• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » How to play H.264 stream in Milestone Xprotect?
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
David61317
Posted by David61317
on Mar 17 2012 00:12 AM
Prodigy85 points
Hi guys,
Now we are using Milestone Xprotect to play DM368 H.264 stream via ONVIF protocol, the problem we encounter is:
Using ONVIF protocol,  Milestone not only finds IPNC and adds it to devices lists, also Milestone gets the correct StreamUri (such as: rtsp :/ / 192.168.1.168:554 / PSIA/Streaming/channels/2?VideoCodecType=H.264, the RTSP port we use have been change to 554).
However, when Milestone plays the StreamUri  via RTSP, the session will be closed  after a few seconds (as shown the following log).  I thought the IPNC had pushed the H.264 stream to Milestone, but Milestone played the stream unsuccessfully, so a few seconds later, it sent the "TEAR DOWN" to IPNC and the session closed. But when the type of stream is MPEG4 or MJPEG, Milestone able to correctly play the stream.
Therefore, we suspect that Milestone can't play the H.264 stream which encodes by DM368 , so I hope somebody can help us to solve the problem as soon as possible, thanks you!
 David
DESCRIBE rtsp://10.0.1.28:554/PSIA/Streaming/channels/2?videoCodecType=H.264 RTSP/1.0
CSeq: 1
Accept: application/sdp
User-Agent: CmRtspClient 61802
Bandwidth: 384000
RTSP/1.0 200 OK
CSeq: 1
Date: Mon, Jan 03 2000 01:15:03 GMT
Content-Base: rtsp://10.0.1.28/PSIA/Streaming/channels/2?videoCodecType=H.264/
Content-Type: application/sdp
Content-Length: 626
 v=0
o=- 946861952144853 1 IN IP4 10.0.1.28
s=RTSP/RTP stream from IPNC
i=2?videoCodecType=H.264
t=0 0
a=tool:LIVE555 Streaming Media v2010.07.29
a=type:broadcast
a=control:*
a=range:npt=0-
a=x-qt-text-nam:RTSP/RTP stream from IPNC
a=x-qt-text-inf:2?videoCodecType=H.264
m=video 0 RTP/AVP 96
c=IN IP4 0.0.0.0
b=AS:12000
a=rtpmap:96 H264/90000
a=fmtp:96 packetization-mode=1;profile-level-id=64001F;sprop-parameter-sets=Z2QAKK2EBUViuKxUdCAqKxXFYqOhAVFYrisVHQgKisVxWKjoQFRWK4rFR0ICorFcVio6ECSFITk8nyfk/k/J8nm5s00IEkKQnJ5Pk/J/J+T5PNzZprQCgC3YCqQAAAMABAAAAwJZgQAB6EgAAiVQve+F4RCNQAAAAAE=,aM48sA==
a=control:track1
SETUP rtsp://10.0.1.28/PSIA/Streaming/channels/2?videoCodecType=H.264/track1 RTSP/1.0
CSeq: 2
Transport: RTP/AVP/TCP;unicast;interleaved=0-1
Blocksize: 65535
 RTSP/1.0 200 OK
CSeq: 2
Transport: RTP/AVP/TCP;unicast;destination=10.0.1.37;source=10.0.1.28;interleaved=0-1
Session: 2B3C55F8
PLAY rtsp://10.0.1.28/PSIA/Streaming/channels/2?videoCodecType=H.264/ RTSP/1.0
Session: 2B3C55F8
CSeq: 3
Range: npt=0.000-
 RTSP/1.0 200 OK
CSeq: 3
Range: npt=0.000-
Session: 2B3C55F8
RTP-Info: url=rtsp://10.0.1.28/PSIA/Streaming/channels/2?videoCodecType=H.264/track1;seq=53254;rtptime=2354776871
 TEARDOWN rtsp://10.0.1.28/PSIA/Streaming/channels/2?videoCodecType=H.264/ RTSP/1.0
CSeq: 4
Session: 2B3C55F8
 RTSP/1.0 200 OK
CSeq: 4
Date: Mon, Jan 03 2000 01:15:06 GMT
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Kirill Brilliantov
    Posted by Kirill Brilliantov
    on Mar 19 2012 13:55 PM
    Genius3470 points
    What method you use for get RTSP-stream from Milestone? I am use "RTP via UDP" and after some work "RTP via HTTP" for get RTSP-stream from camera.
    Report Abuse
    • Reply
  • zhang lei74405
    Posted by zhang lei74405
    on Mar 27 2012 07:09 AM
    Prodigy230 points
    do you try PSIA protocol? In ver 2.6, I use xprotect to connect ipnc368 using PSIA, when I disable audio,video can display ok,but when enable audio, video can only display several seconds just like yours.I advice you to disable audio.
    Report Abuse
    • Reply
  • Suu vivid
    Posted by Suu vivid
    on Apr 08 2012 03:01 AM
    Prodigy10 points
    Hi David,
     I  have the same problem now.
     Did you find out the answer?
    Report Abuse
    • Reply
  • Barath Silvanlabs
    Posted by Barath Silvanlabs
    on May 11 2012 01:30 AM
    Prodigy140 points
    Regarding interoperability with Milestone, we tested IPNC with Milestone X-Protect Enterprise edition 8.0C (trial version) and we were able to successfully view H.264 streams without any changes in the source code. The streams were viewed by selecting the camera as ONVIF con-formant device. These tests were carried out with latest 3.0 binaries.
    Barath Vasudevan
    Report Abuse
    • Reply
  • frivas
    Posted by frivas
    on Aug 02 2012 13:14 PM
    Prodigy125 points
    I am also having trouble getting video in the Mileston XProtect.  My custom board is identical to the DM365 IPNC except for my video comes in through C0-C7 from a TVP5150AM1.  I tried to update to V3.0 but I got an error:
    TimeOut occure in boot_proc.
    Program exit.
    So then I downloaded V4.0 and compiled for TFTP/NFS and got a similar problem (I attached my terminal screen below).  Does the UBL and u-boot have any changes from version 2.5?  I tried with the V2.5 UBL & u-boot and also with the binaries included in V3.0 & V4.0 but still no luck booting the system.
    I would appreciate any help.
    DM36x initialization passed!
    TI UBL Version: 1.50
    Booting Catalog Boot Loader
    BootMode = NAND
    Starting NAND Copy...
    Valid magicnum, 0xA1ACED66, found in block 0x00000008.
       DONE
    Jumping to entry point at 0x81080000.
    DM365_IPNC_UBL_1.0.0
    U-Boot 1.3.4 (Mar  5 2012 - 15:45:15) CVD-IPNC-1.0.2
    I2C:   ready
    DRAM:  128 MB
    NAND:  NAND device: Manufacturer ID: 0xec, Chip ID: 0x75 (Samsung NAND 32MiB 3,3V 8-bit)
    Bad block table found at page 65504, version 0x00
    Bad block table found at page 65472, version 0x00
    32 MiB
    In:    serial
    Out:   serial
    Err:   serial
    ARM Clock :- 297MHz
    DDR Clock :- 270MHz
    Ethernet PHY: GENERIC @ 0x01
    Hit any key to stop autoboot:  0
    TFTP from server 192.168.1.41; our IP address is 192.168.1.168
    Filename 'user/IPNC_V4.0/Source/ipnc_rdk/tftp/uImage_ipnc_dm365'.
    Load address: 0x80700000
    Loading: #################################################################
    done
    Bytes transferred = 3842560 (3aa200 hex)
    ## Booting kernel from Legacy Image at 80700000 ...
       Image Name:   Linux-2.6.37_IPNC_DM365_4.0.0
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    3842496 Bytes =  3.7 MB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    OK
    Starting kernel ...
    [    0.000000] Linux version 2.6.37_IPNC_DM365_4.0.0 (user@ubuntu-desktop) (gcc version 4.3.3 (GCC)
    ) #1 PREEMPT Sat Jul 21 23:17:48 MDT 2012
    [    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    [    0.000000] CPU: VIVT data cache, VIVT instruction cache
    [    0.000000] Machine: DaVinci DM36x IPNC
    [    0.000000] Memory policy: ECC disabled, Data cache writeback
    [    0.000000] DaVinci dm36x_rev1.2 variant 0x8
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 12192
    [    0.000000] Kernel command line: console=ttyS1,115200n8 noinitrd rw ip=192.168.1.168 eth=00:0C:0C
    :A0:FF:FA root=/dev/nfs nfsroot=192.168.1.41:/home/user/IPNC_V4.0/Source/ipnc_rdk/target/filesys,nol
    ock mem=48M cmemk.phys_start="0x83000000" cmemk.phys_end="0x88000000" cmemk.phys_start_1="0x00001000
    " cmemk.phys_end_1="0x00008000" cmemk.pools_1="1x28672" cmemk.allowOverlap=1
    [    0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: 00:0C:0C:A0:FF:FA
    [    0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
    [    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Memory: 48MB = 48MB total
    [    0.000000] Memory: 44772k/44772k available, 4380k reserved, 0K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     DMA     : 0xff000000 - 0xffe00000   (  14 MB)
    [    0.000000]     vmalloc : 0xc3800000 - 0xfea00000   ( 946 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xc3000000   (  48 MB)
    [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
    [    0.000000]       .init : 0xc0008000 - 0xc002a000   ( 136 kB)
    [    0.000000]       .text : 0xc002a000 - 0xc038b000   (3460 kB)
    [    0.000000]       .data : 0xc038c000 - 0xc03b21c0   ( 153 kB)
    [    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] Preemptable hierarchical RCU implementation.
    [    0.000000]  RCU-based detection of stalled CPUs is disabled.
    [    0.000000]  Verbose stalled-CPUs detection is disabled.
    [    0.000000] NR_IRQS:245
    [    0.000000] Console: colour dummy device 80x30
    [    0.000398] Calibrating delay loop... 147.86 BogoMIPS (lpj=739328)
    [    0.220078] pid_max: default: 32768 minimum: 301
    [    0.220501] Mount-cache hash table entries: 512
    [    0.221546] CPU: Testing write buffer coherency: ok
    [    0.227533] DaVinci: 8 gpio irqs
    [    0.228345] NET: Registered protocol family 16
    [    0.247452] EVM: (null) video input
    [    0.348805] bio: create slab <bio-0> at 0
    [    0.355149] SCSI subsystem initialized
    [    0.360393] usbcore: registered new interface driver usbfs
    [    0.362128] usbcore: registered new interface driver hub
    [    0.363276] usbcore: registered new device driver usb
    [    0.367403] vpss vpss: dm365_vpss vpss probed
    [    0.367491] vpss vpss: dm365_vpss vpss probe success
    [    0.369923] Advanced Linux Sound Architecture Driver Version 1.0.23.
    [    0.372823] Switching to clocksource timer0_1
    [    0.453787] NET: Registered protocol family 2
    [    0.454193] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.455221] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
    [    0.455428] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.455561] TCP: Hash tables configured (established 2048 bind 2048)
    [    0.455609] TCP reno registered
    [    0.455670] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.455764] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.456486] NET: Registered protocol family 1
    [    0.457806] RPC: Registered udp transport module.
    [    0.457868] RPC: Registered tcp transport module.
    [    0.457911] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.554349] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    0.555336] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    0.560215] msgmni has been set to 87
    [    0.565533] io scheduler noop registered (default)
    [    0.567535] CSL: Module install successful, device major num = 254
    [    0.567600] CSL: Module version 0.10.00, built on Jul 21 2012 23:08:33
    [    0.567674] I2C: Module install successful, device major num = 253
    [    0.567728] DMA: Module install successful, device major num = 252
    [    0.567767] DRV: Module install successful
    [    0.567803] DRV: Module built on Jul 21 2012 23:08:34
    [    0.567842] DRV: EDMACC.QUEPRI  = 00002777
    [    0.567875] DRV: SYSTEM.MSTPRI0 = 00440011
    [    0.567908] DRV: SYSTEM.MSTPRI1 = 00000444
    [    0.567940] DRV: ISP.BCR        = 00000002
    [    0.567973] DRV: SYSTEM.MISC    = 00000399
    [    0.568005] EDMAK module: built on Jul 21 2012 at 23:08:18
    [    0.568049]   Reference Linux version 2.6.37
    [    0.568083]   File /home/user/IPNC_V4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/
    sdo/linuxutils/edma/src/module/edmak.c
    [    0.569954] IRQK module: built on Jul 21 2012 at 22:54:19
    [    0.570022]   Reference Linux version 2.6.37
    [    0.570060]   File /home/user/IPNC_V4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/
    sdo/linuxutils/irq/src/module/irqk.c
    [    0.571928] irqk initialized
    [    0.572024] CMEMK module: built on Jul 21 2012 at 23:08:16
    [    0.572078]   Reference Linux version 2.6.37
    [    0.572114]   File /home/user/IPNC_V4.0/Source/dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/
    sdo/linuxutils/cmem/src/module/cmemk.c
    [    0.578949] allocated heap buffer 0xc4000000 of size 0x5000000
    [    0.579017] CMEM Range Overlaps Kernel Physical - allowing overlap
    [    0.579072] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
    [    0.579264] cmemk initialized
    [    0.579338] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
    [    0.604529] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
    [    0.627087] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
    [    1.155752] console [ttyS1] enabled
    [    1.163781] brd: module loaded
    [    1.178221] NAND device: Manufacturer ID: 0xec, Chip ID: 0x75 (Samsung )
    [    1.186140] Bad block table not found for chip 0
    [    1.191352] Bad block table not found for chip 0
    [    1.196242] Scanning device for bad blocks
    [    1.250983] Bad eraseblock 797 at 0x000000c74000
    [    1.318679] Bad eraseblock 1792 at 0x000001c00000
    [    1.323555] Bad eraseblock 1793 at 0x000001c04000
    [    1.328327] Bad eraseblock 1794 at 0x000001c08000
    [    1.333196] Bad eraseblock 1795 at 0x000001c0c000
    [    1.337968] Bad eraseblock 1796 at 0x000001c10000
    [    1.342726] Bad eraseblock 1797 at 0x000001c14000
    [    1.347594] Bad eraseblock 1798 at 0x000001c18000
    [    1.352364] Bad eraseblock 1799 at 0x000001c1c000
    [    1.357235] Bad eraseblock 1800 at 0x000001c20000
    [    1.362004] Bad eraseblock 1801 at 0x000001c24000
    [    1.366871] Bad eraseblock 1802 at 0x000001c28000
    [    1.371642] Bad eraseblock 1803 at 0x000001c2c000
    [    1.376511] Bad eraseblock 1804 at 0x000001c30000
    [    1.381283] Bad eraseblock 1805 at 0x000001c34000
    [    1.386151] Bad eraseblock 1806 at 0x000001c38000
    [    1.390923] Bad eraseblock 1807 at 0x000001c3c000
    [    1.395795] Bad eraseblock 1808 at 0x000001c40000
    [    1.400565] Bad eraseblock 1809 at 0x000001c44000
    [    1.405433] Bad eraseblock 1810 at 0x000001c48000
    [    1.410202] Bad eraseblock 1811 at 0x000001c4c000
    [    1.415069] Bad eraseblock 1812 at 0x000001c50000
    [    1.419839] Bad eraseblock 1813 at 0x000001c54000
    [    1.424707] Bad eraseblock 1814 at 0x000001c58000
    [    1.429477] Bad eraseblock 1815 at 0x000001c5c000
    [    1.434345] Bad eraseblock 1816 at 0x000001c60000
    [    1.439115] Bad eraseblock 1817 at 0x000001c64000
    [    1.443983] Bad eraseblock 1818 at 0x000001c68000
    [    1.448753] Bad eraseblock 1819 at 0x000001c6c000
    [    1.453623] Bad eraseblock 1820 at 0x000001c70000
    [    1.458391] Bad eraseblock 1821 at 0x000001c74000
    [    1.463260] Bad eraseblock 1822 at 0x000001c78000
    [    1.468031] Bad eraseblock 1823 at 0x000001c7c000
    [    1.472789] Bad eraseblock 1824 at 0x000001c80000
    [    1.477655] Bad eraseblock 1825 at 0x000001c84000
    [    1.482424] Bad eraseblock 1826 at 0x000001c88000
    [    1.487294] Bad eraseblock 1827 at 0x000001c8c000
    [    1.492064] Bad eraseblock 1828 at 0x000001c90000
    [    1.496934] Bad eraseblock 1829 at 0x000001c94000
    [    1.501705] Bad eraseblock 1830 at 0x000001c98000
    [    1.506571] Bad eraseblock 1831 at 0x000001c9c000
    [    1.511341] Bad eraseblock 1832 at 0x000001ca0000
    [    1.516209] Bad eraseblock 1833 at 0x000001ca4000
    [    1.520979] Bad eraseblock 1834 at 0x000001ca8000
    [    1.525850] Bad eraseblock 1835 at 0x000001cac000
    [    1.530619] Bad eraseblock 1836 at 0x000001cb0000
    [    1.535487] Bad eraseblock 1837 at 0x000001cb4000
    [    1.540259] Bad eraseblock 1838 at 0x000001cb8000
    [    1.545127] Bad eraseblock 1839 at 0x000001cbc000
    [    1.549895] Bad eraseblock 1840 at 0x000001cc0000
    [    1.554765] Bad eraseblock 1841 at 0x000001cc4000
    [    1.559534] Bad eraseblock 1842 at 0x000001cc8000
    [    1.564404] Bad eraseblock 1843 at 0x000001ccc000
    [    1.569172] Bad eraseblock 1844 at 0x000001cd0000
    [    1.574042] Bad eraseblock 1845 at 0x000001cd4000
    [    1.578812] Bad eraseblock 1846 at 0x000001cd8000
    [    1.583682] Bad eraseblock 1847 at 0x000001cdc000
    [    1.588452] Bad eraseblock 1848 at 0x000001ce0000
    [    1.593319] Bad eraseblock 1849 at 0x000001ce4000
    [    1.598091] Bad eraseblock 1850 at 0x000001ce8000
    [    1.602849] Bad eraseblock 1851 at 0x000001cec000
    [    1.607715] Bad eraseblock 1852 at 0x000001cf0000
    [    1.612483] Bad eraseblock 1853 at 0x000001cf4000
    [    1.617349] Bad eraseblock 1854 at 0x000001cf8000
    [    1.622117] Bad eraseblock 1855 at 0x000001cfc000
    [    1.626984] Bad eraseblock 1856 at 0x000001d00000
    [    1.631756] Bad eraseblock 1857 at 0x000001d04000
    [    1.636622] Bad eraseblock 1858 at 0x000001d08000
    [    1.641394] Bad eraseblock 1859 at 0x000001d0c000
    [    1.646263] Bad eraseblock 1860 at 0x000001d10000
    [    1.651032] Bad eraseblock 1861 at 0x000001d14000
    [    1.655900] Bad eraseblock 1862 at 0x000001d18000
    [    1.660671] Bad eraseblock 1863 at 0x000001d1c000
    [    1.665541] Bad eraseblock 1864 at 0x000001d20000
    [    1.670311] Bad eraseblock 1865 at 0x000001d24000
    [    1.675175] Bad eraseblock 1866 at 0x000001d28000
    [    1.679947] Bad eraseblock 1867 at 0x000001d2c000
    [    1.684816] Bad eraseblock 1868 at 0x000001d30000
    [    1.689583] Bad eraseblock 1869 at 0x000001d34000
    [    1.694451] Bad eraseblock 1870 at 0x000001d38000
    [    1.699221] Bad eraseblock 1871 at 0x000001d3c000
    [    1.704095] Bad eraseblock 1872 at 0x000001d40000
    [    1.708864] Bad eraseblock 1873 at 0x000001d44000
    [    1.713732] Bad eraseblock 1874 at 0x000001d48000
    [    1.718498] Bad eraseblock 1875 at 0x000001d4c000
    [    1.723368] Bad eraseblock 1876 at 0x000001d50000
    [    1.728137] Bad eraseblock 1877 at 0x000001d54000
    [    1.732897] Bad eraseblock 1878 at 0x000001d58000
    [    1.737761] Bad eraseblock 1879 at 0x000001d5c000
    [    1.742530] Bad eraseblock 1880 at 0x000001d60000
    [    1.747401] Bad eraseblock 1881 at 0x000001d64000
    [    1.752169] Bad eraseblock 1882 at 0x000001d68000
    [    1.757035] Bad eraseblock 1883 at 0x000001d6c000
    [    1.761804] Bad eraseblock 1884 at 0x000001d70000
    [    1.766675] Bad eraseblock 1885 at 0x000001d74000
    [    1.771443] Bad eraseblock 1886 at 0x000001d78000
    [    1.776311] Bad eraseblock 1887 at 0x000001d7c000
    [    1.781079] Bad eraseblock 1888 at 0x000001d80000
    [    1.785945] Bad eraseblock 1889 at 0x000001d84000
    [    1.790713] Bad eraseblock 1890 at 0x000001d88000
    [    1.795583] Bad eraseblock 1891 at 0x000001d8c000
    [    1.800353] Bad eraseblock 1892 at 0x000001d90000
    [    1.805226] Bad eraseblock 1893 at 0x000001d94000
    [    1.809995] Bad eraseblock 1894 at 0x000001d98000
    [    1.814864] Bad eraseblock 1895 at 0x000001d9c000
    [    1.819635] Bad eraseblock 1896 at 0x000001da0000
    [    1.824504] Bad eraseblock 1897 at 0x000001da4000
    [    1.829272] Bad eraseblock 1898 at 0x000001da8000
    [    1.834143] Bad eraseblock 1899 at 0x000001dac000
    [    1.838911] Bad eraseblock 1900 at 0x000001db0000
    [    1.843776] Bad eraseblock 1901 at 0x000001db4000
    [    1.848546] Bad eraseblock 1902 at 0x000001db8000
    [    1.853415] Bad eraseblock 1903 at 0x000001dbc000
    [    1.858186] Bad eraseblock 1904 at 0x000001dc0000
    [    1.863056] Bad eraseblock 1905 at 0x000001dc4000
    [    1.867824] Bad eraseblock 1906 at 0x000001dc8000
    [    1.872583] Bad eraseblock 1907 at 0x000001dcc000
    [    1.877455] Bad eraseblock 1908 at 0x000001dd0000
    [    1.882229] Bad eraseblock 1909 at 0x000001dd4000
    [    1.887099] Bad eraseblock 1910 at 0x000001dd8000
    [    1.891871] Bad eraseblock 1911 at 0x000001ddc000
    [    1.896742] Bad eraseblock 1912 at 0x000001de0000
    [    1.901513] Bad eraseblock 1913 at 0x000001de4000
    [    1.906383] Bad eraseblock 1914 at 0x000001de8000
    [    1.911155] Bad eraseblock 1915 at 0x000001dec000
    [    1.916029] Bad eraseblock 1916 at 0x000001df0000
    [    1.920798] Bad eraseblock 1917 at 0x000001df4000
    [    1.925670] Bad eraseblock 1918 at 0x000001df8000
    [    1.930441] Bad eraseblock 1919 at 0x000001dfc000
    [    1.935313] Bad eraseblock 1920 at 0x000001e00000
    [    1.940081] Bad eraseblock 1921 at 0x000001e04000
    [    1.944954] Bad eraseblock 1922 at 0x000001e08000
    [    1.949722] Bad eraseblock 1923 at 0x000001e0c000
    [    1.954596] Bad eraseblock 1924 at 0x000001e10000
    [    1.959365] Bad eraseblock 1925 at 0x000001e14000
    [    1.964235] Bad eraseblock 1926 at 0x000001e18000
    [    1.969004] Bad eraseblock 1927 at 0x000001e1c000
    [    1.973877] Bad eraseblock 1928 at 0x000001e20000
    [    1.978649] Bad eraseblock 1929 at 0x000001e24000
    [    1.983516] Bad eraseblock 1930 at 0x000001e28000
    [    1.988284] Bad eraseblock 1931 at 0x000001e2c000
    [    1.993153] Bad eraseblock 1932 at 0x000001e30000
    [    1.997921] Bad eraseblock 1933 at 0x000001e34000
    [    2.002678] Bad eraseblock 1934 at 0x000001e38000
    [    2.007549] Bad eraseblock 1935 at 0x000001e3c000
    [    2.012318] Bad eraseblock 1936 at 0x000001e40000
    [    2.017186] Bad eraseblock 1937 at 0x000001e44000
    [    2.021954] Bad eraseblock 1938 at 0x000001e48000
    [    2.026822] Bad eraseblock 1939 at 0x000001e4c000
    [    2.031590] Bad eraseblock 1940 at 0x000001e50000
    [    2.036456] Bad eraseblock 1941 at 0x000001e54000
    [    2.041222] Bad eraseblock 1942 at 0x000001e58000
    [    2.046093] Bad eraseblock 1943 at 0x000001e5c000
    [    2.050858] Bad eraseblock 1944 at 0x000001e60000
    [    2.055726] Bad eraseblock 1945 at 0x000001e64000
    [    2.060493] Bad eraseblock 1946 at 0x000001e68000
    [    2.065361] Bad eraseblock 1947 at 0x000001e6c000
    [    2.070128] Bad eraseblock 1948 at 0x000001e70000
    [    2.074994] Bad eraseblock 1949 at 0x000001e74000
    [    2.079761] Bad eraseblock 1950 at 0x000001e78000
    [    2.084633] Bad eraseblock 1951 at 0x000001e7c000
    [    2.089403] Bad eraseblock 1952 at 0x000001e80000
    [    2.094271] Bad eraseblock 1953 at 0x000001e84000
    [    2.099041] Bad eraseblock 1954 at 0x000001e88000
    [    2.103907] Bad eraseblock 1955 at 0x000001e8c000
    [    2.108678] Bad eraseblock 1956 at 0x000001e90000
    [    2.113547] Bad eraseblock 1957 at 0x000001e94000
    [    2.118317] Bad eraseblock 1958 at 0x000001e98000
    [    2.123190] Bad eraseblock 1959 at 0x000001e9c000
    [    2.127959] Bad eraseblock 1960 at 0x000001ea0000
    [    2.132717] Bad eraseblock 1961 at 0x000001ea4000
    [    2.137583] Bad eraseblock 1962 at 0x000001ea8000
    [    2.142354] Bad eraseblock 1963 at 0x000001eac000
    [    2.147223] Bad eraseblock 1964 at 0x000001eb0000
    [    2.151992] Bad eraseblock 1965 at 0x000001eb4000
    [    2.156859] Bad eraseblock 1966 at 0x000001eb8000
    [    2.161629] Bad eraseblock 1967 at 0x000001ebc000
    [    2.166503] Bad eraseblock 1968 at 0x000001ec0000
    [    2.171273] Bad eraseblock 1969 at 0x000001ec4000
    [    2.176139] Bad eraseblock 1970 at 0x000001ec8000
    [    2.180907] Bad eraseblock 1971 at 0x000001ecc000
    [    2.185781] Bad eraseblock 1972 at 0x000001ed0000
    [    2.190551] Bad eraseblock 1973 at 0x000001ed4000
    [    2.195420] Bad eraseblock 1974 at 0x000001ed8000
    [    2.200188] Bad eraseblock 1975 at 0x000001edc000
    [    2.205054] Bad eraseblock 1976 at 0x000001ee0000
    [    2.209821] Bad eraseblock 1977 at 0x000001ee4000
    [    2.214689] Bad eraseblock 1978 at 0x000001ee8000
    [    2.219457] Bad eraseblock 1979 at 0x000001eec000
    [    2.224327] Bad eraseblock 1980 at 0x000001ef0000
    [    2.229095] Bad eraseblock 1981 at 0x000001ef4000
    [    2.233965] Bad eraseblock 1982 at 0x000001ef8000
    [    2.238733] Bad eraseblock 1983 at 0x000001efc000
    [    2.243606] Bad eraseblock 1984 at 0x000001f00000
    [    2.248378] Bad eraseblock 1985 at 0x000001f04000
    [    2.253244] Bad eraseblock 1986 at 0x000001f08000
    [    2.258011] Bad eraseblock 1987 at 0x000001f0c000
    [    2.262771] Bad eraseblock 1988 at 0x000001f10000
    [    2.267637] Bad eraseblock 1989 at 0x000001f14000
    [    2.272408] Bad eraseblock 1990 at 0x000001f18000
    [    2.277280] Bad eraseblock 1991 at 0x000001f1c000
    [    2.282052] Bad eraseblock 1992 at 0x000001f20000
    [    2.286927] Bad eraseblock 1993 at 0x000001f24000
    [    2.291697] Bad eraseblock 1994 at 0x000001f28000
    [    2.296568] Bad eraseblock 1995 at 0x000001f2c000
    [    2.301341] Bad eraseblock 1996 at 0x000001f30000
    [    2.306212] Bad eraseblock 1997 at 0x000001f34000
    [    2.310981] Bad eraseblock 1998 at 0x000001f38000
    [    2.315849] Bad eraseblock 1999 at 0x000001f3c000
    [    2.320616] Bad eraseblock 2000 at 0x000001f40000
    [    2.325485] Bad eraseblock 2001 at 0x000001f44000
    [    2.330253] Bad eraseblock 2002 at 0x000001f48000
    [    2.335119] Bad eraseblock 2003 at 0x000001f4c000
    [    2.339888] Bad eraseblock 2004 at 0x000001f50000
    [    2.344760] Bad eraseblock 2005 at 0x000001f54000
    [    2.349531] Bad eraseblock 2006 at 0x000001f58000
    [    2.354399] Bad eraseblock 2007 at 0x000001f5c000
    [    2.359167] Bad eraseblock 2008 at 0x000001f60000
    [    2.364040] Bad eraseblock 2009 at 0x000001f64000
    [    2.368807] Bad eraseblock 2010 at 0x000001f68000
    [    2.373675] Bad eraseblock 2011 at 0x000001f6c000
    [    2.378446] Bad eraseblock 2012 at 0x000001f70000
    [    2.383319] Bad eraseblock 2013 at 0x000001f74000
    [    2.388091] Bad eraseblock 2014 at 0x000001f78000
    [    2.392854] Bad eraseblock 2015 at 0x000001f7c000
    [    2.397719] Bad eraseblock 2016 at 0x000001f80000
    [    2.402488] Bad eraseblock 2017 at 0x000001f84000
    [    2.407359] Bad eraseblock 2018 at 0x000001f88000
    [    2.412128] Bad eraseblock 2019 at 0x000001f8c000
    [    2.416996] Bad eraseblock 2020 at 0x000001f90000
    [    2.421764] Bad eraseblock 2021 at 0x000001f94000
    [    2.426631] Bad eraseblock 2022 at 0x000001f98000
    [    2.431400] Bad eraseblock 2023 at 0x000001f9c000
    [    2.436268] Bad eraseblock 2024 at 0x000001fa0000
    [    2.441038] Bad eraseblock 2025 at 0x000001fa4000
    [    2.445907] Bad eraseblock 2026 at 0x000001fa8000
    [    2.450678] Bad eraseblock 2027 at 0x000001fac000
    [    2.455547] Bad eraseblock 2028 at 0x000001fb0000
    [    2.460315] Bad eraseblock 2029 at 0x000001fb4000
    [    2.465180] Bad eraseblock 2030 at 0x000001fb8000
    [    2.469950] Bad eraseblock 2031 at 0x000001fbc000
    [    2.474814] Bad eraseblock 2032 at 0x000001fc0000
    [    2.479582] Bad eraseblock 2033 at 0x000001fc4000
    [    2.484451] Bad eraseblock 2034 at 0x000001fc8000
    [    2.489222] Bad eraseblock 2035 at 0x000001fcc000
    [    2.494092] Bad eraseblock 2036 at 0x000001fd0000
    [    2.498862] Bad eraseblock 2037 at 0x000001fd4000
    [    2.503730] Bad eraseblock 2038 at 0x000001fd8000
    [    2.508500] Bad eraseblock 2039 at 0x000001fdc000
    [    2.513366] Bad eraseblock 2040 at 0x000001fe0000
    [    2.518134] Bad eraseblock 2041 at 0x000001fe4000
    [    2.522892] Bad eraseblock 2042 at 0x000001fe8000
    [    2.527760] Bad eraseblock 2043 at 0x000001fec000
    [    2.532657] Bad eraseblock 2046 at 0x000001ff8000
    [    2.537526] Bad eraseblock 2047 at 0x000001ffc000
    [    2.546852] Creating 5 MTD partitions on "davinci_nand.0":
    [    2.552411] 0x000000000000-0x000000080000 : "bootloader"
    [    2.563151] 0x000000080000-0x000000200000 : "params"
    [    2.573547] 0x000000200000-0x000000600000 : "kernel"
    [    2.584175] 0x000000600000-0x000001e00000 : "filesystem1"
    [    2.595825] 0x000001e00000-0x000002000000 : "filesystem2"
    [    2.606947] davinci_nand davinci_nand.0: controller rev. 2.3
    [    2.663048] davinci_mdio davinci_mdio.0: davinci mdio revision 1.4
    [    2.669276] davinci_mdio davinci_mdio.0: detected phy mask fffffffd
    [    2.677460] davinci_mdio.0: probed
    [    2.680927] davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
    [    2.689074] i2c /dev entries driver
    [    2.695494] Linux media interface: v0.10
    [    2.700343] Linux video capture interface: v2.00
    [    2.707954] vpbe-osd vpbe-osd: OSD sub device probe success
    [    2.714898] vpbe-venc vpbe-venc: VENC sub device probe success
    [    2.722022] vpbe-v4l2 vpbe-v4l2: vpbe v4l2 device registered
    [    2.728199] Setting default output to Composite
    [    2.732766] Setting default mode to ntsc
    [    2.737065] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
    [    2.743927] vpbe-v4l2 vpbe-v4l2: layer=c28b4a00,layer->video_dev=c28b4ae8
    [    2.751789] vpbe-v4l2 vpbe-v4l2: Trying to register VPBE display device.
    [    2.758833] vpbe-v4l2 vpbe-v4l2: layer=c28b4400,layer->video_dev=c28b44e8
    [    2.768064] watchdog watchdog: heartbeat 60 sec
    [    2.779616] Error: Driver 'davinci-mcbsp' is already registered, aborting...
    [    2.790573] asoc: cq93vc-hifi <-> davinci-vcif mapping ok
    [    2.800538] ALSA device list:
    [    2.803924]   #0: DaVinci DM365 EVM
    [    2.809198] TCP cubic registered
    [    2.812477] NET: Registered protocol family 17
    [    2.829146] net eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, id=181b8b0)
    [    2.853399] IP-Config: Guessing netmask 255.255.255.0
    [    2.859034] IP-Config: Complete:
    [    2.862125]      device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
    [    2.870443]      host=192.168.1.168, domain=, nis-domain=(none),
    [    2.876594]      bootserver=255.255.255.255, rootserver=192.168.1.41, rootpath=
    [    4.823382] PHY: 0:01 - Link is Up - 100/Full
    [    4.940380] VFS: Mounted root (nfs filesystem) on device 0:13.
    [    4.946404] VFS: mounted rootfs
    [    4.949807] Freeing init memory: 136K
    INIT: version 2.86 booting
    Starting mounting local filesystems: mount Creat queue id:0
    queue id:0
    FileMngThread created
    Creat queue id:32769
    queue id:32769
    AlramThread created
    Share memory init success
    IPNC_DM365_4.0.0 (user@ubuntu-desktop) (gcc version 4.3.3 (GCC) ) #1 PREEMPT S
    queue id:32769
    FileMng: Error Can't create system file
    FileMng: Error Initialize fail (FileMgnInit)
    Creat queue id:65537
    queue id:65537
    Creat queue id:98306
    queue id:98306
    FileMsgDrv: Error
    Data read error
    Can't get system info!!
    Kill queue id:32769
    Error CleanupFileEnv is called
    queue id:65537
    FileMsgDrv: Error
    Data read error
    FileMsgDrv: Error
    Data read error
    mount: mounting /dev/root on / failed: No such file or directory
    failed (1: ).
    Starting internet superserver: inetd.
    insmod: can't read '/opt/ipnc/modules/deflate.ko': No such file or directory
    insmod: can't read '/opt/ipnc/modules/des_generic.ko': No such file or directory
    insmod: can't read '/opt/ipnc/modules/md5.ko': No such file or directory
    [    6.952672] davinci_mmc davinci_mmc.0: Using DMA, 4-bit mode
    [    7.126133] Loading iSCSI transport class v2.0-870.
    [    7.547053] iscsi: registered transport (tcp)
    [    7.647442] musb-hdrc: version 6.0, peripheral, debug=0
    [    7.756595] musb-hdrc musb-hdrc: dma type: dma-cppi3
    [    7.784259] musb-hdrc musb-hdrc: USB Peripheral mode controller at fec64000 using DMA, IRQ 12
    [    7.943838] loop: module loaded
    [    8.043298] tun: Universal TUN/TAP device driver, 1.6
    [    8.048393] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [    8.135959] console [netcon0] enabled
    [    8.139650] netconsole: network logging started
    [    8.267942] PPP generic driver version 2.4.2
    [    8.311449] PPP Deflate Compression module registered
    mkdosfs 2.11 (12 Mar 2005)
    unable to get drive geometry, using default 255/63/dev/ram0 has 255 heads and 63 sectors per track,
    logical sector size is 512,
    using 0xf8 media descriptor, with 8192 sectors;
    file system has 2 12-bit FATs and 4 sectors per cluster.
    FAT size is 6 sectors, and provides 2036 clusters.
    Root directory contains 512 slots.
    Volume ID is 00000009, no volume label.
    queue id:0
    Program exit.
    ApproDrvInit: 3
    Creat queue id:131075
    queue id:131075
    INIT: Entering runlevel: 5
    Starting telnet daemon.
    Starting syslogd/klogd: done
    getty: ioctl() TIOCSPGR
    _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org 192.168.1.168 console
    Arago 2009.11 192.168.1.168 console
    192.168.1.168 login: root
    -sh: can't access tty; job control turned off
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
