• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » ONVIF verify failed on Appro 3.0
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
zhang lei74405
Posted by zhang lei74405
on Apr 09 2012 08:14 AM
Prodigy200 points
  Recently I got Appro 3.0 ,  I writed the images into DM368 IPNC and the IPNC can work correctly. Today  I  tested ONVIF protocol using ONVIF Conformance  Tool v1.02.4.But when I began to test, DM368 IPNC  ttyS0 output "caught SIGSEGV, dumping core in /tmp". After output these information, I can't ping IPNC.
So anyone can tell me how to debug this kind of error?
Thanks very much!
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Barath Silvanlabs
    Posted by Barath Silvanlabs
    on Apr 09 2012 09:46 AM
    Prodigy140 points
    Dear Zhang,
    Can you please provide the following details
    - Are you using the binaries given along with 3.0 ref design?
    - Can you please clarify whether, you weren't able to ping the camera or you weren't able to open the GUI page on the IE
    - Please provide the name of the test where it failed
    - It would be helpful if you can provide the screenshot of the test page in ONVIF tool
    Barath Vasudevan
    Report Abuse
    • Reply
  • Raghu Kudva
    Posted by Raghu Kudva
    on Apr 11 2012 05:26 AM
    Expert6665 points
    Also, can you check with tool version 11.12 which we used for the tests
    Raghu
    Please mark this reply as Verify Answer on this post if it answers the question.
    Report Abuse
    • Reply
  • zhang lei74405
    on Apr 13 2012 23:14 PM
    Prodigy200 points
    I am sorry for some mistake discrpition.
    1: I wrote the image into IPNC368 with the raw binary image from 3.0 ref design without any modify;
    2:After error information appear , boa process disappear , and I can't login IE GUI ,but I still can ping IPNC;
    3:when I connect IPNC using swtich equipment when IPNC boot OK,above error information appear almost even if I can't use any PC test tools,
      when I connect IPNC directly to PC ,when IPNC boot OK, above error information disappear almost, but when I use PC ONVIF test tools  to verify IPNC ,error information appear again!
    And I search such error signal,it seems to be memory error or hardware error.
    So anyone can point to how to debug this error?
    Thank you very much
    onvif
    Report Abuse
    • Reply
  • zhang lei74405
    on Apr 15 2012 03:37 AM
    Prodigy200 points
    Raghu Kudva
    Raghu
    Hi ,can you tell me how to get tool version 11.12?I found only onvif members can download test tools from onvif website.
    Thank you very much
    Report Abuse
    • Reply
  • Raghu Kudva
    on Apr 16 2012 03:12 AM
    Expert6665 points
    HI,
    You need to check at ONVIF site for details on the tool, are you a member of this forum? you need to be one to get this detail
    Raghu
    Report Abuse
    • Reply
  • Barath Silvanlabs
    on Apr 16 2012 03:36 AM
    Prodigy140 points
    Hi zhang,
    Can you also please send us the log of the entire boot process?
    Barath Vasudevan
    Report Abuse
    • Reply
  • zhang lei74405
    on Apr 17 2012 07:47 AM
    Prodigy200 points
    The following is my IPNC368 log message:
    DM36x initialization passed!
    TI UBL Base Version: 1.50
    Boot Loader BootMode = NAND
    Starting NAND Copy...
    Valid magicnum, 0xA1ACED66, found in block 0x00000008.
    Boot Mode Task Completed
    IPNC UBL Version: 2.0.0
    Platform: DM368
    Jumping to entry point at 0x81080000
    U-Boot 1.3.4 (Feb 28 2012 - 15:29:09) DM368-IPNC-2.0.0
    I2C: ready
    DRAM: 128 MB
    NAND: NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
    Bad block table found at page 65472, version 0x01
    Bad block table found at page 65408, version 0x01
    128 MiB
    In: serial
    Out: serial
    Err: serial
    ARM Clock :- 432MHz
    DDR Clock :- 340MHz
    Ethernet PHY: GENERIC @ 0x01
    Hit any key to stop autoboot: 4  3  2  1  0
    Loading from NAND 128MiB 3,3V 8-bit, offset 0x500000
    Image Name: Linux-2.6.18_pro500-davinci_IPNC
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 2658244 Bytes = 2.5 MB
    Load Address: 80008000
    Entry Point: 80008000
    ## Booting kernel from Legacy Image at 80700000 ...
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    [ 0.000000] Linux version 2.6.18_pro500-davinci_IPNC_DM368_3.0.0 (a0875405@bangvideoapps01) (gcc version 4.2.0 20070126 (prerelease) (MontaVista 4.2.0-3.0.0.0702771 2007-03-10)) #1 PREEMPT Tue Feb 28 15:37:29 IST 2012
    [ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
    [ 0.000000] Machine: DaVinci DM368 IPNC
    [ 0.000000] Memory policy: ECC disabled, Data cache writeback
    [ 0.000000] DaVinci DM0365 variant 0x8
    [ 0.000000] PLL0: fixedrate: 24000000, commonrate: 170000000, vpssrate: 340000000
    [ 0.000000] PLL0: vencrate_sd: 75555555, ddrrate: 340000000 mmcsdrate: 48571428
    [ 0.000000] PLL1: armrate: 432000000, voicerate: 20571428, vencrate_hd: 27000000
    [ 0.000000] CPU0: D VIVT write-back cache
    [ 0.000000] CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
    [ 0.000000] CPU0: D cache: 8192 bytes, associativity 4, 32 byte lines, 64 sets
    [ 0.000000] Built 1 zonelists. Total pages: 12288
    [ 0.000000] Kernel command line: mem=48M console=ttyS0,115200n8 root=/dev/mtdblock3 rootfstype=squashfs ip=192.168.1.168 eth=00:0C:0C:A0:05:A1 lpj=1077248 cmemk.phys_start="0x83000000" cmemk.phys_end="0x88000000" cmemk.phys_start_1="0x00001000" cmemk.phys_end_1="0x00008000" cmemk.pools_1="1x28672" cmemk.allowOverlap="1"
    [ 0.000000] TI DaVinci EMAC: kernel boot params Ethernet address: 00:0C:0C:A0:05:A1
    [ 0.000000] PID hash table entries: 256 (order: 8, 1024 bytes)
    [ 0.000000] Clock event device timer0_0 configured with caps set: 07
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.000000] Memory: 48MB = 48MB total
    [ 0.000000] Memory: 45860KB available (2289K code, 276K data, 176K init)
    [ 0.000000] Calibrating delay loop (skipped)... 215.44 BogoMIPS preset
    [ 0.000000] Security Framework v1.0.0 initialized
    [ 0.000000] Capability LSM initialized
    [ 0.000000] Mount-cache hash table entries: 512
    [ 0.000000] CPU: Testing write buffer coherency: ok
    [ 0.010000] NET: Registered protocol family 16
    [ 0.010000] DaVinci: 104 gpio irqs
    [ 0.010000] MUX: initialized GPIO20
    [ 0.010000] MUX: initialized I2C_SCL
    [ 0.010000] Generic PHY: Registered new driver
    [ 0.010000] ch0 default output "COMPOSITE", mode "NTSC"
    [ 0.020000] VPBE Encoder Initialized
    [ 0.020000] SCSI subsystem initialized
    [ 0.020000] NET: Registered protocol family 2
    [ 0.110000] IP route cache hash table entries: 512 (order: -1, 2048 bytes)
    [ 0.110000] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.110000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.110000] TCP: Hash tables configured (established 2048 bind 1024)
    [ 0.110000] TCP reno registered
    [ 0.120000] VFS: Disk quotas dquot_6.5.1
    [ 0.120000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [ 0.120000] squashfs: version 3.1 (2006/08/19) Phillip Lougher
    [ 0.120000] JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
    [ 0.130000] Initializing Cryptographic API
    [ 0.130000] io scheduler noop registered
    [ 0.130000] io scheduler anticipatory registered (default)
    [ 0.130000] io scheduler deadline registered
    [ 0.130000] io scheduler cfq registered
    [ 0.160000] CSL: Module install successful, device major num = 253
    [ 0.160000] CSL: Module version 0.10.00, built on Feb 28 2012 15:29:46
    [ 0.160000] I2C: Module install successful, device major num = 252
    [ 0.160000] DMA: Module install successful, device major num = 251
    [ 0.160000] DRV: Module install successful
    [ 0.160000] DRV: Module built on Feb 28 2012 15:29:48
    [ 0.160000] DRV: EDMACC.QUEPRI = 00002777
    [ 0.160000] DRV: SYSTEM.MSTPRI0 = 00440011
    [ 0.160000] DRV: SYSTEM.MSTPRI1 = 00000444
    [ 0.160000] DRV: ISP.BCR = 00000002
    [ 0.160000] DRV: SYSTEM.MISC = 00000391
    [ 0.160000] EDMAK module: built on Feb 28 2012 at 15:29:34
    [ 0.160000] Reference Linux version 2.6.18
    [ 0.160000] File /data/datalocal_videoapps01/user/kudva/DM36x/IPNetCam/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
    [ 0.160000] IRQK module: built on Feb 28 2012 at 15:29:35
    [ 0.160000] File /data/datalocal_videoapps01/user/kudva/DM36x/IPNetCam/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
    [ 0.160000] irqk initialized
    [ 0.160000] CMEMK module: built on Feb 28 2012 at 15:29:33
    [ 0.170000] Reference Linux version 2.6.18
    [ 0.170000] File /data/datalocal_videoapps01/user/kudva/DM36x/IPNetCam/dvsdk_ipnctools/linuxutils_2_24_03/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
    [ 0.170000] allocated heap buffer 0xc4000000 of size 0x5000000
    [ 0.170000] CMEM Range Overlaps Kernel Physical - allowing overlap
    [ 0.170000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
    [ 0.170000] cmemk initialized
    [ 0.170000] Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
    [ 0.170000] serial8250.0: ttyS0 at MMIO map 0x1d06000 mem 0xfbd06000 (irq = 41) is a 16550A
    [ 0.180000] RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
    [ 0.200000] Davinci EMAC MII Bus: probed
    [ 0.200000] MAC address is 00:0C:0C:A0:05:A1
    [ 0.210000] TI DaVinci EMAC Linux version updated 4.0
    [ 0.210000] Linux video capture interface: v2.00
    [ 0.220000] Trying to register davinci display video device.
    [ 0.220000] layer=c04cb200,layer->video_dev=c04cb360
    [ 0.230000] Trying to register davinci display video device.
    [ 0.230000] layer=c04cb000,layer->video_dev=c04cb160
    [ 0.240000] davinci_init:DaVinci V4L2 Display Driver V1.0 loaded
    [ 0.250000] i2c /dev entries driver
    [ 0.250000] nand_davinci nand_davinci.0: Using 4-bit hardware ECC
    [ 0.260000] NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit)
    [ 0.270000] Creating 6 MTD partitions on "nand_davinci.0":
    [ 0.280000] 0x00000000-0x00300000 : "bootloader"
    [ 0.280000] 0x00300000-0x00500000 : "params"
    [ 0.290000] 0x00500000-0x00900000 : "kernel"
    [ 0.290000] 0x00900000-0x02100000 : "filesystem"
    [ 0.300000] 0x02100000-0x02300000 : "data1"
    [ 0.310000] 0x02300000-0x08000000 : "data2"
    [ 0.310000] nand_davinci nand_davinci.0: hardware revision: 2.3
    [ 0.320000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: proc
    [ 0.330000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc intf: dev (254:0)
    [ 0.330000] rtc_davinci_dm365 rtc_davinci_dm365.0: rtc core: registered rtc_davinci_dm365 as rtc0
    [ 0.340000] Advanced Linux Sound Architecture Driver Version 1.0.12rc1 (Thu Jun 22 13:55:50 2006 UTC).
    [ 0.350000] ASoC version 0.13.1
    [ 0.360000] CQ0093 Voice Codec 0.1
    [ 0.360000] asoc: cq93vc <-> davinci-vcif mapping ok
    [ 0.370000] ALSA device list:
    [ 0.370000] #0: On-chip voice codec (cq93vc)
    [ 0.380000] IPv4 over IPv4 tunneling driver
    [ 0.380000] TCP bic registered
    [ 0.390000] NET: Registered protocol family 1
    [ 0.390000] NET: Registered protocol family 17
    [ 0.400000] rtc_davinci_dm365 rtc_davinci_dm365.0: setting the system clock to 2000-01-01 00:00:56 (946684856)
    [ 0.410000] Time: timer0_1 clocksource has been installed.
    [ 0.410000] Clock event device timer0_0 configured with caps set: 08
    [ 0.410000] Switched to high resolution mode on CPU 0
    [ 0.450000] IP-Config: Guessing netmask 255.255.255.0
    [ 0.450000] IP-Config: Complete:
    [ 0.450000] device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
    [ 0.460000] host=192.168.1.168, domain=, nis-domain=(none),
    [ 0.470000] bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
    [ 0.480000] VFS: Mounted root (squashfs filesystem) readonly.
    [ 0.490000] Freeing init memory: 176K
    INIT: version 2.86 booting
    [ 2.490000] Empty flash at 0x00189834 ends at 0x0018a000
    [ 2.580000] JFFS2 notice: (250) read_dnode: node CRC failed on dnode at 0x1897f0: read 0xffffffff, calculated 0x62843199
    Creat queue id:0
    queue id:0
    FileMngThread created
    Creat queue id:32769
    queue id:32769
    AlramThread created
    Share memory init success
    queue id:32769
    Creat queue id:65538
    queue id:65538
    Creat queue id:98307
    queue id:98307
    queue id:65538
    net_search_gateway:eth0, 1A8C0, 0, 1
    CPU is DM368
    IPNC BUILD VERSION: DM368 IPNC REF DESIGN VERSION 3.00.00.10
    ./av_server.out DM368 NTSC APPRO2A AEWB 720P H264 64000 VBR AUTO MENUOFF &
    Check_device_version : DEVICE VER = 1 !!
    Setting up networking ...rm: unable to remove `/etc/network/run': Read-only file system
    log status
    Starting portmap daemon: log status
    portmapstart_daemon
    ApproDrvInit: 7
    Creat queue id:131076
    queue id:131076
    ApproDrvInit: 9
    queue id:131076
    ApproDrvInit: 8
    queue id:131076
    ApproDrvInit: 2
    queue id:131076
    ApproDrvInit: 6
    queue id:131076
    ApproDrvInit: 10
    queue id:131076
    AVSERVER UI: Initializing.
    CLK Hz,
    ARM Hz = 432000000
    DDR Hz = 340000000
    VPSS Hz = 340000000
    IMCOP Hz = 340000000
    [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
    IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
    SYSTEM.MSTPRI0 value changed to 00440011
    CONFIGURING AVSERVER FOR DM368 .....
    queue id:65538
    SENSOR FPS VALUE = 30
    [ 4.850000] DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:
    [ 4.850000] layer.pix_fmt.bytesperline = 640,
    [ 4.850000] layer.pix_fmt.width = 640,
    [ 4.850000] layer.pix_fmt.height = 480,
    [ 4.850000] layer.pix_fmt.sizeimage =460800
    queue id:131076 [ 4.880000] DavinciDisplay DavinciDisplay.1: pixfmt->width = 640,
    [ 4.880000] layer->layer_info.config.line_length= 640
    FR : 0 users registered from exsiting face album
    Initializing...
    IPNC AUTO_IRIS = 1
    Initializing...
    Initializing...
    Initializing...
    Initializing...
    ...done initializing
    Play this stream using the URL:
    rtsp://192.168.1.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
    (We use port 8303 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
    (We use port 8302 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
    (We use port 8300 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
    (We use port 8301 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
    (We use port 8304 for optional RTSP-over-HTTP tunneling.)
    APPRO AEW TRIAL VERSION !!!
    APPRO AEW DATE LINE 2012/12
    /opt/ipnc/modules/init.d_ins/portmap: /opt/ipnc/modules/init.d_ins/portmap: 162: cannot create /var/run/portmap.pid: Read-only file system
    log success
    log status
    log status
    Starting mounting local filesystems: log status
    mount none on /dev/shm type tmpfs (rw,size=5M)
    none on /var/run type tmpfs (rw)
    none on /tmp type tmpfs (rw,sync)
    log success
    log status
    Starting hotplug subsystem:
    usb
    Simple mixer control 'PGA',0
    Capabilities: cvolume
    Capture channels: Mono
    Limits: Capture 0 - 3
    Mono: Capture 2 [67%]
    Simple mixer control 'Mono DAC',0
    Capabilities: pvolume pvolume-joined
    Playback channels: Mono
    Limits: Playback 0 - 63
    Mono: Playback 47 [75%]
    SystemInit success
    Schedule manager init success
    usb [success]
    input
    input [success]
    done.
    [ 8.940000] loop: loaded (max 8 devices)
    [ 9.110000] tun: Universal TUN/TAP device driver, 1.6
    [ 9.110000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [ 9.670000] CSLIP: code copyright 1989 Regents of the University of California
    [ 10.150000] netconsole: not configured, aborting
    [ 10.330000] PPP generic driver version 2.4.2
    [ 10.550000] PPP Deflate Compression module registered
    Starting internet superserver: inetd.
    [ 11.390000] sbulla: unknown partition table
    [ 12.830000] davinci-mmc davinci-mmc.0: Supporting 4-bit mode
    [ 12.850000] davinci-mmc davinci-mmc.0: Using DMA mode
    [ 13.370000] usbcore: registered new driver usbfs
    [ 13.460000] usbcore: registered new driver hub
    [ 13.710000] musb_hdrc: version 6.0, cppi-dma, peripheral, debug=0
    [ 13.840000] musb_hdrc musb_hdrc: No DMA interrupt line
    [ 13.850000] musb_hdrc: USB Peripheral mode controller at c3904000 using DMA, IRQ 12
    [ 14.200000] Loading iSCSI transport class v1.1-646.<5>iscsi: registered transport (tcp)
    [ 15.100000] sbulla: unknown partition table
    mkdosfs 3.0.6 (04 Oct 2009)
    unable to get drive geometry, using default 255/63
    /dev/sbulla has 255 heads and 63 sectors per track,
    logical sector size is 512,
    using 0xf8 media descriptor, with 1024 sectors;
    file system has 2 12-bit FATs and 4 sectors per cluster.
    FAT size is 1 sector, and provides 247 clusters.
    Root directory contains 512 slots.
    Volume ID is 3c86189a, no volume label.
    queue id:0
    umount: /mnt/mmc: not mounted
    dns=192.168.1.1
    net_search_gateway:eth0, 0, FE01A8C0, 3
    dns=192.168.1.1
    ERROR: Module g_file_storage does not exist in /proc/modules
    [ 17.220000] g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005
    [ 17.240000] g_file_storage gadget: Number of LUNs=1
    [ 17.240000] g_file_storage gadget-lun0: ro=0, file: /dev/sbulla
    [ 17.270000] system_server/260[CPU#0]: BUG in local_bh_enable at kernel/softirq.c:196
    ApproDrvInit: 3
    queue id:131076
    queue id:0
    queue id:32769
    [01/Jan/2000:00:01:14 +0000] boa: server version Boa/0.94.13
    [01/Jan/2000:00:01:14 +0000] boa: server built Apr 5 2012 at 17:09:57.
    [01/Jan/2000:00:01:14 +0000] boa: starting server pid=664, port 80
    queue id:0
    INIT: Entering runlevel: 5
    c
    MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774)
    192 login: root (automatic login)
    Welcome to MontaVista(R) Linux(R) Professional Edition 5.0.0 (0702774).
    login[686]: root login on `ttyS0'
    UDPString=uuid:Upnp-TVEmulator-1_0-00_0077606280</UDN>
    Upnp port is 0
    UPnP Initialized OK ip=192.168.1.168, port=49152
    desc_doc_url = http://192.168.1.168/tvdevicedesc.xml
    error code = 0
    # device advertisement succeed.
    # Stream 8 is not avaliable~~~~~~~~
    caught SIGTERM: shutting down
    ApproDrvExit: 8
    I found that every boot log is different and error information is different too.
    When I use the third VMS software to connect IPNC with PSIA ,such as Milestone XProtect , there are failed.
    the part error information is below:
    [01/Jan/2000:00:25:41 +0000] request from 192.168.1.188 "GET /PSIA/System/Video/inputs/channels/Single/capabilities HTTP/1.1" ("/var/www/PSIA/System/Video/inputs/channels/Single/capabilities"): document open: No such file or directory
    [01/Jan/2000:00:25:41 +0000] request from 192.168.1.188 "GET /PSIA/System/Video/inputs/channels/Single HTTP/1.1" ("/var/www/PSIA/System/Video/inputs/channels/Single"): document open: No such file or directory
    [01/Jan/2000:00:25:41 +0000] request from 192.168.1.188 "GET /PSIA/PTZ/channels HTTP/1.1" ("/var/www/PSIA/PTZ/channels"): document open: No such file or directory
    [01/Jan/2000:00:27:06 +0000] caught SIGSEGV, dumping core in /tmp
    When I use the third VMS software to connect IPNC with ONVIF,such as Milestone XProtect or Axxon Smart Pro, there are failed too.
    [  338.380000] Alignment trap: boa (670) PC=0x000a9614 Instr=0xe5911000 Address=0x6669766e FSR 0x001
    [01/Jan/2000:01:26:10 +0000] caught SIGBUS, dumping core in /tmp
    [ 459.480000] CMEMK Error: get_phys: Unable to find phys addr for 0x4d55aa72
    [ 459.500000] CMEMK Error: get_phys: get_user_pages() failed: -14
    [ 459.500000] CMEMK Error: GETPHYS: Failed to convert virtual 0x4d55aa72 to physical.
    CMEM Error: getPhys: Failed to get physical address of 0x4d55aa72
    So it looks terrible, and now we are not the member of ONVIF or PSIA, we can't get complete protocol documents.
    We dont know how to debug these error.Anyone can tell me how to debug these kind of error?
    Thank you very much
    Report Abuse
    • Reply
  • Raghu Kudva
    on May 10 2012 01:12 AM
    Expert6665 points
    Zhang,
    Thanks for the bootlog. Since you are using third party VMS, I would like to know the root cause of the problem. I would like to know for which request the boa crashed. To start with, can you please send us a wireshark capture between VMS and IPNC.
    Barathkumar Vasudevan
    Silvan Innovation Labs
    Report Abuse
    • Reply
  • Jay Wu101688
    Posted by Jay Wu101688
    on Jul 09 2012 14:28 PM
    Prodigy10 points
    Hi Raghu:
    Is there an update on this topic.  We are evaluating DM368 MT5 running RDK v3 with Milestone XProtect Enterprise 8.0c trail version.  We observed similar issues(Web server crashes).  If there is a fix/patch already addressing the issue, how does TI typically make them available to people who uses DM368 MT5 code base?
    --jwu
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
