Compiler/TMS320DM365: I am getting Error while compiling IPNC for DM365.
Part Number: TMS320DM365
Other Parts Discussed in Thread: TVP5150
We have changed below parameters in /yourapp/Source/ipnc_rdk/Rules.mk .
SYSTEM_PLATFORM := EVM
IPNC_DEVICE := DM365
FILESYS_MODE := NFS
Commented all sensors and IMGS_ID , as we are using TVP5150 on Reference design .
I made AEWB_BUILD_MODE := no , then also while compiling it gives undefined reference to  appro library.
ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/lib/dmvastub.a /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/dm365mm-module_01_00_03/lib/libdm365mm.a
/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/lib/debug/alg.a(alg_aewb.o): In function `ALG_aewbCreate':
/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/alg_aewb.c:345: undefined reference to `TI_2A_init_tables'
/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/alg_aewb.c:351: undefined reference to
Could you please let me know whether DM365 EVM works with IPNC ? Or It only supported on APPRO and Leopard boards ?
Our requirement is to take the D1(NTSC) and Audio from DM365 and stream to Mobile using RTSP or HTTP . Please help us to achieve this with IPNC.
    Can you share your Rules.make.
    What is the IPNC RDK version you use?
    You should specify atleast one sensor here.
    FILESYS_MODE := NFS
    IMGS_ID := IMGS_TVP514X
    AEWB_BUILD_MODE := yes
    the above settings works fine for me. I am able to compile. If you specify the IMGS_ID then it should build.
  • Hi, Prashanth
    below i have copied our Rules.make file contents. Pls check.
    IPNC version we are using is 5.1.0
    # Default build environment, set to linux
    ifeq ($(OS), )
      OS := Linux
    endif
    #CONFIGURATION
    # Select Hardware Platform: EVM or IPNC
    #SYSTEM_PLATFORM := IPNC
    # IPNC Platform Device needs to selected
    #IPNC_DEVICE := DM368
    #IPNC_DEVICE := DM369
    #IPNC_DEVICE := DMVA1
    #IPNC_DEVICE := DMVA2
    # Filesystem mode to selected: NAND or NFS
    FILESYS_MODE := NFS
    #FILESYS_MODE := UBIFS
    # Build configuration : debug or release
    APP_BUILD_CFG    := debug
    #APP_BUILD_CFG   := release
    # UBIFS mtd-utils mode
    MTD_UTILS_MODE := 64bit
    #MTD_UTILS_MODE := 32bit
    # Sensor Selected for the build, based on SYSTEM_PLATFORM
    # IPNC and EVM platform have different set of Sensor supported
    ifeq ($(SYSTEM_PLATFORM), IPNC)
    #IMGS_ID := IMGS_MICRON_MT9P031_5MP
    #IMGS_ID := IMGS_MICRON_MT9D131_2MP
    #IMGS_ID := IMGS_OV10630_1MP
    #IMGS_ID := IMGS_MICRON_MT9M031_1.2MP
    #IMGS_ID := IMGS_MICRON_MT9M034_1.2MP
    #IMGS_ID := IMGS_OV2715_2MP
    #IMGS_ID := IMGS_SONY_IMX035_1_3MP
    #IMGS_ID := IMGS_SONY_IMX036_3MP
    #IMGS_ID := IMGS_SONY_IMX104_1_3MP
    #IMGS_ID := IMGS_SONY_IMX136_2_3MP
    #IMGS_ID := IMGS_SONY_IMX122_2_3MP
    #IMGS_ID := IMGS_AR0130_1.2MP
    #IMGS_ID := IMGS_AR0330_3.1MP
    #IMGS_ID := IMGS_AR0331_3.1MP
    #IMGS_ID := IMGS_AR0331_3.1MP_WDR
    #IMGS_ID := IMGS_PANASONIC_MN34041_2.1MP
    endif
    ifeq ($(SYSTEM_PLATFORM), EVM)
    #IMGS_ID := IMGS_TVP514X
    endif
    # This flag will determine whether any 2A modules is required in build or not
    #AEWB_BUILD_MODE := yes
    # WiFi hardware mode flag: ON or OFF
    # ON:if WiFi Hardware module is present else this needs to be set to OFF
    #WIFI_MODULE_MODE := ON
    WIFI_MODULE_MODE := OFF
    # AES Encyrption mode flag: ON or OFF
    # ON:if AES Encyprtion module is present else this needs to be set to OFF
    #AES_MODULE_MODE := ON
    AES_MODULE_MODE := OFF
    # Face Recognition flag: ON or OFF
    # ON:if Face Recognitio module is present else this needs to be set to OFF
    #FACE_RECOG_MODE := ON
    FACE_RECOG_MODE := OFF
    # Sensor Board Vendor: Appro or Leopard Imaging
    # APPRO:if Appro Sensor Board is used or LIMG: if Leopard Imaging Board are used
    SENSOR_BOARD_VENDOR := APPRO
    #SENSOR_BOARD_VENDOR := LIMG
    # Build warnings will be treated as errors for av_capture folder
    TREAT_WARNINGS_AS_ERROR := no
    #TREAT_WARNINGS_AS_ERROR := yes
    # Combinations checks for the options set above are done here
    ifeq ($(IPNC_DEVICE), DM368)
    HARDWARE_CFG := dm368
    else ifeq ($(IPNC_DEVICE), DM369)
    else ifeq ($(IPNC_DEVICE), DMVA2)
    else ifeq ($(IPNC_DEVICE), DMVA1)
    HARDWARE_CFG := dm365
    else
    endif
    ifeq ($(FILESYS_MODE), UBIFS)
    BUILD_CFG := ubifs
    else
    BUILD_CFG := nfs
    endif
    SYSTEM_CFG := evm
    else
    SYSTEM_CFG := ipnc
    endif
    ifeq ($(AEWB_BUILD_MODE), yes)
    AEWB_ID := AEWB_ENABLE
    else
    AEWB_ID := AEWB_NONE
    endif
    BOARD_ID := BOARD_AP_IPNC
    else
    BOARD_ID := BOARD_TI_EVM
    endif
    DVSDK_ARGS=
    ifeq ($(SYSTEM_CFG), ipnc)
    ifeq ($(HARDWARE_CFG), dm368)
    DVSDK_ARGS=USE_UDEV=1
    endif
    endif
    # All build tools paths are set in this section
    BASE_INSTALL_DIR      := $(shell pwd)/..
    # Defining the install base directory for IPNC RDK
    IPNC_INSTALL_DIR       := $(BASE_INSTALL_DIR)/ipnc_rdk
    DVSDK_BASE_DIR           := $(BASE_INSTALL_DIR)/dvsdk_ipnctools
    # Defining the build tools directory for IPNC RDK
    BUILD_TOOL_DIR           := $(DVSDK_BASE_DIR)/linux-devkit
    BUILD_TOOL_PREFIX       := $(BUILD_TOOL_DIR)/bin/arm-arago-linux-gnueabi-
    # The directory that points to the Linux Support Package
    PSP_BASE_DIR           := $(DVSDK_BASE_DIR)/ipnc_psp_03_21_00_04
    KERNELDIR         := $(PSP_BASE_DIR)/kernel
    UBOOTDIR         := $(PSP_BASE_DIR)/u-boot
    # The directory that points to the AVCAPTURE module folder
    AVCAPTURE_BASE_DIR    := $(IPNC_INSTALL_DIR)/av_capture
    AVCAPTURE_BUILD_DIR    := $(AVCAPTURE_BASE_DIR)/build
    # The directory that points to where filesystem is mounted
    FILESYS_BASE_DIR      := $(IPNC_INSTALL_DIR)/target
    TARGET_FS         := $(FILESYS_BASE_DIR)/filesys_$(HARDWARE_CFG)
    UBIFS_PATH          := $(FILESYS_BASE_DIR)/mtd-utils/$(MTD_UTILS_MODE)
    # The directory that points to the tftp directory
    # This will have generated binaries likeu-boot, uImage, ubifs etc
    # And also other binary files can be kept here
    # This will all files needed that are needed for burning to NAND
    TFTP_HOME         := $(IPNC_INSTALL_DIR)/tftp/$(IPNC_DEVICE)
    # Where to copy the resulting executables and data to (when executing 'make
    # install') in a proper file structure. This IPNC_EXEC_DIR should either be visible
    # from the target, or you will have to copy this (whole) directory onto the
    # target filesystem.
    IPNC_EXEC_DIR        := $(TARGET_FS)/opt/ipnc
    # The directory that points to the IPNC Application package
    IPNC_DIR        := $(IPNC_INSTALL_DIR)/ipnc_app
    # The directory to IPNC application interface modules to AVCAPTURE
    IPNC_INTERFACE_DIR    := $(IPNC_DIR)/interface
    PUBLIC_INCLUDE_DIR    := $(IPNC_INTERFACE_DIR)/inc
    APP_LIB_DIR        := $(IPNC_INTERFACE_DIR)/lib
    include $(DVSDK_BASE_DIR)/Rules.make
    # All EXPORT symbols are defined here
    export BUILD_TOOL_DIR
    export IPNC_DIR
    export PUBLIC_INCLUDE_DIR
    export APP_LIB_DIR
    export TARGET_FS
    export SYSTEM_PLATFORM
    export HARDWARE_CFG
    export IPNC_DEVICE
    export LINUXKERNEL_INSTALL_DIR
    export IPNC_EXEC_DIR
    export SQUASHFS_PATH
    export KERNELDIR
    export UBOOTDIR
    export AVCAPTURE_BUILD_DIR
    export APP_BUILD_CFG
    export DVSDK_BASE_DIR
    export CMEM_INSTALL_DIR
    export BUILD_TOOL_PREFIX
    export BOARD_ID
    export IMGS_ID
    export SENSOR_BOARD_VENDOR
    export AEWB_ID
    export FILESYS_MODE
    export TFTP_HOME
    export WIFI_MODULE_MODE
    export AES_MODULE_MODE
    export FACE_RECOG_MODE
    export TREAT_WARNINGS_AS_ERROR
    export DVSDK_ARGS
  • Hi Prashanth,
    We changed as per you suggestion, but we are getting following error.
    IPNC RDK version is 5.1.0
    ifeq ($(SYSifeq ($(SYSTEM_PLATFORM), EVM)
    endif
    Then I am getting below error.
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I"./ldc_tables"   drv_imgsCalcCfg_TVP514X.c  drv_imgsH3aCfg_TVP514X.c  drv_imgsIpipeCfg_TVP514X.c  drv_imgsIsifCfg_TVP514X.c  drv_imgsLdcCfg_TVP514X.c  drv_imgs_TVP514X.c   -M > MAKEFILE.DEPEND
    make[8]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/drv/usermod/src/imgs_TVP514X'
    make[7]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/drv'
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/drv'
    make -fMAKEFILE.MK -C./osa/src MODULE=osa depend
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/osa/src'
    osa: Making Directories, if not already created
    mkdir -p /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/lib/debug
    mkdir -p /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/obj/osa/debug
    osa: Building dependancies
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv     osa_buf.c  osa.c  osa_cmem.c  osa_file.c  osa_flg.c  osa_ipc.c  osa_mbx.c  osa_msgq.c  osa_mutex.c  osa_prf.c  osa_que.c  osa_sem.c  osa_test.c  osa_test_ipc.c  osa_thr.c  osa_tsk.c   -M > MAKEFILE.DEPEND
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/osa/src'
    make -fMAKEFILE.MK -C./alg/src MODULE=alg depend
    cat: alg_config/compiler.opt: No such file or directory
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src'
    alg: Making Directories, if not already created
    mkdir -p /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/obj/alg/debug
    alg: Building dependancies
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDM355 -Dti_sdo_ce_osal_Memory_USEDEPRECATEDAPIS=1  -Dxdc_target_name__=GCArmv5T -Dxdc_target_types__=gnu/targets/arm/std.h -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/codecs-dm365/examples -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/codecs-dm365/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/codec-engine_2_26_02_11/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdais_6_26_01_03/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/framework-components_2_26_00_01/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/framework-components_2_26_00_01/fctools/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages -I/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdctools_3_16_03_36/packages -I../priv/aewb -I../priv/vstab -I../priv/swosd -I../priv/gbce -I../priv/facetrack -I./aewb_ap/include -I./aewb_ti/include   alg_aes.c  alg_aewb.c  alg_aewb_control.c  alg_afocus.c  alg_audEnc.c  alg.c  alg_crypto.c  alg_dei.c  alg_dmval.c  alg_face.c  alg_jpgDec.c  alg_jpgEnc.c  alg_motionDetect.c  alg_swosd.c  alg_util.c  alg_vidDec.c  alg_vidEnc.c  alg_vnf.c  alg_vstab.c   -M > MAKEFILE.DEPEND
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src'
    make -fMAKEFILE.MK -C./image_tune/src MODULE=image_tune depend
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/image_tune/src'
    image_tune: Making Directories, if not already created
    mkdir -p /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/obj/image_tune/debug
    image_tune: Building dependancies
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv   imageTune.c  imageTuneClient.c  imageTuneCmdHandlerAwb.c  imageTuneCmdHandler.c  imageTuneCmdHandlerCcdc.c  imageTuneCmdHandlerIpipe.c  imageTuneCmdHandlerIpipeif.c  imageTuneCmdHandlerLdc.c  imageTuneCmdHandlerSys.c  imageTuneCmdHandlerVnf.c  imageTuneCommunication.c  imageTuneMultiParams.c  imageTunePacket.c  imageTuneServer.c  imageTuneTestMain.c   -M > MAKEFILE.DEPEND
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/image_tune/src'
    make -fMAKEFILE.MK -C./alg/src/aewb_ap MODULE=alg depend
    cat: ../alg_config/compiler.opt: No such file or directory
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/aewb_ap'
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDM355 -Dti_sdo_ce_osal_Memory_USEDEPRECATEDAPIS=1  -Dxdc_target_name__=GCArmv5T -Dxdc_target_types__=gnu/targets/arm/std.h -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdais_6_26_01_03/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdctools_3_16_03_36/packages -I./include -I../../priv/aewb   Appro_aewb_tables.c   -M > MAKEFILE.DEPEND
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/aewb_ap'
    make -fMAKEFILE.MK -C./alg/src/aewb_ti MODULE=alg depend
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/aewb_ti'
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDM355 -Dti_sdo_ce_osal_Memory_USEDEPRECATEDAPIS=1  -Dxdc_target_name__=GCArmv5T -Dxdc_target_types__=gnu/targets/arm/std.h -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdais_6_26_01_03/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdctools_3_16_03_36/packages -I./include -I../../priv/aewb   ae_ti.c  TI_fd.c   -M > MAKEFILE.DEPEND
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/aewb_ti'
    make -fMAKEFILE.MK -C./alg/src/aewb_ti/imgs_MT9P031_5MP MODULE=alg depend
    cat: ../../alg_config/compiler.opt: No such file or directory
    make[6]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/framework/alg/src/aewb_ti/imgs_MT9P031_5MP'
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linux-devkit/bin/arm-arago-linux-gnueabi-gcc    -c -Wall -fPIC -g -w -DDM355 -Dti_sdo_ce_osal_Memory_USEDEPRECATEDAPIS=1  -DDEBUG -DBOARD_TI_EVM -DIMGS_TVP514X -DYUV_MODE -DYUV_MODE_INTERLACED  -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/mach-davinci/include -I../inc -I../priv  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/osa/inc   -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/include  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc  -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/dmval/priv   -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/csl/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/drv/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/image_tune/priv -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/inc -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/swosd -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/vstab -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/facetrack -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/saldre -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ap/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/src/aewb_ti/include -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdais_6_26_01_03/packages -I/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdctools_3_16_03_36/packages -I../include -I../../../priv/aewb   alg_aewb_control2.c  awb_calc_data.c  TI_aewb_config.c  TI_aewb_ISP.c  TI_aewb_tables.c  TI_fd_config.c   -M > MAKEFILE.DEPEND
    In file included from /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb/iae.h:26,
                     from /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/av_capture/build/../framework/alg/priv/aewb/alg_aewb_priv.h:5,
                     from alg_aewb_control2.c:2:
    /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/xdctools_3_16_03_36/packages/xdc/std.h:85:2: error: #error xdc_target_types__ must be defined to name a target-specific header containing definitions of xdc_Int8, xdc_Int16, ...
                     from TI_aewb_config.c:1:
                     from TI_aewb_ISP.c:2:
                     from TI_aewb_tables.c:2:
                     from TI_fd_config.c:1:
    make[6]: *** [depend] Error 1
  • Hi Sriharsha,
    Thanks for sharing your Rules.make and the error. Can you try with
    APP_BUILD_CFG := release, along with the earlier settings said by me?
    And then make sysclean & make sysall.
  • Thanks Prashanth,
    I tried as you told , now xdc related error not there , but again it stuck @ install . I hope there is some issue with filesys , there is not usr/share/info folder created. Please help us.
    make[9]: Entering directory `/home/nimesh/yourapp/Source/ipnc_rdk/ipnc_app/sys_server/src'
    install -d /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/target/filesys_dm365/opt/ipnc
    install release/system_server /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/target/filesys_dm365/opt/ipnc
    ln -sf /tmp/localtime /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/target/filesys_dm365/usr/share/info/localtime
    ln: failed to create symbolic link ‘/home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/target/filesys_dm365/usr/share/info/localtime’: No such file or directory
    make[9]: *** [install] Error 1
    make[9]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/ipnc_app/sys_server/src'
    make[8]: *** [src.install] Error 2
    make[8]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/ipnc_app/sys_server'
    make[7]: *** [sys_server.install] Error 2
    make[7]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/ipnc_app'
    make[6]: *** [libs] Error 2
    make[6]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/application/ipnc'
    make[5]: *** [install] Error 2
    make[5]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk/av_capture/application/ipnc'
    make[4]: *** [libs] Error 2
    make[4]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk'
    make[3]: *** [install] Error 2
    make[3]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk'
    make[2]: *** [app] Error 2
    make[2]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/nimesh/yourapp/Source/ipnc_rdk'
  • Hi Sriharsha,
    goto ../Source/ipnc_rdk/target. extract the filesystem. [tar -zxvf filesys_ipnc_dm36x.tar.gz] and then give full permission to the extracted directory.
  • Thanks Prashanth,
    I did the same and it compile till Kernel and now uImage is not getting generated. What could be issue for this compilation errors ? Is this due to host machine ? I am using ubuntu 14.04 .
    CC net/ipv6/sit.mod.o
    LD [M] net/ipv6/sit.ko
    CC net/ipv6/xfrm6_mode_beet.mod.o
    LD [M] net/ipv6/xfrm6_mode_beet.ko
    CC net/ipv6/xfrm6_mode_transport.mod.o
    LD [M] net/ipv6/xfrm6_mode_transport.ko
    CC net/ipv6/xfrm6_mode_tunnel.mod.o
    LD [M] net/ipv6/xfrm6_mode_tunnel.ko
    make[4]: Leaving directory `/home/nimesh/yourapp/Source/dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel'
    cp /home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/boot/uImage /home/nimesh/yourapp/Source/ipnc_rdk/../ipnc_rdk/tftp/DM365/uImage_evm_dm365
    cp: cannot stat ‘/home/nimesh/yourapp/Source/ipnc_rdk/../dvsdk_ipnctools/ipnc_psp_03_21_00_04/kernel/arch/arm/boot/uImage’: No such file or directory
    make[2]: *** [lsp] Error 1
    make[1]: *** [lspall] Error 2
    make: *** [sysall] Error
  • Hi Sriharsha,
    Mine is  Ubuntu 12.04. It works fine here. I don't have a ready Ubuntu 14.04. Did you try building it for IPNC? I mean to say did it build with default Rules.make? If not can you try it once. If it builds for IPNC it should build for EVM too.
  • Hi Sriharsha Desai,
    I tried to build IPNC RDK v5.1.0 from the very start on ubuntu 14.04 and it builds successfully.
    Below are the steps which i followed :
    sudo chmod 777 IPNC_RDK_DM36x_V5.1.0-Linux-x86-Install.bin
    sudo ./IPNC_RDK_DM36x_V5.1.0-Linux-x86-Install.bin
    tar -xvf IPNC_RDK_DM36x_V5.1.0.tar.gz
    cd Source/ipnc_rdk/
    sudo tar -xvzf target/filesys_ipnc_dm36x.tar.gz -C target/
    sudo chown $USER -R /home/anuj.gupta/project/RDK_TI/IPNC_RDK_DM36x_Release_5.1.0/Source/ipnc_rdk/target/filesys_dm365/
    make sysall
    Please check the Rules.make below
    # Copyright (c) Texas Instruments Inc 2013
    # Use of this software is controlled by the terms and conditions found in the
    # license agreement under which this software has been supplied or provided.
    ifeq ($(OS), )
      OS := Linux
    endif
    #CONFIGURATION
    FILESYS_MODE := NFS
    #APP_BUILD_CFG    := debug
    endif
    endif
    #AEWB_BUILD_MODE := no
    else
    endif
    BUILD_CFG := ubifs
    else
    BUILD_CFG := nfs
    endif
    SYSTEM_CFG := evm
    else
    SYSTEM_CFG := ipnc
    endif
    else
    endif
    else
    endif
    DVSDK_ARGS=
    endif
    endif
    export IPNC_DIR
    export APP_LIB_DIR
    export TARGET_FS
    export HARDWARE_CFG
    export IPNC_DEVICE
    export KERNELDIR
    export UBOOTDIR
    export BOARD_ID
    export IMGS_ID
    export AEWB_ID
    export FILESYS_MODE
    export TFTP_HOME
    export DVSDK_ARGS
    Anuj
    Pathpartner Technology Pvt. Ltd.
    I hope above inputs were helpful in solving your issue.
    If the issue is resolved then please close the thread by verifying answer.
    Anuj
    Pathpartner Technology Pvt Ltd
    You need to install u-boot-tools into the Linux machine. If it is ubuntu/debian based then, "sudo apt-get install u-boot-tools"
  • Hi all,
    Thank you for the suggestions, there was a problem with the mkfs tool for creating the images. We manually created the images and it is working now.
    BR,
    Sriharsha Desai
