• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » RTSP server bind error on port 8555 (JPEG) - ONVIF RTSS-1-1-1 MEDIA CONTROL test case
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Antoine DUBOST BULARD
Posted by Antoine DUBOST BULARD
on Aug 09 2012 03:02 AM
Intellectual255 points
Dear All,
I have a problem with ONVIF test case RTSS-1-1-1 MEDIA CONTROL
If my camera is configured to output H.264 video stream, and if I start the RTSS-1-1-1 MEDIA CONTROL test, the av_server and streamers are killed to be restarted to output a JPEG video stream.
In this case, when the streamers are restarted, the "ERROR: Failed to create RTSP server: bind() error (port number: 8555): Address already in use" error appear.
As far as port 8555 is used for JPEG RTSP stream,  RTSS-1-1-1 MEDIA CONTROL test fail.
If at first the camera is configured to output JPEG video stream, av_server and streamers do not restart and RTSS-1-1-1 MEDIA CONTROL test goes wright.
Does anyone have this problem, and if yes is there a solution ?
I use a DM365 IPNETCAM reference design with precompiled binaries provided with the 4.0 release
ADB
1 DM365 DM368 DM36x
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Barath Silvanlabs
    Posted by Barath Silvanlabs
    on Aug 10 2012 04:47 AM
    Prodigy140 points
    Antoine,
    Can you please try to use the attached source file (onvif.c) and try it. The source file has been modified to address the above mentioned issue.Please place the attached source file in the following folder
    Application/src/ipnc_app/network/boa-0.94.13/src/onvif_src/
    6433.onvif.c
    Barath Vasudevan
    Report Abuse
    • Reply
  • Antoine DUBOST BULARD
    on Aug 10 2012 10:03 AM
    Dear Barath,
    Thanks for your fast reply.
    I update the onvif.c file with your version and rebuilt boa, but the error still appear.
    Here is the console output from the beginning of RTSS-1-1-1 MEDIA CONTROL test case :
    root@192:~# Stream 8 is not avaliable~~~~~~~~
    caught SIGTERM: shutting down
    ApproDrvExit: 8
    Change in Config Data: Restart AVSERVER!!
    killall: Appro_avi_save: no process killed
    killall: audio-receiver: no process killed
    ApproDrvExit: 7
    caught SIGINT: shutting down
    ApproDrvExit: 6
    ApproDrvExit: 2
    ApproDrvExit: 10
    ApproDrvExit: 9
    killall: wis-streamer: no process killed
    AVSERVER UI: Stoping.....
    Msg_ThrFxn closing...
    Kill queue id:131076
    AVSERVER UI: Exiting.....
    AVSERVER UI: Closed Successfully
    CPU CurrentStatus is = 0
    IPNC BUILD VERSION: DM365 IPNC RDK V4.00.00.08
    ./av_server.out DM365 NTSC APPRO2A AEWB 2MP MJPEG 75 MENUOFF &
    ApproDrvInit: 7
    Creat queue id:196612
    queue id:196612
    DM365MM Init Successful
    AVSERVER UI: Initializing.
    CLK Hz,
    ARM Hz = 297000000
    DDR Hz = 270000000
    VPSS Hz = 270000000
    IMCOP Hz = 270000000
    [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
    IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
    DM365MM Init SuccessfulSYSTEM.MSTPRI0 value changed to 00440011
    CONFIGURING AVSERVER FOR DM365 .....
    queue id:65538
    SENSOR FPS VALUE = 30
    queue id:196612
    FR : 0 users registered from exsiting face album
    IPNC_DM365_4.0.0 (antoine@antoine-desktop) (gcc version 4.3.3 (GCC) ) #1 PREEM
    IPNC AUTO_IRIS = 0
    APPRO AEW TRIAL VERSION !!!
    APPRO AEW DATE LINE 2012/12
    Simple mixer control 'PGA',0
    Capabilities: cvolume cvolume-joined penum
    Capture channels: Mono
    Limits: Capture 0 - 3
    Mono: Capture 2 [67%]
    Simple mixer control 'Mono DAC',0
    Capabilities: pvolume pvolume-joined penum
    Playback channels: Mono
    Limits: Playback 0 - 63
    Mono: Playback 47 [75%]
    ApproDrvInit: 3
    queue id:196612
    queue id:0
    queue id:32769
    [01/Jan/1970:00:00:35 +0000] boa: server version Boa/0.94.13
    [01/Jan/1970:00:00:35 +0000] boa: server built Aug 10 2012 at 16:22:05.
    [01/Jan/1970:00:00:35 +0000] boa: starting server pid=741, port 80
    ApproDrvInit: 9
    queue id:196612
    ApproDrvInit: 8
    queue id:196612
    ApproDrvInit: 2
    queue id:196612
    ApproDrvInit: 6
    queue id:196612
    ApproDrvInit: 10
    queue id:196612
    Initializing...
    ...done initializing
    Initializing...
    Initializing...
    ERROR: Initializing...
    Initializing...
    Play this stream using the URL:
    rtsp://192.168.1.168:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
    (We use port 8304 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
    (We use port 8303 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
    (We use port 8301 for optional RTSP-over-HTTP tunneling.)
    rtsp://192.168.1.168:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
    (We use port 8300 for optional RTSP-over-HTTP tunneling.)
    As you can see, port 8555 seem to be still open and cause bind fail.
    I tested in NFS and with an updated ubifs firmware, but the result are the same. I suspected at first latency due to NFS but it seems to be a wrong way.
    Did you find why the socket bind fail ?
    Did you see the same problem and solve it by updating only onvif.c ? Maybe there are other files to patch to make things work.
    Anyway, thanks for you help, if you have other ideas, please let me know.
    Best Regards
    Antoine
    Report Abuse
    • Reply
  • Barath Silvanlabs
    on Aug 13 2012 03:00 AM
    Prodigy140 points
    Just the onvif.c file needs to be replaced. No other change is required. Can you try erasing the config files from /mnt/nand and then try running the tests again.
    Barath Vasudevan
    Report Abuse
    • Reply
    on Aug 16 2012 05:07 AM
    Dear Barath and All,
    Thanks for your last reply. I already had removed the config file to be sure to be in Factory settings but without success.
    So i was little confused about the problem which seems to be solved on your side and still here in my side.
    I dug a little deeper and found that RTSS 1-1-1 MEDIA CONTROL let the port 8555 in FIN_WAIT2 state, which seems to mean that ONVIF DEVICE TEST TOOL(192.168.1.10 = PC where is executed ONVIF TEST TOOL)  was still using port 8555 even if the camera(192.168.1.168) has closed it.
    netstat -nan | grep 8555
    tcp        0      0 192.168.1.168:8555      192.168.1.10:1582       FIN_WAIT2
    I checked that RTSP Streamer have SO_REUSEADDR socket option which seems to be the right option for reuse a port, but still do not work.
    I also try with a PC with Seven (I was using a XP SP2), socket seems to be released and the the camera streamer restart correctly but test fail at step 9 (Checking Filters, No Codecs in Graph)
    So, what do you think about that ? I'm really confused about this problem.
    Best Regards
    Antoine
    Report Abuse
    • Reply
  • Barathkumar Vasudevan
    Posted by Barathkumar Vasudevan
    on Aug 24 2012 04:18 AM
    Verified Answer
    Verified by Antoine DUBOST BULARD
    Prodigy30 points
    Antoine,
    Also can you please make sure that in the 'Management' tab of the Onvif Test Tool, the 'Time between Requests (ms)' is set to at least 9999. Checking filters error has come for us as well on some windows machine. Just try increasing the time between requests and see if those errors are repeating.
    Report Abuse
    • Reply
    on Aug 24 2012 09:46 AM
    Dear Barathkumar Vasudevan,
    Thanks for your feedback. You're right !
    Setting a "long" time between tests prevent the bind error on port.
    I guess this is a lack in the ONVIF Device Test Tool because I tried with a VMS (Milestone XProject) and do basically the same thing by asking a JPEG stream without problem.
    Anyway thank you.
    Best Regards
    Antoine
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
