, height=480, y4
    @0x000bbaee:[T:0x4001f970] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffes
    @0x000bbd29:[T:0x4001f970] ti.sdo.dmai - [Buffer] Set user pointer 0x403ca000 ()
    @0x000bc7b3:[T:0x4001f970] ti.sdo.dmai - [Display] Display buffer 0 mapped to 00
    @0x000c2495:[T:0x40bf6490] ti.sdo.dmai - [Capture] Cannot open /dev/video0 (No )
    @0x000c2c83:[T:0x413f6490] ti.sdo.dmai - [Venc1] Creating encoder mpeg4enc for 4
    @0x000c691b:[T:0x413f6490] ti.sdo.dmai - [Venc1] Failed to open video encode al)
    @0x000d9d70:[T:0x41bf6490] ti.sdo.dmai - [BufTab] Allocating BufTab for 9 buffes
    @0x000d9fd0:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000da1b8:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000da38a:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000da593:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000da76a:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000da942:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000dab57:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000dad3b:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000daf45:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 0 at 0x4)
    @0x000db816:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000db938:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dba4c:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dbb20:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dbcb0:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dbda9:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dbe7d:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dbf71:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    @0x000dc043:[T:0x41bf6490] ti.sdo.dmai - [Buffer] Free Buffer of size 0 at 0x41)
    #include <linux/videodev2.h>
    #include <linux/slab.h>
    #include <linux/i2c.h>
    #include <linux/log2.h>
    #include <linux/delay.h>
    #include <media/v4l2-device.h>
    #include <media/v4l2-common.h>
    #include <media/v4l2-chip-ident.h>
    #define MT9D131_PAGE_REGISTRE       0xF0
    #define MT9D131_CHIP_VERSION        0x00
    #define MT9D131_ROW_START            0x01
    #define MT9D131_COLUMN_START        0x02
    #define MT9D131_ROW_WIDTH            0x03
    #define MT9D131_COL_WIDTH            0x04
    #define MT9D131_HORIZONTAL_BLANKINGB 0x05
    #define MT9D131_VERTICAL_BLANKINGB  0x06
    #define MT9D131_HORIZONTAL_BLANKINGA 0x07
    #define MT9D131_VERTICAL_BLANKINGA  0x08
    #define MT9D131_SHUTTER_WIDTH       0x09
    #define MT9D131_ROW_SPEED           0x0A
    #define MT9D131_SHUTTER_DELAY       0x0C
    #define MT9D131_RESET_LOGICIEL      0x0D
    #define MT9D131_CLOCK_CONTROL       0x65
    #define MT9D131_MCU_BOOTMODE        0xC1
    #define MT9D131_PLL_CONTROL1        0x66
    #define MT9D131_PLL_CONTROL2        0x67
    #define MT9D131_VARIABLE_ADDRESS    0xC6
    #define MT9D131_VARIABLE_DATA       0xC8
    #define MT9D131_ID_SEQ              0x01
    #define MT9D131_ID_MODE             0x07
    #define MT9D131_OUT_FORMATA         125
    #define MT9D131_OUT_FORMATB         126
    #define MT9D131_SEQ_CAPTUREMODE     32
    #define MT9D131_SEQ_CMD             3
    #define MT9D131_MODE_CONFIG         11
    #define MT9D131_ID_JPEG             0x09
    #define MT9D131_JPEG_FORMAT         6
    #define MT9D131_OUTPUT_WIDTHB       7
    #define MT9D131_OUTPUT_HEIGHTB      9
    #define MT9D131_CROP_X0B            53
    #define MT9D131_CROP_X1B            55
    #define MT9D131_CROP_Y0B            57
    #define MT9D131_CROP_Y1B            59
    #define MT9D131_BUS_PARAM    (SOCAM_PCLK_SAMPLE_RISING |    \
        SOCAM_PCLK_SAMPLE_FALLING | SOCAM_HSYNC_ACTIVE_HIGH |    \
        SOCAM_VSYNC_ACTIVE_HIGH | SOCAM_DATA_ACTIVE_HIGH |    \
        SOCAM_MASTER | SOCAM_DATAWIDTH_10)
    #define MT9D131_MAX_WIDTHA          800
    #define MT9D131_MAX_HEIGHTA          600
    #define MT9D131_MAX_WIDTHB          1600
    #define MT9D131_MAX_HEIGHTB          1200
    static int debug;
    module_param(debug, bool, 0644);
    MODULE_PARM_DESC(debug, "Debug level (0-1)");
    static const struct v4l2_fmtdesc mt9d131_formats[] = {
            .index = 0,
            .type = V4L2_BUF_TYPE_VIDEO_CAPTURE,
            .description = "YUV Format",
            .pixelformat = V4L2_PIX_FMT_UYVY,
            .index = 1,
            .description = "RGB Format",
            .pixelformat = V4L2_PIX_FMT_RGB565X,
            .index=2,
            .description = "JPEG Format",
            .pixelformat = V4L2_PIX_FMT_JPEG,
    static const unsigned int mt9d131_num_formats = ARRAY_SIZE(mt9d131_formats);
    static const struct v4l2_queryctrl mt9d131_controls[] = {
            .id        = V4L2_CID_VFLIP,
            .type        = V4L2_CTRL_TYPE_BOOLEAN,
            .name        = "Flip Vertically",
            .minimum    = 0,
            .maximum    = 1,
            .step        = 1,
            .default_value    = 0,
            .id        = V4L2_CID_HFLIP,
            .name        = "Flip Horizontally",
            .minimum    = 0,
            .maximum    = 1,
            .step        = 1,
            .default_value    = 0,
            .id        = V4L2_CID_GAIN,
            .type        = V4L2_CTRL_TYPE_INTEGER,
            .name        = "Gain",
            .minimum    = 0,
            .maximum    = 127,
            .step        = 1,
            .default_value    = 64,
            .flags        = V4L2_CTRL_FLAG_SLIDER,
            .id        = V4L2_CID_EXPOSURE,
            .name        = "Exposure",
            .minimum    = 1,
            .maximum    = 255,
            .step        = 1,
            .default_value    = 255,
            .id        = V4L2_CID_EXPOSURE_AUTO,
            .name        = "Automatic Exposure",
            .minimum    = 0,
            .maximum    = 1,
            .step        = 1,
            .default_value    = 1,
    static const unsigned int mt9d131_num_controls = ARRAY_SIZE(mt9d131_controls);
    struct mt9d131 {
        struct v4l2_subdev sd;
        int model;    /* V4L2_IDENT_MT9D131* codes from v4l2-chip-ident.h */
    static inline struct mt9d131 *to_mt9d131(struct v4l2_subdev *sd)
        return container_of(sd, struct mt9d131, sd);
    //The fonction to read the content in certaine register
    static int reg_read(struct i2c_client *client, const u8 reg)
        s32 data;
        data = i2c_smbus_read_word_data(client, reg);
        return data < 0 ? data : swab16(data);
    //The fonction to write the content into certaine register
    static int reg_write(struct i2c_client *client, const u8 reg,
                 const u16 data)
        return i2c_smbus_write_word_data(client, reg, swab16(data));
    //Turn certaine bits of the reg to 1
    static int reg_set(struct i2c_client *client, const u8 reg,
               const u16 data)
        int ret;
        ret = reg_read(client, reg);
        if (ret < 0)
            dev_dbg(&client->dev, "Can not set register: %x\n",reg);
            return ret;
        return reg_write(client, reg, ret | data);
    //Turn certaines bits of the reg to 0
    static int reg_clear(struct i2c_client *client, const u8 reg,
                 const u16 data)
        int ret;
        if (ret < 0)
            return ret;
        return reg_write(client, reg, ret & ~data);
    //Change the page of register
    static int change_page(struct i2c_client *client,const u16 data)
        int ret;
        u8 reg= MT9D131_PAGE_REGISTRE;
        if (ret < 0)
            dev_dbg(&client->dev, "Can not read register: %x\n",reg);
            return ret;
        else
            return reg_write(client,reg,data);
    static int set_shutter(struct i2c_client *client, const u32 data)
        int ret;
        ret=change_page(client,0);
        if(ret<0)
            return -ret;
        ret = reg_write(client, MT9D131_SHUTTER_WIDTH, data >> 16);
        return ret;
    static int set_shutter_delay(struct i2c_client *client, const u16 data)
        int ret;
        if(ret<=0)
            return ret;
        ret = reg_write(client, MT9D131_SHUTTER_DELAY, data);
        return ret;
    static int get_shutter(struct i2c_client *client,u32 *data)
        int ret;
        ret=reg_read(client,MT9D131_SHUTTER_WIDTH);
        *data=ret;
        return ret;
    //This fonction change the variables of drivers
    static int driver_write(struct i2c_client *client,const u8 id,const u8 offset,const u16 val,const int bits_access)
        u16 addr;
        u16 ret;
        addr=(((u16)id)<<8)|offset;
        if(bits_access)
            addr|=0xA000;
        else
            addr|=0x2000;
        if(ret<0)
            return ret;
        ret=reg_write(client,MT9D131_VARIABLE_ADDRESS ,addr);
        if(ret<0)
            return ret;
        if(bits_access)
            ret=reg_write(client,MT9D131_VARIABLE_DATA,(u8)val);
        else
            ret=reg_write(client,MT9D131_VARIABLE_DATA,val);
        if(ret<0)
            dev_dbg(&client->dev, "Access to driver id=%d,offset=0x%x failes",id,offset );
        return ret;
    static int driver_read(struct i2c_client* client,const u8 id,const u8 offset,const int bits_access)
        u16 addr;
        u16 data;
        u16 ret;
        if(bits_access)
            addr|=0xA000;
        else
            addr|=0x2000;
        if(ret<0)
            return ret;
        if(ret<0)
            return ret;
        data=reg_read(client,MT9D131_VARIABLE_DATA);
        if(data<0)
            return data;
        if(bits_access)
            return data&0x00ff;
        else
            return data;
    //Set the bits of certaine driver to 1
    static int driver_set(struct i2c_client* client,const u8 id,const u8 offset,const u8 mask,const int bits_access)
        s16 data=driver_read(client,id,offset,bits_access);
        if(data<0)
            return data;
        return driver_write(client,id,offset,data|mask,bits_access);
    //Set the bits of certain driver to 0
    static int driver_clear(struct i2c_client* client,const u8 id,const u8 offset,const u8 mask,const int bits_access)
        if(data<0)
            return data;
        return driver_write(client,id,offset,data&~mask,bits_access);
    //Disable the pll
    static int pll_disable(struct i2c_client *client)
        int ret;
        if(ret<0)
            return ret;
        //Bypasse the PLL
        ret=reg_set(client,MT9D131_CLOCK_CONTROL,0xC000);
        return ret;
    //Enable the pll,and set the frequence by M,N,P fin=25MHZ
    static int pll_enable(struct i2c_client *client,int M,int N,int P)
        int ret;
        u16 data=0;
        if(ret<0)
            return ret;
        if(ret<0)
            return ret;
        if(M<16||N>64||P>128)
            return -EIO;
        data=data|(M<<8)|N;
        ret=reg_write(client,MT9D131_PLL_CONTROL1,data);
        if(ret<0)
            return ret;
        ret=reg_clear(client,MT9D131_PLL_CONTROL2,0x0f);
        ret=reg_set(client,MT9D131_PLL_CONTROL2,P);
        if(ret<0)
            return ret;
        ret=reg_clear(client,MT9D131_CLOCK_CONTROL,0x4000);
        if(ret<0)
            return ret;
        msleep(1);
        printk("PLL enabled" );
        ret=reg_clear(client,MT9D131_CLOCK_CONTROL,0x8000);
        return ret;
    //Change the mode of the camera ,mode=0 for preview,mode=1 for capture and start capture image
    static int change_mode(struct i2c_client *client,int mode)
        int ret;
        if(mode)
            ret=driver_set(client,MT9D131_ID_SEQ,MT9D131_SEQ_CAPTUREMODE,0x0002,1);
        else
            ret=driver_clear(client,MT9D131_ID_SEQ,MT9D131_SEQ_CAPTUREMODE,0x0002,1);
        if(ret<0)
            dev_dbg(&client->dev, "Failed to change mode" );
        return ret;
        int ret;
        if(ret<0)
            return -EIO;
        //Perform MCU reset
        if(ret<0)
            return -EIO;
        if(ret<0)
            return -EIO;
        //Enable Reset
        if(ret<0)
            return -EIO;
        if(ret<0)
            return -EIO;
        if(ret<0)
            return -EIO;
        msleep(20);
        //Enable PLL
        int ret;
            return -EIO;
        //Enable the output
        if (enable) {
                return -EIO;
        } else {
                return -EIO;
        return 0;
        int i,ret;
        int flag=0;
                //bypass the JPEG
                    break;
                    break;
                flag=1;
                if(ret<0)
                    return ret;
                break;
        if(flag==0)
            return -EIO;
            if(ret<0)
                return ret;
        else
            return -EIO;
        return ret<0?ret:0;
        int ret,i;
        int flag=0;
                flag=1;
                break;
        if(!flag)
        return 0;
    //Get identification of this camera
    static int mt9d131_get_chip_id(struct v4l2_subdev *sd,
                       struct v4l2_dbg_chip_ident *id)
        struct mt9d131 *mt9d131 = to_mt9d131(sd);
        struct i2c_client *client = v4l2_get_subdevdata(sd);;
        if (id->match.type != V4L2_CHIP_MATCH_I2C_ADDR)
            return -EINVAL;
        if (id->match.addr != client->addr)
            return -ENODEV;
        id->ident    = mt9d131->model;
        id->revision    = 0;
        return 0;
    //Register the camera,copy from mt9t031.c
    #ifdef CONFIG_VIDEO_ADV_DEBUG
    static int mt9d131_get_register(struct v4l2_subdev *sd,
                    struct v4l2_dbg_register *reg)
        if (reg->match.type != V4L2_CHIP_MATCH_I2C_ADDR || reg->reg > 0xff)
            return -EINVAL;
        if (reg->match.addr != client->addr)
            return -ENODEV;
        reg->val = reg_read(client, reg->reg);
        if (reg->val > 0xffff)
            return -EIO;
        return 0;
    static int mt9d131_set_register(struct v4l2_subdev *sd,
            return -EINVAL;
            return -ENODEV;
        if (reg_write(client, reg->reg, reg->val) < 0)
            return -EIO;
        return 0;
    #endif
    static const struct v4l2_subdev_core_ops mt9d131_core_ops = {
        .g_chip_ident = mt9d131_get_chip_id,
        .init = mt9d131_init,
        .get_register = mt9d131_get_register,
        .set_register = mt9d131_set_register,
    #endif
    static const struct v4l2_subdev_video_ops mt9d131_video_ops = {
        .s_fmt = mt9d131_set_fmt,
        .try_fmt = mt9d131_try_fmt,
        .s_stream = mt9d131_s_stream,
    static const struct v4l2_subdev_ops mt9d131_ops = {
        .core = &mt9d131_core_ops,
        .video = &mt9d131_video_ops,
    /* Interface active, can use i2c. If it fails, it can indeed mean, that
     * this wasn't our capture interface, so, we wait for the right one */
    static int mt9d131_detect(struct i2c_client *client, int *model)
        s32 data;
        int ret;
        /* Read out the chip version register */
        data = reg_read(client, MT9D131_CHIP_VERSION);
        switch (data) {
        case 0x1519:
            *model = V4L2_IDENT_MT9D131;
            break;
        default:
            dev_err(&client->dev,
                "No MT9D131 chip detected, register read %x\n", data);
            return -ENODEV;
        dev_info(&client->dev, "Detected a MT9D131 chip ID %x\n", data);
        return 0;
    static int mt9d131_probe(struct i2c_client *client,
                 const struct i2c_device_id *did)
        struct mt9d131 *mt9d131;
        struct v4l2_subdev *sd;
        int pclk_pol;
        int ret;
        if (!i2c_check_functionality(client->adapter,
                         I2C_FUNC_SMBUS_WORD_DATA)) {
            dev_warn(&client->dev,
                 "I2C-Adapter doesn't support I2C_FUNC_SMBUS_WORD\n");
            return -EIO;
        if (!client->dev.platform_data) {
            dev_err(&client->dev, "No platform data!!\n");
            return -ENODEV;
        pclk_pol = (int)client->dev.platform_data;
        mt9d131 = kzalloc(sizeof(struct mt9d131), GFP_KERNEL);
        if (!mt9d131)
            return -ENOMEM;
        ret = mt9d131_detect(client, &mt9d131->model);
        if (ret)
            goto clean;
        /* Register with V4L2 layer as slave device */
        sd = &mt9d131->sd;
        v4l2_i2c_subdev_init(sd, client, &mt9d131_ops);
        if (!pclk_pol)
            reg_clear(v4l2_get_subdevdata(sd),
                  MT9D131_ROW_SPEED, 0x0100);
        else
            reg_set(v4l2_get_subdevdata(sd),
        v4l2_info(sd, "%s decoder driver registered !!\n", sd->name);
        return 0;
    clean:
        kfree(mt9d131);
        return ret;
    static int mt9d131_remove(struct i2c_client *client)
        struct v4l2_subdev *sd = i2c_get_clientdata(client);
        v4l2_device_unregister_subdev(sd);
        kfree(mt9d131);
        return 0;
    static const struct i2c_device_id mt9d131_id[] = {
        { "mt9d131", 0 },
    MODULE_DEVICE_TABLE(i2c, mt9d131_id);
    static struct i2c_driver mt9d131_i2c_driver = {
        .driver = {
            .name = "mt9d131",
        .probe        = mt9d131_probe,
        .remove        = mt9d131_remove,
        .id_table    = mt9d131_id,
    static int __init mt9d131_mod_init(void)
        printk("Enabling mt9d131 sensor\n");
        return i2c_add_driver(&mt9d131_i2c_driver);
    static void __exit mt9d131_mod_exit(void)
        i2c_del_driver(&mt9d131_i2c_driver);
    module_init(mt9d131_mod_init);
    module_exit(mt9d131_mod_exit);
    MODULE_DESCRIPTION("Micron MT9D131 Camera driver");
    MODULE_AUTHOR("Thibault BEYOU");
    MODULE_LICENSE("GPL v2");
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 07 2011 12:14 PM
    Expert4685 points
    Hey,
    device/sub-device registrations seem to be fine. But, the application is trying to set COMPOSITE input. Since it is camera you are trying to capture from , you should provide right arguments so that it can capture from it [ if it has such a opt ion ].
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 08 2011 03:02 AM
    Sorry, please look at the line in black, the first time I lance the application, I use the application, I change the code like this itocl(/dev/video2,............), but when I try to open the /dev/video0, it can not be opened, that is my problem
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 08 2011 03:05 AM
    My question is, is anybody knows when the board DM365 is booted, which module created this node /dev/video0, thank you very much.
    Report Abuse
    • Reply
  • Nagabhushana
    on Jun 08 2011 03:18 AM
    Expert4685 points
    Mingming Chen,
    please use following commands after system boots up.
    ls /dev/v*
    This will display all the video nodes which are present. Result might be like,
    /dev/video
    /dev/video1
    /dev/video2
    If the video nodes are present, there should not be problem with opening them.
    In the debug messages I am seeing following error message.
    This means application is looking for COMPOSITE input. This needs to be addressed as well. It should look for CAMERA input. You might need to check for application's options.
    Nagabhushana
    Report Abuse
    • Reply
  • Mingming Chen
    on Jun 08 2011 03:59 AM
    @0x00093aff:[T:0x4001f970] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note.
    @0x000e1161:[T:0x4001f970] ti.sdo.dmai - [Display] Found width=720 height=480, 4
    @0x000e1300:[T:0x4001f970] ti.sdo.dmai - [Display] Setting width=720 height=4800
    @0x000e140a:[T:0x4001f970] ti.sdo.dmai - [Display] New width=720, height=480, y4
    @0x000e154b:[T:0x4001f970] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffes
    @0x000e1773:[T:0x4001f970] ti.sdo.dmai - [Buffer] Set user pointer 0x403ca000 ()
    @0x000e1cba:[T:0x4001f970] ti.sdo.dmai - [Display] Display buffer 0 mapped to 00
    @0x000ea5dc:[T:0x40bf6490] ti.sdo.dmai - [Capture] Cannot open /dev/video0 (No )
    root@192.168.2.199:/opt# ls /dev/video*
    /dev/video0  /dev/video2  /dev/video3
    I modify the file v4l2_dev, when the system is booted, the information is like that
    TTTTTTTTTTTTTTTTTTTTTTTTTTTTvideo0
    Reset to high
    msg.addr = 115
    layer=c2173000,layer->video_dev=c2173170
    TTTTTTTTTTTTTTTTTTTTTTTTTTTTvideo2
    layer=c2173200,layer->video_dev=c2173370
    TTTTTTTTTTTTTTTTTTTTTTTTTTTTvideo3
    I think that video2..3 is the output device, now I am getting mad of this probleme
    Report Abuse
    • Reply
12
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
