I am planning to use mDDR part 'MT46H64M16LFBF-5 IT' in one of our design with DM365. We will be using 216Mhz part DM365. Video use case include D1 resolution YUV422 video capture, H264 encode it to 25FPS and then record it in SD card, in parallel there will be same D1 resolution video will output through VPSS back end in analog format.
Can you please suggest 'MT46H64M16LFBF-5 IT' mDDR part can be supported by DM365 or not.
Also above video use-case is possible with DM365-216Mhz model and mDDR@166Mhz ?
Is there anly PLL configuration settings available for mDDR ?
Sree
