Other Parts Discussed in Thread: DM388
Hi, I am new to this platform and may not have configured memory appropriately. I am trying to load the video firmware to the M3 on our DM385-IPNC-based platform, and I get this crash, which seems to be linked to linux memory configuration. Could you instruct me where I am making the mistake?
The commands I am giving are:
/opt/ipnc/bin/remote_debug_client.out 0xbff00000 &
# load syslink
insmod /opt/ipnc/kermod/syslink.ko TRACE=1 TRACEFAILURE=1 2> /dev/null
# load video compression and decompression management to M3
/opt/ipnc/bin/fw_load.out startup VIDEO-M3 /opt/ipnc/firmware/ipnc_rdk_fw_m3video.xem3
# load video input output processing code to M3
/opt/ipnc/bin/fw_load.out startup VPSS-M3 /opt/ipnc/firmware/ipnc_rdk_fw_m3vpss.xem3
# set priorities
/opt/ipnc/bin/sys_pri.out --L3-bw-reg-set HDVICP0 0 0 900 2500&
/opt/ipnc/bin/sys_pri.out --L3-bw-reg-set ISS 3 3 400 2500&
/opt/ipnc/bin/sys_pri.out --dmm-pri-set ISS 0&
/opt/ipnc/bin/sys_pri.out --dmm-pri-set HDVICP0 1&
The startup sequence is:
U-Boot 2010.06-svn302 (Feb 15 2016 - 18:47:36) DM385_PMRS_0.00.00
DM385-GP rev 1.1
ARM clk: 600MHz
DDR clk: 533MHz
L3 clk: 200MHz
IVA clk: 450MHz
ISS clk: 400MHz
DSP Default OFF
DSS Default OFF
I2C: ready
DRAM: 1 GiB
DCACHE: On
NAND: HW ECC BCH8 Selected
256 MiB
MMC: OMAP SD/MMC: 0, ON-BOARD SDIO: 1
@@ @@@ @. @. @@@@ @@@@ G@@@@@@ @@
@@ @@@@@ L@@ @@@ @@@@@@ @@@@@i @@@@@@ @@
@@ @@ @@ @@@ @@@ @@@@ @@;@@: C@@@@@. @@
@@ @@ @@ @@@.l@L@ G@@@ ,@@@@ @@@ @@ @@
@@ @@ @@ l@ @@@@ @. l@@ @@ L@@ @ G@ @@
@@ @@ @@ @@ @@@@ @@ @@ C@ @@ @@ @@
@@ @@ ,@C @@ @@@ @@ @i @@ C@ @@ @@ @@ @@
@@ @@@@@@@ @@ @@ @@ @@@@@l @@@@@@ L@@@@@ @@
@@ @@@@@ @ @ @ L@@ @@@, ,@@G @@
Net: Ethernet clocking: 0x52
Detected MACID:64:34:3a:66:35:3a
cpsw
Hit any key to stop autoboot: 3 2 1 0
NAND read: device 0 offset 0x400000, size 0x400000
4194304 bytes read: OK
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.37_DM388_IPNC_3.80.00-
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2660524 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 2.6.37_DM388_IPNC_3.80.00-svn307 (gadi@debian-g41) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #3 Tue Jul 12 13:21:03 IDT 2016
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: pmrs1000
vram size = 52428800 at 0x0
ti81xx_reserve: ### Reserved DDR region @8ff00000
reserved size = 52428800 at 0x0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
OMAP chip is DM385 1.0
SRAM: Mapped pa 0x402f1000 to va 0xfe400000 size: 0xf000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 51968
Kernel command line: console=ttyO0,115200n8 mem=256M notifyk.vpssm3_sva=0xBF900000 vram=50M lpj=4997120 ip=10.0.4.24 root=/dev/nfs nfsroot=10.30.40.50:/cygdrive/f/svn_root/rfs1000/rootfs,nolock,nfsvers=2
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 204MB 1MB = 205MB total
Memory: 201900k/201900k available, 60244k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc003e000 ( 216 kB)
.text : 0xc003e000 - 0xc0511000 (4940 kB)
.data : 0xc0512000 - 0xc0555100 ( 269 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop (skipped) preset value.. 999.42 BogoMIPS (lpj=4997120)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
TI81XX: Map 0x8ff00000 to 0xfe500000 for dram barrier
TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
omap_voltage_early_init: voltage driver support not added
NET: Registered protocol family 16
omap_voltage_domain_lookup: Voltage driver init not yet happened.Faulting!
omap_voltage_add_dev: VDD specified does not exist!
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
ti81xx_register_mcasp: platform not supported
omap_mux_set_gpio: Could not set gpio86
Cannot clk_get ck_32
Debugfs: Only enabling/disabling deep sleep and wakeup timer is supported now
registered ti81xx_vpss device
registered ti81xx on-chip HDMI device
registered ti81xx_fb device
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USBSS revision 4ea2080b
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, otg (peripheral+host), debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
MUSB controller-0 revision 4ea20800
usb2phy: computed values rxcalib(15)DACs(37 14 15)
usb2phy: override computed values rxcalib(15)DACs(37 14 15)
usb2phy_config: musb(0) rxcalib done, rxcalib read value 6f72dd7e
musb-hdrc musb-hdrc.0: USB Peripheral mode controller at d081e000 using DMA, IRQ 18
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
PMU: registered new PMU device of type 0
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 394
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
brd: module loaded
loop: module loaded
omap2-nand driver initializing
ONFI param page 0 valid
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
omap2-nand: detected x16 NAND flash
Creating 7 MTD partitions on "omap2-nand.0":
0x000000000000-0x000000200000 : "U-Boot"
0x000000400000-0x000002000000 : "Kernel"
0x000002000000-0x000004000000 : "ubifs"
0x000004000000-0x000008000000 : "cramfs"
0x000008000000-0x00000ff80000 : "ex4"
0x000000000000-0x00000ff80000 : "flash"
0x000000300000-0x000000400000 : "uboot-env"
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver Micrel KS8001 or KS8721
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver Micrel KS8001 or KS8721
usbcore: registered new interface driver cdc_acm
cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
usbcore: registered new interface driver uas
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbf900000
cm: Module associated with clock hdmi_i2s_fck didn't enable in 100000 tries
ALSA device list:
No soundcards found.
nf_conntrack version 0.5.0 (3154 buckets, 12616 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 17
Bridge firewalling registered
lib80211: common routines for IEEE802.11 drivers
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Power Management for TI81XX.
Detected MACID=d4:f5:13:94:e1:ac
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
CPSW phy found : id is : 0x221613
IP-Config: Guessing netmask 255.0.0.0
IP-Config: Complete:
device=eth0, addr=10.0.4.24, mask=255.0.0.0, gw=255.255.255.255,
host=10.0.4.24, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=10.30.40.50, rootpath=
PHY: 0:01 - Link is Up - 0/Half
Link is up. Setting carrier on.
Link is up. Waking up queue.
PHY: 0:01 - Link is Down
Link is down. Setting carrier off and stopping queue!
PHY: 0:00 - Link is Up - 100/Full
PHY: 0:01 - Link is Up - 100/Full
VFS: Mounted root (nfs filesystem) on device 0:14.
devtmpfs: mounted
Freeing init memory: 216K
INIT: version 2.86 booting
Please wait: booting...
set reboot on kernel panic
starting mdev
mdev done.
Activating swap
Root filesystem already rw, not remounting
Mounting local filesystems...
EXT4-fs (mtdblock4): Filesystem with huge files cannot be mounted RDWR without CONFIG_LBDAF
root: mount: mounting /dev/mtdblock4 on /big_part failed: Invalid argument
Populating volatile Filesystems.
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... done.
System time was Sat Jan 1 00:00:10 UTC 2000.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Sat Jan 1 00:00:10 UTC 2000.
INIT: Entering runlevel: 5
RTNETLINK answers: File exists
ifup: ignoring unknown interface eth0
Starting syslogd/klogd: Cannot find device "wlan0"
done
Starting TFTP server: tftpd.
udpsvd: listening on 0.0.0.0:69, starting
Starting davici app [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[m3video] Remote Debug Shared Memory @ 0xbff05020
[m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
SysLink version : 2.21.02.10
SysLink module created on Date:Jan 12 2017 Time:14:44:04
Trace enabled
Trace SetFailureReason enabled
[host] Attached to slave procId 0.
BUG: Your driver calls ioremap() on system memory. This leads
to architecturally unpredictable behaviour on ARMv6+, and ioremap()
will fail in the next kernel release. Please fix your driver.
------------[ cut here ]------------
WARNING: at arch/arm/mm/ioremap.c:211 __arm_ioremap_pfn_caller+0x58/0x190()
Modules linked in: syslink
Backtrace:
[<c004c274>] (dump_backtrace+0x0/0x110) from [<c03d040c>] (dump_stack+0x18/0x1c)
r6:c049335a r5:000000d3 r4:00000000 r3:c052d5cc
[<c03d03f4>] (dump_stack+0x0/0x1c) from [<c00706d8>] (warn_slowpath_common+0x54/0x6c)
[<c0070684>] (warn_slowpath_common+0x0/0x6c) from [<c0070714>] (warn_slowpath_null+0x24/0x2c)
r8:bf0a1664 r7:00000000 r6:00000000 r5:0008cb00 r4:00297966
r3:00000009
[<c00706f0>] (warn_slowpath_null+0x0/0x2c) from [<c004f6ac>] (__arm_ioremap_pfn_caller+0x58/0x190)
[<c004f654>] (__arm_ioremap_pfn_caller+0x0/0x190) from [<c004f864>] (__arm_ioremap_caller+0x60/0x68)
[<c004f804>] (__arm_ioremap_caller+0x0/0x68) from [<c0061668>] (omap_ioremap+0x60/0x64)
r5:bf01b8b4 r4:8cb00000
[<c0061608>] (omap_ioremap+0x0/0x64) from [<bf01b8b4>] (MemoryOS_map+0xe8/0x1e4 [syslink])
r7:00000002 r6:d4a9c000 r5:00000000 r4:cb92fc48
[<bf01b7cc>] (MemoryOS_map+0x0/0x1e4 [syslink]) from [<bf002e58>] (_ProcMgr_map+0xcc/0x318 [syslink])
r6:d4a9c000 r5:00000001 r4:cb92fcb4
[<bf002d8c>] (_ProcMgr_map+0x0/0x318 [syslink]) from [<bf007acc>] (ElfLoaderTrgWrite_copy+0xf4/0x26c [syslink])
[<bf0079d8>] (ElfLoaderTrgWrite_copy+0x0/0x26c [syslink]) from [<bf00af4c>] (DLIF_copy+0x10/0x1c [syslink])
[<bf00af3c>] (DLIF_copy+0x0/0x1c [syslink]) from [<bf009cd4>] (DLOAD_load+0x714/0xa2c [syslink])
[<bf0095c0>] (DLOAD_load+0x0/0xa2c [syslink]) from [<bf00710c>] (ElfLoader_load+0x90/0x100 [syslink])
[<bf00707c>] (ElfLoader_load+0x0/0x100 [syslink]) from [<bf002038>] (Loader_load+0x6c/0x9c [syslink])
[<bf001fcc>] (Loader_load+0x0/0x9c [syslink]) from [<bf004074>] (ProcMgr_load+0x90/0xf0 [syslink])
[<bf003fe4>] (ProcMgr_load+0x0/0xf0 [syslink]) from [<bf0053bc>] (ProcMgrDrv_ioctl+0x974/0x16b0 [syslink])
[<bf004a48>] (ProcMgrDrv_ioctl+0x0/0x16b0 [syslink]) from [<c00d4a08>] (vfs_ioctl+0x28/0x44)
r8:00000000 r7:00000008 r6:c020e0a2 r5:ccb57f80 r4:be94ebf8
[<c00d49e0>] (vfs_ioctl+0x0/0x44) from [<c00d50e8>] (do_vfs_ioctl+0x4d8/0x520)
[<c00d4c10>] (do_vfs_ioctl+0x0/0x520) from [<c00d5188>] (sys_ioctl+0x58/0x7c)
[<c00d5130>] (sys_ioctl+0x0/0x7c) from [<c0048560>] (ret_fast_syscall+0x0/0x30)
r8:c0048708 r7:00000036 r6:be94ebf8 r5:00000000 r4:0001f1bc
---[ end trace 7936cd319acab829 ]---
Unable to handle kernel paging request at virtual address 78051950
pgd = cb944000
[78051950] *pgd=00000000
Internal error: Oops: 5 [#1]
last sysfs file: /sys/devices/virtual/syslinkipc/syslinkipc_RingIOShm/dev
CPU: 0 Tainted: G W (2.6.37_DM388_IPNC_3.80.00-svn307 #3)
PC is at put_page+0xc/0x140
LR is at skb_release_data+0x74/0xac
pc : [<c00a9afc>] lr : [<c031fa84>] psr: 80000113
sp : cb92f6a0 ip : cb92f6b8 fp : cb92f6b4
r10: ccafc4e8 r9 : c03aaff4 r8 : cb92f730
r7 : 00000450 r6 : 5aa6d032 r5 : 00000001 r4 : ccae2d80
r3 : ccb05640 r2 : 00000006 r1 : 00000d90 r0 : 78051950
Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 8b944019 DAC: 00000017
Process fw_load.out (pid: 193, stack limit = 0xcb92e2e8)
Stack: (0xcb92f6a0 to 0xcb930000)
f6a0: ccb05640 ccae2d80 cb92f6cc cb92f6b8 c031fa84 c00a9afc ccae2d80 00000450
f6c0: cb92f6e4 cb92f6d0 c0320058 c031fa1c ccafc4e8 ccae2d80 cb92f6fc cb92f6e8
f6e0: c031f600 c0320048 ccafc4e8 ccafc480 cb92f72c cb92f700 c035970c c031f5f8
f700: 00010000 ccafc480 ccae2d80 ccae2d98 00000000 ccb05064 00000394 00000450
f720: cb92f754 cb92f730 c03aafd4 c03595b0 cb92f754 00010000 ccafb800 c0364590
f740: ccafc480 ccafc480 cb92f784 cb92f758 c0362498 c03aaf70 00000470 ccae2d80
f760: ccafc480 ccb05064 ccb05050 00000002 00000394 1804000a cb92f7bc cb92f788
f780: c0369354 c0362028 00000000 ccae2d80 cb92f7bc cb92f7a0 c0336f94 c0075aa0
f7a0: ccae2d80 ccafc480 ccb05064 ccb05050 cb92f7fc cb92f7c0 c03699ac c0369330
f7c0: 1804000a 00000394 00000002 cb92f7d8 c033f708 ccae2d80 c04039f4 00496e62
f7e0: 00000000 00000001 00000000 ccae2e2c cb92f81c cb92f800 c034dc34 c03694dc
f800: ccae2d80 ccb05050 00496e62 00000000 cb92f844 cb92f820 c034ddc4 c034daf0
f820: 00000000 c034dae4 80000000 00000001 00000000 ccae2d80 cb92f86c cb92f848
f840: c034d7ac c034dd44 cc926000 00000001 ccae2d80 cc926000 00496e62 00000000
f860: cb92f8a4 cb92f870 c034daa0 c034d4a0 00000000 c034d494 80000000 cb92f888
f880: ccae2d80 c0590d88 cc926000 00000008 00000000 00000003 cb92f8dc cb92f8a8
f8a0: c0326f30 c034d7d8 cb92f8cc cb92f8b8 c0320058 c0590da8 ccae2d80 ccae2d80
f8c0: 00000492 00000000 ccae2d80 00000492 cb92f8fc cb92f8e0 c0327108 c0326c08
f8e0: c031f6e8 cc926000 cc926000 cc926000 cb92f924 cb92f900 c027d870 c03270bc
f900: cb92f91c cb92f910 60000113 cca4ef00 ccab0180 00010000 cb92f94c cb92f928
f920: c02797d4 c027d818 00010000 c4010496 4a1022e0 1a9fa2e0 c0576580 ffff905d
f940: cb92f96c cb92f950 c02798d0 c0279758 cca4ef00 00000000 00000040 00000000
f960: cb92f98c cb92f970 c0279918 c02797e4 c027c710 cc926340 cc926350 00000040
f980: cb92f9b4 cb92f990 c027c744 c02798f0 c027c710 cc926350 00000001 0000012c
f9a0: 00000040 c0576580 cb92f9dc cb92f9b8 c0327340 c027c71c cb92e000 00000001
f9c0: 0000000c 00000101 c0576580 0000000a cb92fa14 cb92f9e0 c00756d4 c03272f4
f9e0: cb92fa0c cb92f9f0 00000000 00000029 00000000 65826282 059c5422 d1016542
fa00: 00000000 0028fb36 cb92fa24 cb92fa18 c00757ac c0075664 cb92fa3c cb92fa28
fa20: c003e07c c0075770 ffffffff fa200000 cb92fadc cb92fa40 c03d2434 c003e00c
fa40: d50088b0 cbcb3a80 00000500 6682242c 660266c2 664265c2 65826282 059c5422
fa60: d1016542 00000000 0028fb36 cb92fadc e00a1c14 cb92fa8c 4d0a125c c01fd6a8
fa80: 20000013 ffffffff c0051024 c0711660 00000000 00001000 cbcb3000 d5007e30
faa0: 00001000 00000000 cb92fb44 c00a1014 00001000 c0711660 00000008 00000000
fac0: ccb57680 cc5b6664 00000000 00000000 cb92fb84 cb92fae0 c00a3148 c00a0f94
fae0: 00000006 00000292 00000001 00000041 000001d0 00000000 00000008 cb92fbf8
fb00: cc5b65c0 00000298 cb877600 cb92fb74 00000001 000000d2 00000000 ccb576c0
fb20: 00000000 cb92fc38 00000007 cb92fb38 00001000 00000000 cb877640 00000001
fb40: cb92fb64 00007e30 0028fb36 d5007e30 00000000 00000000 cb92fb84 cb92fbc0
fb60: cb92fc38 000001d0 00000001 00000000 d4b21000 cc5b65c0 cb92fbb4 cb92fb88
fb80: c0174e60 c00a2d28 000001d0 00000000 ccb57680 cb92fbc0 ccb576a0 d5000000
fba0: cb92fcd8 00000000 cb92fc5c cb92fbb8 c00c7a44 c0174da0 000001d0 00000000
fbc0: cb92fbec cb92fbd0 00000000 00000001 ffffffff ccb57680 00000000 00000000
fbe0: 00000000 00000000 cb95c580 06a85000 00000000 00000000 000001d0 00000000
fc00: cb92fc6c 00000001 00297966 bf014780 00297966 cb92fcb4 cb92fc6c d4a9c000
fc20: ccb57680 00000000 000001d0 00000000 cb92fc6c cb92fc40 d5000000 00297966
fc40: 00000000 d4b21000 bf000000 00297966 cb92fc94 cb92fc60 bf019fc0 c00c79b0
fc60: d5000000 00297966 00000001 bf014780 00000000 cb92fd40 bf0a1664 d5000000
fc80: d4a90000 03046000 cb92fd0c cb92fc98 bf007bac bf019ef0 cb92fcd8 d5000000
fca0: 00297966 00000001 00000000 00297966 00000001 d5000000 cb92fcec 8cb00000
fcc0: 8cb00000 bf014834 00297966 00000000 cb92fd04 d4b1101c 00000000 8cb00000
fce0: cb92fcfc d4b11000 00000001 d4b21000 d4b45090 d4b24000 d4b21000 00000004
fd00: cb92fd1c cb92fd10 bf00af4c bf0079e4 cb92fd94 cb92fd20 bf009cd4 bf00af48
fd20: c0174f1c c00c73cc 00000000 00000000 00000009 cb92fd40 bff0f060 d4b1101c
fd40: d4b21000 d4b51000 f90207f0 00000001 000001d0 00000000 00000002 00000010
fd60: d4b24000 d4b24000 cb92fdac 03046000 d4a90000 d4a8a000 00000000 00000000
fd80: 00000000 bf0a1664 cb92fdd4 cb92fd98 bf00710c bf0095cc d4b1e000 00000000
fda0: 00000000 00000000 cb92fdf4 d4b21000 d4a8a000 d4b1e000 00000000 00000000
fdc0: bf0a1664 00000000 cb92fe0c cb92fdd8 bf002038 bf007088 00000000 cb92feb0
fde0: 00000000 00000000 d4a9c000 00000000 d4b1e000 00000000 cb92feb0 00000000
fe00: cb92fe4c cb92fe10 bf004074 bf001fd8 00000000 cb92feb0 00000000 00000000
fe20: 0000002c be94ebf8 00000000 00000000 d4b1e000 00000000 cb92e000 00000000
fe40: cb92fee4 cb92fe50 bf0053bc bf003ff0 00000000 cb92feb0 cb92fecc cb92fe68
fe60: c00b57b4 c00b4d10 00000058 00000000 00000000 00000025 40d7c000 00000000
fe80: 00000027 0000009c cb944000 cb86589c 00000000 00000000 d4a9c000 be94eef1
fea0: 0000002c 00000000 00000000 00000000 00000000 cb92fec0 c008b734 c0205438
fec0: cb92ff04 be94ebf8 ccb57f80 c020e0a2 00000008 00000000 cb92fef4 cb92fee8
fee0: c00d4a08 bf004a54 cb92ff74 cb92fef8 c00d50e8 c00d49ec cb92ffac cb92ff08
ff00: c003e1f8 c03d41c4 00000000 00000000 00000000 00000025 ccae0a08 00000002
ff20: cca49e70 00000000 00000000 00000000 cb92ff6c cb92ff40 c00c8444 c00f2c70
ff40: 00000000 ccae0a00 00000025 ccb57f80 be94ebf8 c020e0a2 00000008 00000000
ff60: cb92e000 00000000 cb92ffa4 cb92ff78 c00d5188 c00d4c1c c03d0cbc 00000001
ff80: ffffffff 0001f1bc 00000000 be94ebf8 00000036 c0048708 00000000 cb92ffa8
ffa0: c0048560 c00d513c 0001f1bc 00000000 00000008 c020e0a2 be94ebf8 00000008
ffc0: 0001f1bc 00000000 be94ebf8 00000036 be94eef1 00000000 00000000 00000000
ffe0: c020e0a2 be94ebe0 00013738 4028aaec 20000010 00000008 bf06e268 00000004
Backtrace:
[<c00a9af0>] (put_page+0x0/0x140) from [<c031fa84>] (skb_release_data+0x74/0xac)
r4:ccae2d80 r3:ccb05640
[<c031fa10>] (skb_release_data+0x0/0xac) from [<c0320058>] (skb_release_all+0x1c/0x20)
r5:00000450 r4:ccae2d80
[<c032003c>] (skb_release_all+0x0/0x20) from [<c031f600>] (__kfree_skb+0x14/0xb4)
r4:ccae2d80 r3:ccafc4e8
[<c031f5ec>] (__kfree_skb+0x0/0xb4) from [<c035970c>] (tcp_read_sock+0x168/0x1f4)
r4:ccafc480 r3:ccafc4e8
[<c03595a4>] (tcp_read_sock+0x0/0x1f4) from [<c03aafd4>] (xs_tcp_data_ready+0x70/0x90)
[<c03aaf64>] (xs_tcp_data_ready+0x0/0x90) from [<c0362498>] (tcp_rcv_established+0x47c/0x600)
r4:ccafc480
[<c036201c>] (tcp_rcv_established+0x0/0x600) from [<c0369354>] (tcp_v4_do_rcv+0x30/0x1ac)
[<c0369324>] (tcp_v4_do_rcv+0x0/0x1ac) from [<c03699ac>] (tcp_v4_rcv+0x4dc/0x82c)
r7:ccb05050 r6:ccb05064 r5:ccafc480 r4:ccae2d80
[<c03694d0>] (tcp_v4_rcv+0x0/0x82c) from [<c034dc34>] (ip_local_deliver_finish+0x150/0x254)
[<c034dae4>] (ip_local_deliver_finish+0x0/0x254) from [<c034ddc4>] (ip_local_deliver+0x8c/0x9c)
r7:00000000 r6:00496e62 r5:ccb05050 r4:ccae2d80
[<c034dd38>] (ip_local_deliver+0x0/0x9c) from [<c034d7ac>] (ip_rcv_finish+0x318/0x338)
r4:ccae2d80
[<c034d494>] (ip_rcv_finish+0x0/0x338) from [<c034daa0>] (ip_rcv+0x2d4/0x318)
r7:00000000 r6:00496e62 r5:cc926000 r4:ccae2d80
[<c034d7cc>] (ip_rcv+0x0/0x318) from [<c0326f30>] (__netif_receive_skb+0x334/0x388)
r9:00000003 r8:00000000 r7:00000008 r6:cc926000 r5:c0590d88
r4:ccae2d80
[<c0326bfc>] (__netif_receive_skb+0x0/0x388) from [<c0327108>] (netif_receive_skb+0x58/0x68)
[<c03270b0>] (netif_receive_skb+0x0/0x68) from [<c027d870>] (cpsw_rx_handler+0x64/0x13c)
r4:cc926000
[<c027d80c>] (cpsw_rx_handler+0x0/0x13c) from [<c02797d4>] (__cpdma_chan_free+0x88/0x8c)
r7:00010000 r6:ccab0180 r5:cca4ef00 r4:60000113
[<c027974c>] (__cpdma_chan_free+0x0/0x8c) from [<c02798d0>] (__cpdma_chan_process+0xf8/0x10c)
[<c02797d8>] (__cpdma_chan_process+0x0/0x10c) from [<c0279918>] (cpdma_chan_process+0x34/0x50)
r7:00000000 r6:00000040 r5:00000000 r4:cca4ef00
[<c02798e4>] (cpdma_chan_process+0x0/0x50) from [<c027c744>] (cpsw_poll+0x34/0xa0)
r6:00000040 r5:cc926350 r4:cc926340 r3:c027c710
[<c027c710>] (cpsw_poll+0x0/0xa0) from [<c0327340>] (net_rx_action+0x58/0x154)
r8:c0576580 r7:00000040 r6:0000012c r5:00000001 r4:cc926350
r3:c027c710
[<c03272e8>] (net_rx_action+0x0/0x154) from [<c00756d4>] (__do_softirq+0x7c/0x10c)
[<c0075658>] (__do_softirq+0x0/0x10c) from [<c00757ac>] (irq_exit+0x48/0x94)
[<c0075764>] (irq_exit+0x0/0x94) from [<c003e07c>] (asm_do_IRQ+0x7c/0x9c)
[<c003e000>] (asm_do_IRQ+0x0/0x9c) from [<c03d2434>] (__irq_svc+0x34/0xa0)
Exception stack(0xcb92fa40 to 0xcb92fa88)
r5:fa200000 r4:ffffffff
[<c00a0f88>] (file_read_actor+0x0/0xfc) from [<c00a3148>] (generic_file_aio_read+0x42c/0x6fc)
[<c00a2d1c>] (generic_file_aio_read+0x0/0x6fc) from [<c0174e60>] (nfs_file_read+0xcc/0x100)
[<c0174d94>] (nfs_file_read+0x0/0x100) from [<c00c7a44>] (do_sync_read+0xa0/0xe0)
[<c00c79a4>] (do_sync_read+0x0/0xe0) from [<bf019fc0>] (OsalKfile_read+0xdc/0x168 [syslink])
r6:00297966 r5:bf000000 r4:d4b21000
[<bf019ee4>] (OsalKfile_read+0x0/0x168 [syslink]) from [<bf007bac>] (ElfLoaderTrgWrite_copy+0x1d4/0x26c [syslink])
r8:03046000 r7:d4a90000 r6:d5000000 r5:bf0a1664 r4:cb92fd40
Code: c00a9eb0 e1a0c00d e92dd818 e24cb004 (e5902000)
---[ end trace 7936cd319acab82a ]---
Kernel panic - not syncing: Fatal exception in interrupt
Backtrace:
r6:00000001 r5:cb92f4ec r4:c0555c50 r3:c052d5cc
[<c03d03f4>] (dump_stack+0x0/0x1c) from [<c03d046c>] (panic+0x5c/0x178)
[<c03d0410>] (panic+0x0/0x178) from [<c004c648>] (die+0x288/0x2d8)
r3:00000300 r2:cb92f4b8 r1:00005ee6 r0:c049263e
r7:c00a9b00
[<c004c3c0>] (die+0x0/0x2d8) from [<c004ebe8>] (__do_kernel_fault+0x6c/0x8c)
[<c004eb7c>] (__do_kernel_fault+0x0/0x8c) from [<c03d43a4>] (do_page_fault+0x1ec/0x208)
r8:00000005 r7:ccae7d80 r6:cb95c580 r5:78051950 r4:cb92f658
r3:cb92f658
[<c03d41b8>] (do_page_fault+0x0/0x208) from [<c03d43e4>] (do_translation_fault+0x24/0xa8)
[<c03d43c0>] (do_translation_fault+0x0/0xa8) from [<c003e298>] (do_DataAbort+0x3c/0xa0)
r7:cb92f658 r6:78051950 r5:c05165f0 r4:00000005
[<c003e25c>] (do_DataAbort+0x0/0xa0) from [<c03d23ec>] (__dabt_svc+0x4c/0x60)
Exception stack(0xcb92f658 to 0xcb92f6a0)
f640: 78051950 00000d90
f660: 00000006 ccb05640 ccae2d80 00000001 5aa6d032 00000450 cb92f730 c03aaff4
f680: ccafc4e8 cb92f6b4 cb92f6b8 cb92f6a0 c031fa84 c00a9afc 80000113 ffffffff
r7:00000450 r6:5aa6d032 r5:cb92f68c r4:ffffffff
r4:ccafc480
r4:ccae2d80
r4:ccae2d80
r4:cc926000
r3:c027c710
Rebooting in 1 seconds..
