A BUG in local_bh_enable at kernel/softirq.c
hi
i am trying to do the setup for DM365IPNC by APPRO using ipnc2.6.0
i am following the steps given in Users_Guide_IPNC_DM365_.pdf. and i met some problem while starting the DM365 ipnc from appro, could you help me ?
i just coppied the message from console.
Starting kernel ...
Linux version 2.6.18_pro500-davinci_IPNC_DM365_2.6.0 (root@rockingblue-G41MT-S2) (gcc 版本 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Fri Nov 11 16:38:52   1
   usb      [success]
   isapnp
   isapnp   [success]
Simple mixer control 'PGA',0
  Capabilities: cvolume
  Capture channels: Mono
  Limits: Capture 0 - 3
  Mono: Capture 2 [67%]
Simple mixer control 'Mono DAC',0
  Capabilities: pvolume pvolume-joined
  Playback channels: Mono
  Limits: Playback 0 - 63
  Mono: Playback 47 [75%]
SystemInit success
Schedule manager init success
   ide
   ide      [success]
   input
   input    [success]
   scsi
   scsi     [success]
done.
Starting portmap daemon: portmap.
Starting internet superserver: inetd.
io scheduler deadline registered
io scheduler cfq registered
TI DaVinci EMAC: kernel boot params Ethernet address: 00:11:22:33:46:01
 sbulla: unknown partition table
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
loop: loaded (max 8 devices)
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
CSLIP: code copyright 1989 Regents of the University of California
netconsole: not configured, aborting
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
Davinci EMAC MII Bus: probed
MAC address is 00:11:22:33:46:01
TI DaVinci EMAC Linux version updated 4.0
davinci-mmc davinci-mmc.0: Supporting 4-bit mode
davinci-mmc davinci-mmc.0: Using DMA mode
usbcore: registered new driver usbfs
usbcore: registered new driver hub
musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0
musb_hdrc musb_hdrc: No DMA interrupt line
musb_hdrc: USB Peripheral mode controller at c38f8000 using DMA, IRQ 12
Loading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp)
mkdosfs 3.0.6 (04 Oct 2009)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
Root directory contains 512 slots.
Volume ID is 6e067d05, no volume label.
queue id:0
umount: /mnt/mmc: not mounted
killall: dhcpcd: no process killed
rm: cannot remove `/var/run/dhcpcd-eth0.pid': No such file or directory
net_search_gateway:eth0, 4A8C0, 0, 1
dns=192.168.5.1
net_search_gateway:eth0, 0, 105A8C0, 3
dns=192.168.5.1
ERROR: Module g_file_storage does not exist in /proc/modules
g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, file: /dev/sbulla
system_server/512[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196
ApproDrvInit: 9
queue id:131076
Initializing...
...done initializing
ApproDrvInit: 8
queue id:131076
Initializing...
ApproDrvInit: 6
queue id:131076
Initializing...
ApproDrvInit: 10
queue id:131076
Initializing...
Play this stream using the URL:
        rtsp://192.168.5.158:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
        rtsp://192.168.5.158:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
        rtsp://192.168.5.158:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
        rtsp://192.168.5.158:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
ApproDrvInit: 3
queue id:131076
queue id:0
queue id:32769
ApproDrvInit: 2
queue id:131076
Initializing...
        rtsp://192.168.5.158:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
queue id:0
[16/Nov/2011:07:31:47 +0000] boa: server version Boa/0.94.13
[16/Nov/2011:07:31:47 +0000] boa: server built Nov 11 2011 at 16:41:51.
[16/Nov/2011:07:31:47 +0000] boa: starting server pid=792, port 80
UDPString=uuid:Upnp-TVEmulator-1_0-00_0006303610</UDN>
INIT: Entering runlevel: 3
error code = 0
device advertisement succeed.
MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774)
DM365_IPNC login:
I just want to know why did it happen? ( system_server/512[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196 )  and how do i resolve it ?
please help me,thank you very much
