• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » DM365 exception vector table at 0xffff0000?
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Mitch Rybczynski
Posted by Mitch Rybczynski
on Apr 27 2012 11:05 AM
Intellectual300 points
Hi, I've seen several cases of our custom DM365 based DVR design freeze up, and when JTAG connecting to diagnose the issue, the state of PC and registers seems to point at an ARM exception, however in the wrong vector address space.  The ARM TRM mentions the VINITHI signal could set the vector address to 0xffff0000, but the TMS320DM36x ARM Subsystem guide mentions that it should be always in the 0x00000000 low range.  I see that UBL startup code sets up CP15 correctly to the low vector address space. Our applications are not intentionally changing anything in the supervisor processor CP15 registers, is it possible that this is some spurious error on the DM365 CPU core?  I don't seem mention of this in the errata.
CPU Registers
    PC    0xFFFF0010    Core Register
    SP    0xC0433A2C    Core Register
    LR    0xFFFF0330    Core Register
    CPSR    0x20000097    Core Register
    R0    0xC0433A2C    Core Register
    R1    0xFBAD0000    Core Register
    R2    0x4096A000    Core Register
    R3    0x00000000    Core Register
    R4    0x00000000    Core Register
    R5    0x00283B34    Core Register
    R6    0x00283A88    Core Register
    R7    0x00000001    Core Register
    R8    0x409546C4    Core Register
    R9    0x00000000    Core Register
    R10    0x4096A000    Core Register
    R11    0xBEFE3934    Core Register
    R12    0x00283B28    Core Register
ffff0010:   FFFFFFFF .word         0xFFFFFFFF
ffff0014:   EA00009A B             0xFFFF0284
ffff0018:   EA0000FA B             0xFFFF0408
ffff001c:   EA000078 B             0xFFFF0204
ffff0020:   EA0000F7 B             0xFFFF0404
ffff0024:   00000000 ANDEQ         R0, R0, R0
And another case
    PC    0xFFFF000C    Core Register
    LR    0xFE7B0058    Core Register
    CPSR    0xA0000097    Core Register
        N    1
        Z    0
        C    1
        V    0
        Q    0
        A    0
        I    1
        F    0
        T    0
        Mode    10111
    R0    0x00000000    Core Register
    R1    0x00000001    Core Register
    R2    0x002F17A8    Core Register
    R5    0x4096A000    Core Register
    R6    0x002F17A8    Core Register
    R7    0x002F1708    Core Register
    R8    0x40022ED0    Core Register
    R9    0x00000FF0    Core Register
    R10    0x00000001    Core Register
    R11    0x40023370    Core Register
    R12    0x409546C4    Core Register
And another case:
    CPSR    0x00000097    Core Register
        N    0
        Z    0
        C    0
        V    0
        Q    0
        A    0
        I    1
        F    0
        T    0
        Mode    10111
    R1    0x0025E8D8    Core Register
    R2    0xE18F600C    Core Register
    R4    0xBEDF93F0    Core Register
    R5    0x8F57D7FF    Core Register
    R6    0x401625A4    Core Register
    R7    0x33713001    Core Register
    R8    0xE1A03F00    Core Register
    R10    0x40025000    Core Register
    R11    0xBEDF936C    Core Register
    R12    0x00000000    Core Register
ffff000c:   EA9F0010 B             0xFE7B0054
ffff0010:   EA0000BB B             0xFFFF0304
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Renjith Thomas
    Posted by Renjith Thomas
    on Jun 13 2012 10:24 AM
    Verified Answer
    Verified by Mitch Rybczynski
    Guru23890 points
    Mitch,
    CP15 register is set by the kernel while booting up just before enabling the MMU to point the vector table to 0xffff0000. Hope this clarifies your doubt.
    Also JTAG will freeze when you're connecting while kernel is running. This behavior is because MMU is enabled and the addresses are virtual.
    -Renjith | www.pathpartnertech.com | Verify the answer if you think your query is resolved
    Report Abuse
    • Reply
  • Mitch Rybczynski
    on Jun 13 2012 10:51 AM
    Thanks!  I'll look over this part of the kernel arch code.
    Report Abuse
    • Reply
  • Alex Nancekievill
    Posted by Alex Nancekievill
    on Sep 30 2012 16:40 PM
    Intellectual350 points
    Hi Mitch,
    Do you mind telling us what your problem turned out to be? We've got a failure with the same symptoms and I'm looking for clues.
    Alex
    Report Abuse
    • Reply
  • Mitch Rybczynski
    on Oct 01 2012 08:09 AM
    Root cause unknown, suspect DDR controller or DDR parts.
    Downclocking the entire ARM subsystem via UBL seemed to improve stability...
    Report Abuse
    • Reply
  • Renjith Thomas
    on Oct 07 2012 01:11 AM
    Guru23890 points
    Alex,
    Can you describe your problem? What is the exact use case and behavior, along with complete logs.
    Report Abuse
    • Reply
  • Alex Nancekievill
    on Oct 08 2012 04:27 AM
    Thanks Mitch and Renjith. Our problem turned out to be DDR drive strength. Jeff's reply in this post http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/100/t/64431.aspx put me on to the issue.
    Since we reduced the drive strength our board has been stable.
    Alex
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
