• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM3x DaVinci Video Processor Forum » Updating Uboot from Uboot prompt for dm365
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Jagdish Suyani
Posted by Jagdish Suyani
on Aug 17 2012 08:49 AM
Intellectual260 points
HI,
We have designed our board with DM365 processor and we are in the production mode.
We want to update Uboot in our DM365 based board from U-boot serial port prompt.
We have hardwired the nand boot mode and we can only update ubl/uboot using JTAG Emulator.  We have a production lot of 100 boards with uboot, which does not have Ethernet support. We have recently added the Ethernet support in updated U-boot and we want to update all 100 boards without JTAG Emulator.
We tried following script to create an uboot.bin image with header  but the resulted image does not solve our problem. The U-boot is written at 0x19 block
#!/bin/bash -e
PAGESIZE=2048
FIRSTBLOCK=25
MAGIC=0xA1ACED66
SIZE=$(stat --format '%s' u-boot.bin)
ENTRYPOINT=$(readelf -h u-boot | grep "Entry point" | cut -d : -f 2)
binary() {
printf '\\x%02x' $(( $1 & 0xff ))
printf '\\x%02x' $(( ($1 >> 8) & 0xff ))
printf '\\x%02x' $(( ($1 >> 16) & 0xff ))
printf '\\x%02x' $(( ($1 >> 24) & 0xff ))
printf $(binary $MAGIC) > u-boot.ubl
printf $(binary $ENTRYPOINT) >> u-boot.ubl
printf $(binary $(( ($SIZE / $PAGESIZE)+1 ))) >> u-boot.ubl
printf $(binary FIRSTBLOCK) >> u-boot.ubl
printf $(binary 1) >> u-boot.ubl
dd if=u-boot.bin of=u-boot.ubl bs=$PAGESIZE seek=1
echo "Created u-boot.ubl"
After updating the image using following command
loady 0x80700000
nand write 0x320000 0x40000
When we reboot the system using reset command it gives following error
DM36x initialization passed!
TI UBL Version: 1.50
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
No valid boot image found!
NAND Boot failed.
Aborting...
Can anyone  please suggest us the solution for this problem?
Jagdish
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Renjith Thomas
    Posted by Renjith Thomas
    on Aug 17 2012 09:19 AM
    Guru23890 points
    Hi Jagdish,
    Can you send me the logs for your update procedure? Also can you let me know the size of the ubl, u-boot.bin and u-boot.ubl binares?
    -Renjith | www.pathpartnertech.com | Verify the answer if you think your query is resolved
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 17 2012 10:06 AM
    Hi Renjit,
    Thanks for your quick support.
    When the uboot is written with JTAG emulator it does not any error and log message is as below
    BootMode = NAND
    Valid magicnum, 0xA1ACED66, found in block 0x00000019.
       DONE
    Jumping to entry point at 0x81080000.
    U-Boot 2009.03 (Jun 21 2010 - 15:55:57)
    I2C:   ready
    DRAM:  128 MB
    NAND:  NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
    Bad block table found at page 65472, version 0x01
    Bad block table found at page 65408, version 0x01
    256 MiB
    *** Warning - bad CRC or NAND, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    No ETH PHY detected!!!
    ethernet init failed!
    Hit any key to stop autoboot:  4  3  2  0
    DM365 EVM >
    I have changed script little bit because, when  last command dd executes for writing header to u-boot.ubl it writes header and skips first page. Ideally the skipped bytes should be 0xFF but it fills it with 0x00. So i changed the script as below..
    PAGESIZE=2048
    FIRSTBLOCK=25
    MAGIC=0xA1ACED66
    echo $ENTRYPOINT
    echo $SIZE
    binary() {
    printf $(binary $MAGIC) > header
    printf $(binary $ENTRYPOINT) >> header
    printf $(binary $(( ($SIZE / $PAGESIZE)+1 ))) >> header
    printf $(binary FIRSTBLOCK) >> header
    printf $(binary 1) >> header
     tr  "\000" "\377" < /dev/zero | dd ibs=1k count=384 of=paddedfile.bin
     dd if=u-boot.bin of=paddedfile.bin  bs=2048  seek=1 conv=notrunc
     dd if=header of=paddedfile.bin  bs=2048  conv=notrunc
    The size in bytes  of the
    1. Ubl = 20480
    2. u-boot.bin  =  297712
    3. size of u-boot.ubl = 393216
    The nand command sequence is as below.
    1. loady 0x80700000
    2. nand erase 0x320000 0x60000
    3 nand write 0x80700000 0x320000 0x60000
    4. reset
    After resetting the board, i get following message.
    BootMode = NAND
    NAND Boot failed.
    Aborting...
    Please let me know if i am missing something.
    One more question, is it possible to update Uboot on Dm365 based board by this method ?
    FYI : we are using 128Mbyte Micron of Nand Flash with same block size of 128KBytes and Page size 2K
    Jagdish
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 17 2012 10:11 AM
    Guru23890 points
    Jagdish,
    Why are you flashing the image to 0x320000? It should be flashed to 0x0 instead. The UBL logs that you are seeing is from the older ubl which was already there in flash. Since you've not erased that it will come up.
    Try flashing it to 0x0. If your script is correct(I've not verified) it should boot-up properly. Atleast UBL should comeup.
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 17 2012 10:28 AM
    Renjith,
    Thanks for looking in to the matter.
    I am not updating ubl. I am only updating uboot.bin file in nand flash. The script  i have posted adds header to  uboot.bin file with is required by ubl progrma while running uboot.
    If you see in the log, which runs ubl/uboot properly . It shows below line
    This means ubl copies data from block 0x19 . The block size is of 128K and calculating the address it gives 128K*25 = 0x320000 starting address of U-boot, which should have proper header which contains the information about magicnum number and starting block number
    The reference was taken from below link.
    https://linuxlink.timesys.com/docs/gsg/dm365_evm
    Jagdish
    If you see closely,
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 17 2012 10:50 AM
    Guru23890 points
    Jagdish,
    I overlooked the script. You are right.
    Can you upload the files u-boot.bin, header, paddedfile.bin?
    Also can you send the logs of the commands.
    1. loady 0x80700000
    4. reset
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 17 2012 14:44 PM
    Renjit,
    Jagdish
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 17 2012 15:17 PM
    Renjith,
    Please find the log herewith as you have asked
    DM365 EVM > loady 0x80700000
    ## Ready for binary (ymodem) download to 0x80700000 at 115200 bps...
    CCCC xyzModem - CRC mode, 2(SOH)/384(STX)/0(CAN) packets, 6 retries
    ## Total Size = 0x00060000 = 393216 Bytes
    DM365 EVM >
    DM365 EVM > nand erase 0x320000 0x60000
    NAND erase: device 0 offset 0x320000, size 0x60000
    Erasing at 0x360000 -- 100% complete.
    OK
    DM365 EVM > nand write 0x80700000 0x320000 0x60000
    NAND write: device 0 offset 0x320000, size 0x60000
    393216 bytes written: OK
    DM365 EVM > reset
    resetting ...
    BootMode = NAND
    NAND Boot failed.
    Aborting...
    I could not upload all the files you asked for here so I have mailed it you on your email address.
    Jagdish
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 18 2012 07:15 AM
    Guru23890 points
    Hi Jagdish,
    I got the binaries. Can you do this small experiment and send me the logs?
    run the command "nand dump 0x320000" from u-boot prompt, before flashing the image and after flashing the image?
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 18 2012 10:07 AM
    Renjith,
    Please find the nand dump log from uboot prompt.
    1. Before flashing u-boot
    DM365 EVM > nand dump 0x320000
    Page 00320000 dump:
    66 ed ac a1 00 00 08 81 4a 00 00 00 19 00 00 00
    01 00 00 00 00 00 08 81 ff ff ff ff ff ff ff ff
    ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
    OOB:
    ff ff ff ff ff ff 27 42
    7f 1a 80 60 b8 41 b6 e9
    ff ff ff ff ff ff 3f 27
    56 f5 29 d8 61 d9 9d 14
    2. After writing flash memory the nand dump is
    Page 00320000 dump:
    66 ed ac a1 00 00 08 81 91 00 00 00 19 00 00 00
    OOB:
    a5 bb da cd ae ee 77 30
    24 78 3f 27 56 f5 29 d8
    61 d9 9d 14 3f 27 56 f5
    29 d8 61 d9 9d 14 3f 27
    is something wrong is writing the flash memory ?
    Jagdish
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 18 2012 10:24 AM
    Guru23890 points
    Jagdish,
    Its clear now. The ECC layout of u-boot is different from the layout what UBL expects. If you compare the OOB area of the dump you'll get it. In case of CCS the spare area is organized like, (6 + 10), (6 + 10), (6 + 10), (6 + 10) whereas in u-boot its (24 + 10 + 10 + 10 + 10). There will be ECC error when UBL tries to read from the NAND. That's the reason why you are not able to see the U-boot magic number.
    To solve this, you've to change the NAND driver of either UBL or u-boot for this layout. Chaning u-boot makes sense as UBL is following same layout as ROM Bootloader follows.
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 18 2012 10:25 AM
    Guru23890 points
    Jagdish,
    If you are changing the u-boot layout, then if you are flashing your file system from u-boot, you'll face issues in mounting as kernel might be already following the u-boot layout. Do remember to change both if you are trying this.
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 18 2012 11:02 AM
    Renjith,
    Thanks a lot for pointing out the problem.
    Will update uboot nand drivier according to ubl lay out you suggested.
    You are right, i also need to update nand driver for kernel otherwise will get problems in mounting and re-writing filesystem.
    Thanks once again for all the help and support.
    I will update you about the issue after testing changed ECC layout.
    Jagdish
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 18 2012 14:08 PM
    Renjith,
    I changed Uboot code to update ECC layout to be (6 + 10), (6 + 10), (6 + 10), (6 + 10).  But I faced the same problem. It did not work.
    1. If i update my new u-boot.bin (with (24 + 10 + 10 + 10 + 10 ECC layout ) using JTAG Emulator, it works well But if try to write the same u-boot.bin using uboot prompt, it does not work.
    2. Even I created new padderfile.bin with original u-boot.bin(is provided with dm365 evm board and having ECC layout same as ubl) it also gives same oob out put
    OOB:
    Can please  suggest  what might be  going wrong in this case ?
    I have also tried a different way to update u-boot memory area in to flash memory.  I have one board with new u-boot.bin updated using JTAG Emulator. I logged in to the  board and create blcok file using following command.
     dd if=/dev/mtd1 of=uboot_mtd1.bin   (checked the partition from linux partition table from board support file)
    Even I checked the content of uboot_mtd1.bin file using hexdump -C command, it's same as the data written by JTAG emulator, but when i update the binary at 0x320000 location from uboot prompt, and give the reset command then the on the start ubl is not able to find uboot image and the device hangs. And i have to use JTAG emulator for updating the uboot in the device.
    Jagdish
    Report Abuse
    • Reply
  • Renjith Thomas
    on Aug 18 2012 14:38 PM
    Guru23890 points
    Jagdish,
    If the oob layout is like what you've given in the post, it will not work. The oob has to look like this.
    ff ff ff ff ff ff a5 bb
    da cd ae ee 77 30 24 78
    After updating the u-boot image from your new u-boot the nand dump oob layout should like the above. Can you double check this?
    Report Abuse
    • Reply
  • Jagdish Suyani
    on Aug 18 2012 14:52 PM
    Renjith,
    I double checked it. It does not work.
    Somehow the oob layout changes. The common thing in all the experiments is my script, which creates a uboot.bin file with a proper header. Is something wrong with the script ?
    Can you please let me know, why the new uboot.bin works if i update using JTAG emulator ? The uboot is having 24+10+10+10+10 oob layout. ?
    Jagdish
    Report Abuse
    • Reply
123
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
