E2E DM36x Community,
Here's a procedure that can come in handy in the case that you would want to use the CLKOUT0, CLKOUT1 or CLKOUT2 in DM36x.
hotmenu Clkout0_driver()
*(unsigned int *)0x01C40048 &= 0xFFFFFFFE; // Enable CLKOUT0 driver
*(unsigned int *)0x01C40010 |= 0x00300000; // GIO37 will act as CLKOUT0
*(unsigned int *)0x01C40000 |= 0x00008000; // GIO 93 as CLKOUT0
*(unsigned int *)0x01C40948 |= 0x00000002; // OBS CLK enabled
*(unsigned int *)0x01C40904 = 0x00000000; // Oscillator divider output enabled
*(unsigned int *)0x01C40924 = 0x00008001; // Expecting 12 Mhz clock
GEL_TextOut(" Clkout 0 enabled \n");
hotmenu Clkout1_driver()
*(unsigned int *)0x01C40048 &= 0xFFFFFFFD; // Enable CLKOUT1 driver
*(unsigned int *)0x01C40010 |= 0x30000; // GIO35 will act as CLKOUT1
*(unsigned int *)0x01C40D48 |= 0x2; // OBS CLK enabled
*(unsigned int *)0x01C40D04 = 0x00; // Oscillator divider output enabled
*(unsigned int *)0x01C40D24 = 0x8001; // Expecting 12 Mhz clock
GEL_TextOut(" Clkout 1 enabled \n");
hotmenu Clkout2_driver()
*(unsigned int *)0x01C40048 &= 0xFFFFFFFB; // Enable CLKOUT2 driver
*(unsigned int *)0x01C40010 |= 0x00000300; // GIO31 will act as CLKOUT2
*(unsigned int *)0x01C40904 = 0x00; // Oscillator divider output enabled
*(unsigned int *)0x01C40924 = 0x8001; // Default value observed on CLKOUT2 will be PLLC1_VCO/(((SYSCLK99 +1)*16))- 15 Mhz clock (using 24Mhz crystal)
GEL_TextOut(" Clkout 2 enabled \n");
