Can someone give me directions how to use GStreamer for loopback video from a composite source.
I have attached a WD Element play to the composite input on DM365 and I playback a 688x384 video.
I tried the encodedecode on the 4_02_00_06 which works OK
./encodedecode -b 2000000 -I 1 -y 1
./encode -y 1 -I 1 -r '688'x'384' -v test1.264
And then tried with GStreamer loop back which fails.
gst-launch -v v4l2src always-copy=FALSE input-src=composite ! TIDmaiVideoSink videoStd=D1_NTSC videoOutput=composite contiguousInputFrame=TRUE sync=false
This fails with:
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
davinci_previewer davinci_previewer.2: ipipe_set_preview_config
vpfe-capture vpfe-capture: IPIPE Chained
vpfe-capture vpfe-capture: Resizer present
EVM: switch to tvp5146 SD video input
tvp7002 1-005c: querystd, erorxxx, val = 1, val1 = 2
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 16, height = 2, bpp = 2, bytesperline = 32, sizeimage = 64
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 2, bytesperline = 4352, sizeimage = 6684672
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 32, height = 2, bpp = 1, bytesperline = 32, sizeimage = 96
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 1, bytesperline = 2176, sizeimage = 5013504
vpfe-capture vpfe-capture: width = 8, height = 2, bpp = 2
vpfe-capture vpfe-capture: width = 32775, height = 32769, bpp = 2
vpfe-capture vpfe-capture: width = 2176, height = 1536, bpp = 2
vpfe-capture vpfe-capture: dma_alloc_coherent size 4763648 failed
Segmentation fault
