I am following the steps given in Users_Guide_IPNC_DM36x_OV2715.pdf. while installing the IPNC APPLICATION, in section 3.2, and getting errors like this: Linux version 2.6.18_pro500-davinci_IPNC_DM368_2.0.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Fri Mar 16 13:22:33 CST 2012CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177Machine: DaVinci DM368 IPNCMemory policy: ECC disabled, Data cache writebackDaVinci DM0365 variant 0x8PLL0: fixedrate: 24000000, commonrate: 135000000, vpssrate: 270000000PLL0: vencrate_sd: 27000000, ddrrate: 270000000 mmcsdrate: 49090909PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000CPU0: D VIVT write-back cacheCPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 setsCPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 setsBuilt 1 zonelists. Total pages: 14336Kernel command line: console=ttyS1,115200n8 noinitrd rw ip=dhcp root=/dev/nfs nfsroot=192.168.1.31:/home/kent/work/mytest/ipnc_dm368_v100/ipnc/target/filesys, nolock mem=56MPID hash table entries: 256 (order: 8, 1024 bytes)Clock event device timer0_0 configured with caps set: 07Console: colour dummy device 80x30Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)Memory: 56MB = 56MB totalMemory: 52644KB available (3193K code, 653K data, 184K init)Security Framework v1.0.0 initializedCapability LSM initializedMount-cache hash table entries: 512CPU: Testing write buffer coherency: okNET: Registered protocol family 16DaVinci: 104 gpio irqsMUX: initialized GPIO20MUX: initialized I2C_SCLGeneric PHY: Registered new driverch0 default output "COMPOSITE", mode "NTSC"VPBE Encoder InitializedSCSI subsystem initializedNET: Registered protocol family 2IP route cache hash table entries: 512 (order: -1, 2048 bytes)TCP established hash table entries: 2048 (order: 1, 8192 bytes)TCP bind hash table entries: 1024 (order: 0, 4096 bytes)TCP: Hash tables configured (established 2048 bind 1024)TCP reno registeredVFS: Disk quotas dquot_6.5.1Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)squashfs: version 3.1 (2006/08/19) Phillip LougherJFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.yaffs Mar 16 2012 13:19:45 Installing. SGI XFS with no debug enabledInitializing Cryptographic APIio scheduler noop registeredio scheduler anticipatory registered (default)LTT : ltt-facilities initLTT : ltt-facility-core init in kernelDAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 secSerial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabledserial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550Aserial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550ARAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksizeDavinci EMAC MII Bus: probedMAC address is deadbeafTI DaVinci EMAC Linux version updated 4.0netconsole: not configured, abortingLinux video capture interface: v2.00Trying to register davinci display video device.layer=c0652000,layer->video_dev=c0652160Trying to register davinci display video device.layer=c066ee00,layer->video_dev=c066ef60davinci_init:DaVinci V4L2 Display Driver V1.0 loadedi2c /dev entries drivernand_davinci nand_davinci.0: Using 4-bit hardware ECCNAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)Creating 6 MTD partitions on "nand_davinci.0":0x00000000-0x00300000 : "bootloader"0x00300000-0x00500000 : "params"0x00500000-0x00700000 : "kernel"0x00700000-0x01f00000 : "filesystem"0x01f00000-0x02100000 : "data1"0x02100000-0x08000000 : "data2"nand_davinci nand_davinci.0: hardware revision: 2.3musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0musb_hdrc musb_hdrc: No DMA interrupt linemusb_hdrc: USB Peripheral mode controller at c4066000 using DMA, IRQ 12rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: procrtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!davinci-mmc davinci-mmc.0: Supporting 4-bit modedavinci-mmc davinci-mmc.0: Using DMA modeAdvanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).ASoC version 0.13.1CQ0093 Voice Codec 0.1asoc: cq93vc <-> davinci-vcif mapping okALSA device list: #0: On-chip voice codec (cq93vc)IPv4 over IPv4 tunneling driverTCP bic registeredNET: Registered protocol family 1NET: Registered protocol family 17rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!Time: timer0_1 clocksource has been installed.Clock event device timer0_0 configured with caps set: 08Switched to high resolution mode on CPU 0rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-09-14 01:01:01 (968893261)1:01 not found1:02 not found1:03 not found1:04 not found1:05 not found1:06 not found1:07 not found1:08 not found1:09 not found1:0a not found1:0b not found1:0c not foundSending DHCP requests .., OKIP-Config: Got DHCP answer from 192.168.1.31, my address is 192.168.1.102IP-Config: Complete: device=eth0, addr=192.168.1.102, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.102, domain=example.org, nis-domain=(none), bootserver=192.168.1.31, rootserver=192.168.1.31, rootpath=Looking up port of RPC 100003/2 on 192.168.1.31Looking up port of RPC 100005/1 on 192.168.1.31VFS: Mounted root (nfs filesystem).Freeing init memory: 184KINIT: version 2.86 booting0Starting the hotplug events dispatcher: udevd.Synthesizing the initial hotplug events...done.Waiting for /dev to be fully populated...done.0CSL: Module install successful, device major num = 253 CSL: Module version 0.10.00, built on Mar 16 2012 13:24:34 I2C: Module install successful, device major num = 252 DMA: Module install successful, device major num = 251 DRV: Module install successfulDRV: Module built on Mar 16 2012 13:24:38 DRV: EDMACC.QUEPRI = 00000777DRV: SYSTEM.MSTPRI0 = 00550011DRV: SYSTEM.MSTPRI1 = 00000444DRV: ISP.BCR = 00000002DRV: SYSTEM.MISC = 00000311CMEMK module: built on Mar 16 2012 at 13:24:05 Reference Linux version 2.6.18 File /home/kent/work/mytest/ipnc_dm368_v100/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.callocated heap buffer 0xc5000000 of size 0x4700000CMEM Range Overlaps Kernel Physical - allowing overlapCMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83800000)cmemk initializedEDMAK module: built on Mar 16 2012 at 13:24:08 Reference Linux version 2.6.18 File /home/kent/work/mytest/ipnc_dm368_v100/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.cIRQK module: built on Mar 16 2012 at 13:24:09 Reference Linux version 2.6.18 File /home/kent/work/mytest/ipnc_dm368_v100/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.cirqk initializedCreat queue id:0queue id:0FileMngThread createdCreat queue id:32769queue id:32769queue id:32769AlramThread createdShare memory init successIPNC_DM368_2.0.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4 Creat queue id:65538queue id:65538queue id:65538Check_device_version : DEVICE VER = 0 !!CPU is DM368DEMOCFG Value : 0Videocodecmode : 0Videocodecres : 0./av_server.out FD OSD DM368 AEWB APPRO2A AUDIO 8000 720P H264 5000000 VBR AUTO MENUOFF &Starting mounting local filesystems: mount none on /dev/shm type tmpfs (rw,size=5M)none on /var/run type tmpfs (rw)none on /tmp type tmpfs (rw,sync)Setting up networking ...ApproDrvInit: 7Creat queue id:98307queue id:98307 AVSERVER UI: Initializing.DRV_SyncRst: module = 47, domain = 0, state = 0DRV_SyncRst: module = 47, domain = 0, state = 3 CLK Hz, ARM Hz = 432000000 DDR Hz = 270000000 VPSS Hz = 270000000 IMCOP Hz = 270000000 DRV LDC: GetConfig 0003 0x0 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameterCONFIGURING AVSERVER FOR DM368 ..... SENSOR FPS VALUE = 30 Sensor Mode Info, Width = 1920 Height = 1080 fps = 30 Bin Enable = 1 flipH = 0 flipV = 0 Sensor Frame Timing Info, fps = 30 t_frame (ns) = 33333334.000000 t_row (ns) = 29375.000000 t_pclk (ns) = 10.416667 W = 1920 H = 1080 SW = 17568 SD = 0 HB = 450 VB = 54 HBmin = 450 VBmin = 9 f_pclk = 96000000 shutterOverhead (ns) = 4437.500000 col_size = 1919 row_size = 1079 col_skip = 0 row_skip = 0 col_bin = 0 row_bin = 0 col_start = 0 row_start = 0 pll_M = 16 pll_N = 1 pll_DIV = 1 vdint0 = 955 vdint1 = 1060 .Starting hotplug subsystem:APPRO Setting AppliedDavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:layer.pix_fmt.bytesperline = 640, layer.pix_fmt.width = 640, layer.pix_fmt.height = 480, layer.pix_fmt.sizeimage =460800queue id:98307DavinciDisplay DavinciDisplay.1: pixfmt->width = 640, layer->layer_info.config.line_length= 640 pci FR : 0 users registered from exsiting face albumIPNC_DM368_2.0.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4 IPNC AUTO_IRIS = 1 #####################Aew_Cal_read_parameter !! CAL Error: Magic number not match!!!GBCE in EVAL MODE queue id:65538 pci [success] usb usb [success] isapnp isapnp [success] ide ide [success] input input [success] scsi scsi [success]done.Starting portmap daemon: portmap. Starting internet superserver: inetd.io scheduler deadline registeredio scheduler cfq registeredinsmod: /opt/ipnc/modules/i2c-emac.ko: No such file or directory sbulla: unknown partition tableInstalling knfsd (copyright (C) 1996 okir@monad.swb.de).loop: loaded (max 8 devices)tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>CSLIP: code copyright 1989 Regents of the University of Californiainsmod: /opt/ipnc/modules/netconsole.ko: No such file or directoryPPP generic driver version 2.4.2PPP Deflate Compression module registeredinsmod: /opt/ipnc/modules/davinci_emac.ko: No such file or directoryinsmod: /opt/ipnc/modules/mmc_core.ko: No such file or directoryinsmod: /opt/ipnc/modules/mmc_block.ko: No such file or directoryinsmod: /opt/ipnc/modules/davinci-mmc.ko: No such file or directoryinsmod: /opt/ipnc/modules/usbcore.ko: No such file or directoryinsmod: /opt/ipnc/modules/musb_hdrc.ko: No such file or directoryinsmod: /opt/ipnc/modules/usbmon.ko: No such file or directoryLoading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp) sbulla: unknown partition tablemkdosfs 3.0.6 (04 Oct 2009)unable to get drive geometry, using default 255/63/dev/sbulla has 255 heads and 63 sectors per track,logical sector size is 512,using 0xf8 media descriptor, with 1024 sectors;file system has 2 12-bit FATs and 4 sectors per cluster.FAT size is 1 sector, and provides 247 clusters.Root directory contains 512 slots.Volume ID is 36168f79, no volume label.queue id:0ApproDrvExit: 7Error: WaitStreamReady Fail.Error: Can't control AV server!!!Recieved Quit eventKill queue id:65538Kill queue id:32769ApproDrvExit: 1Error: Invalid Semaphore handlerKill queue id:0Error: Invalid Semaphore handlerError: Invalid Semaphore handlerError: Invalid Semaphore handlerError: Invalid Semaphore handlerApproDrvInit: 3queue id:98307Creat queue id:131072queue id:131072Creat queue id:163841queue id:163841INIT: Entering runlevel: 3MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774) any one has faced the same? how to proceed this problem?
It looks like your 2A has issue and has expired,
Can you check with Appro on this
Raghu
Please mark this reply as Verify Answer on this post if it answers the question.
Thanks a lot. When CMOS Sensor output is right, I got error like: -->CHIPX Version:0xFFChipx Id Check fail.
Appro Check License ID Fail !!!Please contact www.appropho.com !!! APPRO2A can not be use, So i use AEWB_NONE to replace AEWB_APPRO, IPNC application can be run now. But when i use default user name (admin) and password (9999) to login in IE, it login failed. What cause this problem and how to solve it?
DM36x initialization passed!TI UBL Version: 1.50Booting Catalog Boot LoaderBootMode = NANDStarting NAND Copy...Valid magicnum, 0xA1ACED66, found in block 0x00000008. DONEJumping to entry point at 0x81080000. Reset RTC Fail.. DM368_IPNC_UBL_1.0.0U-Boot 1.3.4-dirty (Mar 14 2012 - 16:16:09) DM368-IPNC-1.0.1I2C: readyDRAM: 128 MBNAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)Bad block table found at page 65472, version 0x01Bad block table found at page 65408, version 0x01128 MiBIn: serialOut: serialErr: serialARM Clock :- 432MHzDDR Clock :- 270MHzPHY ID: 0x00008201Ethernet PHY: RTL8201 @ 0x0dHit any key to stop autoboot: 0 TFTP from server 192.168.1.31; our IP address is 192.168.1.33Filename 'uImage_ipnc_DM368_OV2715'.Load address: 0x80700000Loading: ################################################################# ###############################################################doneBytes transferred = 1865372 (1c769c hex)## Booting kernel from Legacy Image at 80700000 ... Image Name: Linux-2.6.18_pro500-davinci_IPNC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1865308 Bytes = 1.8 MB Load Address: 80008000 Entry Point: 80008000 Verifying Checksum ... OK Loading Kernel Image ... OKOKStarting kernel ...Linux version 2.6.18_pro500-davinci_IPNC_DM368_2.6.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4.2.0-16.0.32.0801914 2008-08-30)) #1 PREEMPT Fri Mar 30 10:02:37 CST 2012CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177Machine: DaVinci DM368 IPNCMemory policy: ECC disabled, Data cache writebackDaVinci DM0365 variant 0x8PLL0: fixedrate: 24000000, commonrate: 135000000, vpssrate: 270000000PLL0: vencrate_sd: 27000000, ddrrate: 270000000 mmcsdrate: 49090909PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000CPU0: D VIVT write-back cacheCPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 setsCPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 setsBuilt 1 zonelists. Total pages: 12288Kernel command line: console=ttyS1,115200n8 noinitrd rw ip=192.168.1.168:192.168.1.31:192.168.1.1:255.255.255.0:::off eth=00:0c:0c:a0:01:01 root=/dev/nfs nfsroot=192.168.1.31:/home/kent/work/mytest/dm368_ov2715_ipnc/target/filesys, nolock mem=48MTI DaVinci EMAC: kernel boot params Ethernet address: 00:0c:0c:a0:01:01PID hash table entries: 256 (order: 8, 1024 bytes)Clock event device timer0_0 configured with caps set: 07Console: colour dummy device 80x30Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)Memory: 48MB = 48MB totalMemory: 44580KB available (3193K code, 653K data, 184K init)Security Framework v1.0.0 initializedCapability LSM initializedMount-cache hash table entries: 512CPU: Testing write buffer coherency: okNET: Registered protocol family 16DaVinci: 104 gpio irqsMUX: initialized GPIO20MUX: initialized I2C_SCLGeneric PHY: Registered new driverch0 default output "COMPOSITE", mode "NTSC"VPBE Encoder InitializedSCSI subsystem initializedNET: Registered protocol family 2IP route cache hash table entries: 512 (order: -1, 2048 bytes)TCP established hash table entries: 2048 (order: 1, 8192 bytes)TCP bind hash table entries: 1024 (order: 0, 4096 bytes)TCP: Hash tables configured (established 2048 bind 1024)TCP reno registeredVFS: Disk quotas dquot_6.5.1Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)squashfs: version 3.1 (2006/08/19) Phillip LougherJFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.yaffs Mar 30 2012 10:00:14 Installing. SGI XFS with no debug enabledInitializing Cryptographic APIio scheduler noop registeredio scheduler anticipatory registered (default)LTT : ltt-facilities initLTT : ltt-facility-core init in kernelDAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 60 secSerial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabledserial8250.0: ttyS0 at MMIO map 0x1c20000 mem 0xfbc20000 (irq = 40) is a 16550Aserial8250.0: ttyS1 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550ARAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksizeDavinci EMAC MII Bus: probedMAC address is 00:0c:0c:a0:01:01TI DaVinci EMAC Linux version updated 4.0netconsole: not configured, abortingLinux video capture interface: v2.00Trying to register davinci display video device.layer=c0632000,layer->video_dev=c0632160Trying to register davinci display video device.layer=c055ae00,layer->video_dev=c055af60davinci_init:DaVinci V4L2 Display Driver V1.0 loadedi2c /dev entries drivernand_davinci nand_davinci.0: Using 4-bit hardware ECCNAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)Creating 6 MTD partitions on "nand_davinci.0":0x00000000-0x00300000 : "bootloader"0x00300000-0x00500000 : "params"0x00500000-0x00700000 : "kernel"0x00700000-0x01f00000 : "filesystem"0x01f00000-0x02100000 : "data1"0x02100000-0x08000000 : "data2"nand_davinci nand_davinci.0: hardware revision: 2.3musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0musb_hdrc musb_hdrc: No DMA interrupt linemusb_hdrc: USB Peripheral mode controller at c3866000 using DMA, IRQ 12rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: procrtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!davinci-mmc davinci-mmc.0: Supporting 4-bit modedavinci-mmc davinci-mmc.0: Using DMA modeAdvanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).ASoC version 0.13.1CQ0093 Voice Codec 0.1asoc: cq93vc <-> davinci-vcif mapping okALSA device list: #0: On-chip voice codec (cq93vc)IPv4 over IPv4 tunneling driverTCP bic registeredNET: Registered protocol family 1NET: Registered protocol family 17rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!rtc wait time out !!!!!Time: timer0_1 clocksource has been installed.Clock event device timer0_0 configured with caps set: 08Switched to high resolution mode on CPU 0rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-09-14 01:01:01 (968893261)1:01 not found1:02 not found1:03 not found1:04 not found1:05 not found1:06 not found1:07 not found1:08 not found1:09 not found1:0a not found1:0b not found1:0c not foundIP-Config: Complete: device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=192.168.1.1, host=192.168.1.168, domain=, nis-domain=(none), bootserver=192.168.1.31, rootserver=192.168.1.31, rootpath=Looking up port of RPC 100003/2 on 192.168.1.31Looking up port of RPC 100005/1 on 192.168.1.31VFS: Mounted root (nfs filesystem).Freeing init memory: 184KINIT: version 2.86 booting0Starting the hotplug events dispatcher: udevd.Synthesizing the initial hotplug events...done.Waiting for /dev to be fully populated...done.0CSL: Module install successful, device major num = 253 CSL: Module version 0.10.00, built on Mar 30 2012 10:04:31 I2C: Module install successful, device major num = 252 DMA: Module install successful, device major num = 251 DRV: Module install successfulDRV: Module built on Mar 30 2012 10:04:35 DRV: EDMACC.QUEPRI = 00000777DRV: SYSTEM.MSTPRI0 = 00440022DRV: SYSTEM.MSTPRI1 = 00000244DRV: ISP.BCR = 00000002DRV: SYSTEM.MISC = 00000311CMEMK module: built on Mar 30 2012 at 10:04:07 Reference Linux version 2.6.18 File /home/kent/work/mytest/dm368_ov2715_ipnc/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.callocated heap buffer 0xc4000000 of size 0x5000000CMEM Range Overlaps Kernel Physical - allowing overlapCMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)cmemk initializedEDMAK module: built on Mar 30 2012 at 10:04:09 Reference Linux version 2.6.18 File /home/kent/work/mytest/dm368_ov2715_ipnc/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.cIRQK module: built on Mar 30 2012 at 10:04:10 Reference Linux version 2.6.18 File /home/kent/work/mytest/dm368_ov2715_ipnc/dvsdk_2_10_01_18/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.cirqk initializedEmpty flash at 0x0006880c ends at 0x00069000Creat queue id:0queue id:0FileMngThread createdCreat queue id:32769queue id:32769queue id:32769AlramThread createdShare memory init successIPNC_DM368_2.6.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4 Creat queue id:65538queue id:65538queue id:65538Creat queue id:98307queue id:98307CPU is DM368./av_server.out DM368 NTSC NONE2A AEWB 720P H264 5000000 VBR AUTO MENUOFF &Check_device_version : DEVICE VER = 0 !!Starting mounting local filesystems: mount none on /dev/shm type tmpfs (rw,size=5M)none on /var/run type tmpfs (rw)none on /tmp type tmpfs (rw,sync)AVSERVER UI: Initializing.Setting up networking ...ApproDrvInit: 7Creat queue id:131076queue id:131076 CLK Hz, ARM Hz = 432000000 DDR Hz = 270000000 VPSS Hz = 270000000 IMCOP Hz = 270000000 DRV LDC: GetConfig 0003 0x0 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameterCONFIGURING AVSERVER FOR DM368 .....queue id:65538 SENSOR FPS VALUE = 30 Sensor Mode Info, Width = 1920 Height = 1080 fps = 30 Bin Enable = 1 flipH = 0 flipV = 0 Sensor Frame Timing Info, fps = 30 t_frame (ns) = 33333334.000000 t_row (ns) = 29375.000000 t_pclk (ns) = 10.416667 W = 1920 H = 1080 SW = 17568 SD = 0 HB = 450 VB = 54 HBmin = 450 VBmin = 9 f_pclk = 96000000 shutterOverhead (ns) = 4437.500000 col_size = 1919 row_size = 1079 col_skip = 0 row_skip = 0 col_bin = 0 row_bin = 0 col_start = 0 row_start = 0 pll_M = 16 pll_N = 1 pll_DIV = 1 vdint0 = 955 vdint1 = 1060 .Starting hotplug subsystem:Common Setting AppliedDavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:layer.pix_fmt.bytesperline = 640, layer.pix_fmt.width = 640, layer.pix_fmt.height = 480, layer.pix_fmt.sizeimage =460800DavinciDisplay DavinciDisplay.1: pixfmt->width = 640, layer->layer_info.config.line_length= 640 FR : 0 users registered from exsiting face albumIPNC_DM368_2.6.0 (root@ubuntu) (gcc version 4.2.0 (MontaVista 4 IPNC AUTO_IRIS = 1 ##################### pci pci [success] usb Simple mixer control 'PGA',0 Capabilities: cvolume Capture channels: Mono Limits: Capture 0 - 3 Mono: Capture 2 [67%]Simple mixer control 'Mono DAC',0 Capabilities: pvolume pvolume-joined Playback channels: Mono Limits: Playback 0 - 63 Mono: Playback 47 [75%]SystemInit successSchedule manager init success usb [success] isapnp isapnp [success] ide ide [success] input input [success] scsi scsi [success]done.Starting portmap daemon: portmap. Starting internet superserver: inetd.io scheduler deadline registeredio scheduler cfq registeredinsmod: sbulla:/opt/ipnc/module unknown partition tables/i2c-emac.ko: No such file or directoryInstalling knfsd (copyright (C) 1996 okir@monad.swb.de).loop: loaded (max 8 devices)tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>CSLIP: code copyright 1989 Regents of the University of Californiainsmod: /opt/ipnc/modules/netconsole.ko: No such file or directoryPPP generic driver version 2.4.2PPP Deflate Compression module registeredinsmod: /opt/ipnc/modules/davinci_emac.ko: No such file or directoryinsmod: /opt/ipnc/modules/mmc_core.ko: No such file or directoryinsmod: /opt/ipnc/modules/mmc_block.ko: No such file or directoryinsmod: /opt/ipnc/modules/davinci-mmc.ko: No such file or directoryinsmod: /opt/ipnc/modules/usbcore.ko: No such file or directoryinsmod: /opt/ipnc/modules/musb_hdrc.ko: No such file or directoryinsmod: /opt/ipnc/modules/usbmon.ko: No such file or directoryLoading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp) sbulla: unknown partition tablemkdosfs 3.0.6 (04 Oct 2009)unable to get drive geometry, using default 255/63/dev/sbulla has 255 heads and 63 sectors per track,logical sector size is 512,using 0xf8 media descriptor, with 1024 sectors;file system has 2 12-bit FATs and 4 sectors per cluster.FAT size is 1 sector, and provides 247 clusters.Root directory contains 512 slots.Volume ID is 36152c07, no volume label.queue id:0umount: /mnt/mmc: not mountedkillall: dhcpcd: no process killedrm: cannot remove `/var/run/dhcpcd-eth0.pid': No such file or directorynet_search_gateway:eth0, 1A8C0, 0, 1net_search_gateway:eth0, 0, 101A8C0, 3dns=192.168.1.1net_search_gateway:eth0, 1A8C0, 0, 1net_search_gateway:eth0, 0, FE01A8C0, 3dns=192.168.1.1g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005ERROR: Module g_g_file_storage gadget: Number of LUNs=1file_storage does not exist in /proc/modulesg_file_storage gadget-lun0: ro=0, file: /dev/sbullaUnable to handle kernel NULL pointer dereference at virtual address 00000004pgd = c2128000[00000004] *pgd=8201d031, *pte=00000000, *ppte=00000000Internal error: Oops: 17 [#1]Modules linked in: g_file_storage sbull iscsi_tcp libiscsi scsi_transport_iscsi ppp_deflate ppp_async ppp_synctty ppp_generic slhc tun loop nfsd exportfs nls_utf8 nls_ascii sha1 md5 des deflate crc32c cfq_iosched deadline_iosched libcrc32c crc_ccitt dm365mmap irqk edmak cmemk drv cslCPU: 0PC is at phy_read+0x1c/0x60LR is at emac_control+0x118/0x4d4pc : [<c0205690>] lr : [<c02077e4>] Not taintedsp : c2203cc8 ip : c2203ce8 fp : c2203ce4r10: c2203eb0 r9 : c2202000 r8 : 00000000r7 : 00000001 r6 : c2203dac r5 : 00000000 r4 : c2202000r3 : c04e9284 r2 : c2203dac r1 : 00000001 r0 : 00000000Flags: Nzcv IRQs off FIQs on Mode SVC_32 Segment userControl: 5317FTable: 82128000 DAC: 00000015Process system_server (pid: 538, stack limit = 0xc2202258)Stack: (0xc2203cc8 to 0xc2204000)3cc0: c04e9280 c04e9280 c2203dac c2203dac c2203da4 c2203ce8 3ce0: c02077e4 c0205684 c2203d0c c2203cf8 c00b2c0c c00b2b78 c271b058 ffffffea 3d00: c2203d34 c2203d10 c00d6930 c00b2bb4 00000000 c2761c58 00000000 c2715d98 3d20: c2715e0c c2203f00 c2203d6c c2203d38 c00a8540 c00a843c c2203d6c c2203d48 3d40: c00b38f8 c01d59cc c271b058 c2203f00 c2715d98 c2202000 00000000 00000003 3d60: c2203dbc c2203d70 c00aaf88 c00b38d0 00000101 c2203d80 c0067ba0 117f4036 3d80: 60000013 c04e9280 c2203dac c2202000 00000000 c2203eb0 c2203e6c c2203da8 3da0: c020bb3c c02076dc c0555118 00000001 00000001 00000001 c00ab240 c00b8a5c 3dc0: c0555118 c0474220 c2761ed8 c0474120 c2203f4c 00000000 00000020 00000000 3de0: c03034b4 00000000 c2203e0c c2303df8 c0055b68 c01c3f84 00000000 00000000 3e00: c2203e1c c2203e10 c0055ba8 c0055b54 c2203e3c 00000000 00000020 00000000 3e20: c03034b4 00000000 00000044 35383f00 00003134 ffffffff 60000013 c00d236c 3e40: c2203e6c c2203e50 00000016 42a23d8c c0093f90 000089f0 c04e9000 c2203eb0 3e60: c2203e8c c2203e70 c027f304 c020ba0c c2203e8c c2203eb0 000089f0 42a23d6c 3e80: c2203f04 c2203e90 c0280780 c027ef74 c2203eec c2203ea0 c01da3a4 c01d964c 3ea0: 0000000a ffffffff ffffffff 00000000 30687465 00000000 00000000 00000000 3ec0: 42a23d98 00000000 00000000 00000000 00000119 c2203f3c c28d1114 c0f4cb20 3ee0: 000089f0 42a23d6c c0f4cb20 00000004 c2202000 00000000 c2203f24 c2203f08 3f00: c02728e8 c0280240 c2203f64 c0f4cb20 42a23d6c 000089f0 c2203f44 c2203f28 3f20: c00adc2c c0272700 00000002 c0f4cb20 00000004 42a23d6c c2203f74 c2203f48 3f40: c00adf50 c00adc04 c0f9ee20 00000004 409ef000 00000000 42a23d6c 000089f0 3f60: 00000004 c2202000 c2203fa4 c2203f78 c00ae02c c00adc9c c2203fa4 00000001 3f80: c0273a24 00000000 00000001 42a23d6c 00000036 c0036f88 00000000 c2203fa8 3fa0: c0036f58 c00adf88 00000000 00000001 00000004 000089f0 42a23d6c 42a23d98 3fc0: 00000000 00000001 42a23d6c 00000036 00000000 003d0f00 4009685c 00000000 3fe0: 00000004 42a23d68 0001adf0 4016b27c 60000010 00000004 ffffffff ffffffff Backtrace: [<c0205674>] (phy_read+0x0/0x60) from [<c02077e4>] (emac_control+0x118/0x4d4) r7 = C2203DAC r6 = C2203DAC r5 = C04E9280 r4 = C04E9280[<c02076cc>] (emac_control+0x0/0x4d4) from [<c020bb3c>] (emac_ioctl+0x140/0x4a0)[<c020b9fc>] (emac_ioctl+0x0/0x4a0) from [<c027f304>] (dev_ifsioc+0x3a0/0x3e8) r6 = C2203EB0 r5 = C04E9000 r4 = 000089F0 [<c027ef64>] (dev_ifsioc+0x0/0x3e8) from [<c0280780>] (dev_ioctl+0x550/0x5ec) r6 = 42A23D6C r5 = 000089F0 r4 = C2203EB0 [<c0280230>] (dev_ioctl+0x0/0x5ec) from [<c02728e8>] (sock_ioctl+0x1f8/0x230)[<c02726f0>] (sock_ioctl+0x0/0x230) from [<c00adc2c>] (do_ioctl+0x38/0x98) r6 = 000089F0 r5 = 42A23D6C r4 = C0F4CB20 [<c00adbf4>] (do_ioctl+0x0/0x98) from [<c00adf50>] (vfs_ioctl+0x2c4/0x2ec) r6 = 42A23D6C r5 = 00000004 r4 = C0F4CB20 [<c00adc8c>] (vfs_ioctl+0x0/0x2ec) from [<c00ae02c>] (sys_ioctl+0xb4/0xe8) r9 = C2202000 r8 = 00000004 r6 = 000089F0 r5 = 42A23D6C r4 = 00000000 [<c00adf78>] (sys_ioctl+0x0/0xe8) from [<c0036f58>] (__sys_trace_return+0x0/0x28) r8 = C0036F88 r7 = 00000036 r6 = 42A23D6C r5 = 00000001 r4 = 00000000 Code: e3cd4d7f e3c4403f e1a05000 e1a07001 (e5906004) ApproDrvInit: 3queue id:131076queue id:0queue id:32769[14/Sep/2000:01:01:23 +0000] boa: server version Boa/0.94.13[14/Sep/2000:01:01:23 +0000] boa: server built Mar 30 2012 at 10:05:57.[14/Sep/2000:01:01:23 +0000] boa: starting server pid=800, port 80queue id:0UDPString=uuid:Upnp-TVEmulator-1_0-00_0060419972</UDN>Timeout reached while wating for return valueCould not receive return value from daemon process. Module | Avg Time/Frame | Frame-rate | Total time | Total Frames | CAPTURE | 33.74 | 29.64 | 30399 | 901 | ENCODE0 | 17.99 | 55.59 | 16191 | 900 | STREAM | 0.17 | 5732.48 | 157 | 900 | OSD0 | 0.04 | 22282.05 | 39 | 869 | AEWB | 0.01 | 69230.77 | 13 | 900 |Timeout reached while wating for return valueCould not receive return value from daemon process.INIT: Entering runlevel: 3MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774)192.168.1.168 login: Module | Avg Time/Frame | Frame-rate | Total time | Total Frames | CAPTURE | 33.36 | 29.98 | 30056 | 901 | ENCODE0 | 17.40 | 57.47 | 15677 | 901 | STREAM | 0.16 | 6300.70 | 143 | 901 | OSD0 | 0.03 | 32178.57 | 28 | 901 | AEWB | 0.01 | 69307.70 | 13 | 901 | Module | Avg Time/Frame | Frame-rate | Total time | Total Frames | CAPTURE | 33.37 | 29.97 | 30062 | 901 | ENCODE0 | 17.40 | 57.46 | 15680 | 901 | STREAM | 0.17 | 5812.90 | 155 | 901 | OSD0 | 0.04 | 27303.03 | 33 | 901 | AEWB | 0.02 | 56312.50 | 16 | 901 |
Can you please run this command to erase old flash setting
cd /opt/ipnc./killall.shumount /mnt/nand/flash_eraseall /dev/mtd4
Also, please check the v3.0 of IPNC RDK which is available now
I use those commands to umount nand flash and erase. but reboot IPNC, it is still login fail in IE.
Looks like some issue with your fielesystem, can you untar the filesystem again as ROOt and rebuild the code and try it.
filesystem.tar.gz is available at utils\bin folder
RAghu
I untar filesystem.tar.gz and rebuild, but there is the same issues.
