Hi
I am using DM388 IPNC RDK ver 3.8(H/W rev2).
My bootargs are:
setenv bootcmd 'ipnc_ff_init 1;tftp 0x81000000 uImage; bootm'
setenv bootargs 'console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.170:/home/jayakrishnan/work/projects/dm388/ipnc_rdk_orig/Source/ipnc_rdk/target/filesys,nolock eth=00:0C:0C:02:50:A1 ip=192.168.1.224 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk rootdelay=4'
I am getting the below error
Load address: 0x81000000
Loading: *#################################################################
done
Bytes transferred = 2482256 (25e050 hex)
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.37_DM388_IPNC_3.80.00-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2482192 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37_DM388_IPNC_3.80.00-00103-g1a13629 (x0066085@bangvideoapps01) (gcc version 4.5.3 20110311 (prerelease) (GCC) ) #1 Fri Jan 24 16:14:35 IST 2014
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: dm385ipnc
vram size = 4194304 at 0x0
bootconsole [earlycon0] enabled
ti81xx_reserve: ### Reserved DDR region @84f00000
reserved size = 4194304 at 0x0
FB: Reserving 4194304 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is DM385 1.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19040
Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw mem=80M vram=4M notifyk.vpssm3_sva=0xBFD00000 nfsroot=192.168.1.170:/home/jayakrishnan/work/projects/dm388/ipnc_rdk_orig/Source/ipnc_rdk/target/filesys,nolock eth=00:0C:0C:02:50:A1 ip=192.168.1.168 cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 earlyprintk rootdelay=4
cpsw: kernel boot params Ethernet address: 00:0C:0C:02:50:A1
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 74MB 1MB = 75MB total
Memory: 70676k/70676k available, 11244k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xc5800000 - 0xf8000000 ( 808 MB)
lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc04b9000 (4588 kB)
.data : 0xc04ba000 - 0xc04fa980 ( 259 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x84f00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx_vidout device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
PWM0 init success.
PWM1 init success.
bio: create slab <bio-0> at 0
SCSI subsystem initialized
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
tps65910 1-002d: No interrupt support, no core IRQ
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, peripheral, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(24 14 17)
usb2phy: override computed values rxcalib(15)DACs(24 14 17)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f6c5d8e
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at c581e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 138
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
CMEMK module: built on Jan 24 2014 at 16:01:30
Reference Linux version 2.6.37
File /data/datalocal1_videoapps01/user/santosh/Releases/Rel_3_8/DM388/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xc7000000 of size 0x4000000
cmemk initialized
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled, bootconsole disabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
omap2-nand driver initializing
ONFI param page 0 valid
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
omap2-nand: detected x16 NAND flash
Creating 8 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000020000 : "U-Boot-min"
0x000000020000-0x000000260000 : "U-Boot"
0x000000260000-0x000000280000 : "U-Boot Env"
0x000000280000-0x0000006c0000 : "Kernel"
0x0000006c0000-0x000006fc0000 : "File System"
0x000006fc0000-0x000007bc0000 : "Data"
0x000007bc0000-0x00000b0c0000 : "File System2"
0x00000b0c0000-0x000010000000 : "Reserved"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
asoc: HDMI-DAI-CODEC <-> hdmi-dai mapping ok
ALSA device list:
#0: TI81XX EVM
nf_conntrack version 0.5.0 (1104 buckets, 4416 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=0:c:c:2:50:a1
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
CPSW phy found : id is : 0x4dd074
PHY 0:01 not found
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.1.168, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.168, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=192.168.1.170, rootpath=
Waiting 4sec before mounting root device...
PHY: 0:00 - Link is Up - 1000/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
Root filesystem already rw, not remounting
Caching udev devnodes
root: mount: mounting /dev/root on / failed: No such file or directory
NOT configuring network interfaces: / is an NFS mount
rm: cannot remove '/tmp': Device or resource busy
Fri Nov 9 12:48:00 GMT-8 2012
inside finish.sh
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: empty MTD device detected
UBI: max. sequence number: 0
UBI: create volume table (copy #1)
UBI: create volume table (copy #2)
UBI: attached mtd5 to ubi0
UBI: MTD device name: "Data"
UBI: MTD device size: 12 MiB
UBI: number of good PEBs: 96
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 0
UBI: available PEBs: 90
UBI: total number of reserved PEBs: 6
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 0/0
UBI: image sequence number: 561117415
UBI: background thread "ubi_bgt0d" started, PID 251
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 90 LEBs (11427840 bytes, 10.9 MiB), LEB size 126976 bytes (124.0 KiB)
Set volume size to 11427840
Volume ID 0, size 90 LEBs (11427840 bytes, 10.9 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "ubifs_volume", alignment 1
UBIFS: default file-system created
UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
UBIFS: file system size: 10285056 bytes (10044 KiB, 9 MiB, 81 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 485787 bytes (474 KiB)
UBI: attaching mtd7 to ubi1
UBI: max. sequence number: 20
UBI: attached mtd7 to ubi1
UBI: MTD device name: "Reserved"
UBI: MTD device size: 79 MiB
UBI: number of good PEBs: 634
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 634
UBI: number of PEBs reserved for bad PEB handling: 6
UBI: max/mean erase counter: 15/13
UBI: image sequence number: 1245370820
UBI: background thread "ubi_bgt1d" started, PID 265
UBI device number 1, total 634 LEBs (80502784 bytes, 76.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
UBIFS: file system size: 78090240 bytes (76260 KiB, 74 MiB, 615 LEBs)
UBIFS: journal size: 3936256 bytes (3844 KiB, 3 MiB, 31 LEBs)
UBIFS: reserved for root: 3688395 bytes (3601 KiB)
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=127,127
| dBscale-min=-63.50dB,step=0.50dB,mute=0
SysLink version : 2.21.02.10
SysLink module created on Date:Aug 1 2014 Time:14:31:06
Trace enabled
Trace SetFailureReason enabled
[c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
/dev/mem opened.
Phy Addr : 0x48181560 Data : 0x00000002
Unhandled fault: external abort on non-linefetch (0x1018) at 0x402820e4
Phy Addr : 0x48180f10 Data : 0x00000000
Phy Addr : 0x48180508 Data : 0x00000302
Phy Addr : 0x48180520 Data : 0x00000002
Phy Addr : 0x48180524 Data : 0x00000002
Phy Addr : 0x48180528 Data : 0x00000002
Phy Addr : 0x4c0000e4 Data : 0x00170209
Bus error
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
Creat queue id:0
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
Creat queue id:65538
queue id:65538
Creat queue id:98307
queue id:98307
queue id:32769
Initialize IPNC Default Values
[host] Attached to slave procId 0.
[host] Attached to slave procId 1.
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.
[host] After Ipc_startcallback status [0x00000000]
[m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[m3video]
[m3vpss ] notify_attach rtnVal 0
[m3video] *** UTILS: CPU KHz = 400000 Khz ***
[m3video]
[m3video] 77: SYSTEM : System Common Init in progress !!!
[m3video] 84: SYSTEM: IPC init in progress !!!
[m3vpss ] initProxyServer rtnVal 0
[m3video] 88: SYSTEM: Attaching to [HOST] ...
[m3vpss ]
[m3video] 143: SYSTEM: Attaching to [HOST] ...
[m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[m3video] 161: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ]
[m3video] 161: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 190: SYSTEM : System Common Init in progress !!!
[m3video] 211: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 190: SYSTEM: IPC init in progress !!!
[m3vpss ] 190: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 240: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 242: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 243: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 261: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 293: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 293: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 294: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 293: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3vpss ] 294: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 294: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 295: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3vpss ] 297: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 297: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 297: SYSTEM: IPC init DONE !!!
[m3vpss ] 313: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 313: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[m3vpss ] 316: SYSTEM : System Common Init Done !!!
[m3vpss ] Received character 's'
[m3video] 394: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 395: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3video] 395: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3video] 397: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 397: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3video] 398: SYSTEM: IPC init DONE !!!
[m3video] Received character 's'
queue id:65538
[m3video] 413: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 413: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[m3video] 415: SYSTEM : System Common Init Done !!!
Creat queue id:131076
queue id:131076
CPU is TI812x
IPNC BUILD VERSION: IPNC RDK VERSION 03.80.00.05 (FULL FEATURE)
DEMOCFG Value : 0
Videocodecmode : 8
Videocodecres : 0
streamtype : 2
vsenable : 0
./bin/ipnc_rdk_mcfw.out VNF_QUALITY TRISTREAM TRIPLE_H264 APPRO2A AEWB 1080P_D1 H264 HIGH_SPEED1 H264 HIGH_SPEED2 MJPEG 80 &
Error: SemWait: Invalid Semaphore handler
Error: SemRelease: Invalid Semaphore handler
Creat queue id:163845
queue id:163845
queue id:65538
ApproDrvInit: 7
queue id:163845
[m3vpss ] 616: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] === I2C0/2 Clk is active ===
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[m3vpss ] 635: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 635: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 636: SYSTEM: ListElem Shared Addr = 0xbe984180
[m3vpss ] 638: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 639: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 639: SYSTEM: ListElem Shared Addr = 0xbe987680
[m3vpss ] 653: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 653: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 654: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[m3vpss ] 657: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 657: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 658: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[m3vpss ] 660: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[m3vpss ] 661: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[m3vpss ] 661: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[m3vpss ] 668: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 668: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 669: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[m3vpss ] 671: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[m3vpss ] 672: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[m3vpss ] 672: SYSTEM: ListElem Shared Addr = 0xbea03600
[m3vpss ] 674: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 674: SYSTEM : FVID2 Init in progress !!!
[m3video] 715: SYSTEM : System Video Init in progress !!!
[m3video] 716: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 716: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 717: SYSTEM: ListElem Shared Addr = 0xbea1d280
[m3video] 719: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 719: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 720: SYSTEM: ListElem Shared Addr = 0xbea20780
[m3video] 730: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3video] 730: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 731: SYSTEM: ListElem Shared Addr = 0xbea23c80
[m3video] 733: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[m3video] 734: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[m3video] 734: SYSTEM: ListElem Shared Addr = 0xbea3d900
[m3video] 736: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 736: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 738: SYSTEM : Initializing Links !!!
[m3vpss ] 747: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 747: SYSTEM : Device Init in progress !!!
[m3video] 738: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[m3vpss ] Iss_init called !!!!!!
[m3video] 738: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[m3vpss ] CPIS_init DONE !!!!!!
[m3video] 739: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3vpss ] initPrms.isI2cInitReq = 1
[m3video] 739: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[m3vpss ] initPrms.isI2cInitReq = 0
[m3video] 739: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 740: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[m3video] Entered the MctnfLink_init()
[m3video] 800: SYSTEM : Initializing Links ... DONE !!!
[m3video] 801: SYSTEM : System Video Init Done !!!
[m3vpss ] 874: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] Sensor in 1080p Mode...
[m3vpss ] XXXXX DRV_imgsSetAgain() Error(1000)
[m3vpss ] With IMX136 SETTING_-_-,DRV_imgsSetRegs,598 0
[m3vpss ] 1058: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 1059: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 1059: SYSTEM : Initializing Links !!!
[m3vpss ] 1059: SYSTEM : FREE SPACE : System Heap = 1682704 B, Mbx = 10240 msgs)
[m3vpss ] 1059: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[m3vpss ] 1060: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 1060: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[m3vpss ] 1061: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[m3vpss ] Received character 't'
[m3vpss ] 1196: SYSTEM : Initializing Links ... DONE !!!
[m3video] Received character 't'
HDMI W1 rev 4.0
HDMI CEC Spec version 1.2
DMA: Module install successful, device major num = 247
DRV: Module install successful
DRV: Module built on Aug 1 2014 14:37:45
I2C No Ack
HDMI failed to read E-EDID
[host]
[host] ORG 0x46c00524: 0
[host] NEW 0x46c00524: 2
[host]
[host] Application Start Completed
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 10: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[host] 10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 10: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[host] 10: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 10: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 12: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 14: SYSTEM: CreDMA: ChannelID allocated:4
ating MsgQ [HOSTDMA: ChannelID allocated:5
_ACK_MSGQ] ...
[host] 15: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 16: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 17: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 17: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 18: SYSTEM: IPC init DONE !!!
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 23: SYSTEM: ListElem Shared Addr = 0x40d15580
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 25: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 27: SYSTEM: ListElem Shared Addr = 0x40d2f200
[host] 29: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 30: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 32: SYSTEM: ListElem Shared Addr = 0x40d48e80
[host] 33: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 35: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 36: SYSTEM: ListElem Shared Addr = 0x40d68880
[host] 37: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 39: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 41: SYSTEM: ListElem Shared Addr = 0x40d88280
[host] 42: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4c52f000,size = 65011712
##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0x5164a000,size = 29127
[host] DCC buffer allocated for size 29127
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[host]
********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 133: MCFW : CPU Revision [ES1.0] !!!
[host] 133: MCFW : Detected [4x TVP5158 VS] Board !!!
[host] 133: MCFW : Base Board Revision [REV A] !!!
[host] 133: MCFW : Daughter Card Revision [REV A] !!!
[m3vpss ] VPS_DCTRL_INST_0
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[m3vpss ] HDCOMPCLK
[m3vpss ] 2249: CAMERA: Create in progress !!!
[m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[m3vpss ] 2250: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
inside autorun
sbulla: unknown partition table
INIT: Entering runlevel: 5
Starting telnet daemon.
Starting syslogd/klogd: done
c
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org DM385_IPNC ttyO0
Arago 2011.09 DM385_IPNC ttyO0
DM385_IPNC login: root (automatic login)
root@DM385_IPNC:~# mkdosfs 3.0.12 (29 Oct 2011)
unable to get drive geometry, using default 255/63
/dev/sbulla has 255 heads and 63 sectors per track,
logical sector size is 512,
using 0xf8 media descriptor, with 1024 sectors;
file system has 2 12-bit FATs and 4 sectors per cluster.
FAT size is 1 sector, and provides 247 clusters.
There is 1 reserved sector.
Root directory contains 512 slots and uses 32 sectors.
Volume ID is b109413b, no volume label.
[m3vpss ] I2C: timed out in wait_for_bb: I2C_IRQSTATUS=1000 !!!
[m3vpss ] 7250: CAMERA: VIP 0: VID DEC 268436750 (0x2d): 8f0fcb80:ffff0000:8f0ff03c, AUD_STATUS -1894774072
[m3vpss ] Iss_captCreate:1661
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
Simple mixer control 'PGA',0
Capabilities: cvolume cswitch penum
Capture channels: Front Left - Front Right
Limits: Capture 0 - 119
Front Left: Capture 80 [67%] [40.00dB] [on]
Front Right: Capture 80 [67%] [40.00dB] [on]
[m3vpss ] 7469: CAMERA: Create Done !!!
[m3vpss ] 7561: CAMERA: Detect video in progress !!!
[m3vpss ] 7561: CAMERA: Detect video Done !!!
[m3vpss ] 7757: DUP : Create Done !!!
[m3vpss ] 7757: IPC_OUT_M3 : Create in progress !!!
[m3video] 7759: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 7759: IPC_OUT_M3 : Create Done !!!
[m3video] 7760: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[m3vpss ] DCC server task running
[m3video] 7760: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[m3video] 7764: IPC_IN_M3 : Create Done !!!
[m3video] Entered the MctnfLink_tskMain()
[m3video] inChInfo->width = 1920
[m3video] inChInfo->height = 1080
[m3video] inChInfo->pitch[0] = 1984
[m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.08.00.00 Done...
[m3video] [MCTNF] startX = 0
[m3vpss ] 7946: IPC_IN_M3 : Create in progress !!!
[m3video] [MCTNF] startY = 0
[m3vpss ] 7946: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] [MCTNF] outChInfo->width = 1920
[m3vpss ] 7947: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] [MCTNF] outChInfo->height = 1080
[m3vpss ] 7948: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3video] [MCTNF] outChInfo->pitch[0] = 1984
[m3vpss ] 7950: IPC_IN_M3 : Create Done !!!
[m3video] [MCTNF] outChInfo->pitch[1] = 1984
[m3video] 7944: IPC_OUT_M3 : Create in progress !!!
[m3video] 7945: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 7763: VNF:
[m3vpss ] Create in progress ... !!!
[m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[m3vpss ] 7764: VNF:
[m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[m3vpss ] 7937: VNF:
[m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1920 outChInfo->width=1920,outChInfo->height=1080
[m3vpss ] 7939: VNF:
[m3vpss ] Create ... DONE !!!
[m3vpss ] 8128: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:0 USED:128
[m3vpss ] NSF::HEAPID:1 USEDDMA: ChannelID allocated:6
:4928
[m3vpss DMA: ChannelID allocated:7
] 8256: NSF: Create Done !!!
[m3vpss ] 8257: Mux : Creating... !!!
[m3vpss ] 8259: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[m3vpss ] 8259: Mux : Create Done !!!
[m3vpss ] 8267: DUP : Create Done !!!
[m3vpss ] 8275: DUP : Create Done !!!
[m3vpss ] 8275: Mux : Creating... !!!
[m3vpss ] 8277: Mux : Create Done !!!
[m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[m3vpss ] {SWOSD} edma3Handle->chId = 36
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[m3vpss ] {SWOSD} edma3Handle->chId = 37
[m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[m3vpss ] {SWOSD} edma3Handle->chId = 38
[m3vpss ] 8288: SYSTEM: Opening MsgQ DMA: ChannelID allocated:8
[HOST_MSGQ] ...
[m3vpss ] 8161: SWOSD : Create Done !!!
[m3vpss ] 8357: DUP : Create Done !!!
[m3vpss ] 8357: SCLR: Create in progress !!!
[m3vpss ] 8364: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 8364: SCLR : Co-effs Loading ... DONE !!!
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 8
[m3video] 8377: IPC_IN_M3 : Create in progress !!!
[m3vpss ] SCLR:HEAPID:0 USED:64
[m3video] 8377: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3vpss ] SCLR:HEAPID:1 USED:5952
[m3video] 8378: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] 8364: SCLR: Create Done !!!
[m3video] 8381: IPC_IN_M3 : Create Done !!!
[m3vpss ] 8186: FD : Alg Create Done !!!
[m3video] 8381: ENCODE: Create in progress ... !!!
[m3vpss ] 8186: FD : Create Done !!!
[m3vpss ] 8375: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 8376: IPC_OUT_M3 : Create Done !!!
[m3video] 8507: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
queue id:0
[m3video] ENCLINK_H264:HEAPID:0 USED:11720
[m3video] 8593: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 6385: IPC_BITS_IN : Create in progress !!!
[host] 6385: IPC_BITS_IN : ListMPOpen start !!!
[host] 6385: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 6387: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 6388: IPC_BITS_IN : ListMPOpen done !!!
[host] 6390: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 6390: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONE
[m3vpss ] 8693: DISPLAY: Create in progress !!!
[m3video] 8679: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] DisplayId = 1,DataFormat = 7
[m3vpss ] SC2 displayInstId = 6
[m3vpss ] 8695: DISPLAY: Create Done !!!
[m3video] ENCLINK_JPEG:HEAPID:0 USED:4368
[m3vpss ] 8696: DISPLAY: Create in progress !!!
[m3video] 8680: ENCODE: All CH Create ... DONE !!!
[m3vpss ] DisplayId = 4,DataFormat = 7
[m3vpss ] SD displayInstId = 2
[m3vpss ] 8697: DISPLAY: Create Done !!!
[m3video] ENCLINK:HEAPID:0 USED:28136
[m3vpss ] 8699: DISPLAY: Start in progress !!!
[m3video] 8683: ENCODE: Create ... DONE !!!
[m3video] 8613: VSTAB : Alg Create Done !!!
[m3video] 8613: VSTAB : Create Done !!!
[m3video] 8684: IPC_BITS_OUT : Create in progress !!!
[m3video] 8687: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 8736: DISPLAY: Start Done !!!
[m3vpss ] 8736: DISPLAY: AUX PATH: 54 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 8737: DISPLAY: Start in progress !!!
[m3vpss ] 8795: DISPLAY: Start Done !!!
[m3vpss ] 8795: DISPLAY: SDDAC(SEC1): 17 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 8609: CAMERA: Start in progress !!!
[m3vpss ] 8609: CAMERA: Start Done !!!
[host]
Application Run Completed
[host] ITT server task running !!!
[host]
ITT ittServer_run
[host] ITT Server Message initialization successful
[host]
ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <40bc1c00>
[host] Posting message <40bc1c00> in QId <10002>
[m3vpss ] Command 1 recived from HOST A8
[host] Response from M3 is : 1
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[m3vpss ] Command 2 recived from HOST A8
[m3vpss ] New DCC data of size <29127>
[m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC 536870980
./boa: /usr/lib/libssl.so.1.0.0: no version information available (required by ./boa)
./boa: /usr/lib/libcrypto.so.1.0.0: no version information available (required by ./boa)
ApproDrvInit: 3
queue id:163845
queue id:0
queue id:32769
queue id:0
As per some suggestion in this group, I did a clean make
make -s sysclean
After that things moved little further. The log is
Net: Ethernet clocking: 0x52
Detected MACID:0:c:c:2:50:a1
cpsw
Hit any key to stop autoboot: 3 2 1 0
phy info reg 0x1e addr 0 val 2
phy info reg 0x1e addr 0 val a
Auto negotitation failed
Using cpsw device
TFTP from server 192.168.1.170; our IP address is 192.168.1.168
Filename 'uImage'.
Loading: *T link up on port 0, speed 1000, full duplex
T #################################################################
done
OK
Starting kernel ...
Machine: dm385ipnc
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
PWM0 init success.
PWM1 init success.
Cppi41 Init Done
TCP reno registered
cmemk initialized
brd: module loaded
loop: module loaded
ONFI flash detected
ALSA device list:
#0: TI81XX EVM
PHY 0:01 not found
devtmpfs: mounted
Starting udev
inside finish.sh
UBI: max. sequence number: 25
UBI: total number of reserved PEBs: 96
UBI: max/mean erase counter: 2/1
UBI: image sequence number: 1687366485
UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
UBI: max. sequence number: 18
UBI: background thread "ubi_bgt1d" started, PID 263
: values=127,127
Trace enabled
/dev/mem opened.
Unhandled fault: external abort on non-linefetch (0x1018) at 0x4023c0e4
Bus error
Creat queue id:0
queue id:0
queue id:32769
queue id:32769
AlramThread created
queue id:65538
queue id:98307
[m3vpss ]
[m3vpss ]
[m3vpss ] 69: SYSTEM : System Common Init in progress !!!
[m3vpss ] 69: SYSTEM: IPC init in progress !!!
[m3vpss ] 69: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 119: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 250: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3vpss ] 250: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 299: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 349: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 399: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 449: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 499: SYSTEM: Attaching to [VIDEO-M3] ...
[m3vpss ] 549: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video]
[m3video]
[m3video] 548: SYSTEM : System Common Init in progress !!!
[m3video] 549: SYSTEM: IPC init in progress !!!
[m3video] 549: SYSTEM: Attaching to [HOST] ...
[m3video] 598: SYSTEM: Attaching to [HOST] ...
[m3vpss ] 599: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 601: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[m3video] 601: SYSTEM: Attaching to [VPSS-M3] ...
[m3video] 651: SYSTEM: Attaching to [VPSS-M3] ...
[m3vpss ] 649: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 700: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[m3vpss ] 699: SYSTEM: Attaching to [VIDEO-M3] ...
[m3video] 700: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 700: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[m3vpss ] 700: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3vpss ] 701: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 701: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[m3vpss ] 703: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3vpss ] 704: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[m3vpss ] 704: SYSTEM: IPC init DONE !!!
[m3vpss ] 720: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3vpss ] 720: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[m3vpss ] 722: SYSTEM : System Common Init Done !!!
[m3video] 800: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[m3video] 801: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[m3video] 801: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[m3video] 803: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[m3video] 803: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[m3video] 804: SYSTEM: IPC init DONE !!!
[m3video] 819: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[m3video] 819: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[m3video] 822: SYSTEM : System Common Init Done !!!
queue id:65538
queue id:131076
CPU is TI812x
DEMOCFG Value : 0
Videocodecmode : 8
Videocodecres : 0
streamtype : 2
vsenable : 0
queue id:163845
queue id:65538
ApproDrvInit: 7
queue id:163845
[m3vpss ] 1022: SYSTEM : System VPSS Init in progress !!!
[m3vpss ] 1042: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[m3vpss ] 1042: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[m3vpss ] 1043: SYSTEM: ListElem Shared Addr = 0xbe984180
[m3vpss ] 1045: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[m3vpss ] 1046: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[m3vpss ] 1046: SYSTEM: ListElem Shared Addr = 0xbe987680
[m3vpss ] 1060: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[m3vpss ] 1060: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[m3vpss ] 1061: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[m3vpss ] 1063: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[m3vpss ] 1064: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[m3vpss ] 1064: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[m3vpss ] 1067: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[m3vpss ] 1068: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[m3vpss ] 1068: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[m3vpss ] 1074: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[m3vpss ] 1075: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[m3vpss ] 1075: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[m3vpss ] 1078: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[m3vpss ] 1078: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[m3vpss ] 1079: SYSTEM: ListElem Shared Addr = 0xbea03600
[m3vpss ] 1081: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[m3vpss ] 1081: SYSTEM : FVID2 Init in progress !!!
[m3video] 1121: SYSTEM : System Video Init in progress !!!
[m3video] 1122: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[m3video] 1122: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[m3video] 1123: SYSTEM: ListElem Shared Addr = 0xbea1d280
[m3video] 1125: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[m3video] 1126: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[m3video] 1126: SYSTEM: ListElem Shared Addr = 0xbea20780
[m3video] 1136: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[m3video] 1137: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[m3video] 1137: SYSTEM: ListElem Shared Addr = 0xbea23c80
[m3video] 1139: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[m3video] 1140: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[m3video] 1140: SYSTEM: ListElem Shared Addr = 0xbea3d900
[m3video] 1142: HDVICP: Doing PRCM for IVAHD[0] ...
[m3video] 1143: HDVICP: PRCM for IVAHD[0] ... DONE.
[m3video] 1144: SYSTEM : Initializing Links !!!
[m3video] 1144: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[m3vpss ] 1154: SYSTEM : FVID2 Init in progress DONE !!!
[m3vpss ] 1154: SYSTEM : Device Init in progress !!!
[m3video] 1144: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[m3video] 1145: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[m3video] 1145: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[m3video] 1146: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 1147: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[m3video] 1207: SYSTEM : Initializing Links ... DONE !!!
[m3video] 1207: SYSTEM : System Video Init Done !!!
[m3vpss ] 1281: SYSTEM : Device Init in progress DONE !!!
[m3vpss ] 1464: SYSTEM : System VPSS Init Done !!!
[m3vpss ] 1464: UTILS: DMA: HWI Create for INT62 !!!
[m3vpss ] 1465: SYSTEM : Initializing Links !!!
[m3vpss ] 1465: SYSTEM : FREE SPACE : System Heap = 1682704 B, Mbx = 10240 msgs)
[m3vpss ] 1465: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[m3vpss ] 1466: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[m3vpss ] 1466: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[m3vpss ] 1467: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[m3vpss ] 1602: SYSTEM : Initializing Links ... DONE !!!
DMA: Module install successful, device major num = 248
HDMI W1 rev 4.0
I2C No Ack
[host]
[host]
[host] 1: SYSTEM: IPC init in progress !!!
[host] 11: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[host] 12: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!!
[host] 12: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!!
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 15: SYSTEM: CreDMA: ChannelID allocated:4
_ACK_MSGQ] ...
[host] 16: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 17: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 18: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 18: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 19: SYSTEM: IPC init DONE !!!
[host] 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 24: SYSTEM: ListElem Shared Addr = 0x40e26580
[host] 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 27: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 29: SYSTEM: ListElem Shared Addr = 0x40e40200
[host] 30: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 32: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 34: SYSTEM: ListElem Shared Addr = 0x40e59e80
[host] 35: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 37: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 38: SYSTEM: ListElem Shared Addr = 0x40e79880
[host] 39: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 41: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 43: SYSTEM: ListElem Shared Addr = 0x40e99280
[host] 43: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0x4c702000,size = 65011712
[host] Vsys_allocBuf - addr = 0x516f1000,size = 29127
[host]
[host] 134: MCFW : CPU Revision [ES1.0] !!!
[host] 134: MCFW : Detected [4x TVP5158 VS] Board !!!
[host] 134: MCFW : Base Board Revision [REV A] !!!
[host] 134: MCFW : Daughter Card Revision [REV A] !!!
[m3vpss ] HDCOMPCLK
[m3vpss ] 2802: CAMERA: Create in progress !!!
[m3vpss ] 2803: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
inside autorun
[m3vpss ] 7803: CAMERA: VIP 0: VID DEC 268436750 (0x2d): 8f0fcb80:ffff0000:8f0ff03c, AUD_STATUS -1894774072
[m3vpss ] 8016: CAMERA: Create Done !!!
[m3vpss ] 8114: CAMERA: Detect video in progress !!!
[m3vpss ] 8114: CAMERA: Detect video Done !!!
[m3vpss ] 8198: DUP : Create Done !!!
Volume ID is b107af6f, no volume label.
[m3vpss ] 8203: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 8205: IPC_OUT_M3 : Create Done !!!
[m3video] 8235: IPC_IN_M3 : Create in progress !!!
[m3video] 8235: SYSTEM: Opc
[m3video] MCTNF Algorithm Instag_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
nce Creation forg_file_storage gadget: Number of LUNs=1
the Module MCTNg_file_storage gadget-lun0: ro=0, nofua=0, file: /dev/sbulla
_____ _____ _ _
|___| |___|
[m3vpss ] 8440: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 8440: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3vpss ] 8441: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] 8438: IPC_OUT_M3 : Create in progress !!!
[m3video] 8439: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 8442: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3vpss ] 8444: IPC_IN_M3 : Create Done !!!
[m3vpss ] 8378: VNF:
[m3vpss ] 8379: VNF:
root@DM385_IPNC:~# [m3vpss ] 8549: VNF:
[m3vpss ] 8551: VNF:
[m3vpss ] 8630: NSF: Create in progress !!!
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3vpss ] 8755: NSF: CrDMA: ChannelID allocated:6
eate Done !!!
[m3vpss ] 8756: Mux : Creating... !!!
[m3vpss ] 8758: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[m3vpss ] 8758: Mux : Create Done !!!
[m3vpss ] 8766: DUP : Create Done !!!
[m3vpss ] 8774: DUP : Create Done !!!
[m3vpss ] 8775: Mux : Creating... !!!
[m3vpss ] 8777: Mux : Create Done !!!
[m3vpss ] 8787: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3vpss ] 878DMA: ChannelID allocated:8
2: SWOSD : Create Done !!!
[m3vpss ] 8857: DUP : Create Done !!!
[m3vpss ] 8857: SCLR: Create in progress !!!
[m3vpss ] 8863: SCLR : Loading Up-scaling Co-effs ...
[m3vpss ] 8863: SCLR : Co-effs Loading ... DONE !!!
[m3video] 8877: IPC_IN_M3 : Create in progress !!!
[m3video] 8877: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 8878: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] 8864: SCLR: Create Done !!!
[m3video] 8881: IPC_IN_M3 : Create Done !!!
[m3vpss ] 8807: FD : Alg Create Done !!!
[m3video] 8881: ENCODE: Create in progress ... !!!
[m3vpss ] 8807: FD : Create Done !!!
[m3vpss ] 8875: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 8876: IPC_OUT_M3 : Create Done !!!
[m3video] 9008: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[m3video] 9092: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[host] 6451: IPC_BITS_IN : Create in progress !!!
[host] 6451: IPC_BITS_IN : ListMPOpen start !!!
[host] 6452: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 6454: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 6455: IPC_BITS_IN : ListMPOpen done !!!
[host] 6456: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 6457: IPC_BITS_IN : Create Done !!!
[m3vpss ] 9191: DISPLAY: Create in progress !!!
[m3video] 9177: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[m3vpss ] 9193: DISPLAY: Create Done !!!
[m3vpss ] 9194: DISPLAY: Create in progress !!!
[m3video] 9178: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 9195: DISPLAY: Create Done !!!
[m3vpss ] 9197: DISPLAY: Start in progress !!!
[m3video] 9181: ENCODE: Create ... DONE !!!
[m3video] 8635: VSTAB : Alg Create Done !!!
[m3video] 8635: VSTAB : Create Done !!!
[m3video] 9182: IPC_BITS_OUT : Create in progress !!!
[m3video] 9185: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 9234: DISPLAY: Start Done !!!
[m3vpss ] 9235: DISPLAY: AUX PATH: 52 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 9235: DISPLAY: Start in progress !!!
[m3vpss ] 9271: DISPLAY: Start Done !!!
[m3vpss ] 9272: DISPLAY: SDDAC(SEC1): 27 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[m3vpss ] 9207: CAMERA: Start in progress !!!
[m3vpss ] 9207: CAMERA: Start Done !!!
[host]
[m3vpss ] 9349: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
queue id:0
[m3video] Channel:1 inputframerate:30 targetfps:60
[m3video] [MCTNF] MctnfChObj->dynParams.vidnf1DynamicParams.inputWidth = 1920
[m3video] [MCTNF] MctnfChObj->dynParams.vidnf1DynamicParams.inputHeight = 1088
[m3video] [MCTNF] MctnfChObj->dynParams.vidnf1DynamicParams.captureWidth = 1984
[m3video] [MCTNF] MctnfChObj->gOutputBufDesc.imagePitch[0] = 1984
[m3video] [MCTNF] MctnfChObj->format.pitch[0] = 1984
[host]
ITT ittServer_run
[host]
[host] Setting cmd <1> in message <40cd2c00>
[host] Posting message <40cd2c00> in QId <10002>
[m3video] Channel:0 inputframerate:30 targetfps:60
[m3video] Channel:2 inputframerate:60 targetfps:5
[m3vpss ] ********************************************************************
[m3vpss ] APPRO AEWB TRIAL VERSION (LIMITATION is 1 DAY in 60fps)
[m3vpss ] For the formal release PLEASE CONTACT http://www.appropho.com !!!
[m3vpss ] 11610: DISPLAY: Stop in progress !!!
[m3vpss ] 11674: DISPLAY: Stop Done !!!
Venc not supported!!
ApproDrvInit: 3
queue id:163845
[m3vpss ] 11760: DISPLAY: Start in progress !!!
queue id:0
queue id:32769
[m3vpss ] 11805: DISPLAY: Start Done !!!
[m3vpss ] 11806: DISPLAY: SDDAC(SEC1): 1565 fps, Latency (Min / Max) = ( 6 / 18 ), Callback Interval (Min / Max) = ( 28 / 34 ) !!!
[m3vpss ] 11761: VNF:
[m3vpss ] EnableSNF current SNF 1 => new 0!!!
[m3vpss ] NSF: EnableSNF 0 current mode 0!!!
[host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[host]
Channel Selected: 0
[host]
Channel Selected: 0,rate control = 0 [m3vpss ] 11791: VNF:
[m3vpss ] EnableTNF current TNF 1 => new 0!!!
[m3vpss ] NSF: EnableTNF 0 current mode 1!!!
[host]
========== Stream FrameRate1 = 30 =================
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0
[host]
Channel Selected: 0,packet size = 100
[host]
Channel Selected: 0,encPreset = 0 [m3video] Channel:0 inputframerate:30 targetfps:30
[host]
Channel Selected: 0,enable = 0
[host]
Channel Selected: 1
[host]
Channel Selected: 1,rate control = 0 [m3video] Channel:2 inputframerate:30 targetfps:5
[m3video] ENCLINK: new targetbitrate to set:10000000
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1
[host]
Channel Selected: 1,packet size = 100 [m3video] ENCLINK: new targetframerate to set:30000
[host]
Channel Selected: 1,encPreset = 0
[host]
Channel Selected: 1,enable = 0
[host]
Channel Selected: 2
[host]
Channel Selected: 2,rate control = 2
[host] MJPEG in Rate Control OFF Mode
Check_device_version : read device error !!
[m3video] ENCLINK: new intraFrameInterval to set:30,new maxPicSizeRatioI to set = 960
[m3video] ENCLINK: new QP I Param to set:10 36 -1
[m3video] ENCLINK: new QP P Param to set:10 40 28
[m3video] ENCLINK: new rate control algorithm to set:0
[m3video] Channel:1 inputframerate:30 targetfps:30
[m3video] ENCLINK: new PacketSize Param to set:100
[m3video] ENCLINK: new Encode Preset Param to set:0
[m3video] ENCLINK: new targetbitrate to set:2000000
Front Left: Capture 95 [80%] [47.50dB] [on]
Front Right: Capture 95 [80%] [47.50dB] [on]
[m3video] JPGLINK: new targetframerate to set:5000 for bitrate 100000
[m3video] JPGLINK: new QP Param to set:1 51 80
Simple mixer control 'PCM',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 127
Mono:
Front Left: Playback 101 [80%] [-13.00dB]
Front Right: Playback 101 [80%] [-13.00dB]
[m3video] JPGLINK: new qualityFactor Param to set:80
[host]
Force IDR on Channel: 0
[host]
Force IDR on Channel: 1 [m3video] JPGLINK: new rate control algorithm to set:2 for bitrate: 100000
[m3video] JPGLINK: Run time parameters changed 0
SystemInit success
Schedule manager init success
Dmva Schedule manager init success
umount: can't umount /mnt/mmc: Invalid argument
killall: dhcpcd: no process killed
rm: cannot remove '/var/run/dhcpcd-eth0.pid': No such file or directory
TimeOut occure in boot_proc.
Program exit.
ifconfig
[host]
Usecase is Active !!!
[m3video] ==================== EncLink_PrintDetails ====================
[m3video] 42973: HDVICP-ID:0
[m3video] totalAcquire2wait in msec: 921
[m3video] totalWait2Isr in msec: 31130
[m3video] totalIsr2Done in msec: 86
[m3video] totalWait2Done in msec: 31216
[m3video] totalDone2Release in msec: 0
[m3video] totalAcquire2Release in msec: 34667
[m3video] totalAcq2acqDelay in msec: 766
[m3video] totalElapsedTime in msec: 33542
[m3video] numAccessCnt: 3269
[m3video] IVA-FPS : 99
[m3video]
[m3video] *** ENCODE Statistics ***
[m3video]
[m3video] Elasped Time : 31 secs
[m3video]
[m3video]
[m3video] CH | In Recv In Skip In User Out Latency
[m3video] Num | FPS FPS Skip FPS FPS Min / Max
[m3video] --------------------------------------------
[m3video] 0 | 30 0 0 30.77 129 / 181
[m3video] 1 | 30 0 0 30.42 11 / 50
[m3video] 2 | 30 0 25 5.10 140 / 184
[m3video]
[m3video] Multi Channel Encode Average Submit Batch Size
[m3video] Max Submit Batch Size : 24
[m3video] IVAHD_0 Average Batch Size : 1
[m3video] IVAHD_0 Max achieved Batch Size : 1
[m3video] ==============================================================
[m3vpss ] 69383: CAMERA: Fields = 3565 (fps = 59), Total Resets = 0 (Avg 0 ms per reset)
[host]
[m3video] 75437: HDVICP-ID:0
[m3video] totalAcquire2wait in msec: 1900
[m3video] totalWait2Isr in msec: 61355
[m3video] totalIsr2Done in msec: 175
[m3video] totalWait2Done in msec: 61530
[m3video] totalAcquire2Release in msec: 67904
[m3video] totalAcq2acqDelay in msec: 1282
[m3video] totalElapsedTime in msec: 66017
[m3video] numAccessCnt: 6443
[m3video] IVA-FPS : 97
[m3video]
[m3video]
[m3video] Elasped Time : 32 secs
[m3video]
[m3video]
[m3video] 0 | 30 0 0 30.44 129 / 171
[m3video] 1 | 30 0 0 30.44 12 / 42
[m3video] 2 | 30 0 25 5.09 146 / 175
[m3video]
[host]
[m3video] 108443: HDVICP-ID:0
[m3video] totalAcquire2wait in msec: 2841
[m3video] totalWait2Isr in msec: 92159
[m3video] totalIsr2Done in msec: 256
[m3video] totalWait2Done in msec: 92415
[m3video] totalAcquire2Release in msec: 101612
[m3video] totalAcq2acqDelay in msec: 1814
[m3video] totalElapsedTime in msec: 99022
[m3video] numAccessCnt: 9661
[m3video]
[m3video]
[m3video] Elasped Time : 33 secs
[m3video]
[m3video]
[m3video] 0 | 30 0 0 30.00 127 / 172
[m3video] 1 | 29 0 0 30.00 11 / 42
[m3video] 2 | 30 0 25 5.00 143 / 175
[m3video]
But when I run second time, I am stuck at the first error.
Things I already tried
1. flash_eraseall /dev/mtd5 & mtd4
2. deleted env file from /mnt/nand
I am stuck at this point. Appreciate any help
Best Regards
JK
